[Darshan-commits] [Git][darshan/darshan][dev-detailed-hdf5-mod] 2 commits: support for h5d chunking & common access
Shane Snyder xgitlab at cels.anl.gov
Tue Mar 31 14:16:55 CDT 2020
Shane Snyder pushed to branch dev-detailed-hdf5-mod at darshan / darshan
Commits:
23a8c503 by Shane Snyder at 2020-03-31T14:07:11-05:00
a7f10928 by Shane Snyder at 2020-03-31T14:16:17-05:00
updated hdf5 logutils code
14 changed files:
- darshan-hdf5-log-format.h
- darshan-runtime/darshan-common.h
- darshan-runtime/lib/darshan-common.c
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-posix.c
- darshan-util/darshan-dxt-logutils.c
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-lustre-logutils.c
- darshan-util/darshan-mpiio-logutils.c
- darshan-util/darshan-null-logutils.c
- darshan-util/darshan-pnetcdf-logutils.c
- darshan-util/darshan-posix-logutils.c
- darshan-util/darshan-stdio-logutils.c
Changes:
@@ -8,9 +8,11 @@
 #define __DARSHAN_HDF5_LOG_FORMAT_H
 /* current HDF5 log format versions */
-#define DARSHAN_H5F_VER 2
+#define DARSHAN_H5F_VER 3
 #define DARSHAN_H5D_VER 1
+#define H5D_MAX_NDIMS 5
 #define H5F_COUNTERS \
     /* count of HDF5 file opens/creates */\
     X(H5F_OPENS) \
@@ -81,11 +83,53 @@
     X(H5D_SIZE_WRITE_AGG_10M_100M) \
     X(H5D_SIZE_WRITE_AGG_100M_1G) \
     X(H5D_SIZE_WRITE_AGG_1G_PLUS) \
-    /* the four most frequently appearing H5D access sizes */\
+    /* the four most frequently appearing H5D accesses, identified by
+     * access size and access lengths (count * block) and strides
+     * in last 5 hyperslab dimensions */\
     X(H5D_ACCESS1_ACCESS) \
+    X(H5D_ACCESS1_LENGTH_D1) \
+    X(H5D_ACCESS1_LENGTH_D2) \
+    X(H5D_ACCESS1_LENGTH_D3) \
+    X(H5D_ACCESS1_LENGTH_D4) \
+    X(H5D_ACCESS1_LENGTH_D5) \
+    X(H5D_ACCESS1_STRIDE_D1) \
+    X(H5D_ACCESS1_STRIDE_D2) \
+    X(H5D_ACCESS1_STRIDE_D3) \
+    X(H5D_ACCESS1_STRIDE_D4) \
+    X(H5D_ACCESS1_STRIDE_D5) \
     X(H5D_ACCESS2_ACCESS) \
+    X(H5D_ACCESS2_LENGTH_D1) \
+    X(H5D_ACCESS2_LENGTH_D2) \
+    X(H5D_ACCESS2_LENGTH_D3) \
+    X(H5D_ACCESS2_LENGTH_D4) \
+    X(H5D_ACCESS2_LENGTH_D5) \
+    X(H5D_ACCESS2_STRIDE_D1) \
+    X(H5D_ACCESS2_STRIDE_D2) \
+    X(H5D_ACCESS2_STRIDE_D3) \
+    X(H5D_ACCESS2_STRIDE_D4) \
+    X(H5D_ACCESS2_STRIDE_D5) \
     X(H5D_ACCESS3_ACCESS) \
+    X(H5D_ACCESS3_LENGTH_D1) \
+    X(H5D_ACCESS3_LENGTH_D2) \
+    X(H5D_ACCESS3_LENGTH_D3) \
+    X(H5D_ACCESS3_LENGTH_D4) \
+    X(H5D_ACCESS3_LENGTH_D5) \
+    X(H5D_ACCESS3_STRIDE_D1) \
+    X(H5D_ACCESS3_STRIDE_D2) \
+    X(H5D_ACCESS3_STRIDE_D3) \
+    X(H5D_ACCESS3_STRIDE_D4) \
+    X(H5D_ACCESS3_STRIDE_D5) \
     X(H5D_ACCESS4_ACCESS) \
+    X(H5D_ACCESS4_LENGTH_D1) \
+    X(H5D_ACCESS4_LENGTH_D2) \
+    X(H5D_ACCESS4_LENGTH_D3) \
+    X(H5D_ACCESS4_LENGTH_D4) \
+    X(H5D_ACCESS4_LENGTH_D5) \
+    X(H5D_ACCESS4_STRIDE_D1) \
+    X(H5D_ACCESS4_STRIDE_D2) \
+    X(H5D_ACCESS4_STRIDE_D3) \
+    X(H5D_ACCESS4_STRIDE_D4) \
+    X(H5D_ACCESS4_STRIDE_D5) \
     /* count of each of the most frequent H5D access sizes */\
     X(H5D_ACCESS1_COUNT) \
     X(H5D_ACCESS2_COUNT) \
@@ -97,6 +141,13 @@
     X(H5D_DATASPACE_NPOINTS) \
     /* size of dataset elements in bytes */\
     X(H5D_DATATYPE_SIZE) \
+    /* chunk sizes in the last 5 dimensions of the dataset */\
+    /* NOTE: D1 is the last dimension (i.e., row) , D2 is 2nd to last (i.e., column), and so on */\
+    X(H5D_CHUNK_SIZE_D1) \
+    X(H5D_CHUNK_SIZE_D2) \
+    X(H5D_CHUNK_SIZE_D3) \
+    X(H5D_CHUNK_SIZE_D4) \
+    X(H5D_CHUNK_SIZE_D5) \
     /* flag indicating use of MPI-IO collectives */\
     X(H5D_USE_MPIIO_COLLECTIVE) \
     /* flag indicating whether deprecated create/open calls were used */\
@@ -67,8 +67,13 @@
         *(__bucket_base_p + 9) += 1; \
 } while(0)
-/* potentially set or increment a common value counter, depending on the __count
- * for the given __value. This macro ensures common values are stored first in
+/* maximum number of common values that darshan will track per file at runtime */
+#define DARSHAN_COMMON_VAL_MAX_RUNTIME_COUNT 32
+/* maximum number of counters in each common value */
+#define DARSHAN_COMMON_VAL_MAX_NCOUNTERS 12
+/* potentially set or add common value counters, depending on the __val_count
+ * for the given __vals. This macro ensures common values are stored first in
  * decreasing order of their total count, and second by decreasing order of
  * their value.
@@ -79,33 +84,32 @@
  * counters) and __cnt_p is a pointer to the base of the count counters (i.e.
  * the first of 4 contiguous common count counters). It is assumed your counters
  * are stored as int64_t types. __add_flag is set if the given count should be
- * added to the common access counter, rather than just incrementing it.
+ * added to the common access counter, rather than just setting it.
-#define DARSHAN_COMMON_VAL_COUNTER_INC(__val_p, __cnt_p, __value, __count, __add_flag) do {\
+#define DARSHAN_UPDATE_COMMON_VAL_COUNTERS(__val_p, __cnt_p, __vals, __val_size, __val_count, __add_flag) do {\
     int i; \
-    int inc_count, total_count; \
-    int64_t tmp_val[4] = {0}; \
+    int total_count = __val_count; \
+    int64_t tmp_val[4*DARSHAN_COMMON_VAL_MAX_NCOUNTERS] = {0}; \
     int64_t tmp_cnt[4] = {0}; \
     int tmp_ndx = 0; \
-    if(__value == 0) break; \
-    if(__add_flag) \
-        inc_count = 1; \
-    else \
-        inc_count = __count; \
+    if(*(int64_t *)__vals == 0) break; \
     for(i=0; i<4; i++) { \
-        if(*(__val_p + i) == __value) { \
-            total_count = *(__cnt_p + i) + inc_count; \
+        if(__add_flag && \
+            !memcmp(__val_p + (i * sizeof(*__vals) * __val_size), \
+                __vals, sizeof(*__vals) * __val_size)) { \
+            total_count += *(__cnt_p + i); \
             break; \
-    if(i == 4) total_count = __count; \
     /* first, copy over any counters that should be sorted above this one \
      * (counters with higher counts or equal counts and larger values) \
-    for(i=0;i < 4; i++) { \
+    for(i=0; i < 4; i++) { \
         if((*(__cnt_p + i) > total_count) || \
-           ((*(__cnt_p + i) == total_count) && (*(__val_p + i) > __value))) { \
-            tmp_val[tmp_ndx] = *(__val_p + i); \
+           ((*(__cnt_p + i) == total_count) && \
+           (*(__val_p + (i * sizeof(*__vals) * __val_size)) > *(int64_t *)__vals))) { \
+            memcpy(&tmp_val[tmp_ndx * __val_size], __val_p + (i * sizeof(*__vals) * __val_size), \
+                sizeof(*__vals) * __val_size); \
             tmp_cnt[tmp_ndx] = *(__cnt_p + i); \
             tmp_ndx++; \
@@ -113,27 +117,28 @@
     if(tmp_ndx == 4) break; /* all done, updated counter is not added */ \
     /* next, add the updated counter */ \
-    tmp_val[tmp_ndx] = __value; \
+    memcpy(&tmp_val[tmp_ndx * __val_size], __vals, sizeof(*__vals) * __val_size); \
     tmp_cnt[tmp_ndx] = total_count; \
     tmp_ndx++; \
     /* last, copy over any remaining counters to make sure we have 4 sets total */ \
     while(tmp_ndx != 4) { \
-        if(*(__val_p + i) != __value) { \
+        if(memcmp(__val_p + (i * sizeof(*__vals) * __val_size), \
             tmp_ndx++; \
         i++; \
-    memcpy(__val_p, tmp_val, 4*sizeof(int64_t)); \
+    memcpy(__val_p, tmp_val, 4*sizeof(int64_t)*__val_size); \
     memcpy(__cnt_p, tmp_cnt, 4*sizeof(int64_t)); \
 } while(0)
-/* maximum number of common values that darshan will track per file at runtime */
-#define DARSHAN_COMMON_VAL_MAX_RUNTIME_COUNT 32
 struct darshan_common_val_counter
-    int64_t val;
+    int64_t vals[DARSHAN_COMMON_VAL_MAX_NCOUNTERS];
+    int nvals;
     int freq;
@@ -245,8 +250,8 @@ void darshan_record_sort(
     int rec_count,
     int rec_size);
-/* darshan_common_val_counter()
+/* darshan_track_common_val_counters()
+ * XXX
  * Potentially increment an existing common value counter or allocate
  * a new one to keep track of commonly occuring values. Example use
  * cases would be to track the most frequent access sizes or strides
@@ -260,12 +265,11 @@ void darshan_record_sort(
  * a pointer to the base counter of the common counts (which are
  * again expected to be contiguous in memory).
