[Darshan-commits] [Git][darshan/darshan][master] 2 commits: check lustre striping for all files
Shane Snyder
xgitlab at cels.anl.gov
Thu Apr 29 13:42:02 CDT 2021
Shane Snyder pushed to branch master at darshan / darshan
Commits:
8b3771d4 by Shane Snyder at 2021-04-29T18:02:50+00:00
This attempts to work around issue #302, where Darshan can't
instrument Lustre striping information for symlinks to Lustre
files that reside on other file systems. The method for querying
Lustre striping info is general enough (based on xattrs) and
low-overhead enough that this should not create any issues for
Darshan users.
Closes #302
5ec3e5a9 by Shane Snyder at 2021-04-29T13:41:59-05:00
Merge branch 'snyder/dev-issue302-lustre-symlinks' into 'master'
Closes #302
See merge request darshan/darshan!108
1 changed file:
- darshan-runtime/lib/darshan-core.c
Changes:
@@ -2342,8 +2342,16 @@ char *darshan_core_lookup_record_name(darshan_record_id rec_id)
void darshan_instrument_fs_data(int fs_type, const char *path, int fd)
#ifdef DARSHAN_LUSTRE
- /* allow lustre to generate a record if we configured with lustre support */
- if(fs_type == LL_SUPER_MAGIC)
+ /* allow Lustre to generate a record if we configured with Lustre support */
+ /* XXX: Note that we short-circuit this Lustre file system check and try to
+ * query Lustre striping stats for *all* files instrumented by Darshan (i.e.,
+ * Lustre files or not). We do this so that symlinks to Lustre files are
+ * properly instrumented, since these symlinks might live on other non-Lustre
+ * file systems. We have instrumented this Lustre file system check on a number
+ * of file systems and believe it is low overhead enough to not be noticable by
+ * users.
+ if(1 || fs_type == LL_SUPER_MAGIC)
darshan_instrument_lustre_file(path, fd);
return;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/compare/95678e943cfdafab39b8ba549dfa5775bf938e5c...5ec3e5a9f5ce4be7faddc266ee18c8db0d2cf5bc
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210429/3e0de1a1/attachment.html>
More information about the Darshan-commits
