[Darshan-commits] [Git][darshan/darshan][master] 2 commits: alternative implementation of DARSHAN_WRAPPER_MAP
Shane Snyder
xgitlab at cels.anl.gov
Fri Mar 27 09:27:27 CDT 2020
Shane Snyder pushed to branch master at darshan / darshan
Commits:
5102d021 by Philip Carns at 2020-03-27T09:27:23-05:00
- uses function alias (via glibc's __REDIRECT macro) rather than
generating a shim function
- this is intended to avoid possibility of infinite loop if a
conventional PMPI instrumentation tool is used at the same time as an
explicitly linked darshan library
405131f9 by Shane Snyder at 2020-03-27T09:27:23-05:00
Merge branch 'carns/dev-wrapper-map-alias' into 'master'
See merge request darshan/darshan!39
3 changed files:
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-core-init-finalize.c
- darshan-runtime/lib/darshan-mpiio.c
Changes:
@@ -33,13 +33,13 @@
/* creates P* variant of MPI symbols for LD_PRELOAD so that we can handle
* language bindings that map to MPI or PMPI symbols under the covers.
+ * We use an alias attribute rather than generating a function shim in order
+ * to prevent accidental function call loop if there a conventional PMPI
+ * profiler is attempting to intercept the same function name.
#define DARSHAN_WRAPPER_MAP(__func,__ret,__args,__fcall) \
- __ret __func __args { \
- __ret i; \
- i = __fcall; \
- return i; \
+ __ret __func __args __attribute__ ((alias (#__fcall)));
/* Map the desired function call to a pointer called __real_NAME at run
* time. Note that we fall back to looking for the same symbol with a P
@@ -64,13 +64,13 @@
/* creates P* variant of MPI symbols for static linking so that we can handle
- __ret __wrap_ ## __func __args { \
- __ret i; \
- i = __wrap_ ## __fcall; \
- return i; \
+ __ret __wrap_ ## __func __args __attribute__ ((alias ("__wrap_" #__fcall)));
#define MAP_OR_FAIL(__func)
@@ -48,7 +48,7 @@ int DARSHAN_DECL(MPI_Init)(int *argc, char ***argv)
return(ret);
-DARSHAN_WRAPPER_MAP(PMPI_Init, int, (int *argc, char ***argv), MPI_Init(argc,argv))
+DARSHAN_WRAPPER_MAP(PMPI_Init, int, (int *argc, char ***argv), MPI_Init)
int DARSHAN_DECL(MPI_Init_thread)(int *argc, char ***argv, int required, int *provided)
@@ -74,7 +74,7 @@ int DARSHAN_DECL(MPI_Init_thread)(int *argc, char ***argv, int required, int *pr
return(ret);
-DARSHAN_WRAPPER_MAP(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided), MPI_Init_thread(argc,argv,required,provided))
+DARSHAN_WRAPPER_MAP(PMPI_Init_thread, int, (int *argc, char ***argv, int required, int *provided), MPI_Init_thread)
int DARSHAN_DECL(MPI_Finalize)(void)
@@ -87,7 +87,7 @@ int DARSHAN_DECL(MPI_Finalize)(void)
ret = __real_PMPI_Finalize();
return(ret);
-DARSHAN_WRAPPER_MAP(PMPI_Finalize, int, (void), MPI_Finalize())
+DARSHAN_WRAPPER_MAP(PMPI_Finalize, int, (void), MPI_Finalize)
#endif
@@ -337,9 +337,9 @@ int DARSHAN_DECL(MPI_File_open)(MPI_Comm comm, char *filename, int amode, MPI_In
return(ret);
#ifdef HAVE_MPIIO_CONST
-DARSHAN_WRAPPER_MAP(PMPI_File_open, int, (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh), MPI_File_open(comm,filename,amode,info,fh))
+DARSHAN_WRAPPER_MAP(PMPI_File_open, int, (MPI_Comm comm, const char *filename, int amode, MPI_Info info, MPI_File *fh), MPI_File_open)
#else
-DARSHAN_WRAPPER_MAP(PMPI_File_open, int, (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh), MPI_File_open(comm,filename,amode,info,fh))
+DARSHAN_WRAPPER_MAP(PMPI_File_open, int, (MPI_Comm comm, char *filename, int amode, MPI_Info info, MPI_File *fh), MPI_File_open)
#endif
int DARSHAN_DECL(MPI_File_read)(MPI_File fh, void *buf, int count,
@@ -361,7 +361,7 @@ int DARSHAN_DECL(MPI_File_read)(MPI_File fh, void *buf, int count,
return(ret);
DARSHAN_WRAPPER_MAP(PMPI_File_read, int, (MPI_File fh, void *buf, int count,
- MPI_Datatype datatype, MPI_Status *status), MPI_File_read(fh,buf,count,datatype,status))
+ MPI_Datatype datatype, MPI_Status *status), MPI_File_read)
int DARSHAN_DECL(MPI_File_write)(MPI_File fh, const void *buf, int count,
@@ -388,10 +388,10 @@ int DARSHAN_DECL(MPI_File_write)(MPI_File fh, void *buf, int count,