-void darshan_common_val_counter(
+struct darshan_common_val_counter *darshan_track_common_val_counters(
     void **common_val_root,
-    int *common_val_count,
-    int64_t val,
-    int64_t *val_p,
-    int64_t *cnt_p);
+    int64_t *vals,
+    int nvals,
+    int *common_val_count);
 #ifdef HAVE_MPI
 /* darshan_variance_reduce()
@@ -213,34 +213,29 @@ void darshan_record_sort(void *rec_buf, int rec_count, int rec_size)
     return;
-static int darshan_common_val_compare(const void *a_p, const void *b_p)
+static int darshan_common_vals_compare(const void *a_p, const void *b_p)
     const struct darshan_common_val_counter* a = a_p;
     const struct darshan_common_val_counter* b = b_p;
-    if(a->val < b->val)
-        return(-1);
-    if(a->val > b->val)
-        return(1);
-    return(0);
+    return(memcmp(a->vals, b->vals, sizeof(*(a->vals)) * a->nvals));
-void darshan_common_val_counter(void **common_val_root, int *common_val_count,
-    int64_t val, int64_t *common_val_p, int64_t *common_cnt_p)
+    void **common_val_root, int64_t *vals, int nvals, int *common_val_count)
     struct darshan_common_val_counter* counter;
     struct darshan_common_val_counter* found = NULL;
     struct darshan_common_val_counter tmp_counter;
     void* tmp;
-    /* don't count any values of 0 */
-    if(val == 0)
-        return;
+    assert(nvals <= DARSHAN_COMMON_VAL_MAX_NCOUNTERS);
     /* check to see if this val is already recorded */
-    tmp_counter.val = val;
+    memcpy(tmp_counter.vals, vals, sizeof(*vals) * nvals);
+    tmp_counter.nvals = nvals;
     tmp_counter.freq = 1;
-    tmp = tfind(&tmp_counter, common_val_root, darshan_common_val_compare);
+    tmp = tfind(&tmp_counter, common_val_root, darshan_common_vals_compare);
     if(tmp)
         found = *(struct darshan_common_val_counter**)tmp;
@@ -252,13 +247,14 @@ void darshan_common_val_counter(void **common_val_root, int *common_val_count,
         counter = malloc(sizeof(*counter));
         if(!counter)
-            return;
+            return(NULL);
-        counter->val = val;
+        memcpy(counter->vals, vals, sizeof(*vals) * nvals);
+        counter->nvals = nvals;
         counter->freq = 1;
-        tmp = tsearch(counter, common_val_root, darshan_common_val_compare);
+        tmp = tsearch(counter, common_val_root, darshan_common_vals_compare);
         /* if we get a new answer out here we are in trouble; this was
          * already checked with the tfind()
@@ -268,15 +264,7 @@ void darshan_common_val_counter(void **common_val_root, int *common_val_count,
         (*common_val_count)++;
-    /* update common access counters as we go, as long as we haven't already
-     * hit the limit in the number we are willing to track */
-    if(found)
-        DARSHAN_COMMON_VAL_COUNTER_INC(common_val_p, common_cnt_p,
-            found->val, found->freq, 1);
-    return;
+    return(found);
 #ifdef HAVE_MPI
@@ -146,7 +146,7 @@ static int my_rank = -1;
         if(__newpath != __path) free(__newpath); \
         break; \
-    if(H5Pget_fapl_mpio(__fapl, NULL, NULL) >= 0) \
+    if(__fapl != H5P_DEFAULT && H5Pget_fapl_mpio(__fapl, NULL, NULL) >= 0) \
         __rec_ref->file_rec->counters[H5F_USE_MPIIO] = 1; \
     __rec_ref->file_rec->counters[H5F_OPENS] += 1; \
     if(__rec_ref->file_rec->fcounters[H5F_F_OPEN_START_TIMESTAMP] == 0 || \
@@ -190,6 +190,7 @@ hid_t DARSHAN_DECL(H5Fcreate)(const char *filename, unsigned flags,
     tm1 = darshan_core_wtime();
     ret = __real_H5Fcreate(filename, flags, create_plist, access_plist);
     tm2 = darshan_core_wtime();
     if(ret >= 0)
         /* use ROMIO approach to strip prefix if present */
@@ -241,6 +242,7 @@ hid_t DARSHAN_DECL(H5Fopen)(const char *filename, unsigned flags,
     ret = __real_H5Fopen(filename, flags, access_plist);
     if(ret >= 0)
@@ -276,20 +278,23 @@ herr_t H5Fflush(hid_t object_id, H5F_scope_t scope)
     /* convert object_id to file_id so we can look it up */
-    file_id = H5Iget_file_id(object_id);
-    if(file_id > 0)
+    if(ret >= 0)
-        H5F_PRE_RECORD();
-        rec_ref = darshan_lookup_record_ref(hdf5_file_runtime->hid_hash,
-            &file_id, sizeof(hid_t));
-        if(rec_ref)
+        file_id = H5Iget_file_id(object_id);
+        if(file_id > 0)
-            rec_ref->file_rec->counters[H5F_FLUSHES] += 1;
-            DARSHAN_TIMER_INC_NO_OVERLAP(
-                rec_ref->file_rec->fcounters[H5F_F_META_TIME],
-                tm1, tm2, rec_ref->last_meta_end);
+            H5F_PRE_RECORD();
+            rec_ref = darshan_lookup_record_ref(hdf5_file_runtime->hid_hash,
+                &file_id, sizeof(hid_t));
+            if(rec_ref)
+                rec_ref->file_rec->counters[H5F_FLUSHES] += 1;
+                DARSHAN_TIMER_INC_NO_OVERLAP(
+                    rec_ref->file_rec->fcounters[H5F_F_META_TIME],
+                    tm1, tm2, rec_ref->last_meta_end);
+            H5F_POST_RECORD();
-        H5F_POST_RECORD();
     return(ret);
@@ -307,22 +312,25 @@ herr_t DARSHAN_DECL(H5Fclose)(hid_t file_id)
     ret = __real_H5Fclose(file_id);
-    H5F_PRE_RECORD();
-    if(rec_ref)
+    if(ret >= 0)
-        if(rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] == 0 ||
-         rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] > tm1)
-           rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] = tm1;
-        rec_ref->file_rec->fcounters[H5F_F_CLOSE_END_TIMESTAMP] = tm2;
-        darshan_delete_record_ref(&(hdf5_file_runtime->hid_hash),
+        H5F_PRE_RECORD();
+        if(rec_ref)
+            if(rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] == 0 ||
+             rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] > tm1)
+               rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] = tm1;
+            rec_ref->file_rec->fcounters[H5F_F_CLOSE_END_TIMESTAMP] = tm2;
+            darshan_delete_record_ref(&(hdf5_file_runtime->hid_hash),
     return(ret);
@@ -349,12 +357,14 @@ herr_t DARSHAN_DECL(H5Fclose)(hid_t file_id)
     HDF5_UNLOCK(); \
 } while(0)
-#define H5D_RECORD_OPEN(__ret, __loc_id, __name, __type_id, __space_id, __use_depr,  __tm1, __tm2) do { \
+#define H5D_RECORD_OPEN(__ret, __loc_id, __name, __type_id, __space_id, __dcpl_id, __use_depr,  __tm1, __tm2) do { \
     char *__file_path, *__tmp_ptr; \
     char __rec_name[DARSHAN_HDF5_MAX_NAME_LEN] = {0}; \
     ssize_t __req_name_len = DARSHAN_HDF5_MAX_NAME_LEN-1, __ret_name_len; \
     darshan_record_id __rec_id; \
     struct hdf5_dataset_record_ref *__rec_ref; \
+    hsize_t __chunk_dims[H5D_MAX_NDIMS] = {0}; \
+    int __i, __n_chunk_dims = 0; \
     /* get corresponding file name */\
     __ret_name_len = H5Fget_name(__loc_id, __rec_name, __req_name_len); \
     if(__ret_name_len < 0) break; \
@@ -396,6 +406,12 @@ herr_t DARSHAN_DECL(H5Fclose)(hid_t file_id)
         __tm1, __tm2, __rec_ref->last_meta_end); \
     __rec_ref->dataset_rec->counters[H5D_DATASPACE_NDIMS] = H5Sget_simple_extent_ndims(__space_id); \
     __rec_ref->dataset_rec->counters[H5D_DATASPACE_NPOINTS] = H5Sget_simple_extent_npoints(__space_id); \
+    if(__dcpl_id != H5P_DEFAULT && H5Pget_layout(__dcpl_id) == H5D_CHUNKED) { \
+        __n_chunk_dims = H5Pget_chunk(__dcpl_id, H5D_MAX_NDIMS, __chunk_dims); \
