[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » x86-master-cc-wrapper-static #561
no-reply at alcf.anl.gov
Sun May 17 06:02:46 CDT 2020
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-cc-wrapper-static/561/display/redirect>
Changes:
[...truncated 755.28 KB...]
uthash-1.9.2/doc/html/userguide.pdf
uthash-1.9.2/doc/html/utarray.html
uthash-1.9.2/doc/html/utlist.html
uthash-1.9.2/doc/html/utstring.html
uthash-1.9.2/doc/pdf/
uthash-1.9.2/doc/pdf/userguide.pdf
uthash-1.9.2/doc/txt/
uthash-1.9.2/doc/txt/ChangeLog.txt
uthash-1.9.2/doc/txt/sflogo.txt
uthash-1.9.2/doc/txt/toc.txt
uthash-1.9.2/doc/txt/topnav.txt
uthash-1.9.2/doc/txt/topnav_utarray.txt
uthash-1.9.2/doc/txt/topnav_utlist.txt
uthash-1.9.2/doc/txt/topnav_utstring.txt
uthash-1.9.2/doc/txt/userguide.txt
uthash-1.9.2/doc/txt/utarray.txt
uthash-1.9.2/doc/txt/utlist.txt
uthash-1.9.2/doc/txt/utstring.txt
uthash-1.9.2/src/
uthash-1.9.2/src/utarray.h
uthash-1.9.2/src/uthash.h
uthash-1.9.2/src/utlist.h
uthash-1.9.2/src/utstring.h
uthash-1.9.2/tests/
uthash-1.9.2/tests/Makefile
uthash-1.9.2/tests/README
uthash-1.9.2/tests/all_funcs
uthash-1.9.2/tests/bloom_perf.c
uthash-1.9.2/tests/bloom_perf.sh
uthash-1.9.2/tests/do_tests
uthash-1.9.2/tests/do_tests.cygwin
uthash-1.9.2/tests/do_tests.mingw
uthash-1.9.2/tests/do_tests_win32.cmd
uthash-1.9.2/tests/emit_keys.c
uthash-1.9.2/tests/example.c
uthash-1.9.2/tests/hashscan.c
uthash-1.9.2/tests/keystat.c
uthash-1.9.2/tests/keystats
uthash-1.9.2/tests/mexpand
uthash-1.9.2/tests/simkeys.pl
uthash-1.9.2/tests/sleep_test.c
uthash-1.9.2/tests/tdiff.cpp
uthash-1.9.2/tests/test1.ans
uthash-1.9.2/tests/test1.c
uthash-1.9.2/tests/test10.ans
uthash-1.9.2/tests/test10.c
uthash-1.9.2/tests/test11.ans
uthash-1.9.2/tests/test11.c
uthash-1.9.2/tests/test11.dat
uthash-1.9.2/tests/test12.ans
uthash-1.9.2/tests/test12.c
uthash-1.9.2/tests/test13.ans
uthash-1.9.2/tests/test13.c
uthash-1.9.2/tests/test14.ans
uthash-1.9.2/tests/test14.c
uthash-1.9.2/tests/test14.dat
uthash-1.9.2/tests/test15.ans
uthash-1.9.2/tests/test15.c
uthash-1.9.2/tests/test16.ans
uthash-1.9.2/tests/test16.c
uthash-1.9.2/tests/test17.ans
uthash-1.9.2/tests/test17.c
uthash-1.9.2/tests/test18.ans
uthash-1.9.2/tests/test18.c
uthash-1.9.2/tests/test19.ans
uthash-1.9.2/tests/test19.c
uthash-1.9.2/tests/test2.ans
uthash-1.9.2/tests/test2.c
uthash-1.9.2/tests/test20.ans
uthash-1.9.2/tests/test20.c
uthash-1.9.2/tests/test21.ans
uthash-1.9.2/tests/test21.c
uthash-1.9.2/tests/test22.ans
uthash-1.9.2/tests/test22.c
uthash-1.9.2/tests/test23.ans
uthash-1.9.2/tests/test23.c
uthash-1.9.2/tests/test24.ans
uthash-1.9.2/tests/test24.c
uthash-1.9.2/tests/test25.ans
uthash-1.9.2/tests/test25.c
uthash-1.9.2/tests/test26.ans
uthash-1.9.2/tests/test26.c
uthash-1.9.2/tests/test27.ans
uthash-1.9.2/tests/test27.c
uthash-1.9.2/tests/test28.ans
uthash-1.9.2/tests/test28.c
uthash-1.9.2/tests/test29.ans
uthash-1.9.2/tests/test29.c
uthash-1.9.2/tests/test3.ans
uthash-1.9.2/tests/test3.c
uthash-1.9.2/tests/test30.ans
uthash-1.9.2/tests/test30.c
uthash-1.9.2/tests/test31.ans
uthash-1.9.2/tests/test31.c
uthash-1.9.2/tests/test32.ans
uthash-1.9.2/tests/test32.c
uthash-1.9.2/tests/test33.ans
uthash-1.9.2/tests/test33.c
uthash-1.9.2/tests/test34.ans
uthash-1.9.2/tests/test34.c
uthash-1.9.2/tests/test35.ans
uthash-1.9.2/tests/test35.c
uthash-1.9.2/tests/test36.ans
uthash-1.9.2/tests/test36.c
uthash-1.9.2/tests/test37.ans
uthash-1.9.2/tests/test37.c
uthash-1.9.2/tests/test38.ans
uthash-1.9.2/tests/test38.c
uthash-1.9.2/tests/test39.ans
uthash-1.9.2/tests/test39.c
uthash-1.9.2/tests/test4.ans
uthash-1.9.2/tests/test4.c
uthash-1.9.2/tests/test40.ans
uthash-1.9.2/tests/test40.c
uthash-1.9.2/tests/test41.ans
uthash-1.9.2/tests/test41.c
uthash-1.9.2/tests/test42.ans
uthash-1.9.2/tests/test42.c
uthash-1.9.2/tests/test43.ans
uthash-1.9.2/tests/test43.c
uthash-1.9.2/tests/test44.ans
uthash-1.9.2/tests/test44.c
uthash-1.9.2/tests/test45.ans
uthash-1.9.2/tests/test45.c
uthash-1.9.2/tests/test46.ans
