[Darshan-commits] [Git][darshan/darshan][autoperf-mod-update] Autoperf module name updates
Sudheer Chunduri
xgitlab at cels.anl.gov
Tue Jan 12 21:12:35 CST 2021
Sudheer Chunduri pushed to branch autoperf-mod-update at darshan / darshan
Commits:
c77d86a4 by Sudheer Chunduri at 2021-01-13T03:11:59+00:00
4 changed files:
- darshan-log-format.h
- darshan-runtime/lib/darshan-core.c
- darshan-util/pydarshan.py
- modules/autoperf
Changes:
@@ -142,17 +142,17 @@ struct darshan_base_record
* in the module id space
#ifdef DARSHAN_USE_APXC
-#define __DARSHAN_APXC_VER DARSHAN_APXC_VER
+#define __APXC_VER APXC_VER
#define __apxc_logutils &apxc_logutils
#else
-#define __DARSHAN_APXC_VER 0
+#define __APXC_VER 0
#define __apxc_logutils NULL
#endif
#ifdef DARSHAN_USE_APMPI
-#define __DARSHAN_APMPI_VER DARSHAN_APMPI_VER
+#define __APMPI_VER APMPI_VER
#define __apmpi_logutils &apmpi_logutils
#else
-#define __DARSHAN_APMPI_VER 0
+#define __APMPI_VER 0
#define __apmpi_logutils NULL
#endif
@@ -169,8 +169,8 @@ struct darshan_base_record
X(DXT_POSIX_MOD, "DXT_POSIX", DXT_POSIX_VER, &dxt_posix_logutils) \
X(DXT_MPIIO_MOD, "DXT_MPIIO", DXT_MPIIO_VER, &dxt_mpiio_logutils) \
X(DARSHAN_MDHIM_MOD, "MDHIM", DARSHAN_MDHIM_VER, &mdhim_logutils) \
- X(DARSHAN_APXC_MOD, "DARSHAN_APXC", __DARSHAN_APXC_VER, __apxc_logutils) \
- X(DARSHAN_APMPI_MOD, "DARSHAN_APMPI", __DARSHAN_APMPI_VER, __apmpi_logutils)
+ X(APXC_MOD, "APXC", __APXC_VER, __apxc_logutils) \
+ X(APMPI_MOD, "APMPI", __APMPI_VER, __apmpi_logutils)
/* unique identifiers to distinguish between available darshan modules */
/* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
@@ -521,7 +521,7 @@ void darshan_core_shutdown()
/* get a list of records which are shared across all processes */
darshan_get_shared_records(final_core, &shared_recs, &shared_rec_cnt);
+ printf(" L 524 --- my_rank: %d shared_rec_cnt: %d\n", my_rank, shared_rec_cnt);
mod_shared_recs = malloc(shared_rec_cnt * sizeof(darshan_record_id));
assert(mod_shared_recs);
@@ -593,7 +593,7 @@ void darshan_core_shutdown()
mod_buf = final_core->mod_array[i]->rec_buf_start;
mod_buf_sz = final_core->mod_array[i]->rec_buf_p - mod_buf;
- printf("l 596 --- MOD_ID: %d mod_buf_sz: %d\n", i, mod_buf_sz);
+ printf("l 596 --- MOD_ID: %d my_rank: %d mod_buf_sz: %d\n", i, my_rank, mod_buf_sz);
#ifdef HAVE_MPI
if(using_mpi)
@@ -608,13 +608,13 @@ void darshan_core_shutdown()
HASH_FIND(hlink, final_core->name_hash, &shared_recs[j],
sizeof(darshan_record_id), ref);
assert(ref);
- printf("l 611 --- MOD_ID: %d ref->global_mod_flags: %d \n", i, ref->global_mod_flags );
+ printf("l 611 --- MOD_ID: %d my_rank: %d j: %d ref->mod_flags: %d ref->global_mod_flags: %d \n", i, my_rank, j, ref->mod_flags, ref->global_mod_flags );
if(DARSHAN_MOD_FLAG_ISSET(ref->global_mod_flags, i))
mod_shared_recs[mod_shared_rec_cnt++] = shared_recs[j];
- printf("l 617 --- MOD_ID: %d shared_rec_cnt:%d mod_shared_rec_cnt:%d\n", i, shared_rec_cnt, mod_shared_rec_cnt);
+ printf("l 617 --- MOD_ID: %d my_rank: %d shared_rec_cnt:%d mod_shared_rec_cnt:%d\n", i, my_rank, shared_rec_cnt, mod_shared_rec_cnt);
/* int comm_size;
MPI_Comm_size(final_core->mpi_comm, &comm_size);
@@ -622,7 +622,7 @@ void darshan_core_shutdown()
int name_length;
MPI_Comm_get_name(final_core->mpi_comm, name, &name_length);
- printf("l 624 --- MOD_ID: %d DARSHAN_DISABLE_SHARED_REDUCTION:%d \n", i, getenv("DARSHAN_DISABLE_SHARED_REDUCTION"));
+ printf("l 624 --- MOD_ID: %d my_rank: %d DARSHAN_DISABLE_SHARED_REDUCTION:%d \n", i, my_rank, getenv("DARSHAN_DISABLE_SHARED_REDUCTION"));
/* allow the module an opportunity to reduce shared files */
if(this_mod->mod_funcs.mod_redux_func && (mod_shared_rec_cnt > 0) &&
(!getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))){
@@ -1227,7 +1227,7 @@ static int darshan_add_name_record_ref(struct darshan_core_runtime *core,
