[Darshan-commits] [Git][darshan/darshan][master] updated changelog for darshan-3.3.0-pre1
    Shane Snyder
    xgitlab at cels.anl.gov
    Fri Apr  9 16:12:35 CDT 2021
Shane Snyder pushed to branch master at darshan / darshan
Commits:
9d064ea9 by Shane Snyder at 2021-04-09T16:11:38-05:00
2 changed files:
- ChangeLog
- darshan-runtime/darshan-core.h
Changes:
ChangeLog
@@ -2,12 +2,35 @@
 Darshan Release Change Log
-Darshan-3.3
-* add wrappers for preadv, preadv2, pwritev, and pwritev2 (improves profiling
-  of ompio)
-* improve error handling in command line parsers to make incomplete logs more
+Darshan-3.3.0-pre1
+* added first version of PyDarshan, which provides interfaces for
+  accessing Darshan log file data from Python applications
+* added AutoPerf modules for tracking MPI communication usage (APMPI) and
+  for tracking Cray XC performance counters (APXC)
+* modified Lustre module to use 'fgetxattr' rather than 'ioctl' for
+  querying stripe info to avoid known bug in Lustre that could cause
+  application crashes
+* fixed bug leading to potential deadlock when reducing shared file records
+  for MPI applications (known to affect mvapich2)
+* fixed bug preventing usage of Darshan's non-MPI mode in builds that use
+  MPI compilers
+* boosted Darshan's default internal memory allocation from 2 MiB to 4 MiB
+* added wrappers for openat, preadv, preadv2, pwritev, and pwritev2 (improves
+  profiling of ompio)
+* various bug fixes to enable usage of HDF5 modules in non-MPI applications
+* fixed HDF5 module bug leading to warnings on stdout for applications using
+  non-MPIIO VFD for HDF5
+* fixed HDF5 module bug leading to potentially incorrect values in H5D module
+  common access counters
+* added new H5D record value to indicate corresponding H5F record ID, to
+  allow easier mapping of HDF5 datasets to files they belong to
+* improved error handling in command line parsers to make incomplete logs more
   obvious to users
+* fixed bug leading to incorrect internal timing information at Darshan
+  shutdown time
+* fixed bug causing negative Darshan counter values from being plotted when
+  using the darshan-job-summary tool
 Darshan-3.2.1
@@ -54,7 +54,7 @@
 #ifdef __DARSHAN_MOD_MEM_MAX
 #define DARSHAN_MOD_MEM_MAX (__DARSHAN_MOD_MEM_MAX * 1024L * 1024L)
 #else
-#define DARSHAN_MOD_MEM_MAX (4 * 1024 * 1024) /* 2 MiB default */
+#define DARSHAN_MOD_MEM_MAX (4 * 1024 * 1024) /* 4 MiB default */
 #endif
 /* default name record buf can store 2048 records of size 100 bytes */
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/9d064ea9818fc8119addde4a1b0122f3768ad67e
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20210409/d20c98c8/attachment-0001.html>
More information about the Darshan-commits
