[Darshan-commits] [Git][darshan/darshan][dev-better-error-handling] 67 commits: updated autoperf submodule for bug fix
Shane Snyder xgitlab at cels.anl.gov
Tue May 11 21:51:03 CDT 2021
Shane Snyder pushed to branch dev-better-error-handling at darshan / darshan
Commits:
c7d2fb20 by Shane Snyder at 2021-03-31T20:18:20+00:00
d9fd34f3 by Shane Snyder at 2021-03-31T20:23:45+00:00
update autoperf submodule for one more bug fix
dcc18274 by Sudheer Chunduri at 2021-03-31T23:44:37+00:00
apmpi/pydarshan: update the pydarshan to process APMPI records
7e18ce28 by Sudheer Chunduri at 2021-04-01T21:16:57+00:00
autoperf few fixes and code cleanup
bdec8139 by Sudheer Chunduri at 2021-04-01T16:19:43-05:00
Merge branch 'apmpi-pydarshan-fixes' into 'master'
Apmpi pydarshan fixes
See merge request darshan/darshan!93
f16fd02f by Phil Carns at 2021-04-02T08:28:19-04:00
regenerate revision controlled configure scripts
- these will be removed soon when we can coordinate corresponding
  updates to CI test scripts and spack packaging
e3ec9e3e by Shane Snyder at 2021-04-06T08:47:33-05:00
autoperf submodule ssh->https
cf5cf73f by Sudheer Chunduri at 2021-04-06T17:04:53+00:00
Autoperf: apxc and apmpi submodule updates
Include sample analysis scripts for both
few bug fixes to make record processing work with pydarshan
767a6455 by Shane Snyder at 2021-04-06T17:48:42-05:00
Merge branch 'autoperf-updates' into 'master'
See merge request darshan/darshan!94
9d064ea9 by Shane Snyder at 2021-04-09T16:11:38-05:00
updated changelog for darshan-3.3.0-pre1
242538f3 by Shane Snyder at 2021-04-09T22:23:44+00:00
updated submodule for APXC bug fix
e2664495 by Shane Snyder at 2021-04-09T17:30:18-05:00
update configure scripts for 3.3.0-pre1
20f9503b by Tyler Reddy at 2021-04-15T15:09:01-06:00
TST: allow pytest coverage collection
* add `tests/__init__.py` file to allow `pytest-cov` to collect
test line coverage data via i.e.,
`pytest --cov-report=term-missing --cov=darshan tests/`
* on `master`, this currently fails to collect the coverage
data with this warning:
`coverage.py warning: No data was collected. (no-data-collected)`
* on this feature branch a complete coverage report is produced
65ff2d3f by Shane Snyder at 2021-04-15T16:19:22-05:00
bump pydarshan version numbers for release
caf1c297 by Tyler Reddy at 2021-04-15T15:56:53-06:00
TST: add test for unsupported rec
* add a test case that verifies that an appropriate
`logger` warning is produced for unsupported records
fed to the `mod_read_all_records()` method
of `DarshanReport`
* the warning code is not currently covered by tests
on `master`
634c50e9 by Tyler Reddy at 2021-04-15T16:28:47-06:00
TST: add test for info() method
* the `info()` method of the `pydarshan` `DarshanReport` class
is currently completely uncovered by tests in `master`
* add a regression guard for some of the string contents of
the `info()` printout--this method is used pretty commonly,
at least in my experience
141e2fa6 by Shane Snyder at 2021-04-15T17:43:52-05:00
Merge branch 'treddy_allow_pytest_cov_collection' into 'master'
See merge request darshan/darshan!96
ce78d6b2 by Tyler Reddy at 2021-04-15T16:49:28-06:00
MAINT: rm pass statements
* `darshan/report.py` contains many pointless `pass`
statements; they may have served a placeholding purpose
early in development, but they are no longer of any use
so remove them
7b764116 by Tyler Reddy at 2021-04-20T11:56:20-06:00
TST: add DarshanReport open test
* add test cases to cover previously untested scenario
of `DarshanReport()` properly handling invalid file paths
550f3a65 by Tyler Reddy at 2021-04-20T13:56:02-06:00
TST: add test for to_json() method
* add a regression test for the `to_json()` method
of the `DarshanReport` class, which was previously
uncovered by tests
31db1510 by Tyler Reddy at 2021-04-21T14:56:01-06:00
MAINT: rm extraneous return
* remove a `return` statement that cannot possibly
execute inside `__deepcopy__` method of `DarshanReport`