ref->name_record->id = rec_id;
strcpy(ref->name_record->name, name);
DARSHAN_MOD_FLAG_SET(ref->mod_flags, mod_id);
+printf(" L 1230 ---- my_rank:%d mod_id: %d name: %s ref->mod_flags: %d ref->global_mod_flags:%d \n", my_rank, mod_id, name, ref->mod_flags, ref->global_mod_flags);
/* add the record to the hash table */
HASH_ADD(hlink, core->name_hash, name_record->id,
@@ -1291,7 +1291,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
/* broadcast root's number of records to all other processes */
PMPI_Bcast(&tmp_cnt, 1, MPI_INT, 0, core->mpi_comm);
+ printf("L 1294 --- my_rank: %d core->name_hash: %lu tmp_cnt: %d\n", my_rank, core->name_hash, tmp_cnt);
/* use root record count to allocate data structures */
id_array = malloc(tmp_cnt * sizeof(darshan_record_id));
mod_flags = malloc(tmp_cnt * sizeof(uint64_t));
@@ -1326,6 +1326,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
/* we opened that record too, save the mod_flags */
mod_flags[i] = ref->mod_flags;
+ printf(" --- L 1329 my_rank: %d mod_flags[%d]: %d \n", my_rank, i, mod_flags[i]);
/* now allreduce so everyone agrees which records are shared and
@@ -1333,10 +1334,11 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
PMPI_Allreduce(mod_flags, global_mod_flags, tmp_cnt,
MPI_UINT64_T, MPI_BAND, core->mpi_comm);
j = 0;
for(i=0; i<tmp_cnt; i++)
+ printf(" --- L 1341 my_rank: %d mod_flags[%d]: %d global_mod_flags[%d]: %d\n", my_rank, i, mod_flags[i], i, global_mod_flags[i]);
if(global_mod_flags[i] != 0)
(*shared_recs)[j++] = id_array[i];
@@ -1348,6 +1350,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
HASH_FIND(hlink, core->name_hash, &id_array[i], sizeof(darshan_record_id), ref);
assert(ref);
ref->global_mod_flags = global_mod_flags[i];
+ printf(" L 1351 --- i: %d ref->mod_flags: %d ref->global_mod_flags: %d\n", i, ref->mod_flags, ref->global_mod_flags);
*shared_rec_cnt = j;
@@ -2283,7 +2286,8 @@ void *darshan_core_register_record(
DARSHAN_CORE_UNLOCK();
return(NULL);
+ printf("L 2289 --- my_rank: %d mod_id: %d name: %s \n\n\n\n\n\n\n\n\n\n\n", my_rank, mod_id, name);
+ printf("L 2286 --- my_rank: %d mod_id: %d darshan_core->mod_array[mod_id]->rec_mem_avail: %d rec_len:%d \n", my_rank, mod_id, darshan_core->mod_array[mod_id]->rec_mem_avail, rec_len);
/* check to see if this module has enough space to store a new record */
if(darshan_core->mod_array[mod_id]->rec_mem_avail < rec_len)
@@ -2300,8 +2304,10 @@ void *darshan_core_register_record(
HASH_FIND(hlink, darshan_core->name_hash, &rec_id,
+ printf("L 2303 --- my_rank: %d rec_id: %d ref: %d darshan_core->name_hash: %d \n", my_rank, rec_id, ref, darshan_core->name_hash);
if(!ref)
+ printf(" 2306 --- my_rank:%d mod_id: %d, rec_id: %lu name: %s \n", my_rank, mod_id, rec_id, name );
ret = darshan_add_name_record_ref(darshan_core, rec_id, name, mod_id);
if(ret == 0)
@@ -2309,6 +2315,7 @@ void *darshan_core_register_record(
return(NULL);
+ printf(" 2314 --- my_rank: %d mod_id: %d ret: %d\n", my_rank, mod_id, ret);
else
@@ -242,7 +242,7 @@ def log_get_apxc_record(log):
memory_modes = ['unknown', 'flat', 'equal', 'split', 'cache']
cluster_modes = ['unknown', 'all2all', 'quad', 'hemi', 'snc4', 'snc2']
buf = ffi.new("void **")
- r = libdutil.darshan_log_get_record(log, modules['DARSHAN_APXC']['idx'], buf)
+ r = libdutil.darshan_log_get_record(log, modules['APXC']['idx'], buf)
if r < 1:
return None
prf = ffi.cast("struct darshan_apxc_perf_record **", buf)
modules/autoperf
@@ -1 +1 @@
-Subproject commit 7c34b6a4fb05b4197641c7c8e9b07be3fe089fad
+Subproject commit 5f40cfef242df9463ea877be852fbfff97e0191b
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/c77d86a48c80251dc06b87e53f53ee3777ce67da
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210112/07bd0233/attachment-0001.html>
More information about the Darshan-commits
