[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » x86-master-ld-preload #559
no-reply at alcf.anl.gov no-reply at alcf.anl.gov
Tue Dec 28 11:53:04 CST 2021
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-ld-preload/559/display/redirect>
Changes:
[...truncated 777.54 KB...]
uthash-1.9.2/tests/test1.ans
uthash-1.9.2/tests/test1.c
uthash-1.9.2/tests/test10.ans
uthash-1.9.2/tests/test10.c
uthash-1.9.2/tests/test11.ans
uthash-1.9.2/tests/test11.c
uthash-1.9.2/tests/test11.dat
uthash-1.9.2/tests/test12.ans
uthash-1.9.2/tests/test12.c
uthash-1.9.2/tests/test13.ans
uthash-1.9.2/tests/test13.c
uthash-1.9.2/tests/test14.ans
uthash-1.9.2/tests/test14.c
uthash-1.9.2/tests/test14.dat
uthash-1.9.2/tests/test15.ans
uthash-1.9.2/tests/test15.c
uthash-1.9.2/tests/test16.ans
uthash-1.9.2/tests/test16.c
uthash-1.9.2/tests/test17.ans
uthash-1.9.2/tests/test17.c
uthash-1.9.2/tests/test18.ans
uthash-1.9.2/tests/test18.c
uthash-1.9.2/tests/test19.ans
uthash-1.9.2/tests/test19.c
uthash-1.9.2/tests/test2.ans
uthash-1.9.2/tests/test2.c
uthash-1.9.2/tests/test20.ans
uthash-1.9.2/tests/test20.c
uthash-1.9.2/tests/test21.ans
uthash-1.9.2/tests/test21.c
uthash-1.9.2/tests/test22.ans
uthash-1.9.2/tests/test22.c
uthash-1.9.2/tests/test23.ans
uthash-1.9.2/tests/test23.c
uthash-1.9.2/tests/test24.ans
uthash-1.9.2/tests/test24.c
uthash-1.9.2/tests/test25.ans
uthash-1.9.2/tests/test25.c
uthash-1.9.2/tests/test26.ans
uthash-1.9.2/tests/test26.c
uthash-1.9.2/tests/test27.ans
uthash-1.9.2/tests/test27.c
uthash-1.9.2/tests/test28.ans
uthash-1.9.2/tests/test28.c
uthash-1.9.2/tests/test29.ans
uthash-1.9.2/tests/test29.c
uthash-1.9.2/tests/test3.ans
uthash-1.9.2/tests/test3.c
uthash-1.9.2/tests/test30.ans
uthash-1.9.2/tests/test30.c
uthash-1.9.2/tests/test31.ans
uthash-1.9.2/tests/test31.c
uthash-1.9.2/tests/test32.ans
uthash-1.9.2/tests/test32.c
uthash-1.9.2/tests/test33.ans
uthash-1.9.2/tests/test33.c
uthash-1.9.2/tests/test34.ans
uthash-1.9.2/tests/test34.c
uthash-1.9.2/tests/test35.ans
uthash-1.9.2/tests/test35.c
uthash-1.9.2/tests/test36.ans
uthash-1.9.2/tests/test36.c
uthash-1.9.2/tests/test37.ans
uthash-1.9.2/tests/test37.c
uthash-1.9.2/tests/test38.ans
uthash-1.9.2/tests/test38.c
uthash-1.9.2/tests/test39.ans
uthash-1.9.2/tests/test39.c
uthash-1.9.2/tests/test4.ans
uthash-1.9.2/tests/test4.c
uthash-1.9.2/tests/test40.ans
uthash-1.9.2/tests/test40.c
uthash-1.9.2/tests/test41.ans
uthash-1.9.2/tests/test41.c
uthash-1.9.2/tests/test42.ans
uthash-1.9.2/tests/test42.c
uthash-1.9.2/tests/test43.ans
uthash-1.9.2/tests/test43.c
uthash-1.9.2/tests/test44.ans
uthash-1.9.2/tests/test44.c
uthash-1.9.2/tests/test45.ans
uthash-1.9.2/tests/test45.c
uthash-1.9.2/tests/test46.ans
uthash-1.9.2/tests/test46.c
uthash-1.9.2/tests/test47.ans
uthash-1.9.2/tests/test47.c
uthash-1.9.2/tests/test48.ans
uthash-1.9.2/tests/test48.c
uthash-1.9.2/tests/test49.ans
uthash-1.9.2/tests/test49.c
uthash-1.9.2/tests/test5.ans
uthash-1.9.2/tests/test5.c
uthash-1.9.2/tests/test50.ans
uthash-1.9.2/tests/test50.c
uthash-1.9.2/tests/test51.ans
uthash-1.9.2/tests/test51.c
uthash-1.9.2/tests/test52.ans
uthash-1.9.2/tests/test52.c
uthash-1.9.2/tests/test53.ans
uthash-1.9.2/tests/test53.c
uthash-1.9.2/tests/test54.ans
uthash-1.9.2/tests/test54.c
uthash-1.9.2/tests/test55.ans
uthash-1.9.2/tests/test55.c
uthash-1.9.2/tests/test56.ans
uthash-1.9.2/tests/test56.c
uthash-1.9.2/tests/test57.ans
uthash-1.9.2/tests/test57.c
uthash-1.9.2/tests/test58.ans
uthash-1.9.2/tests/test58.c
uthash-1.9.2/tests/test6.ans
uthash-1.9.2/tests/test6.c
uthash-1.9.2/tests/test7.ans
uthash-1.9.2/tests/test7.c
uthash-1.9.2/tests/test8.ans
uthash-1.9.2/tests/test8.c
uthash-1.9.2/tests/test9.ans
uthash-1.9.2/tests/test9.c
uthash-1.9.2/tests/threads/
uthash-1.9.2/tests/threads/Makefile
uthash-1.9.2/tests/threads/README
uthash-1.9.2/tests/threads/do_tests
uthash-1.9.2/tests/threads/test1.c
uthash-1.9.2/tests/threads/test2.c