* the [vulture](https://github.com/jendrikseipp/vulture) static
code analyzer also agrees with this assessment
97699ea7 by Tyler Reddy at 2021-04-21T16:11:22-06:00
TST: add DarshanReport deepcopy test
* add a regression test for the `__deepcopy__` method
of `DarshanReport`; verifies floating point value
similarity to original data and lack of memory overlap
7c9df6ae by Tyler Reddy at 2021-04-21T17:22:13-06:00
TST: test for get_lib_version()
* add a regression test for `get_lib_version()`, which is
not covered by tests in `master` branch
* incidentally, instead of actually using `get_lib_version()`
the code base currently repeats the code inside the function
c877e9b2 by Tyler Reddy at 2021-04-22T10:48:18-06:00
TST: add DXT testing to pydarshan
* there is currently not a single DXT-enabled test
file in the `pydarshan` test suite; so, add a small
`6.5K` sample DXT-enabled darshan log file along with
a regression test
39dce232 by Shane Snyder at 2021-04-22T22:10:51+00:00
only call hyperslab fns on hyperslab selections
5b596ed1 by Shane Snyder at 2021-04-23T13:13:00-05:00
Merge branch 'snyder/dev-issue315-hdf5-selections' into 'master'
only call HDF5 hyperslab functions on hyperslab selections
Closes #315
See merge request darshan/darshan!107
6c5c6484 by Shane Snyder at 2021-04-23T13:20:43-05:00
don't call MPI_File_get_byte_offset for OpenMPI
A bug observed in some OpenMPI versions could lead to crashes
triggered by Darshan's own internal MPI-IO wrappers.
95678e94 by Shane Snyder at 2021-04-23T13:20:43-05:00
Merge branch 'snyder/dev-issue317-openmpi-check' into 'master'
Disable MPI-IO module offset tracking for OpenMPI builds
See merge request darshan/darshan!106
8b3771d4 by Shane Snyder at 2021-04-29T18:02:50+00:00
check lustre striping for all files
This attempts to work around issue #302, where Darshan can't
instrument Lustre striping information for symlinks to Lustre
files that reside on other file systems. The method for querying
Lustre striping info is general enough (based on xattrs) and
low-overhead enough that this should not create any issues for
Darshan users.
Closes #302
5ec3e5a9 by Shane Snyder at 2021-04-29T13:41:59-05:00
Merge branch 'snyder/dev-issue302-lustre-symlinks' into 'master'
Closes #302
See merge request darshan/darshan!108
2cbf7faf by Shane Snyder at 2021-04-29T14:41:26-05:00
update darshan-util docs to link to PyDarshan docs
be0ade39 by Shane Snyder at 2021-04-29T16:19:35-05:00
updated changelog for darshan-3.3.0-pre2
d0e606a0 by Shane Snyder at 2021-04-29T16:59:35-05:00
remove AutoPerf from changelog for now
7125643d by Shane Snyder at 2021-04-29T17:05:02-05:00
bump configure versions for 3.3.0-pre2
faadaaef by Shane Snyder at 2021-05-03T14:21:33-05:00
updated PyDarshan version numbers for 3.3.0-pre2
96b40da6 by Shane Snyder at 2021-05-05T16:25:49-05:00
small changelog fixups
2efe901a by Shane Snyder at 2021-05-05T16:29:57-05:00
update config versions for final 3.3.0 release
f4f9173f by Shane Snyder at 2021-05-05T16:40:30-05:00
updated changelog for 3.3.0 release
2f8a67e6 by Shane Snyder at 2021-05-05T22:54:06+00:00
update AutoPerf submodule commit
078cf4f3 by Shane Snyder at 2021-05-05T21:21:35-05:00
add example 3.3.0 darshan log
67df16e6 by Shane Snyder at 2021-05-05T22:22:47-05:00
updated PyDarshan versions for 3.3.0.2
abefb7de by Shane Snyder at 2021-05-05T22:23:13-05:00
initial PyDarshan changelog
84e660e0 by Jakob Luettgau at 2021-05-06T15:40:01-05:00
Pypa regression workaround
b0da9f03 by Shane Snyder at 2021-05-06T15:40:01-05:00
Merge branch 'pypa_regression_workaround' into 'master'
See merge request darshan/darshan!109
9f9eb7f9 by Shane Snyder at 2021-05-06T17:02:40-05:00
AutoPerf modules not supported in generic read_all routines for PyDarshan
48636ea5 by Shane Snyder at 2021-05-06T17:02:40-05:00
Merge branch 'snyder/pydarshan-report-read-all-autoperf' into 'master'
See merge request darshan/darshan!110
b50b8dd0 by Shane Snyder at 2021-05-06T18:23:42-05:00