+        __n_chunk_dims = (__n_chunk_dims < H5D_MAX_NDIMS) ? __n_chunk_dims : H5D_MAX_NDIMS; \
+        for(__i = 0; __i < __n_chunk_dims; __i++) \
+            __rec_ref->dataset_rec->counters[H5D_CHUNK_SIZE_D1 + __i] = __chunk_dims[__n_chunk_dims - __i - 1]; \
     __rec_ref->dataset_rec->counters[H5D_DATATYPE_SIZE] = H5Tget_size(__type_id); \
     darshan_add_record_ref(&(hdf5_dataset_runtime->hid_hash), &__ret, sizeof(hid_t), __rec_ref); \
 } while(0)
@@ -411,9 +427,12 @@ hid_t H5Dcreate1(hid_t loc_id, const char *name, hid_t type_id, hid_t space_id,
     ret = __real_H5Dcreate1(loc_id, name, type_id, space_id, dcpl_id);
-    H5D_PRE_RECORD();
-    H5D_RECORD_OPEN(ret, loc_id, name, type_id, space_id, 1, tm1, tm2);
-    H5D_POST_RECORD();
+    if(ret >= 0)
+        H5D_PRE_RECORD();
+        H5D_RECORD_OPEN(ret, loc_id, name, type_id, space_id, dcpl_id, 1, tm1, tm2);
+        H5D_POST_RECORD();
     return(ret);
@@ -430,9 +449,12 @@ hid_t H5Dcreate2(hid_t loc_id, const char *name, hid_t dtype_id, hid_t space_id,
     ret = __real_H5Dcreate2(loc_id, name, dtype_id, space_id, lcpl_id, dcpl_id, dapl_id);
-    H5D_PRE_RECORD();
-    H5D_RECORD_OPEN(ret, loc_id, name, dtype_id, space_id, 0, tm1, tm2);
+    if(ret >= 0)
+        H5D_PRE_RECORD();
+        H5D_RECORD_OPEN(ret, loc_id, name, dtype_id, space_id, dcpl_id, 0, tm1, tm2);
     return(ret);
@@ -441,6 +463,7 @@ hid_t H5Dopen1(hid_t loc_id, const char *name)
     hid_t dtype_id;
     hid_t space_id;
+    hid_t dcpl_id;
     double tm1, tm2;
     hid_t ret;
@@ -450,23 +473,34 @@ hid_t H5Dopen1(hid_t loc_id, const char *name)
     ret = __real_H5Dopen1(loc_id, name);
-    /* query dataset datatype, dataspace, and creation property list */
-    dtype_id = H5Dget_type(ret);
-    if(dtype_id < 0)
-        return(ret);
-    space_id = H5Dget_space(ret);
-    if(space_id < 0)
+    if(ret >= 0)
-        H5Tclose(dtype_id);
-        return(ret);
+        /* query dataset datatype, dataspace, and creation property list */
+        dtype_id = H5Dget_type(ret);
+        if(dtype_id < 0)
+            return(ret);
+        space_id = H5Dget_space(ret);
+        if(space_id < 0)
+            H5Tclose(dtype_id);
+            return(ret);
+        dcpl_id = H5Dget_create_plist(ret);
+        if(dcpl_id < 0)
+            H5Sclose(space_id);
+            return(ret);
-    H5D_PRE_RECORD();
-    H5D_RECORD_OPEN(ret, loc_id, name, dtype_id, space_id, 1, tm1, tm2);
+        H5D_PRE_RECORD();
+        H5D_RECORD_OPEN(ret, loc_id, name, dtype_id, space_id, dcpl_id, 1, tm1, tm2);
-    H5Sclose(space_id);
+        H5Pclose(dcpl_id);
     return(ret);
@@ -475,6 +509,7 @@ hid_t H5Dopen2(hid_t loc_id, const char *name, hid_t dapl_id)
     hid_t dtype_id;
     hid_t space_id;
+    hid_t dcpl_id;
     double tm1, tm2;
     hid_t ret;
@@ -484,23 +519,34 @@ hid_t H5Dopen2(hid_t loc_id, const char *name, hid_t dapl_id)
     ret = __real_H5Dopen2(loc_id, name, dapl_id);
-    if(dtype_id < 0)
-        return(ret);
-    if(space_id < 0)
+    if(ret >= 0)
-        return(ret);
+        if(dtype_id < 0)
+            return(ret);
+        if(space_id < 0)
+            return(ret);
+        if(dcpl_id < 0)
+            return(ret);
-    H5D_PRE_RECORD();
+        H5D_PRE_RECORD();
     return(ret);
@@ -513,7 +559,14 @@ herr_t H5Dread(hid_t dataset_id, hid_t mem_type_id, hid_t mem_space_id,
     size_t type_size;
     ssize_t file_sel_npoints;
     H5S_sel_type file_sel_type;
+    hsize_t start_dims[H5D_MAX_NDIMS] = {0};
+    hsize_t stride_dims[H5D_MAX_NDIMS] = {0};
+    hsize_t count_dims[H5D_MAX_NDIMS] = {0};
+    hsize_t block_dims[H5D_MAX_NDIMS] = {0};
+    int64_t common_access_vals[H5D_MAX_NDIMS+H5D_MAX_NDIMS+1] = {0};
     H5FD_mpio_xfer_t xfer_mode;
+    struct darshan_common_val_counter *cvc;
+    int i;
     double tm1, tm2, elapsed;
     herr_t ret;
     herr_t tmp_ret;
@@ -525,62 +578,83 @@ herr_t H5Dread(hid_t dataset_id, hid_t mem_type_id, hid_t mem_space_id,
         xfer_plist_id, buf);
-    H5D_PRE_RECORD();
-    rec_ref = darshan_lookup_record_ref(hdf5_dataset_runtime->hid_hash,
-        &dataset_id, sizeof(hid_t));
-    if(rec_ref)
+    if(ret >= 0)
-        rec_ref->dataset_rec->counters[H5D_READS] += 1;
-        if(rec_ref->last_io_type == DARSHAN_IO_WRITE)
-            rec_ref->dataset_rec->counters[H5D_RW_SWITCHES] += 1;
-        rec_ref->last_io_type = DARSHAN_IO_READ;
-        if(file_space_id == H5S_ALL)
-            file_sel_npoints = rec_ref->dataset_rec->counters[H5D_DATASPACE_NPOINTS];
-            file_sel_type = H5S_SEL_ALL;
-        else
-            file_sel_npoints = H5Sget_select_npoints(file_space_id);
-            file_sel_type = H5Sget_select_type(file_space_id);
-        if(file_sel_type == H5S_SEL_POINTS)
-            rec_ref->dataset_rec->counters[H5D_POINT_SELECTS] += 1;
-        else if(file_sel_type == H5S_SEL_ALL)
-            rec_ref->dataset_rec->counters[H5D_REGULAR_HYPERSLAB_SELECTS] += 1;
-        else
+        H5D_PRE_RECORD();
+        rec_ref = darshan_lookup_record_ref(hdf5_dataset_runtime->hid_hash,
+            &dataset_id, sizeof(hid_t));
+        if(rec_ref)
-            if(H5Sis_regular_hyperslab(file_space_id))
+            rec_ref->dataset_rec->counters[H5D_READS] += 1;
+            if(rec_ref->last_io_type == DARSHAN_IO_WRITE)
+                rec_ref->dataset_rec->counters[H5D_RW_SWITCHES] += 1;
+            rec_ref->last_io_type = DARSHAN_IO_READ;
+            if(file_space_id == H5S_ALL)
+                file_sel_npoints = rec_ref->dataset_rec->counters[H5D_DATASPACE_NPOINTS];
+                file_sel_type = H5S_SEL_ALL;
+            else
+                file_sel_npoints = H5Sget_select_npoints(file_space_id);
+                file_sel_type = H5Sget_select_type(file_space_id);
+            if(file_sel_type == H5S_SEL_ALL)
+            else if(file_sel_type == H5S_SEL_POINTS)
+                rec_ref->dataset_rec->counters[H5D_POINT_SELECTS] += 1;
             else
-                rec_ref->dataset_rec->counters[H5D_IRREGULAR_HYPERSLAB_SELECTS] += 1;
-        type_size = rec_ref->dataset_rec->counters[H5D_DATATYPE_SIZE];
-        access_size = file_sel_npoints * type_size;
-        rec_ref->dataset_rec->counters[H5D_BYTES_READ] += access_size;
-        DARSHAN_BUCKET_INC(
-            &(rec_ref->dataset_rec->counters[H5D_SIZE_READ_AGG_0_100]), access_size);
-        darshan_common_val_counter(&rec_ref->access_root, &rec_ref->access_count, access_size,
-            &(rec_ref->dataset_rec->counters[H5D_ACCESS1_ACCESS]),
-            &(rec_ref->dataset_rec->counters[H5D_ACCESS1_COUNT]));
-        tmp_ret = H5Pget_dxpl_mpio(xfer_plist_id, &xfer_mode);
-        if(tmp_ret >= 0 && xfer_mode == H5FD_MPIO_COLLECTIVE)
-            rec_ref->dataset_rec->counters[H5D_USE_MPIIO_COLLECTIVE] = 1;
-        if(rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] == 0 ||
-         rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] > tm1)
-            rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] = tm1;
-        rec_ref->dataset_rec->fcounters[H5D_F_READ_END_TIMESTAMP] = tm2;
-        elapsed = tm2 - tm1;
-        if(rec_ref->dataset_rec->fcounters[H5D_F_MAX_READ_TIME] < elapsed)