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-logutils.c -o darshan-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-posix-logutils.c -o darshan-posix-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-mpiio-logutils.c -o darshan-mpiio-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-hdf5-logutils.c -o darshan-hdf5-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-pnetcdf-logutils.c -o darshan-pnetcdf-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-bgq-logutils.c -o darshan-bgq-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-lustre-logutils.c -o darshan-lustre-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-stdio-logutils.c -o darshan-stdio-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-dxt-logutils.c -o darshan-dxt-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-mdhim-logutils.c -o darshan-mdhim-logutils.o
ar rcs libdarshan-util.a darshan-logutils.o darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o darshan-bgq-logutils.o darshan-lustre-logutils.o darshan-stdio-logutils.o darshan-dxt-logutils.o darshan-mdhim-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c  ../../darshan-util/darshan-null-logutils.c -o darshan-null-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2    ../../darshan-util/darshan-analyzer.c libdarshan-util.a -o darshan-analyzer -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2   -c ../../darshan-util/lookup3.c -o lookup3.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2    ../../darshan-util/darshan-convert.c lookup3.o libdarshan-util.a -o darshan-convert -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2    ../../darshan-util/darshan-diff.c libdarshan-util.a -o darshan-diff -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2    ../../darshan-util/darshan-parser.c libdarshan-util.a -o darshan-parser -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2    ../../darshan-util/darshan-dxt-parser.c libdarshan-util.a -o darshan-dxt-parser -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2    ../../darshan-util/darshan-merge.c libdarshan-util.a -o darshan-merge -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2    ../../darshan-util/jenkins-hash-gen.c lookup3.o -o jenkins-hash-gen -lz
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 755 darshan-analyzer /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -m 755 darshan-convert /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -m 755 darshan-diff /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -m 755 darshan-parser /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -m 755 darshan-dxt-parser /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -m 755 darshan-merge /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -m 755 ../../darshan-util/darshan-summary-per-file.sh /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -m 755 ../../darshan-util/dxt_analyzer.py /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -m 755 libdarshan-util.a /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib
install -m 644 ../../darshan-util/darshan-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-posix-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-mpiio-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-hdf5-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-pnetcdf-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-bgq-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-null-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-lustre-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-stdio-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-dxt-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/darshan-mdhim-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-null-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-posix-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-mpiio-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-hdf5-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-pnetcdf-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-bgq-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-lustre-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-stdio-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-dxt-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 644 ../../darshan-util/../darshan-mdhim-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include/uthash-1.9.2
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include/uthash-1.9.2/src
