[Darshan-users] Darshan 2.0.1 release
Phil Carns
carns at mcs.anl.gov
Mon Aug 23 12:14:01 CDT 2010
There is a new Darshan release available on the web site this morning.
Here is the Changelog:
darshan-2.0.1
* bug fix to variance/minimum calculations on shared files
* switch to automatic generation of all MPI compiler scripts using
darshan-gen-* tools
* new run time environment variable: DARSHAN_INTERNAL_TIMING. If set at job
execution time, it will cause Darshan to time its own internal data
aggregation routines and print the results to stdout at rank 0.
As of 2.0.1 we no longer install BG/P compiler scripts by default. The
darshan-gen-* scripts are more portable and easier to use with different
compiler variations at this point.
thanks!
-Phil
More information about the Darshan-users
