[Darshan-commits] [Git][darshan/darshan][dev-better-error-handling] 10 commits: PyDarshan: Record Collections
    Rob Latham
    xgitlab at cels.anl.gov
    Tue Mar 30 08:38:53 CDT 2021
Rob Latham pushed to branch dev-better-error-handling at darshan / darshan
Commits:
92501e87 by Jakob Luettgau at 2021-03-25T11:13:34-05:00
054de670 by Shane Snyder at 2021-03-25T11:13:34-05:00
Merge branch 'pydarshan-RecordCollection' into 'master'
See merge request darshan/darshan!86
cfda2264 by Shane Snyder at 2021-03-25T21:48:40-05:00
Add H5D module counter to indicate corresponding H5F record ID
63130594 by Shane Snyder at 2021-03-25T21:48:40-05:00
Merge branch 'dev-h5d-file-rec-counter' into 'master'
See merge request darshan/darshan!91
f0835bed by Shane Snyder at 2021-03-26T11:28:55-05:00
expose new H5D module counter via pydarshan
6616d73b by Shane Snyder at 2021-03-26T16:37:33-05:00
runtime docs typos
f1b80c21 by Shane Snyder at 2021-03-26T16:49:37-05:00
updated H5D counter documentation
3b8be5c5 by Sudheer Chunduri at 2021-03-29T19:57:46-05:00
Integrate AutoPerf submodule
59379bfb by Shane Snyder at 2021-03-29T19:57:46-05:00
Merge branch 'autoperf-mod-update' into 'master'
Autoperf MPI module (APMPI) in Darshan
See merge request darshan/darshan!80
b1e0f348 by Rob Latham at 2021-03-30T13:38:39+00:00
Beter error handling
Now tells user why a system calls failed
30 changed files:
- + .gitmodules
- darshan-hdf5-log-format.h
- darshan-log-format.h
- darshan-runtime/Makefile.in
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-dynamic.h
- darshan-runtime/darshan-runtime-config.h.in
- darshan-runtime/doc/darshan-runtime.txt
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in
- darshan-runtime/share/ld-opts/darshan-base-ld-opts.in
- darshan-test/RELEASE-CHECKLIST.txt
- darshan-util/Makefile.in
- darshan-util/configure
- darshan-util/configure.in
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-logutils.c
- darshan-util/darshan-logutils.h
- darshan-util/doc/darshan-util.txt
- darshan-util/pydarshan/Makefile
- darshan-util/pydarshan/darshan/__init__.py
- darshan-util/pydarshan/darshan/backend/api_def_c.py
- darshan-util/pydarshan/darshan/backend/cffi_backend.py
- darshan-util/pydarshan/darshan/discover_darshan.py
- + darshan-util/pydarshan/darshan/experimental/aggregators/create_dxttimeline.py
- darshan-util/pydarshan/darshan/experimental/aggregators/name_records_summary.py
- darshan-util/pydarshan/darshan/experimental/aggregators/filter.py → darshan-util/pydarshan/darshan/experimental/operations/filter.py
The diff was not included because it is too large.
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/8ab1e3d937dee75222dc008cc077f37220766dc1...b1e0f348a8c5156be4fe2f986ca167209a9b2b0b
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210330/0ecd4a7c/attachment.html>
More information about the Darshan-commits