uthash-1.9.2/tests/test46.c
uthash-1.9.2/tests/test47.ans
uthash-1.9.2/tests/test47.c
uthash-1.9.2/tests/test48.ans
uthash-1.9.2/tests/test48.c
uthash-1.9.2/tests/test49.ans
uthash-1.9.2/tests/test49.c
uthash-1.9.2/tests/test5.ans
uthash-1.9.2/tests/test5.c
uthash-1.9.2/tests/test50.ans
uthash-1.9.2/tests/test50.c
uthash-1.9.2/tests/test51.ans
uthash-1.9.2/tests/test51.c
uthash-1.9.2/tests/test52.ans
uthash-1.9.2/tests/test52.c
uthash-1.9.2/tests/test53.ans
uthash-1.9.2/tests/test53.c
uthash-1.9.2/tests/test54.ans
uthash-1.9.2/tests/test54.c
uthash-1.9.2/tests/test55.ans
uthash-1.9.2/tests/test55.c
uthash-1.9.2/tests/test56.ans
uthash-1.9.2/tests/test56.c
uthash-1.9.2/tests/test57.ans
uthash-1.9.2/tests/test57.c
uthash-1.9.2/tests/test58.ans
uthash-1.9.2/tests/test58.c
uthash-1.9.2/tests/test6.ans
uthash-1.9.2/tests/test6.c
uthash-1.9.2/tests/test7.ans
uthash-1.9.2/tests/test7.c
uthash-1.9.2/tests/test8.ans
uthash-1.9.2/tests/test8.c
uthash-1.9.2/tests/test9.ans
uthash-1.9.2/tests/test9.c
uthash-1.9.2/tests/threads/
uthash-1.9.2/tests/threads/Makefile
uthash-1.9.2/tests/threads/README
uthash-1.9.2/tests/threads/do_tests
uthash-1.9.2/tests/threads/test1.c
uthash-1.9.2/tests/threads/test2.c
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-logutils.c -o darshan-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-posix-logutils.c -o darshan-posix-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-mpiio-logutils.c -o darshan-mpiio-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-hdf5-logutils.c -o darshan-hdf5-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-pnetcdf-logutils.c -o darshan-pnetcdf-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-bgq-logutils.c -o darshan-bgq-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-lustre-logutils.c -o darshan-lustre-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-stdio-logutils.c -o darshan-stdio-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-dxt-logutils.c -o darshan-dxt-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-mdhim-logutils.c -o darshan-mdhim-logutils.o
ar rcs libdarshan-util.a darshan-logutils.o darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o darshan-bgq-logutils.o darshan-lustre-logutils.o darshan-stdio-logutils.o darshan-dxt-logutils.o darshan-mdhim-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/darshan-null-logutils.c -o darshan-null-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 ../../darshan-util/darshan-analyzer.c libdarshan-util.a -o darshan-analyzer -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -c ../../darshan-util/lookup3.c -o lookup3.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 ../../darshan-util/darshan-convert.c lookup3.o libdarshan-util.a -o darshan-convert -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 ../../darshan-util/darshan-diff.c libdarshan-util.a -o darshan-diff -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 ../../darshan-util/darshan-parser.c libdarshan-util.a -o darshan-parser -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 ../../darshan-util/darshan-dxt-parser.c libdarshan-util.a -o darshan-dxt-parser -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 ../../darshan-util/darshan-merge.c libdarshan-util.a -o darshan-merge -lz
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 ../../darshan-util/jenkins-hash-gen.c lookup3.o -o jenkins-hash-gen -lz
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 755 darshan-analyzer /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -m 755 darshan-convert /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -m 755 darshan-diff /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -m 755 darshan-parser /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -m 755 darshan-dxt-parser /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -m 755 darshan-merge /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -m 755 ../../darshan-util/darshan-summary-per-file.sh /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -m 755 ../../darshan-util/dxt_analyzer.py /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -m 755 libdarshan-util.a /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib
