[Darshan-commits] [Git][darshan/darshan][master] 2 commits: get pydarshan to properly build AutoPerf modules
Shane Snyder
xgitlab at cels.anl.gov
Fri May 7 09:09:25 CDT 2021
Shane Snyder pushed to branch master at darshan / darshan
Commits:
b50b8dd0 by Shane Snyder at 2021-05-06T18:23:42-05:00
d54f6c59 by Shane Snyder at 2021-05-07T09:09:22-05:00
Merge branch 'snyder/pydarshan-autoperf-support' into 'master'
See merge request darshan/darshan!111
3 changed files:
- darshan-util/pydarshan/CHANGELOG.rst
- darshan-util/pydarshan/devel/build-wheels.sh
- darshan-util/pydarshan/setup.py
Changes:
@@ -1,7 +1,6 @@
PyDarshan-3.3.0.3
-* fixed bug resulting in errors when reading logs with AutoPerf data
- accessed using the Darshan Report interface with option 'read_all=True'
+* Added support for Darshan's AutoPerf modules
PyDarshan-3.3.0.2
@@ -18,7 +18,7 @@ yum install -y zlib zlib-devel
# Build and install darshan-util
cd /darshan/darshan-util
-./configure --enable-shared
+./configure --enable-shared --enable-autoperf-apxc --enable-autoperf-apmpi
make install
make distclean
@@ -44,7 +44,7 @@ for root, dirs, files in os.walk("../../modules"):
if f.endswith("-backend.py"):
fname = f.replace("-backend", "")
try:
- os.symlink("../../" + os.path.join(root, f), f"darshan/backend/{fname}")
+ os.link("../../" + os.path.join(root, f), f"darshan/backend/{fname}")
except:
pass
print("Adding {0} to backends.".format(os.path.join(root, f)))
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/48636ea5d4d0d5816d27de4a18dd4890a2649177...d54f6c5955da6ce067dddfd00e71c43e72bd9218
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210507/f782db42/attachment-0001.html>
More information about the Darshan-commits