-            rec_ref->dataset_rec->fcounters[H5D_F_MAX_READ_TIME] = elapsed;
-            rec_ref->dataset_rec->counters[H5D_MAX_READ_TIME_SIZE] = access_size;
+                if(H5Sis_regular_hyperslab(file_space_id))
+                    rec_ref->dataset_rec->counters[H5D_REGULAR_HYPERSLAB_SELECTS] += 1;
+                    H5Sget_regular_hyperslab(file_space_id,
+                        start_dims, stride_dims, count_dims, block_dims);
+                    for(i = 0; i < H5D_MAX_NDIMS; i++)
+                        common_access_vals[1+i] = count_dims[H5D_MAX_NDIMS - i - 1] *
+                            block_dims[H5D_MAX_NDIMS - i - 1];
+                        common_access_vals[1+i+H5D_MAX_NDIMS] =
+                            stride_dims[H5D_MAX_NDIMS - i - 1];
+                else
+                    rec_ref->dataset_rec->counters[H5D_IRREGULAR_HYPERSLAB_SELECTS] += 1;
+            type_size = rec_ref->dataset_rec->counters[H5D_DATATYPE_SIZE];
+            access_size = file_sel_npoints * type_size;
+            rec_ref->dataset_rec->counters[H5D_BYTES_READ] += access_size;
+            DARSHAN_BUCKET_INC(
+                &(rec_ref->dataset_rec->counters[H5D_SIZE_READ_AGG_0_100]), access_size);
+            common_access_vals[0] = access_size;
+            cvc = darshan_track_common_val_counters(&rec_ref->access_root,
+                common_access_vals, H5D_MAX_NDIMS+H5D_MAX_NDIMS+1, &rec_ref->access_count);
+            if(cvc) DARSHAN_UPDATE_COMMON_VAL_COUNTERS(
+                &(rec_ref->dataset_rec->counters[H5D_ACCESS1_ACCESS]),
+                &(rec_ref->dataset_rec->counters[H5D_ACCESS1_COUNT]),
+                cvc->vals, cvc->nvals, cvc->freq, 0);
+            if(xfer_plist_id != H5P_DEFAULT)
+                tmp_ret = H5Pget_dxpl_mpio(xfer_plist_id, &xfer_mode);
+                if(tmp_ret >= 0 && xfer_mode == H5FD_MPIO_COLLECTIVE)
+                    rec_ref->dataset_rec->counters[H5D_USE_MPIIO_COLLECTIVE] = 1;
+            if(rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] == 0 ||
+             rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] > tm1)
+                rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] = tm1;
+            rec_ref->dataset_rec->fcounters[H5D_F_READ_END_TIMESTAMP] = tm2;
+            elapsed = tm2 - tm1;
+            if(rec_ref->dataset_rec->fcounters[H5D_F_MAX_READ_TIME] < elapsed)
+                rec_ref->dataset_rec->fcounters[H5D_F_MAX_READ_TIME] = elapsed;
+                rec_ref->dataset_rec->counters[H5D_MAX_READ_TIME_SIZE] = access_size;
+                rec_ref->dataset_rec->fcounters[H5D_F_READ_TIME],
+                tm1, tm2, rec_ref->last_read_end);
-            rec_ref->dataset_rec->fcounters[H5D_F_READ_TIME],
-            tm1, tm2, rec_ref->last_read_end);
     return(ret);
@@ -593,7 +667,14 @@ herr_t H5Dwrite(hid_t dataset_id, hid_t mem_type_id, hid_t mem_space_id,
     size_t type_size;
+    int i;
     herr_t ret;
     herr_t tmp_ret;
@@ -605,62 +686,83 @@ herr_t H5Dwrite(hid_t dataset_id, hid_t mem_type_id, hid_t mem_space_id,
-    H5D_PRE_RECORD();
-    if(rec_ref)
+    if(ret >= 0)
-        rec_ref->dataset_rec->counters[H5D_WRITES] += 1;
-        if(rec_ref->last_io_type == DARSHAN_IO_READ)
-        rec_ref->last_io_type = DARSHAN_IO_WRITE;
-        else
-        else
+        H5D_PRE_RECORD();
+        if(rec_ref)
+            rec_ref->dataset_rec->counters[H5D_WRITES] += 1;
+            if(rec_ref->last_io_type == DARSHAN_IO_READ)
+            rec_ref->last_io_type = DARSHAN_IO_WRITE;
+            else
+            if(file_sel_type == H5S_SEL_POINTS)
+            else if(file_sel_type == H5S_SEL_ALL)
             else
-        rec_ref->dataset_rec->counters[H5D_BYTES_WRITTEN] += access_size;
-            &(rec_ref->dataset_rec->counters[H5D_SIZE_WRITE_AGG_0_100]), access_size);
-        if(rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] == 0 ||
-         rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] > tm1)
-            rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] = tm1;
-        rec_ref->dataset_rec->fcounters[H5D_F_WRITE_END_TIMESTAMP] = tm2;
-        if(rec_ref->dataset_rec->fcounters[H5D_F_MAX_WRITE_TIME] < elapsed)
-            rec_ref->dataset_rec->fcounters[H5D_F_MAX_WRITE_TIME] = elapsed;
-            rec_ref->dataset_rec->counters[H5D_MAX_WRITE_TIME_SIZE] = access_size;
+                else
+            rec_ref->dataset_rec->counters[H5D_BYTES_WRITTEN] += access_size;
+                &(rec_ref->dataset_rec->counters[H5D_SIZE_WRITE_AGG_0_100]), access_size);
+            if(rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] == 0 ||
+             rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] > tm1)
+                rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] = tm1;
+            rec_ref->dataset_rec->fcounters[H5D_F_WRITE_END_TIMESTAMP] = tm2;
+            if(rec_ref->dataset_rec->fcounters[H5D_F_MAX_WRITE_TIME] < elapsed)
+                rec_ref->dataset_rec->fcounters[H5D_F_MAX_WRITE_TIME] = elapsed;
+                rec_ref->dataset_rec->counters[H5D_MAX_WRITE_TIME_SIZE] = access_size;
+                rec_ref->dataset_rec->fcounters[H5D_F_WRITE_TIME],
+                tm1, tm2, rec_ref->last_write_end);
-            rec_ref->dataset_rec->fcounters[H5D_F_WRITE_TIME],
-            tm1, tm2, rec_ref->last_write_end);
     return(ret);
@@ -677,17 +779,20 @@ herr_t H5Dflush(hid_t dataset_id)
     ret = __real_H5Dflush(dataset_id);
-    H5D_PRE_RECORD();
-    if(rec_ref)
+    if(ret >= 0)
-        rec_ref->dataset_rec->counters[H5D_FLUSHES] += 1;
-            rec_ref->dataset_rec->fcounters[H5D_F_META_TIME],
+        H5D_PRE_RECORD();
+        if(rec_ref)
+            rec_ref->dataset_rec->counters[H5D_FLUSHES] += 1;
+                rec_ref->dataset_rec->fcounters[H5D_F_META_TIME],
     return(ret);
@@ -704,20 +809,23 @@ herr_t H5Dclose(hid_t dataset_id)
     ret = __real_H5Dclose(dataset_id);
-    H5D_PRE_RECORD();
-    if(rec_ref)
+    if(ret >= 0)
-        if(rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] == 0 ||
-         rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] > tm1)
-           rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] = tm1;
-        rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_END_TIMESTAMP] = tm2;
-        DARSHAN_TIMER_INC_NO_OVERLAP(rec_ref->dataset_rec->fcounters[H5D_F_META_TIME],
-        darshan_delete_record_ref(&(hdf5_dataset_runtime->hid_hash), &dataset_id, sizeof(hid_t));
+        H5D_PRE_RECORD();
+        if(rec_ref)
+            if(rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] == 0 ||
+             rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] > tm1)
+               rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] = tm1;
+            rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_END_TIMESTAMP] = tm2;
+            DARSHAN_TIMER_INC_NO_OVERLAP(rec_ref->dataset_rec->fcounters[H5D_F_META_TIME],
+            darshan_delete_record_ref(&(hdf5_dataset_runtime->hid_hash), &dataset_id, sizeof(hid_t));
     return(ret);
@@ -994,7 +1102,7 @@ static void hdf5_dataset_record_reduction_op(void* inrec_v, void* inoutrec_v,
     struct darshan_hdf5_dataset tmp_dataset;
