[Darshan-commits] [Git][darshan/darshan][carns/issue-312-log-time-name] bug fix to internal shutdown timing
Philip Carns
xgitlab at cels.anl.gov
Wed Mar 24 15:55:44 CDT 2021
Philip Carns pushed to branch carns/issue-312-log-time-name at darshan / darshan
Commits:
d26bf896 by Phil Carns at 2021-03-24T16:55:23-04:00
1 changed file:
- darshan-runtime/lib/darshan-core.c
Changes:
@@ -444,13 +444,20 @@ void darshan_core_shutdown()
darshan_core = NULL;
DARSHAN_CORE_UNLOCK();
+ /* NOTE: from this point on, this function must use
+ * darshan_core_wtime_absolute() rather than darshan_core_wtime() to
+ * collect timestamps for internal timing calculations. The former no
+ * longer works because it relies on runtime state to calculate
+ * timestamps relative to job start.
/* grab some initial timing information */
#ifdef HAVE_MPI
/* if using mpi, sync across procs first */
if(using_mpi)
PMPI_Barrier(final_core->mpi_comm);
#endif
- start_log_time = darshan_core_wtime();
+ start_log_time = darshan_core_wtime_absolute();
final_core->log_job_p->end_time = time(NULL);
if(getenv("DARSHAN_INTERNAL_TIMING"))
@@ -524,31 +531,31 @@ void darshan_core_shutdown()
if(internal_timing_flag)
- open1 = darshan_core_wtime();
+ open1 = darshan_core_wtime_absolute();
/* open the darshan log file */
ret = darshan_log_open(logfile_name, final_core, &log_fh);
- open2 = darshan_core_wtime();
+ open2 = darshan_core_wtime_absolute();
/* error out if unable to open log file */
DARSHAN_CHECK_ERR(ret, "unable to create log file %s", logfile_name);
log_created = 1;
- job1 = darshan_core_wtime();
+ job1 = darshan_core_wtime_absolute();
/* write the the compressed darshan job information */
ret = darshan_log_write_job_record(log_fh, final_core, &gz_fp);
- job2 = darshan_core_wtime();
+ job2 = darshan_core_wtime_absolute();
/* error out if unable to write job information */
DARSHAN_CHECK_ERR(ret, "unable to write job record to file %s", logfile_name);
- rec1 = darshan_core_wtime();
+ rec1 = darshan_core_wtime_absolute();
/* write the record name->id hash to the log file */
final_core->log_hdr_p->name_map.off = gz_fp;
ret = darshan_log_write_name_record_hash(log_fh, final_core, &gz_fp);
- rec2 = darshan_core_wtime();
+ rec2 = darshan_core_wtime_absolute();
final_core->log_hdr_p->name_map.len = gz_fp - final_core->log_hdr_p->name_map.off;
/* error out if unable to write name records */
DARSHAN_CHECK_ERR(ret, "unable to write name records to log file %s", logfile_name);
@@ -574,7 +581,7 @@ void darshan_core_shutdown()
- mod1[i] = darshan_core_wtime();
+ mod1[i] = darshan_core_wtime_absolute();
/* if module is registered locally, perform module shutdown operations */
if(this_mod)
@@ -626,7 +633,7 @@ void darshan_core_shutdown()
free(mod_buf);
- mod2[i] = darshan_core_wtime();
+ mod2[i] = darshan_core_wtime_absolute();
/* error out if unable to write module data */
DARSHAN_CHECK_ERR(ret, "unable to write %s module data to log file %s",
@@ -634,10 +641,10 @@ void darshan_core_shutdown()
- header1 = darshan_core_wtime();
+ header1 = darshan_core_wtime_absolute();
ret = darshan_log_write_header(log_fh, final_core);
- header2 = darshan_core_wtime();
+ header2 = darshan_core_wtime_absolute();
DARSHAN_CHECK_ERR(ret, "unable to write header to file %s", logfile_name);
/* done writing data, close the log file */
@@ -655,7 +662,7 @@ void darshan_core_shutdown()
double mod_tm[DARSHAN_MAX_MODS];
double all_tm;
- tm_end = darshan_core_wtime();
+ tm_end = darshan_core_wtime_absolute();
open_tm = open2 - open1;
header_tm = header2 - header1;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/d26bf89688397c045dd5517cbc0a4ca04246299e
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210324/8f90dacb/attachment-0001.html>
More information about the Darshan-commits