install -m 644 ../../darshan-util/darshan-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-posix-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-mpiio-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-hdf5-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-pnetcdf-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-bgq-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-null-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-lustre-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-stdio-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-dxt-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/darshan-mdhim-logutils.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-null-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-posix-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-mpiio-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-hdf5-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-pnetcdf-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-bgq-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-lustre-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-stdio-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-dxt-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 644 ../../darshan-util/../darshan-mdhim-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include/uthash-1.9.2
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include/uthash-1.9.2/src
install -m 644 uthash-1.9.2/src/uthash.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include/uthash-1.9.2/src/
install -m 644 ../../darshan-util/../darshan-log-format.h /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/include
install -m 755 darshan-job-summary/bin/darshan-job-summary.pl /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/bin
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib/TeX
install -m 644 ../../darshan-util/darshan-job-summary/lib/TeX/Encode.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib/TeX/
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib/Number
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib/Number/Bytes
install -m 644 ../../darshan-util/darshan-job-summary/lib/Number/Bytes/Human.pm /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib/Number/Bytes
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/share
install -m 644 ../../darshan-util/darshan-job-summary/share/* /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/share
install -d /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib/pkgconfig
install -m 644 maint/darshan-util.pc /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/install/lib/pkgconfig/darshan-util.pc
[x86-master-cc-wrapper-static] $ /bin/bash /tmp/jenkins7724893018831944340.sh
Running /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/darshan-test/regression/test-cases/mpi-io-test.sh...
# Using mpi-io calls.
nr_procs = 4, nr_iter = 1, blk_sz = 16777216, coll = 0
# total_size = 67108864
# Write: min_t = 0.027668, max_t = 0.030510, mean_t = 0.029611, var_t = 0.000002
# Read: min_t = 0.168478, max_t = 0.206747, mean_t = 0.188404, var_t = 0.000279
Write bandwidth = 2199.573149 Mbytes/sec
Read bandwidth = 324.594799 Mbytes/sec
Error: failed to open darshan log file /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/scratch/mpi-io-test.darshan.
Error: failed to parse /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/scratch/mpi-io-test.darshan
Error: failed to execute test case /gpfs/mira-home/radixio/cinow-01/workspace/Radix-IO/Darshan/x86-master-cc-wrapper-static/darshan-test/regression/test-cases/mpi-io-test.sh
Done.
1 tests failed
Build step 'Execute shell' marked build as failure
Recording test results
More information about the Darshan-commits
