[Darshan-commits] [Git][darshan/darshan][master] 2 commits: TST: add test for unsupported rec
Shane Snyder
xgitlab at cels.anl.gov
Tue May 11 14:54:48 CDT 2021
Shane Snyder pushed to branch master at darshan / darshan
Commits:
caf1c297 by Tyler Reddy at 2021-04-15T15:56:53-06:00
* add a test case that verifies that an appropriate
`logger` warning is produced for unsupported records
fed to the `mod_read_all_records()` method
of `DarshanReport`
* the warning code is not currently covered by tests
on `master`
8049f2f9 by Shane Snyder at 2021-05-11T14:54:45-05:00
Merge branch 'treddy_unsupported_record_warn_test' into 'master'
See merge request darshan/darshan!97
1 changed file:
- darshan-util/pydarshan/tests/test_report.py
Changes:
@@ -46,6 +46,19 @@ def test_load_records():
assert 1 == len(report.data['records']['POSIX'])
+ at pytest.mark.parametrize("unsupported_record",
+ ["DXT_POSIX", "DXT_MPIIO", "LUSTRE"]
+def test_unsupported_record_load(caplog, unsupported_record):
+ # check for appropriate logger warning when attempting to
+ # load unsupported record
+ report = darshan.DarshanReport("tests/input/sample.darshan")
+ report.mod_read_all_records(mod=unsupported_record)
+ for record in caplog.records:
+ assert 'Currently unsupported' in record.message
+ assert unsupported_record in record.message
def test_internal_references():
Test if the reference ids match. This tests mainly serves to make
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/8fc5cb2c57c8a5e4c0e0d613743956c93c81bea6...8049f2f9a2de5e1165a765e888e10ecc8a63643a
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210511/7a6bb916/attachment-0001.html>
More information about the Darshan-commits
