[Darshan-commits] [Git][darshan/darshan][carns/issue-284-incomplete-warning] adjust incomplete log handling
Philip Carns
xgitlab at cels.anl.gov
Mon Mar 15 16:04:14 CDT 2021
Philip Carns pushed to branch carns/issue-284-incomplete-warning at darshan / darshan
Commits:
030b523e by Phil Carns at 2021-03-15T17:03:15-04:00
- make darshan-dxt-parser behave similarly to darshan-parser in this
regard
1 changed file:
- darshan-util/darshan-dxt-parser.c
Changes:
@@ -20,15 +20,14 @@
#include "darshan-logutils.h"
-int usage (char *exename)
- fprintf(stderr, "Usage: %s <filename>\n", exename);
+#define OPTION_SHOW_INCOMPLETE (1 << 7) /* show what we have, even if log is incomplete */
- exit(1);
+static int usage (char *exename);
+static int parse_args (int argc, char **argv, char **filename);
int main(int argc, char **argv)
+ int mask;
int ret;
int i, j;
char *filename;
@@ -49,10 +48,7 @@ int main(int argc, char **argv)
struct lustre_record_ref *lustre_rec_hash = NULL;
char *mod_buf = NULL;
- if (argc != 2)
- usage(argv[0]);
- filename = argv[1];
+ mask = parse_args(argc, argv, &filename);
fd = darshan_log_open(filename);
if (!fd)
@@ -195,11 +191,44 @@ int main(int argc, char **argv)
continue;
/* print warning if this module only stored partial data */
- if(DARSHAN_MOD_FLAG_ISSET(fd->partial_flag, i))
- printf("\n# *WARNING*: The %s module contains incomplete data!\n"
- "# This happens when a module runs out of\n"
- "# memory to store new record data.\n",
- darshan_module_names[i]);
+ if(DARSHAN_MOD_FLAG_ISSET(fd->partial_flag, i)) {
+ if(mask & OPTION_SHOW_INCOMPLETE)
+ /* user requested that we show the data we have anyway */
+ printf("\n# *WARNING*: "
+ "The %s module contains incomplete data!\n"
+ "# This happens when a module runs out of\n"
+ "# memory to store new record data.\n",
+ darshan_module_names[i]);
+ printf(
+ "\n# To avoid this error, consult the darshan-runtime\n"
+ "# documentation and consider setting the\n"
+ "# DARSHAN_EXCLUDE_DIRS or DXT_TRIGGER_CONF_PATH\n"
+ "# environment variable to prevent Darshan from\n"
+ "# instrumenting unecessary files.\n");
+ else
+ /* hard error */
+ fprintf(stderr, "\n# *ERROR*: "
+ fprintf(stderr,
+ fprintf(stderr,
+ "\n# You can display the (incomplete) data that is\n"
+ "# present in this log using the --show-incomplete\n"
+ "# option to darshan-dxt-parser.\n");
+ return(-1);
/* loop over each of this module's records and print them */
while(1)
@@ -311,6 +340,59 @@ cleanup:
return(ret);
+ int index;
+ int mask;
+ static struct option long_opts[] =
+ {"show-incomplete", 0, NULL, OPTION_SHOW_INCOMPLETE},
+ {"help", 0, NULL, 0},
+ {0, 0, 0, 0}
+ mask = 0;
+ while(1)
+ int c = getopt_long(argc, argv, "", long_opts, &index);
+ if (c == -1) break;
+ switch(c)
+ case OPTION_SHOW_INCOMPLETE:
+ mask |= c;
+ break;
+ case 0:
+ case '?':
+ default:
+ usage(argv[0]);
+ break;
+ if (optind < argc)
+ *filename = argv[optind];
+ else
+ usage(argv[0]);
+ return mask;
+ fprintf(stderr, "Usage: %s [options] <filename>\n", exename);
+ fprintf(stderr, " --show-incomplete : display results even if log is incomplete\n");
+ exit(1);
* Local variables:
* c-indent-level: 4
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/030b523eeb11c264f96d877cdb6cc8974a8455df
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210315/843ac061/attachment-0001.html>
More information about the Darshan-commits
