[Darshan-commits] [Git][darshan/darshan][master] 3 commits: clarify comments and configure help for max mem
Philip Carns
xgitlab at cels.anl.gov
Thu Mar 11 16:01:35 CST 2021
Philip Carns pushed to branch master at darshan / darshan
Commits:
4cac1e1e by Phil Carns at 2021-03-11T16:59:17-05:00
117568d3 by Phil Carns at 2021-03-11T16:59:55-05:00
boost default per-process memory limit to 4 MiB
4f87238e by Philip Carns at 2021-03-11T16:01:31-06:00
Merge branch 'carns/issue-290-maxmem' into 'master'
increase max memory per process
Closes #290
See merge request darshan/darshan!83
4 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-core.h
- darshan-runtime/darshan-runtime-config.h.in
Changes:
@@ -1398,7 +1398,8 @@ Optional Packages:
--with-jobid-env=<name> Name of environment variable that stores the jobid
(specify "NONE" if no appropriate environment variable
is available: Darshan will use the pid of rank 0)
- --with-mod-mem=<num> Maximum amount of memory (in MiB) for each Darshan module
+ --with-mod-mem=<num> Maximum runtime memory consumption per process
+ (in MiB) across all instrumentation modules
Some influential environment variables:
MPICC MPI C compiler command
@@ -4188,7 +4189,8 @@ else
fi
if test "x$enable_hdf5_mod" != "xno"; then :
- if test -d "$enable_hdf5_mod"; then :
+ if test -d "$enable_hdf5_mod"; then :
CFLAGS="${CFLAGS} -I${enable_hdf5_mod}/include"
DARSHAN_HDF5_LD_FLAGS="-L${enable_hdf5_mod}/lib -Wl,-rpath=${enable_hdf5_mod}/lib -lhdf5"
else
@@ -166,11 +166,12 @@ AC_ARG_WITH(jobid-env,
AC_ARG_WITH(mod-mem,
-[ --with-mod-mem=<num> Maximum amount of memory (in MiB) for each Darshan module],
+[ --with-mod-mem=<num> Maximum runtime memory consumption per process
+ (in MiB) across all instrumentation modules],
if test x$withval = xyes; then
AC_MSG_ERROR(--with-mod-mem must be given a number)
else
- AC_DEFINE_UNQUOTED(__DARSHAN_MOD_MEM_MAX, ${withval}, Maximum memory (in MiB) for each Darshan module)
+ AC_DEFINE_UNQUOTED(__DARSHAN_MOD_MEM_MAX, ${withval}, Maximum runtime memory consumption per process (in MiB) across all instrumentation modules)
fi
@@ -48,11 +48,13 @@
#define DARSHAN_DEF_MMAP_LOG_PATH "/tmp"
#endif
-/* Maximum amount of memory per instrumentation module in MiB */
+/* Maximum runtime memory consumption per process (in MiB) across
+ * all instrumentation modules
#ifdef __DARSHAN_MOD_MEM_MAX
#define DARSHAN_MOD_MEM_MAX (__DARSHAN_MOD_MEM_MAX * 1024L * 1024L)
#else
-#define DARSHAN_MOD_MEM_MAX (2 * 1024 * 1024) /* 2 MiB default */
+#define DARSHAN_MOD_MEM_MAX (4 * 1024 * 1024) /* 2 MiB default */
#endif
/* default name record buf can store 2048 records of size 100 bytes */
@@ -135,7 +135,8 @@
/* Memory alignment in bytes */
#undef __DARSHAN_MEM_ALIGNMENT
-/* Maximum memory (in MiB) for each Darshan module */
+/* Maximum runtime memory consumption per process (in MiB) across all
+ instrumentation modules */
#undef __DARSHAN_MOD_MEM_MAX
/* Generalized request type for MPI-IO */
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/8f4cdc1cd2d33e63aa85bf513f9e91246aea68c2...4f87238eb0e3899a203b5390784376819a05d47f
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210311/846ae6e4/attachment-0001.html>
More information about the Darshan-commits
