[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » x86-master-dynamic #770
no-reply at alcf.anl.gov
Tue Jan 12 00:44:44 CST 2021
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/770/display/redirect>
Changes:
[...truncated 748.85 KB...]
if [ ! -e <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/share/doc/mpich> ] ; then mkdir -p <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/share/doc/mpich> ; fi
if [ -s ./doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644 ./doc/userguide/user.pdf <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/share/doc/mpich/user.pdf> ; fi
if [ -s ./doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644 ./doc/installguide/install.pdf <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/share/doc/mpich/install.pdf> ; fi
if [ -s ./doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644 ./doc/logging/logging.pdf <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/share/doc/mpich/logging.pdf> ; fi
mkdir -p '<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/include'>
/usr/bin/install -c -m 644 src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_base.mod '<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/include'>
/usr/bin/install -c -m 644 src/binding/cxx/mpicxx.h src/binding/fortran/mpif_h/mpif.h src/include/mpi.h '<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/include'>
mkdir -p '<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/lib/pkgconfig'>
/usr/bin/install -c -m 644 src/packaging/pkgconfig/mpich.pc '<https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-dynamic/ws/mpich-install/lib/pkgconfig'>
make[3]: Leaving directory `/gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/mpich-3.2.1'
make[2]: Leaving directory `/gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/mpich-3.2.1'
Making install in examples
make[2]: Entering directory `/gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/mpich-3.2.1/examples'
make[3]: Entering directory `/gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/mpich-3.2.1/examples'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/mpich-3.2.1/examples'
make[2]: Leaving directory `/gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/mpich-3.2.1/examples'
make[1]: Leaving directory `/gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/mpich-3.2.1'
[x86-master-dynamic] $ /bin/bash /tmp/jenkins3394412501887596000.sh
[x86-master-dynamic] $ /bin/bash /tmp/jenkins4026076136351507056.sh
checking for a BSD-compatible install... /usr/bin/install -c
checking whether to compile using MPI... yes
checking for gcc... mpicc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether mpicc accepts -g... yes
checking for mpicc option to accept ISO C89... none needed
checking for function MPI_Init... yes
checking for mpi.h... yes
checking how to run the C preprocessor... mpicc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for inflateEnd in -lz... yes
checking for BG/Q environment... no
checking lustre/lustre_user.h usability... yes
checking lustre/lustre_user.h presence... yes
checking for lustre/lustre_user.h... yes
checking for inttypes.h... (cached) yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking whether byte ordering is bigendian... no
checking for struct aiocb64... yes
checking for off64_t... yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking for MPI-IO support in MPI... yes
checking for MPI-IO prototypes without const qualifier... no
checking for MPI-IO prototypes with const qualifier... yes
checking for shared libraries in MPI... yes
checking for MPIO_Request... yes
checking for old (pre-3.1.1) style MPICH library naming convention... no
checking for fscanf redirect... no
checking for pwritev... yes
checking for preadv... yes
checking for pwritev2... no
checking for preadv2... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating darshan-mk-log-dirs.pl
config.status: creating darshan-gen-cc.pl
config.status: creating darshan-gen-cxx.pl
config.status: creating darshan-gen-fortran.pl
config.status: creating darshan-config
config.status: creating share/craype-1.x/darshan-module
config.status: creating share/craype-2.x/darshan-module
config.status: creating lib/pkgconfig/darshan-runtime.pc
config.status: creating share/mpi-profile/darshan-cc.conf
config.status: creating share/mpi-profile/darshan-cxx.conf
config.status: creating share/mpi-profile/darshan-f.conf
config.status: creating share/mpi-profile/darshan-cc-static.conf
config.status: creating share/mpi-profile/darshan-cxx-static.conf
config.status: creating share/mpi-profile/darshan-f-static.conf
config.status: creating share/ld-opts/darshan-base-ld-opts
config.status: creating share/ld-opts/darshan-stdio-ld-opts
config.status: creating share/ld-opts/darshan-hdf5-ld-opts
config.status: creating darshan-runtime-config.h
config.status: darshan-runtime-config.h is unchanged
configure: Building Darshan with CC=mpicc and with the following features:
configure: NULL module support: yes
configure: POSIX module support: yes
configure: STDIO module support: yes
configure: DXT module support: yes
configure: MPIIO module support: yes
configure: HDF5 module support: no
configure: PnetCDF module support: yes
configure: BG/Q module support: no
configure: Lustre module support: yes
configure: MDHIM module support: no
checking for gcc... gcc
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking if bzlib is wanted... yes
checking for BZ2_bzCompressInit in -lbz2... no
checking bzlib.h usability... no
checking bzlib.h presence... no
checking for bzlib.h... no
checking bzlib in /usr... failed
configure: WARNING: libbz2 not found; Darshan utilities will use gzip only.
