[Darshan-commits] [Git][darshan/darshan][master] Deleted 2 commits: apmpi/pydarshan: update the pydarshan to process APMPI records
Sudheer Chunduri
xgitlab at cels.anl.gov
Tue Mar 30 20:19:22 CDT 2021
Sudheer Chunduri pushed to branch master at darshan / darshan
WARNING: The push did not contain any new commits, but force pushed to delete the commits and changes below.
Deleted commits:
ba4bc274 by Sudheer Chunduri at 2021-03-30T23:18:37+00:00
d813a891 by Sudheer Chunduri at 2021-03-30T23:19:09+00:00
3 changed files:
- − darshan-runtime/configure
- − darshan-util/configure
- darshan-util/pydarshan/darshan/report.py
Changes:
darshan-runtime/configure deleted
The diff for this file was not included because it is too large.
darshan-util/configure deleted
@@ -675,35 +675,29 @@ class DarshanReport(object):
# handling options
dtype = dtype if dtype else self.dtype
- self.records[mod] = []
+ self.records[mod] = DarshanRecordCollection(mod=mod, report=self)
# update module metadata
- self.modules[mod]['num_records'] = 0
+ self._modules[mod]['num_records'] = 0
if mod not in self.counters:
self.counters[mod] = {}
- # fetch header record
- header_rec = backend.log_get_apmpi_record(self.log, _structdefs[mod+"-HEADER"])
- self.records[mod].append(header_rec)
# fetch records
- rec = backend.log_get_apmpi_record(self.log, _structdefs[mod+"-PERF"])
+ # fetch header record
+ rec = backend.log_get_apmpi_record(self.log, mod, "HEADER", dtype=dtype)
while rec != None:
- if dtype == 'numpy':
- self.records[mod].append(rec)
- else:
+ self.records[mod].append(rec)
self.data['modules'][mod]['num_records'] += 1
# fetch next
+ rec = backend.log_get_apmpi_record(self.log, mod, "PERF", dtype=dtype)
if self.lookup_name_records:
self.update_name_records()
- pass
+ pass
def mod_read_all_dxt_records(self, mod, dtype=None, warnings=True, reads=True, writes=True):
Reads all dxt records for provided module.
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/59379bfb7d909731e15c43f77d45e915b995472d...d813a891ad03eb53b668976e9b107266eb54b5be
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210330/d2ed5e73/attachment-0001.html>
More information about the Darshan-commits
