[Darshan-commits] Darshan 3.3.1 Intel/IMPI 2018
francesco iannone francesco.iannone at enea.it
Wed May 5 05:27:33 CDT 2021
Dear support
I’ profiling a MPI/OPENMP fortran code in  INTEL Skylake arch. Using darshan 3.3.1 to analyse IO with HDF5 subroutines.
I used the env variable LD_PRELOAD and I get the darshan file as output.
My problem is to do a report of that file using the perl script darshan-job-summary.pl.
/marconi/home/userexternal/fiannone/apps.cori-skl/darshan-3.1.3/bin/darshan-job-summary.pl gysela.darshan --output case1_384.pdf
Please verify that both the operating system and the processor support Intel(R) AVX512DQ, AVX512F, AVX512CD, AVX512BW, AVX512VL and CLWB instructions.
darshan-parser failure:  256 at /marconi/home/userexternal/fiannone/apps.cori-skl/darshan-3.1.3/bin/darshan-job-summary.pl line 355
I have a failure in the script as above.
I built my code with Intel/IMPI 2018 with the following flags:
-g -xCORE-AVX512 -qopenmp -mkl -fPIC
Do you have any suggest?
Best regards
Dr. Francesco Iannone
ENEA Italian National Agency
ICT Division - HPC Lab (Head)
ENEA Frascati Research Centre
Via E. Fermi 45
00044 Frascati (Roma) Italy
phone 00-39-06-9400-5124
fax 00-39-06-9400-5524
mailto:francesco.iannone at enea.it
http://www.afs.enea.it/iannone
Questo messaggio e i suoi allegati sono indirizzati esclusivamente alle persone indicate e la casella di posta elettronica da cui e' stata inviata e' da qualificarsi quale strumento aziendale.
La diffusione, copia o qualsiasi altra azione derivante dalla conoscenza di queste informazioni sono rigorosamente vietate (art. 616 c.p, D.Lgs. n. 196/2003 s.m.i. e GDPR Regolamento - UE 2016/679).
Qualora abbiate ricevuto questo documento per errore siete cortesemente pregati di darne immediata comunicazione al mittente e di provvedere alla sua distruzione. Grazie.
This e-mail and any attachments is confidential and may contain privileged information intended for the addressee(s) only.
Dissemination, copying, printing or use by anybody else is unauthorised (art. 616 c.p, D.Lgs. n. 196/2003 and subsequent amendments and GDPR UE 2016/679).
If you are not the intended recipient, please delete this message and any attachments and advise the sender by return e-mail. Thanks.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210505/7bffb27e/attachment.html>
More information about the Darshan-commits mailing list