install -m 644 uthash-1.9.2/src/uthash.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include/uthash-1.9.2/src/
install -m 644 ../../darshan-util/../darshan-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/include
install -m 755 darshan-job-summary/bin/darshan-job-summary.pl /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/bin
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/TeX
install -m 644 ../../darshan-util/darshan-job-summary/lib/TeX/Encode.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/TeX/
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/Number
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/Number/Bytes
install -m 644 ../../darshan-util/darshan-job-summary/lib/Number/Bytes/Human.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/Number/Bytes
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/Pod
install -m 644 ../../darshan-util/darshan-job-summary/lib/Pod/Constants.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/Pod/
install -m 644 ../../darshan-util/darshan-job-summary/lib/Pod/LaTeX.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/Pod/
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/share
install -m 644 ../../darshan-util/darshan-job-summary/share/* /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/share
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/pkgconfig
install -m 644 maint/darshan-util.pc /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/install/lib/pkgconfig/darshan-util.pc
[x86-master-ld-preload] $ /bin/bash /tmp/jenkins13372237184762013289.sh
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/access-size-counter-test.sh...
Done.
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/cxxpi.sh...
Process Process Process 2 of 4 is on cinow-01.mcp.alcf.anl.gov0 of 4 is on cinow-01.mcp.alcf.anl.gov
1 of 4 is on cinow-01.mcp.alcf.anl.gov
Process 3 of 4 is on cinow-01.mcp.alcf.anl.gov
pi is approximately 3.14159 Error is 8.33331e-10
wall clock time = 0.000141621
Done.
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/fperf-f77.sh...
 Access size per process =      4194304  bytes, ntimes =            5
 Write bandwidth without file sync =    16281.523409917630       Mbytes/sec
 Read bandwidth without prior file sync =    311.76065364870590       Mbytes/sec
 Write bandwidth including file sync =    35.134796890419615       Mbytes/sec
 Read bandwidth after file sync =    17264.166873813541       Mbytes/sec
Done.
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/fperf-f90.sh...
 Write bandwidth without file sync =    29308.098366374012       Mbytes/sec
 Read bandwidth without prior file sync =    432.35729667517018       Mbytes/sec
 Write bandwidth including file sync =    40.455013002902099       Mbytes/sec
 Read bandwidth after file sync =    13148.121109428999       Mbytes/sec
Done.
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/fprintf-fscanf-test.sh...
# Using stdio calls.
Done.
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/mpi-io-test-dxt.sh...
# Using mpi-io calls.
nr_procs = 4, nr_iter = 1, blk_sz = 16777216, coll = 0
# total_size = 67108864
# Write: min_t = 0.027781, max_t = 0.029272, mean_t = 0.028593, var_t = 0.000000
# Read:  min_t = 0.107933, max_t = 0.129692, mean_t = 0.121846, var_t = 0.000103
Write bandwidth = 2292.608240 Mbytes/sec
Read bandwidth = 517.447675 Mbytes/sec
Done.
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/mpi-io-test.sh...
# Write: min_t = 0.006460, max_t = 0.006902, mean_t = 0.006604, var_t = 0.000000
# Read:  min_t = 0.008358, max_t = 0.067489, mean_t = 0.031195, var_t = 0.000698
Write bandwidth = 9722.797123 Mbytes/sec
Read bandwidth = 994.372295 Mbytes/sec
Done.
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/stdio-test.sh...
Error: STDIO open count of 0 is incorrect
Error: failed to execute test case /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-ld-preload/darshan-test/regression/test-cases/stdio-test.sh
Done.
1 tests failed
Build step 'Execute shell' marked build as failure
Recording test results
[Checks API] No suitable checks publisher found.
More information about the Darshan-commits mailing list
