[Darshan-commits] [Git][darshan/darshan][autoperf-mod-update] update submodule
Sudheer Chunduri
xgitlab at cels.anl.gov
Mon Feb 1 23:23:26 CST 2021
Sudheer Chunduri pushed to branch autoperf-mod-update at darshan / darshan
Commits:
b197484e by Sudheer Chunduri at 2021-02-02T05:22:46+00:00
update submodule
1 changed file:
- − darshan-util/pydarshan.py
Changes:
darshan-util/pydarshan.py deleted
@@ -1,268 +0,0 @@
-import cffi
-import numpy
-API_def_c = r"""
-/* from darshan-logutils.h */
-struct darshan_mnt_info
- char mnt_type[3031];
- char mnt_path[3031];
-struct darshan_mod_info
- char *name;
- int len;
- int ver;
- int idx;
-/* from darshan-log-format.h */
-struct darshan_job
- int64_t uid;
- int64_t start_time;
- int64_t end_time;
- int64_t nprocs;
- int64_t jobid;
- char metadata[1024];
-struct darshan_base_record
- uint64_t id;
- int64_t rank;
-struct darshan_posix_file
- struct darshan_base_record base_rec;
- int64_t counters[64];
- double fcounters[17];
-struct darshan_stdio_file
- int64_t counters[13];
- double fcounters[15];
-struct darshan_mpiio_file
- int64_t counters[51];
-struct darshan_hdf5_file
- int64_t counters[1];
- double fcounters[2];
-struct darshan_pnetcdf_file
- int64_t counters[2];
-struct darshan_bgq_record
- int64_t counters[11];
- double fcounters[1];
-/* from darshan-apxc-log-format.h */
-struct darshan_apxc_header_record
- int64_t magic;
- int nblades;
- int nchassis;
- int ngroups;
- int memory_mode;
- int cluster_mode;
-struct darshan_apxc_perf_record
- int64_t counters[396];
-/* counter names */
-char *apxc_counter_names[];
-char *bgq_counter_names[];
-char *bgq_f_counter_names[];
-char *hdf5_counter_names[];
-char *hdf5_f_counter_names[];
-char *mpiio_counter_names[];
-char *mpiio_f_counter_names[];
-char *pnetcdf_counter_names[];
-char *pnetcdf_f_counter_names[];
-char *posix_counter_names[];
-char *posix_f_counter_names[];
-char *stdio_counter_names[];
-char *stdio_f_counter_names[];
-/* Supported Functions */
-void* darshan_log_open(char *);
-int darshan_log_get_job(void *, struct darshan_job *);
-void darshan_log_close(void*);
-int darshan_log_get_exe(void*, char *);
-int darshan_log_get_mounts(void*, struct darshan_mnt_info **, int*);
-void darshan_log_get_modules(void*, struct darshan_mod_info **, int*);
-int darshan_log_get_record(void*, int, void **);
-ffi = cffi.FFI()
-ffi.cdef(API_def_c)
-libdutil = ffi.dlopen("/home/harms/working/darshan/theta/install/lib/libdarshan-util.so")
-modules = {}
-def log_open(filename):
- b_fname = filename.encode()
- log = libdutil.darshan_log_open(b_fname)
- mods = log_get_modules(log)
- return log
-def log_close(log):
- libdutil.darshan_log_close(log)
- modules = {}
- return
-def log_get_job(log):
- job = {}
- jobrec = ffi.new("struct darshan_job *")
- libdutil.darshan_log_get_job(log, jobrec)
- job['jobid'] = jobrec[0].jobid
- job['uid'] = jobrec[0].uid
- job['start_time'] = jobrec[0].start_time
- job['end_time'] = jobrec[0].end_time
- mstr = ffi.string(jobrec[0].metadata).decode("utf-8")
- md = {}
- for kv in mstr.split('\n')[:-1]:
- k,v = kv.split('=', maxsplit=1)
- md[k] = v
- job['metadata'] = md
- return job
-def log_get_exe(log):
- exestr = ffi.new("char[]", 4096)
- libdutil.darshan_log_get_exe(log, exestr)
- return ffi.string(exestr).decode("utf-8")
-def log_get_mounts(log):
- mntlst = []
- mnts = ffi.new("struct darshan_mnt_info **")
- cnt = ffi.new("int *")