checking for pdflatex... no
checking for python... /usr/bin/python
checking for python version... 2.7
checking for python platform... linux2
checking for python script directory... ${prefix}/lib/python2.7/site-packages
checking for python extension module directory... ${exec_prefix}/lib64/python2.7/site-packages
checking for strndup... yes
config.status: creating darshan-job-summary/bin/darshan-job-summary.pl
config.status: creating maint/darshan-util.pc
config.status: creating darshan-util-config.h
config.status: darshan-util-config.h is unchanged
configure: WARNING: Please install pdflatex if you wish to use the darshan-job-summary.pl utility
[x86-master-dynamic] $ /bin/bash /tmp/jenkins8045508911395292712.sh
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib
install -m 755 lib/libdarshan.a /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib
install -m 755 lib/libdarshan.so /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-mk-log-dirs.pl /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-gen-cc.pl /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-gen-cxx.pl /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-gen-fortran.pl /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-config /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/craype-1.x/modulefiles/darshan
install -m 755 share/craype-1.x/darshan-module /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/craype-1.x/modulefiles/darshan/3.2.1
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/craype-2.x/modulefiles/darshan
install -m 755 share/craype-2.x/darshan-module /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/craype-2.x/modulefiles/darshan/3.2.1
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/mpi-profile
install -m 755 share/mpi-profile/darshan-cc.conf /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/mpi-profile/darshan-cc.conf
install -m 755 share/mpi-profile/darshan-cxx.conf /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/mpi-profile/darshan-cxx.conf
install -m 755 share/mpi-profile/darshan-f.conf /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/mpi-profile/darshan-f.conf
install -m 755 share/mpi-profile/darshan-cc-static.conf /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/mpi-profile/darshan-cc-static.conf
install -m 755 share/mpi-profile/darshan-cxx-static.conf /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/mpi-profile/darshan-cxx-static.conf
install -m 755 share/mpi-profile/darshan-f-static.conf /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/mpi-profile/darshan-f-static.conf
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/ld-opts
install -m 644 share/ld-opts/darshan-base-ld-opts /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/ld-opts/darshan-base-ld-opts
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-posix-ld-opts /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/ld-opts/darshan-posix-ld-opts
install -m 644 share/ld-opts/darshan-stdio-ld-opts /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/ld-opts/darshan-stdio-ld-opts
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-mpiio-ld-opts /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/ld-opts/darshan-mpiio-ld-opts
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-pnetcdf-ld-opts /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share/ld-opts/darshan-pnetcdf-ld-opts
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/pkgconfig
install -m 644 lib/pkgconfig/darshan-runtime.pc /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/pkgconfig/darshan-runtime.pc
make: Nothing to be done for `all'.
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 755 darshan-analyzer /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-convert /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-diff /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-parser /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-dxt-parser /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 darshan-merge /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 ../../darshan-util/darshan-summary-per-file.sh /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 ../../darshan-util/dxt_analyzer.py /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -m 755 libdarshan-util.a /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib
install -m 644 ../../darshan-util/darshan-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-posix-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-mpiio-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-hdf5-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-pnetcdf-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-bgq-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-null-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-lustre-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-stdio-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-dxt-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/darshan-mdhim-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-null-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-posix-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-mpiio-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-hdf5-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-pnetcdf-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-bgq-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-lustre-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-stdio-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-dxt-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 644 ../../darshan-util/../darshan-mdhim-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include/uthash-1.9.2
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include/uthash-1.9.2/src
install -m 644 uthash-1.9.2/src/uthash.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include/uthash-1.9.2/src/
install -m 644 ../../darshan-util/../darshan-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/include
install -m 755 darshan-job-summary/bin/darshan-job-summary.pl /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/bin
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/TeX
install -m 644 ../../darshan-util/darshan-job-summary/lib/TeX/Encode.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/TeX/
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/Number
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/Number/Bytes
install -m 644 ../../darshan-util/darshan-job-summary/lib/Number/Bytes/Human.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/Number/Bytes
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/Pod
install -m 644 ../../darshan-util/darshan-job-summary/lib/Pod/Constants.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/Pod/
install -m 644 ../../darshan-util/darshan-job-summary/lib/Pod/LaTeX.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/Pod/
install -m 644 ../../darshan-util/darshan-job-summary/share/* /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/share
install -m 644 maint/darshan-util.pc /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-dynamic/install/lib/pkgconfig/darshan-util.pc
[x86-master-dynamic] $ /bin/bash /tmp/jenkins5086802702123552681.sh
Error: unable to find scripts for platform workstation-dynamic
Build step 'Execute shell' marked build as failure
Recording test results
[Checks API] No suitable checks publisher found.
More information about the Darshan-commits
