[Darshan-commits] [Git][darshan/darshan][master] 2 commits: remove AutoPerf from changelog for now
Shane Snyder
xgitlab at cels.anl.gov
Thu Apr 29 17:06:14 CDT 2021
Shane Snyder pushed to branch master at darshan / darshan
Commits:
d0e606a0 by Shane Snyder at 2021-04-29T16:59:35-05:00
7125643d by Shane Snyder at 2021-04-29T17:05:02-05:00
bump configure versions for 3.3.0-pre2
5 changed files:
- ChangeLog
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-util/configure
- darshan-util/configure.in
Changes:
ChangeLog
@@ -16,8 +16,6 @@ Darshan-3.3.0-pre1
* added first version of PyDarshan, which provides interfaces for
accessing Darshan log file data from Python applications
-* added AutoPerf modules for tracking MPI communication usage (APMPI) and
- for tracking Cray XC performance counters (APXC)
* modified Lustre module to use 'fgetxattr' rather than 'ioctl' for
querying stripe info to avoid known bug in Lustre that could cause
application crashes
@@ -1,6 +1,6 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.3.0-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 3.3.0-pre2.
# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
# Identity of this package.
PACKAGE_NAME='darshan-runtime'
PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='3.3.0-pre1'
-PACKAGE_STRING='darshan-runtime 3.3.0-pre1'
+PACKAGE_VERSION='3.3.0-pre2'
+PACKAGE_STRING='darshan-runtime 3.3.0-pre2'
PACKAGE_BUGREPORT=''
PACKAGE_URL=''
@@ -1299,7 +1299,7 @@ if test "$ac_init_help" = "long"; then
# Omit some internal or obsolete options to make the list less imposing.
# This message is too long to be a string in the A/UX 3.1 sh.
cat <<_ACEOF
-\`configure' configures darshan-runtime 3.3.0-pre1 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 3.3.0-pre2 to adapt to many kinds of systems.
Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1361,7 +1361,7 @@ fi
if test -n "$ac_init_help"; then
case $ac_init_help in
- short | recursive ) echo "Configuration of darshan-runtime 3.3.0-pre1:";;
+ short | recursive ) echo "Configuration of darshan-runtime 3.3.0-pre2:";;
esac
cat <<\_ACEOF
@@ -1493,7 +1493,7 @@ fi
test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
cat <<\_ACEOF
-darshan-runtime configure 3.3.0-pre1
+darshan-runtime configure 3.3.0-pre2
generated by GNU Autoconf 2.69
Copyright (C) 2012 Free Software Foundation, Inc.
@@ -1941,7 +1941,7 @@ cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 3.3.0-pre1, which was
+It was created by darshan-runtime $as_me 3.3.0-pre2, which was
generated by GNU Autoconf 2.69. Invocation command line was
$ $0 $@
@@ -5240,7 +5240,7 @@ $as_echo "#define HAVE_OPEN_MPI 1" >>confdefs.h
fi
rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-DARSHAN_VERSION="3.3.0-pre1"
+DARSHAN_VERSION="3.3.0-pre2"
@@ -5784,7 +5784,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
-This file was extended by darshan-runtime $as_me 3.3.0-pre1, which was
+This file was extended by darshan-runtime $as_me 3.3.0-pre2, which was
CONFIG_FILES = $CONFIG_FILES
@@ -5846,7 +5846,7 @@ _ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
-darshan-runtime config.status 3.3.0-pre1
+darshan-runtime config.status 3.3.0-pre2
configured by $0, generated by GNU Autoconf 2.69,
with options \\"\$ac_cs_config\\"
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
dnl You may need to use autoheader as well if changing any DEFINEs
dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [3.3.0-pre1])
+AC_INIT([darshan-runtime], [3.3.0-pre2])
AC_CONFIG_SRCDIR([darshan.h])
AC_CONFIG_AUX_DIR(../maint/config)
AC_CONFIG_MACRO_DIR(../maint/config)
@@ -1,6 +1,6 @@
#! /bin/sh
-# Generated by GNU Autoconf 2.69 for darshan-util 3.3.0-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-util 3.3.0-pre2.
PACKAGE_NAME='darshan-util'
PACKAGE_TARNAME='darshan-util'
-PACKAGE_STRING='darshan-util 3.3.0-pre1'
+PACKAGE_STRING='darshan-util 3.3.0-pre2'
PACKAGE_URL=''
@@ -1264,7 +1264,7 @@ if test "$ac_init_help" = "long"; then
cat <<_ACEOF
-\`configure' configures darshan-util 3.3.0-pre1 to adapt to many kinds of systems.
+\`configure' configures darshan-util 3.3.0-pre2 to adapt to many kinds of systems.
@@ -1326,7 +1326,7 @@ fi
- short | recursive ) echo "Configuration of darshan-util 3.3.0-pre1:";;
+ short | recursive ) echo "Configuration of darshan-util 3.3.0-pre2:";;
esac
cat <<\_ACEOF
@@ -1426,7 +1426,7 @@ fi
cat <<\_ACEOF
-darshan-util configure 3.3.0-pre1
+darshan-util configure 3.3.0-pre2
@@ -1820,7 +1820,7 @@ cat >config.log <<_ACEOF
-It was created by darshan-util $as_me 3.3.0-pre1, which was
+It was created by darshan-util $as_me 3.3.0-pre2, which was
$ $0 $@
@@ -4450,7 +4450,7 @@ fi
done
-DARSHAN_UTIL_VERSION="3.3.0-pre1"
+DARSHAN_UTIL_VERSION="3.3.0-pre2"
@@ -4970,7 +4970,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
ac_log="
-This file was extended by darshan-util $as_me 3.3.0-pre1, which was
+This file was extended by darshan-util $as_me 3.3.0-pre2, which was
@@ -5032,7 +5032,7 @@ _ACEOF
ac_cs_version="\\
-darshan-util config.status 3.3.0-pre1
+darshan-util config.status 3.3.0-pre2
-AC_INIT([darshan-util], [3.3.0-pre1])
+AC_INIT([darshan-util], [3.3.0-pre2])
AC_CONFIG_SRCDIR([darshan-logutils.h])
AC_CONFIG_HEADER(darshan-util-config.h)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/be0ade397e2075eea7df3577598d21668ef71037...7125643d55a4a641e9f05ac902f1eb01aad96994
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210429/2bf5554c/attachment-0001.html>
More information about the Darshan-commits