- libdutil.darshan_log_get_mounts(log, mnts, cnt)
- for i in range(0, cnt[0]):
- mntlst.append((ffi.string(mnts[0][i].mnt_path).decode("utf-8"),
- ffi.string(mnts[0][i].mnt_type).decode("utf-8")))
- return mntlst
-def log_get_modules(log):
- mods = ffi.new("struct darshan_mod_info **")
- libdutil.darshan_log_get_modules(log, mods, cnt)
- modules[ffi.string(mods[0][i].name).decode("utf-8")] = \
- {'len': mods[0][i].len, 'ver': mods[0][i].ver, 'idx': mods[0][i].idx}
- return modules
-def log_get_generic_record(log, mod_name, mod_type):
- rec = {}
- buf = ffi.new("void **")
- r = libdutil.darshan_log_get_record(log, modules[mod_name]['idx'], buf)
- if r < 1:
- return None
- rbuf = ffi.cast(mod_type, buf)
- clst = []
- for i in range(0, len(rbuf[0].counters)):
- clst.append(rbuf[0].counters[i])
- rec['counters'] = numpy.array(clst, dtype=numpy.uint64)
- flst = []
- for i in range(0, len(rbuf[0].fcounters)):
- flst.append(rbuf[0].fcounters[i])
- rec['fcounters'] = numpy.array(clst, dtype=numpy.float64)
- return rec
-def counter_names(mod_name, fcnts=False):
- names = []
- i = 0
- if fcnts:
- F = "f_"
- else:
- F1 = ""
- F2 = ""
- end = "{0}_{1}NUM_INDICES".format(mod_name.upper(), F.upper())
- var_name = "{0}_{1}counter_names".format(mod_name.lower(), F.lower())
- while True:
- try:
- var = getattr(libdutil, var_name)
- except:
- var = None
- if not var:
- return None
- name = ffi.string(var[i]).decode("utf-8")
- if name == end:
- break
- names.append(name)
- i += 1
- return names
-def fcounter_names(mod_name):
- return counter_names(mod_name, fcnts=True)
-def log_get_bgq_record(log):
- return log_get_generic_record(log, "BGQ", "struct darshan_bgq_file **")
-def log_get_hdf5_record(log):
- return log_get_generic_record(log, "HDF5", "struct darshan_hdf5_file **")
-def log_get_mpiio_record(log):
- return log_get_generic_record(log, "MPIIO", "struct darshan_mpiio_file **")
-def log_get_pnetcdf_record(log):
- return log_get_generic_record(log, "PNETCDF", "struct darshan_pnetcdf_file **")
-def log_get_posix_record(log):
- return log_get_generic_record(log, "POSIX", "struct darshan_posix_file **")
-def log_get_stdio_record(log):
- return log_get_generic_record(log, "STDIO", "struct darshan_stdio_file **")
-def log_get_apxc_record(log):
- rec = {}
- memory_modes = ['unknown', 'flat', 'equal', 'split', 'cache']
- cluster_modes = ['unknown', 'all2all', 'quad', 'hemi', 'snc4', 'snc2']
- r = libdutil.darshan_log_get_record(log, modules['APXC']['idx'], buf)
- if r < 1:
- return None
- prf = ffi.cast("struct darshan_apxc_perf_record **", buf)
- hdr = ffi.cast("struct darshan_apxc_header_record **", buf)
- if hdr[0].magic == 4707761685111591494:
- mm = hdr[0].memory_mode & ~(1 << 31)
- cm = hdr[0].cluster_mode & ~(1 << 31)
- rec['nblades'] = hdr[0].nblades
- rec['nchassis'] = hdr[0].nchassis
- rec['ngroups'] = hdr[0].ngroups
- rec['memory_mode'] = memory_modes[mm]
- rec['cluster_mode'] = cluster_modes[cm]
- else:
- rec['group'] = prf[0].counters[0]
- rec['chassis'] = prf[0].counters[1]
- rec['blade'] = prf[0].counters[2]
- rec['node'] = prf[0].counters[3]
- clst = []
- for i in range(0, len(prf[0].counters)):
- clst.append(prf[0].counters[i])
- return rec
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/b197484e76075cde608e88098ec78f66c386cc1c
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210201/08a28904/attachment-0001.html>
More information about the Darshan-commits
