[Darshan-commits] [Git][darshan/darshan][master] 2 commits: preprare 3.2.1 release
Shane Snyder
xgitlab at cels.anl.gov
Fri May 15 15:05:37 CDT 2020
Shane Snyder pushed to branch master at darshan / darshan
Commits:
87b62c98 by Shane Snyder at 2020-05-15T15:05:32-05:00
2ba50601 by Shane Snyder at 2020-05-15T15:05:32-05:00
Merge branch 'prep-release-v3.2.1' into 'master'
See merge request darshan/darshan!56
8 changed files:
- ChangeLog
- darshan-log-format.h
- darshan-runtime/configure
- darshan-runtime/configure.in
- + darshan-test/example-output/mpi-io-test-x86_64-3.2.1.darshan
- darshan-util/configure
- darshan-util/configure.in
- darshan-util/darshan-logutils.c
Changes:
ChangeLog
@@ -2,6 +2,12 @@
Darshan Release Change Log
+Darshan-3.2.1
+* fixed bug causing corruption of Darshan common access
+ counters (POSIX, MPI-IO, and HDF5 modules) and potentially
+ other preceding counters (reported by Gerd Heber)
Darshan-3.2.0
* added detailed instrumentation of HDF5 library file and dataset
@@ -24,7 +24,7 @@
* log format version, NOT when a new version of a module record is
* introduced -- we have module-specific versions to handle that
-#define DARSHAN_LOG_VERSION "3.20"
+#define DARSHAN_LOG_VERSION "3.21"
/* magic number for validating output files and checking byte order */
#define DARSHAN_MAGIC_NR 6567223
@@ -1,6 +1,6 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.2.0.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 3.2.1.
# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
# Identity of this package.
PACKAGE_NAME='darshan-runtime'
PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='3.2.0'
-PACKAGE_STRING='darshan-runtime 3.2.0'
+PACKAGE_VERSION='3.2.1'
+PACKAGE_STRING='darshan-runtime 3.2.1'
PACKAGE_BUGREPORT=''
PACKAGE_URL=''
@@ -1290,7 +1290,7 @@ if test "$ac_init_help" = "long"; then
# Omit some internal or obsolete options to make the list less imposing.
# This message is too long to be a string in the A/UX 3.1 sh.
cat <<_ACEOF
-\`configure' configures darshan-runtime 3.2.0 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 3.2.1 to adapt to many kinds of systems.
Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1352,7 +1352,7 @@ fi
if test -n "$ac_init_help"; then
case $ac_init_help in
- short | recursive ) echo "Configuration of darshan-runtime 3.2.0:";;
+ short | recursive ) echo "Configuration of darshan-runtime 3.2.1:";;
esac
cat <<\_ACEOF
@@ -1476,7 +1476,7 @@ fi
test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
cat <<\_ACEOF
-darshan-runtime configure 3.2.0
+darshan-runtime configure 3.2.1
generated by GNU Autoconf 2.69
Copyright (C) 2012 Free Software Foundation, Inc.
@@ -1828,7 +1828,7 @@ cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 3.2.0, which was
+It was created by darshan-runtime $as_me 3.2.1, which was
generated by GNU Autoconf 2.69. Invocation command line was
$ $0 $@
@@ -4881,7 +4881,7 @@ fi
rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-DARSHAN_VERSION="3.2.0"
+DARSHAN_VERSION="3.2.1"
@@ -5420,7 +5420,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
-This file was extended by darshan-runtime $as_me 3.2.0, which was
+This file was extended by darshan-runtime $as_me 3.2.1, which was
CONFIG_FILES = $CONFIG_FILES
@@ -5482,7 +5482,7 @@ _ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
-darshan-runtime config.status 3.2.0
+darshan-runtime config.status 3.2.1
configured by $0, generated by GNU Autoconf 2.69,
with options \\"\$ac_cs_config\\"
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
dnl You may need to use autoheader as well if changing any DEFINEs
dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [3.2.0])
+AC_INIT([darshan-runtime], [3.2.1])
AC_CONFIG_SRCDIR([darshan.h])
AC_CONFIG_AUX_DIR(../maint/config)
AC_CONFIG_MACRO_DIR(../maint/config)
Binary files /dev/null and b/darshan-test/example-output/mpi-io-test-x86_64-3.2.1.darshan differ
@@ -1,6 +1,6 @@
#! /bin/sh
-# Generated by GNU Autoconf 2.69 for darshan-util 3.2.0.
+# Generated by GNU Autoconf 2.69 for darshan-util 3.2.1.
PACKAGE_NAME='darshan-util'
PACKAGE_TARNAME='darshan-util'
-PACKAGE_STRING='darshan-util 3.2.0'
+PACKAGE_STRING='darshan-util 3.2.1'
PACKAGE_URL=''
@@ -1247,7 +1247,7 @@ if test "$ac_init_help" = "long"; then
cat <<_ACEOF
-\`configure' configures darshan-util 3.2.0 to adapt to many kinds of systems.
+\`configure' configures darshan-util 3.2.1 to adapt to many kinds of systems.
@@ -1309,7 +1309,7 @@ fi
- short | recursive ) echo "Configuration of darshan-util 3.2.0:";;
+ short | recursive ) echo "Configuration of darshan-util 3.2.1:";;
esac
cat <<\_ACEOF
@@ -1405,7 +1405,7 @@ fi
cat <<\_ACEOF
-darshan-util configure 3.2.0
+darshan-util configure 3.2.1
@@ -1770,7 +1770,7 @@ cat >config.log <<_ACEOF
-It was created by darshan-util $as_me 3.2.0, which was
+It was created by darshan-util $as_me 3.2.1, which was
$ $0 $@
@@ -4117,7 +4117,7 @@ fi
done
-DARSHAN_UTIL_VERSION="3.2.0"
+DARSHAN_UTIL_VERSION="3.2.1"
@@ -4633,7 +4633,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
ac_log="
-This file was extended by darshan-util $as_me 3.2.0, which was
+This file was extended by darshan-util $as_me 3.2.1, which was
@@ -4695,7 +4695,7 @@ _ACEOF
ac_cs_version="\\
-darshan-util config.status 3.2.0
+darshan-util config.status 3.2.1
-AC_INIT([darshan-util], [3.2.0])
+AC_INIT([darshan-util], [3.2.1])
AC_CONFIG_SRCDIR([darshan-logutils.h])
AC_CONFIG_HEADER(darshan-util-config.h)
@@ -781,6 +781,13 @@ void darshan_log_close(darshan_fd fd)
void darshan_log_print_version_warnings(const char *version_string)
+ if(strcmp(version_string, "3.20") == 0)
+ printf("# WARNING: Darshan logs generated by runtime version 3.2.0 likely exhibit some corruption in counter values.\n");
+ printf("# This bug clearly results in bogus values for some COMMON_ACCESS counters (POSIX, MPIIO, H5 modules),\n");
+ printf("# but preceding data may also be corrupted.\n");
return;
@@ -897,7 +904,8 @@ static int darshan_log_get_header(darshan_fd fd)
fd->state->get_namerecs = darshan_log_get_namerecs_3_00;
else if((strcmp(fd->version, "3.10") == 0) ||
- (strcmp(fd->version, "3.20") == 0))
+ (strcmp(fd->version, "3.20") == 0) ||
+ (strcmp(fd->version, "3.21") == 0))
fd->state->get_namerecs = darshan_log_get_namerecs;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/f523614c64b0c983e9f94191acf635d20ebafb07...2ba50601701c78d81b9c3e24cdeb9814cf114a6e
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200515/1778205d/attachment-0001.html>
More information about the Darshan-commits