     struct darshan_hdf5_dataset *inrec = inrec_v;
     struct darshan_hdf5_dataset *inoutrec = inoutrec_v;
-    int i, j, k;
+    int i, j, j2, k, k2;
     for(i=0; i<*len; i++)
@@ -1016,39 +1124,52 @@ static void hdf5_dataset_record_reduction_op(void* inrec_v, void* inoutrec_v,
         /* first collapse any duplicates */
-        for(j=H5D_ACCESS1_ACCESS; j<=H5D_ACCESS4_ACCESS; j++)
+        for(j=H5D_ACCESS1_ACCESS, j2=H5D_ACCESS1_COUNT; j<=H5D_ACCESS4_ACCESS;
+            j+=(H5D_MAX_NDIMS+H5D_MAX_NDIMS+1), j2++)
-            for(k=H5D_ACCESS1_ACCESS; k<=H5D_ACCESS4_ACCESS; k++)
+            for(k=H5D_ACCESS1_ACCESS, k2=H5D_ACCESS1_COUNT; k<=H5D_ACCESS4_ACCESS;
+                k+=(H5D_MAX_NDIMS+H5D_MAX_NDIMS+1), k2++)
-                if(inrec->counters[j] == inoutrec->counters[k])
+                if(!memcmp(&inrec->counters[j], &inoutrec->counters[k],
+                    sizeof(int64_t) * (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1)))
-                    inrec->counters[j+4] += inoutrec->counters[k+4];
-                    inoutrec->counters[k] = 0;
-                    inoutrec->counters[k+4] = 0;
+                    memset(&inoutrec->counters[k], 0, sizeof(int64_t) *
+                        (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1));
+                    inrec->counters[j2] += inoutrec->counters[k2];
+                    inoutrec->counters[k2] = 0;
         /* first set */
-            DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_dataset.counters[H5D_ACCESS1_ACCESS]),
-                &(tmp_dataset.counters[H5D_ACCESS1_COUNT]), inrec->counters[j],
-                inrec->counters[j+4], 0);
+            DARSHAN_UPDATE_COMMON_VAL_COUNTERS(
+                &(tmp_dataset.counters[H5D_ACCESS1_ACCESS]),
+                &(tmp_dataset.counters[H5D_ACCESS1_COUNT]),
+                &inrec->counters[j], H5D_MAX_NDIMS+H5D_MAX_NDIMS+1,
+                inrec->counters[j2], 0);
         /* second set */
-                &(tmp_dataset.counters[H5D_ACCESS1_COUNT]), inoutrec->counters[j],
-                inoutrec->counters[j+4], 0);
+                &inoutrec->counters[j], H5D_MAX_NDIMS+H5D_MAX_NDIMS+1,
+                inoutrec->counters[j2], 0);
         tmp_dataset.counters[H5D_DATASPACE_NDIMS] = inrec->counters[H5D_DATASPACE_NDIMS];
         tmp_dataset.counters[H5D_DATASPACE_NPOINTS] = inrec->counters[H5D_DATASPACE_NPOINTS];
         tmp_dataset.counters[H5D_DATATYPE_SIZE] = inrec->counters[H5D_DATATYPE_SIZE];
+        for(j=H5D_CHUNK_SIZE_D1; j<=H5D_CHUNK_SIZE_D5; j++)
+            tmp_dataset.counters[j] = inrec->counters[j];
         if(inoutrec->counters[H5D_USE_MPIIO_COLLECTIVE] == 1 ||
                 inrec->counters[H5D_USE_MPIIO_COLLECTIVE] == 1)
             tmp_dataset.counters[H5D_USE_MPIIO_COLLECTIVE] = 1;
@@ -239,6 +239,8 @@ static int my_rank = -1;
 #define MPIIO_RECORD_READ(__ret, __fh, __count, __datatype, __counter, __tm1, __tm2) do { \
     struct mpiio_file_record_ref *rec_ref; \
     int size = 0; \
+    int64_t size_ll; \
+    struct darshan_common_val_counter *cvc; \
     double __elapsed = __tm2-__tm1; \
     if(__ret != MPI_SUCCESS) break; \
     rec_ref = darshan_lookup_record_ref(mpiio_runtime->fh_hash, &(__fh), sizeof(MPI_File)); \
@@ -248,9 +250,13 @@ static int my_rank = -1;
     /* DXT to record detailed read tracing information */ \
     dxt_mpiio_read(rec_ref->file_rec->base_rec.id, size, __tm1, __tm2); \
     DARSHAN_BUCKET_INC(&(rec_ref->file_rec->counters[MPIIO_SIZE_READ_AGG_0_100]), size); \
-    darshan_common_val_counter(&rec_ref->access_root, &rec_ref->access_count, size, \
+    size_ll = size; \
+    cvc = darshan_track_common_val_counters(&rec_ref->access_root, &size_ll, 1, \
+        &rec_ref->access_count); \
+    if(cvc) DARSHAN_UPDATE_COMMON_VAL_COUNTERS( \
         &(rec_ref->file_rec->counters[MPIIO_ACCESS1_ACCESS]), \
-        &(rec_ref->file_rec->counters[MPIIO_ACCESS1_COUNT])); \
+        &(rec_ref->file_rec->counters[MPIIO_ACCESS1_COUNT]), \
+        cvc->vals, 1, cvc->freq, 0); \
     rec_ref->file_rec->counters[MPIIO_BYTES_READ] += size; \
     rec_ref->file_rec->counters[__counter] += 1; \
     if(rec_ref->last_io_type == DARSHAN_IO_WRITE) \
@@ -270,6 +276,8 @@ static int my_rank = -1;
 #define MPIIO_RECORD_WRITE(__ret, __fh, __count, __datatype, __counter, __tm1, __tm2) do { \
     int size = 0; \
@@ -279,9 +287,13 @@ static int my_rank = -1;
     /* DXT to record detailed write tracing information */ \
     dxt_mpiio_write(rec_ref->file_rec->base_rec.id, size, __tm1, __tm2); \
     DARSHAN_BUCKET_INC(&(rec_ref->file_rec->counters[MPIIO_SIZE_WRITE_AGG_0_100]), size); \
+    size_ll = size; \
     rec_ref->file_rec->counters[MPIIO_BYTES_WRITTEN] += size; \
     if(rec_ref->last_io_type == DARSHAN_IO_READ) \
@@ -1268,17 +1280,19 @@ static void mpiio_record_reduction_op(void* infile_v, void* inoutfile_v,
         /* first set */
         for(j=MPIIO_ACCESS1_ACCESS; j<=MPIIO_ACCESS4_ACCESS; j++)
-            DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_file.counters[MPIIO_ACCESS1_ACCESS]),
-                &(tmp_file.counters[MPIIO_ACCESS1_COUNT]), infile->counters[j],
-                infile->counters[j+4], 0);
+                &(tmp_file.counters[MPIIO_ACCESS1_ACCESS]),
+                &(tmp_file.counters[MPIIO_ACCESS1_COUNT]),
+                &infile->counters[j], 1, infile->counters[j+4], 1);
         /* second set */
-                &(tmp_file.counters[MPIIO_ACCESS1_COUNT]), inoutfile->counters[j],
-                inoutfile->counters[j+4], 0);
+                &inoutfile->counters[j], 1, inoutfile->counters[j+4], 1);
         /* min non-zero (if available) value */
@@ -247,6 +247,7 @@ static int darshan_mem_alignment = 1;
     size_t stride; \
     int64_t this_offset; \
     int64_t file_alignment; \
     if(__ret < 0) break; \
     rec_ref = darshan_lookup_record_ref(posix_runtime->fd_hash, &(__fd), sizeof(int)); \
@@ -273,12 +274,18 @@ static int darshan_mem_alignment = 1;
     rec_ref->file_rec->counters[POSIX_BYTES_READ] += __ret; \
     rec_ref->file_rec->counters[POSIX_READS] += 1; \
     DARSHAN_BUCKET_INC(&(rec_ref->file_rec->counters[POSIX_SIZE_READ_0_100]), __ret); \
-    darshan_common_val_counter(&rec_ref->access_root, &rec_ref->access_count, __ret, \
+    cvc = darshan_track_common_val_counters(&rec_ref->access_root, &__ret, 1, \
         &(rec_ref->file_rec->counters[POSIX_ACCESS1_ACCESS]), \
-        &(rec_ref->file_rec->counters[POSIX_ACCESS1_COUNT])); \
-    darshan_common_val_counter(&rec_ref->stride_root, &rec_ref->stride_count, stride, \
+        &(rec_ref->file_rec->counters[POSIX_ACCESS1_COUNT]), \
+    cvc = darshan_track_common_val_counters(&rec_ref->stride_root, &stride, 1, \
+        &rec_ref->stride_count); \
         &(rec_ref->file_rec->counters[POSIX_STRIDE1_STRIDE]), \
-        &(rec_ref->file_rec->counters[POSIX_STRIDE1_COUNT])); \
+        &(rec_ref->file_rec->counters[POSIX_STRIDE1_COUNT]), \
     if(!__aligned) \
         rec_ref->file_rec->counters[POSIX_MEM_NOT_ALIGNED] += 1; \
     file_alignment = rec_ref->file_rec->counters[POSIX_FILE_ALIGNMENT]; \
@@ -303,6 +310,7 @@ static int darshan_mem_alignment = 1;
     size_t stride; \