get pydarshan to properly build AutoPerf modules
d54f6c59 by Shane Snyder at 2021-05-07T09:09:22-05:00
Merge branch 'snyder/pydarshan-autoperf-support' into 'master'
See merge request darshan/darshan!111
21362b6a by Shane Snyder at 2021-05-07T15:54:46-05:00
revert previous modifications to setup.py
feff6be8 by Shane Snyder at 2021-05-07T15:55:50-05:00
make targets for pydarshan autoperf modules
e930ea08 by Shane Snyder at 2021-05-11T14:37:00-05:00
Merge branch 'treddy_rm_pass_darshan_report' into 'master'
See merge request darshan/darshan!99
8fc5cb2c by Shane Snyder at 2021-05-11T14:42:16-05:00
Merge branch 'treddy_deepcopy_unused_return' into 'master'
See merge request darshan/darshan!102
8049f2f9 by Shane Snyder at 2021-05-11T14:54:45-05:00
Merge branch 'treddy_unsupported_record_warn_test' into 'master'
See merge request darshan/darshan!97
31bdb610 by Shane Snyder at 2021-05-11T14:56:34-05:00
added AutoPerf to pydarshan unsupported_rec test
147c469e by Shane Snyder at 2021-05-11T15:00:42-05:00
Merge branch 'treddy_test_darshanreport_info' into 'master'
See merge request darshan/darshan!98
65f4ed71 by Shane Snyder at 2021-05-11T15:03:22-05:00
fix typo in pydarshan output
18d1054a by Shane Snyder at 2021-05-11T15:30:57-05:00
Merge branch 'treddy/darshan-treddy_test_invalid_darshanreport_file_open' into HEAD
457b69ce by Shane Snyder at 2021-05-11T15:37:57-05:00
Merge branch 'treddy/darshan-treddy_test_to_json' into HEAD
f471874f by Shane Snyder at 2021-05-11T15:42:34-05:00
Merge branch 'treddy/darshan-treddy_test_darshanreport_deepcopy' into HEAD
da63fe1a by Shane Snyder at 2021-05-11T15:57:59-05:00
Merge branch 'treddy_test_get_lib_version' into 'master'
See merge request darshan/darshan!104
1a6fdd9f by Shane Snyder at 2021-05-11T16:01:15-05:00
Merge branch 'treddy_test_dxt_simple' into 'master'
See merge request darshan/darshan!105
3034ae57 by Shane Snyder at 2021-05-11T16:46:47-05:00
Merge branch 'master' into dev-better-error-handling
ad4b0af6 by Shane Snyder at 2021-05-11T20:39:43-05:00
bug fix in fprintf statement
051b3fe5 by Shane Snyder at 2021-05-11T20:42:24-05:00
revert unneeded check for log handle = None
9d8ca7f0 by Shane Snyder at 2021-05-11T21:35:34-05:00
sanity check input darshan-util log file handle
necessary to avoid seg faults if user passes in NULL handle
ac36a9d7 by Shane Snyder at 2021-05-11T21:47:50-05:00
avoid keyerror when module isn't present in log
541f82bb by Shane Snyder at 2021-05-11T21:49:30-05:00
modify test to check correct return values
30 changed files:
- .gitmodules
- ChangeLog
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-core.h
- darshan-runtime/darshan-runtime-config.h.in
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-mpiio.c
- + darshan-test/example-output/mpi-io-test-x86_64-3.3.0.darshan
- darshan-util/configure
- darshan-util/configure.in
- darshan-util/darshan-logutils.c
- darshan-util/doc/darshan-util.txt
- + darshan-util/pydarshan/CHANGELOG.rst
- darshan-util/pydarshan/Makefile
- darshan-util/pydarshan/darshan/__init__.py
- darshan-util/pydarshan/darshan/backend/cffi_backend.py
- darshan-util/pydarshan/darshan/report.py
- darshan-util/pydarshan/devel/build-all.sh
- darshan-util/pydarshan/devel/build-wheels.sh
- − darshan-util/pydarshan/examples/apmpi_analysis.py
- darshan-util/pydarshan/setup.cfg
- darshan-util/pydarshan/setup.py
- + darshan-util/pydarshan/tests/__init__.py
- + darshan-util/pydarshan/tests/input/sample-dxt-simple.darshan
- + darshan-util/pydarshan/tests/test_cffi_misc.py
- darshan-util/pydarshan/tests/test_error.py
- + darshan-util/pydarshan/tests/test_moddxt.py
- darshan-util/pydarshan/tests/test_report.py
The diff was not included because it is too large.
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/71b300ffcfed440dd2f55164e8a321c47722efeb...541f82bba53fb5dd4504ea9c5fe53bb7dd0f80dd
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210511/9f884263/attachment-0001.html>
More information about the Darshan-commits mailing list