     rec_ref = darshan_lookup_record_ref(posix_runtime->fd_hash, &__fd, sizeof(int)); \
@@ -329,12 +337,18 @@ static int darshan_mem_alignment = 1;
     rec_ref->file_rec->counters[POSIX_BYTES_WRITTEN] += __ret; \
     rec_ref->file_rec->counters[POSIX_WRITES] += 1; \
     DARSHAN_BUCKET_INC(&(rec_ref->file_rec->counters[POSIX_SIZE_WRITE_0_100]), __ret); \
     if(!__aligned) \
@@ -1280,7 +1294,7 @@ int DARSHAN_DECL(aio_write64)(struct aiocb64 *aiocbp)
 ssize_t DARSHAN_DECL(aio_return)(struct aiocb *aiocbp)
-    int ret;
+    ssize_t ret;
     double tm2;
     struct posix_aio_tracker *tmp;
     int aligned_flag = 0;
@@ -1317,7 +1331,7 @@ ssize_t DARSHAN_DECL(aio_return)(struct aiocb *aiocbp)
 ssize_t DARSHAN_DECL(aio_return64)(struct aiocb64 *aiocbp)
-    int ret;
+    ssize_t ret;
     double tm2;
@@ -1717,16 +1731,18 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
         /* first set */
         for(j=POSIX_STRIDE1_STRIDE; j<=POSIX_STRIDE4_STRIDE; j++)
-            DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_file.counters[POSIX_STRIDE1_STRIDE]),
-                &(tmp_file.counters[POSIX_STRIDE1_COUNT]), infile->counters[j],
+                &(tmp_file.counters[POSIX_STRIDE1_STRIDE]),
+                &(tmp_file.counters[POSIX_STRIDE1_COUNT]),
         /* second set */
-                &(tmp_file.counters[POSIX_STRIDE1_COUNT]), inoutfile->counters[j],
         /* same for access counts */
@@ -1748,16 +1764,18 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
         /* first set */
         for(j=POSIX_ACCESS1_ACCESS; j<=POSIX_ACCESS4_ACCESS; j++)
-            DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_file.counters[POSIX_ACCESS1_ACCESS]),
-                &(tmp_file.counters[POSIX_ACCESS1_COUNT]), infile->counters[j],
+                &(tmp_file.counters[POSIX_ACCESS1_ACCESS]),
+                &(tmp_file.counters[POSIX_ACCESS1_COUNT]),
         /* second set */
-                &(tmp_file.counters[POSIX_ACCESS1_COUNT]), inoutfile->counters[j],
@@ -88,6 +88,14 @@ static int dxt_log_get_posix_file(darshan_fd fd, void** dxt_posix_buf_p)
     if(fd->mod_map[DXT_POSIX_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DXT_POSIX_MOD] == 0 ||
+        fd->mod_ver[DXT_POSIX_MOD] > DXT_POSIX_VER)
+        fprintf(stderr, "Error: Invalid DXT POSIX module version number (got %d)\n",
+            fd->mod_ver[DXT_POSIX_MOD]);
+        return(-1);
     ret = darshan_log_get_mod(fd, DXT_POSIX_MOD, &tmp_rec,
                 sizeof(struct dxt_file_record));
     if(ret < 0)
@@ -156,6 +164,14 @@ static int dxt_log_get_mpiio_file(darshan_fd fd, void** dxt_mpiio_buf_p)
     if(fd->mod_map[DXT_MPIIO_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DXT_MPIIO_MOD] == 0 ||
+        fd->mod_ver[DXT_MPIIO_MOD] > DXT_MPIIO_VER)
+        fprintf(stderr, "Error: Invalid DXT MPIIO module version number (got %d)\n",
+            fd->mod_ver[DXT_MPIIO_MOD]);
+        return(-1);
     ret = darshan_log_get_mod(fd, DXT_MPIIO_MOD, &tmp_rec,
     if(ret < 0)
@@ -37,6 +37,7 @@ char *h5d_f_counter_names[] = {
 #undef X
 #define DARSHAN_H5F_FILE_SIZE_1 40
+#define DARSHAN_H5F_FILE_SIZE_2 56
 static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p);
 static int darshan_log_put_hdf5_file(darshan_fd fd, void* hdf5_buf);
@@ -86,6 +87,14 @@ static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p)
     if(fd->mod_map[DARSHAN_H5F_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DARSHAN_H5F_MOD] == 0 ||
+        fd->mod_ver[DARSHAN_H5F_MOD] > DARSHAN_H5F_VER)
+        fprintf(stderr, "Error: Invalid H5F module version number (got %d)\n",
+            fd->mod_ver[DARSHAN_H5F_MOD]);
+        return(-1);
     if(*hdf5_buf_p == NULL)
         file = malloc(sizeof(*file));
@@ -107,20 +116,45 @@ static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p)
         char *src_p, *dest_p;
         int len;
-        rec_len = DARSHAN_H5F_FILE_SIZE_1;
-        ret = darshan_log_get_mod(fd, DARSHAN_H5F_MOD, scratch, rec_len);
-        if(ret != rec_len)
-            goto exit;
-        /* upconvert version 1 to version 2 in-place */
-        dest_p = scratch + (sizeof(struct darshan_base_record) +
-            (1 * sizeof(int64_t)) + (3 * sizeof(double)));
-        src_p = dest_p - (2 * sizeof(double));
-        len = sizeof(double);
-        memmove(dest_p, src_p, len);
-        /* set F_CLOSE_START and F_OPEN_END to -1 */
-        *((double *)src_p) = -1;
-        *((double *)(src_p + sizeof(double))) = -1;
+        if(fd->mod_ver[DARSHAN_H5F_MOD] == 1)
+            rec_len = DARSHAN_H5F_FILE_SIZE_1;
+            ret = darshan_log_get_mod(fd, DARSHAN_H5F_MOD, scratch, rec_len);
+            if(ret != rec_len)
+                goto exit;
+            /* upconvert version 1 to version 2 in-place */
+            dest_p = scratch + (sizeof(struct darshan_base_record) +
+                (1 * sizeof(int64_t)) + (3 * sizeof(double)));
+            src_p = dest_p - (2 * sizeof(double));
+            len = sizeof(double);
+            memmove(dest_p, src_p, len);
+            /* set F_CLOSE_START and F_OPEN_END to -1 */
+            *((double *)src_p) = -1;
+            *((double *)(src_p + sizeof(double))) = -1;
+        if(fd->mod_ver[DARSHAN_H5F_MOD] <= 2)
+            if(fd->mod_ver[DARSHAN_H5F_MOD] == 2)
+                rec_len = DARSHAN_H5F_FILE_SIZE_2;
+                    goto exit;
+            /* upconvert version 2 to version 3 in-place */
+                (3 * sizeof(int64_t)));
+            src_p = dest_p - (2 * sizeof(int64_t));
+            len = 4 * sizeof(double);
+            /* set H5F_FLUSHES, H5F_USE_MPIIO to -1 */
+            *((int64_t *)src_p) = -1;
+            *((int64_t *)(src_p + sizeof(int64_t))) = -1;
+            /* set H5F_F_META_TIME to -1 */
+            *((double *)(dest_p + (4 * sizeof(double)))) = -1;
         memcpy(file, scratch, sizeof(struct darshan_hdf5_file));
@@ -146,7 +180,15 @@ exit:
             DARSHAN_BSWAP64(&(file->base_rec.id));
             DARSHAN_BSWAP64(&(file->base_rec.rank));
             for(i=0; i<H5F_NUM_INDICES; i++)
+                /* skip counters we explicitly set to -1 since they don't
+                 * need to be byte swapped
+                if((fd->mod_ver[DARSHAN_H5F_MOD] < 3) &&
+                    ((i == H5F_FLUSHES) || (i == H5F_USE_MPIIO)))
+                    continue;
                 DARSHAN_BSWAP64(&file->counters[i]);
             for(i=0; i<H5F_F_NUM_INDICES; i++)
@@ -156,6 +198,9 @@ exit:
                     ((i == H5F_F_CLOSE_START_TIMESTAMP) ||
                      (i == H5F_F_OPEN_END_TIMESTAMP)))
                     continue;
+                    (i == H5F_F_META_TIME))
+                    continue;
                 DARSHAN_BSWAP64(&file->fcounters[i]);
@@ -174,6 +219,14 @@ static int darshan_log_get_hdf5_dataset(darshan_fd fd, void** hdf5_buf_p)
     if(fd->mod_map[DARSHAN_H5D_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DARSHAN_H5D_MOD] == 0 ||
+        fd->mod_ver[DARSHAN_H5D_MOD] > DARSHAN_H5D_VER)
+        fprintf(stderr, "Error: Invalid H5D module version number (got %d)\n",
+            fd->mod_ver[DARSHAN_H5D_MOD]);
+        return(-1);
         ds = malloc(sizeof(*ds));
@@ -310,10 +363,15 @@ static void darshan_log_print_hdf5_file_description(int ver)
     if(ver == 1)
-        printf("\n# WARNING: HDF5 module log format version 1 does not support the following counters:\n");
+        printf("\n# WARNING: H5F module log format version 1 does not support the following counters:\n");
         printf("# - H5F_F_CLOSE_START_TIMESTAMP\n");
         printf("# - H5F_F_OPEN_END_TIMESTAMP\n");
+    if(ver <= 2)
+        printf("\n# WARNING: H5F module log format version <=2 does not support the following counters:\n");
+        printf("# \t- H5F_F_META_TIME\n");
     return;
@@ -330,21 +388,22 @@ static void darshan_log_print_hdf5_dataset_description(int ver)
     printf("#   H5D_*_SELECTS: number of different access selections (regular/irregular hyperslab or points).\n");
     printf("#   H5D_MAX_*_TIME_SIZE: size of the slowest read and write operations.\n");
     printf("#   H5D_SIZE_*_AGG_*: histogram of H5D total access sizes for read and write operations.\n");
-    printf("#   H5D_ACCESS*_ACCESS: the four most common total access sizes.\n");
+    printf("#   H5D_ACCESS*_*: the four most common total accesses, in terms of size and length/stride (in last 5 dimensions).\n");
     printf("#   H5D_ACCESS*_COUNT: count of the four most common total access sizes.\n");
     printf("#   H5D_DATASPACE_NDIMS: number of dimensions in dataset's dataspace.\n");
     printf("#   H5D_DATASPACE_NPOINTS: number of points in dataset's dataspace.\n");
     printf("#   H5D_DATATYPE_SIZE: size of each dataset element.\n");
-    printf("#   H5F_USE_MPIIO_COLLECTIVE: flag indicating whether MPI-IO collectives were used to access this file.\n");
-    printf("#   H5F_USE_DEPRECATED: flag indicating whether deprecated H5D calls were used.\n");
-    printf("#   H5D_*_RANK: rank of the processes that were the fastest and slowest at I/O (for shared files).\n");
-    printf("#   H5D_*_RANK_BYTES: total bytes transferred at H5D layer by the fastest and slowest ranks (for shared files).\n");
-    printf("#   H5D_F_*_START_TIMESTAMP: timestamp of first HDF5 file open/read/write/close.\n");
-    printf("#   H5D_F_*_END_TIMESTAMP: timestamp of last HDF5 file open/read/write/close.\n");
+    printf("#   H5D_CHUNK_SIZE_D*: chunk size in last 5 dimensions of dataset.\n");
+    printf("#   H5D_USE_MPIIO_COLLECTIVE: flag indicating whether MPI-IO collectives were used to access this dataset.\n");
+    printf("#   H5D_USE_DEPRECATED: flag indicating whether deprecated H5D calls were used.\n");
+    printf("#   H5D_*_RANK: rank of the processes that were the fastest and slowest at I/O (for shared datasets).\n");
+    printf("#   H5D_*_RANK_BYTES: total bytes transferred at H5D layer by the fastest and slowest ranks (for shared datasets).\n");
+    printf("#   H5D_F_*_START_TIMESTAMP: timestamp of first HDF5 dataset open/read/write/close.\n");
+    printf("#   H5D_F_*_END_TIMESTAMP: timestamp of last HDF5 datset open/read/write/close.\n");
     printf("#   H5D_F_READ/WRITE/META_TIME: cumulative time spent in H5D read, write, or metadata operations.\n");
     printf("#   H5D_F_MAX_*_TIME: duration of the slowest H5D read and write operations.\n");
-    printf("#   H5D_F_*_RANK_TIME: fastest and slowest I/O time for a single rank (for shared files).\n");
-    printf("#   H5D_F_VARIANCE_RANK_*: variance of total I/O time and bytes moved for all ranks (for shared files).\n");
+    printf("#   H5D_F_*_RANK_TIME: fastest and slowest I/O time for a single rank (for shared datasets).\n");
+    printf("#   H5D_F_VARIANCE_RANK_*: variance of total I/O time and bytes moved for all ranks (for shared datasets).\n");
     return;
@@ -565,9 +624,9 @@ static void darshan_log_agg_hdf5_datasets(void *rec, void *agg_rec, int init_fla
     struct darshan_hdf5_dataset *hdf5_rec = (struct darshan_hdf5_dataset *)rec;
     struct darshan_hdf5_dataset *agg_hdf5_rec = (struct darshan_hdf5_dataset *)agg_rec;
-    int i, j, k;
     int total_count;
-    int64_t tmp_val[4];
+    int64_t tmp_val[4 * (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1)];
     int64_t tmp_cnt[4];
     int tmp_ndx;
     double old_M;
@@ -631,72 +690,145 @@ static void darshan_log_agg_hdf5_datasets(void *rec, void *agg_rec, int init_fla
                 if(hdf5_rec->counters[i] == 0) break;
                 /* first, collapse duplicates */
-                for(j = i; j < i + 4; j++)
+                for(j = i, j2 = H5D_ACCESS1_COUNT; j <= H5D_ACCESS4_ACCESS;
+                    j += (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1), j2++)
-                    for(k = 0; k < 4; k++)
+                    for(k = i, k2 = H5D_ACCESS1_COUNT; k <= H5D_ACCESS4_ACCESS;
+                        k += (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1), k2++)
-                        if(agg_hdf5_rec->counters[i + k] == hdf5_rec->counters[j])
+                        if(!memcmp(&hdf5_rec->counters[j], &agg_hdf5_rec->counters[k],
-                            agg_hdf5_rec->counters[i + k + 4] += hdf5_rec->counters[j + 4];
-                            hdf5_rec->counters[j] = hdf5_rec->counters[j + 4] = 0;
+                            memset(&hdf5_rec->counters[j], 0, sizeof(int64_t) *
+                            agg_hdf5_rec->counters[k2] += hdf5_rec->counters[j2];
+                            hdf5_rec->counters[j2] = 0;
                 /* second, add new counters */
                     tmp_ndx = 0;
-                    memset(tmp_val, 0, 4 * sizeof(int64_t));
+                    memset(tmp_val, 0, 4 * (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1) * sizeof(int64_t));
                     memset(tmp_cnt, 0, 4 * sizeof(int64_t));
                     if(hdf5_rec->counters[j] == 0) break;
-                            total_count = agg_hdf5_rec->counters[i + k + 4] +
-                                hdf5_rec->counters[j + 4];
+                            total_count = agg_hdf5_rec->counters[k2] +
+                                hdf5_rec->counters[j2];
                             break;
-                    if(k == 4) total_count = hdf5_rec->counters[j + 4];
+                    if(k > H5D_ACCESS4_ACCESS) total_count = hdf5_rec->counters[j2];
-                        if((agg_hdf5_rec->counters[i + k + 4] > total_count) ||
-                           ((agg_hdf5_rec->counters[i + k + 4] == total_count) &&
-                            (agg_hdf5_rec->counters[i + k] > hdf5_rec->counters[j])))
+                        if((agg_hdf5_rec->counters[k2] > total_count) ||
+                           ((agg_hdf5_rec->counters[k2] == total_count) &&
+                            (agg_hdf5_rec->counters[k] > hdf5_rec->counters[j])))
-                            tmp_val[tmp_ndx] = agg_hdf5_rec->counters[i + k];
-                            tmp_cnt[tmp_ndx] = agg_hdf5_rec->counters[i + k + 4];
+                            memcpy(&tmp_val[tmp_ndx * (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1)],
+                                &agg_hdf5_rec->counters[k],
+                                sizeof(int64_t) * (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1));
+                            tmp_cnt[tmp_ndx] = agg_hdf5_rec->counters[k2];
                             tmp_ndx++;
                         else break;
-                    tmp_val[tmp_ndx] = hdf5_rec->counters[j];
-                    tmp_cnt[tmp_ndx] = hdf5_rec->counters[j + 4];
+                        &hdf5_rec->counters[j],
+                    tmp_cnt[tmp_ndx] = hdf5_rec->counters[j2];
                     tmp_ndx++;
                     while(tmp_ndx != 4)
-                        if(agg_hdf5_rec->counters[i + k] != hdf5_rec->counters[j])
+                        if(memcmp(&agg_hdf5_rec->counters[k], &hdf5_rec->counters[j],
                             tmp_ndx++;
-                        k++;
+                        k += (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1);
+                        k2++;
-                    memcpy(&(agg_hdf5_rec->counters[i]), tmp_val, 4 * sizeof(int64_t));
-                    memcpy(&(agg_hdf5_rec->counters[i + 4]), tmp_cnt, 4 * sizeof(int64_t));
+                    memcpy(&(agg_hdf5_rec->counters[H5D_ACCESS1_ACCESS]), tmp_val,
+                        4 * (H5D_MAX_NDIMS+H5D_MAX_NDIMS+1) * sizeof(int64_t));
+                    memcpy(&(agg_hdf5_rec->counters[H5D_ACCESS1_COUNT]), tmp_cnt,
+                        4 * sizeof(int64_t));
                 break;
+            case H5D_ACCESS1_LENGTH_D1:
+            case H5D_ACCESS1_LENGTH_D2:
+            case H5D_ACCESS1_LENGTH_D3:
+            case H5D_ACCESS1_LENGTH_D4:
+            case H5D_ACCESS1_LENGTH_D5:
+            case H5D_ACCESS1_STRIDE_D1:
+            case H5D_ACCESS1_STRIDE_D2:
+            case H5D_ACCESS1_STRIDE_D3:
+            case H5D_ACCESS1_STRIDE_D4:
+            case H5D_ACCESS1_STRIDE_D5:
+            case H5D_ACCESS2_ACCESS:
+            case H5D_ACCESS2_LENGTH_D1:
+            case H5D_ACCESS2_LENGTH_D2:
+            case H5D_ACCESS2_LENGTH_D3:
+            case H5D_ACCESS2_LENGTH_D4:
+            case H5D_ACCESS2_LENGTH_D5:
+            case H5D_ACCESS2_STRIDE_D1:
+            case H5D_ACCESS2_STRIDE_D2:
+            case H5D_ACCESS2_STRIDE_D3:
+            case H5D_ACCESS2_STRIDE_D4:
+            case H5D_ACCESS2_STRIDE_D5:
+            case H5D_ACCESS3_ACCESS:
+            case H5D_ACCESS3_LENGTH_D1:
+            case H5D_ACCESS3_LENGTH_D2:
+            case H5D_ACCESS3_LENGTH_D3:
+            case H5D_ACCESS3_LENGTH_D4:
+            case H5D_ACCESS3_LENGTH_D5:
+            case H5D_ACCESS3_STRIDE_D1:
+            case H5D_ACCESS3_STRIDE_D2:
+            case H5D_ACCESS3_STRIDE_D3:
+            case H5D_ACCESS3_STRIDE_D4:
+            case H5D_ACCESS3_STRIDE_D5:
+            case H5D_ACCESS4_ACCESS:
+            case H5D_ACCESS4_LENGTH_D1:
+            case H5D_ACCESS4_LENGTH_D2:
+            case H5D_ACCESS4_LENGTH_D3:
+            case H5D_ACCESS4_LENGTH_D4:
+            case H5D_ACCESS4_LENGTH_D5:
+            case H5D_ACCESS4_STRIDE_D1:
+            case H5D_ACCESS4_STRIDE_D2:
+            case H5D_ACCESS4_STRIDE_D3:
+            case H5D_ACCESS4_STRIDE_D4:
+            case H5D_ACCESS4_STRIDE_D5:
+            case H5D_ACCESS1_COUNT:
+            case H5D_ACCESS2_COUNT:
+            case H5D_ACCESS3_COUNT:
+            case H5D_ACCESS4_COUNT:
+                /* these are set all at once with common counters above */
+                break;
             case H5D_DATASPACE_NDIMS:
             case H5D_DATASPACE_NPOINTS:
             case H5D_DATATYPE_SIZE:
+            case H5D_CHUNK_SIZE_D1:
+            case H5D_CHUNK_SIZE_D2:
+            case H5D_CHUNK_SIZE_D3:
+            case H5D_CHUNK_SIZE_D4:
+            case H5D_CHUNK_SIZE_D5:
                 /* just set to the input value */
                 agg_hdf5_rec->counters[i] = hdf5_rec->counters[i];
                 break;
@@ -53,6 +53,14 @@ static int darshan_log_get_lustre_record(darshan_fd fd, void** lustre_buf_p)
     if(fd->mod_map[DARSHAN_LUSTRE_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DARSHAN_LUSTRE_MOD] == 0 ||
+        fd->mod_ver[DARSHAN_LUSTRE_MOD] > DARSHAN_LUSTRE_VER)
+        fprintf(stderr, "Error: Invalid Lustre module version number (got %d)\n",
+            fd->mod_ver[DARSHAN_LUSTRE_MOD]);
+        return(-1);
     /* retrieve the fixed-size portion of the record */
     ret = darshan_log_get_mod(fd, DARSHAN_LUSTRE_MOD, &tmp_rec,
         sizeof(struct darshan_lustre_record));
@@ -61,6 +61,14 @@ static int darshan_log_get_mpiio_file(darshan_fd fd, void** mpiio_buf_p)
     if(fd->mod_map[DARSHAN_MPIIO_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DARSHAN_MPIIO_MOD] == 0 ||
+        fd->mod_ver[DARSHAN_MPIIO_MOD] > DARSHAN_MPIIO_VER)
+        fprintf(stderr, "Error: Invalid MPIIO module version number (got %d)\n",
+            fd->mod_ver[DARSHAN_MPIIO_MOD]);
+        return(-1);
     if(*mpiio_buf_p == NULL)
@@ -68,6 +68,14 @@ static int darshan_log_get_null_record(darshan_fd fd, void** null_buf_p)
     if(fd->mod_map[DARSHAN_NULL_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DARSHAN_NULL_MOD] == 0 ||
+        fd->mod_ver[DARSHAN_NULL_MOD] > DARSHAN_NULL_VER)
+        fprintf(stderr, "Error: Invalid NHLL module version number (got %d)\n",
+            fd->mod_ver[DARSHAN_NULL_MOD]);
+        return(-1);
     if(*null_buf_p == NULL)
         rec = malloc(sizeof(*rec));
@@ -61,6 +61,14 @@ static int darshan_log_get_pnetcdf_file(darshan_fd fd, void** pnetcdf_buf_p)
     if(fd->mod_map[DARSHAN_PNETCDF_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DARSHAN_PNETCDF_MOD] == 0 ||
+        fd->mod_ver[DARSHAN_PNETCDF_MOD] > DARSHAN_PNETCDF_VER)
+        fprintf(stderr, "Error: Invalid PNetCDF module version number (got %d)\n",
+            fd->mod_ver[DARSHAN_PNETCDF_MOD]);
+        return(-1);
     if(*pnetcdf_buf_p == NULL)
@@ -63,6 +63,14 @@ static int darshan_log_get_posix_file(darshan_fd fd, void** posix_buf_p)
     if(fd->mod_map[DARSHAN_POSIX_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DARSHAN_POSIX_MOD] == 0 ||
+        fd->mod_ver[DARSHAN_POSIX_MOD] > DARSHAN_POSIX_VER)
+        fprintf(stderr, "Error: Invalid POSIX module version number (got %d)\n",
+            fd->mod_ver[DARSHAN_POSIX_MOD]);
+        return(-1);
     if(*posix_buf_p == NULL)
@@ -198,7 +206,7 @@ exit:
                     ((i == POSIX_F_CLOSE_START_TIMESTAMP) ||
                      (i == POSIX_F_OPEN_END_TIMESTAMP)))
                     continue;
-                if ((fd->mod_ver[DARSHAN_POSIX_MOD] < 4) &&
+                if((fd->mod_ver[DARSHAN_POSIX_MOD] < 4) &&
                      ((i == POSIX_RENAME_SOURCES) || (i == POSIX_RENAME_TARGETS) ||
                       (i == POSIX_RENAMED_FROM)))
                     continue;
@@ -71,6 +71,14 @@ static int darshan_log_get_stdio_record(darshan_fd fd, void** stdio_buf_p)
     if(fd->mod_map[DARSHAN_STDIO_MOD].len == 0)
         return(0);
+    if(fd->mod_ver[DARSHAN_STDIO_MOD] == 0 ||
+        fd->mod_ver[DARSHAN_STDIO_MOD] > DARSHAN_STDIO_VER)
+        fprintf(stderr, "Error: Invalid STDIO module version number (got %d)\n",
+            fd->mod_ver[DARSHAN_STDIO_MOD]);
+        return(-1);
     if(*stdio_buf_p == NULL)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/55c469885b7e17d0995c4c67a1e205d0dc4d18ee...a7f10928db3897f714ad9fd34840b99d311c33f4
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200331/15c4078b/attachment-0001.html>
More information about the Darshan-commits mailing list