DARSHAN_WRAPPER_MAP(PMPI_File_write, int, (MPI_File fh, const void *buf, int count,
- MPI_Datatype datatype, MPI_Status *status), MPI_File_write(fh,buf,count,datatype,status))
+ MPI_Datatype datatype, MPI_Status *status), MPI_File_write)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write, int, (MPI_File fh, void *buf, int count,
#endif
int DARSHAN_DECL(MPI_File_read_at)(MPI_File fh, MPI_Offset offset, void *buf,
@@ -414,7 +414,7 @@ int DARSHAN_DECL(MPI_File_read_at)(MPI_File fh, MPI_Offset offset, void *buf,
return(ret);
DARSHAN_WRAPPER_MAP(PMPI_File_read_at, int, (MPI_File fh, MPI_Offset offset, void *buf,
- int count, MPI_Datatype datatype, MPI_Status *status), MPI_File_read_at(fh, offset, buf, count, datatype, status))
+ int count, MPI_Datatype datatype, MPI_Status *status), MPI_File_read_at)
int DARSHAN_DECL(MPI_File_write_at)(MPI_File fh, MPI_Offset offset, const void *buf,
@@ -442,10 +442,10 @@ int DARSHAN_DECL(MPI_File_write_at)(MPI_File fh, MPI_Offset offset, void *buf,
DARSHAN_WRAPPER_MAP(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, const void *buf,
- int count, MPI_Datatype datatype, MPI_Status *status), MPI_File_write_at(fh, offset, buf, count, datatype, status))
+ int count, MPI_Datatype datatype, MPI_Status *status), MPI_File_write_at)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write_at, int, (MPI_File fh, MPI_Offset offset, void *buf,
#endif
int DARSHAN_DECL(MPI_File_read_all)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
@@ -467,7 +467,7 @@ int DARSHAN_DECL(MPI_File_read_all)(MPI_File fh, void * buf, int count, MPI_Data
return(ret);
DARSHAN_WRAPPER_MAP(PMPI_File_read_all, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
- MPI_File_read_all(fh,buf,count,datatype,status))
+ MPI_File_read_all)
int DARSHAN_DECL(MPI_File_write_all)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
@@ -493,10 +493,10 @@ int DARSHAN_DECL(MPI_File_write_all)(MPI_File fh, void * buf, int count, MPI_Dat
DARSHAN_WRAPPER_MAP(PMPI_File_write_all, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
- MPI_File_write_all(fh, buf, count, datatype, status))
+ MPI_File_write_all)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write_all, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
#endif
int DARSHAN_DECL(MPI_File_read_at_all)(MPI_File fh, MPI_Offset offset, void * buf,
@@ -520,7 +520,7 @@ int DARSHAN_DECL(MPI_File_read_at_all)(MPI_File fh, MPI_Offset offset, void * bu
DARSHAN_WRAPPER_MAP(PMPI_File_read_at_all, int, (MPI_File fh, MPI_Offset offset, void * buf,
int count, MPI_Datatype datatype, MPI_Status * status),
- MPI_File_read_at_all(fh,offset,buf,count,datatype,status))
+ MPI_File_read_at_all)
int DARSHAN_DECL(MPI_File_write_at_all)(MPI_File fh, MPI_Offset offset, const void * buf,
@@ -549,11 +549,11 @@ int DARSHAN_DECL(MPI_File_write_at_all)(MPI_File fh, MPI_Offset offset, void * b
DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, const void * buf,
- MPI_File_write_at_all(fh, offset, buf, count, datatype, status))
+ MPI_File_write_at_all)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all, int, (MPI_File fh, MPI_Offset offset, void * buf,
#endif
int DARSHAN_DECL(MPI_File_read_shared)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
@@ -575,7 +575,7 @@ int DARSHAN_DECL(MPI_File_read_shared)(MPI_File fh, void * buf, int count, MPI_D
return(ret);
DARSHAN_WRAPPER_MAP(PMPI_File_read_shared, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
- MPI_File_read_shared(fh, buf, count, datatype, status))
+ MPI_File_read_shared)
int DARSHAN_DECL(MPI_File_write_shared)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status)
@@ -601,10 +601,10 @@ int DARSHAN_DECL(MPI_File_write_shared)(MPI_File fh, void * buf, int count, MPI_
DARSHAN_WRAPPER_MAP(PMPI_File_write_shared, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
- MPI_File_write_shared(fh, buf, count, datatype, status))
+ MPI_File_write_shared)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write_shared, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, MPI_Status *status),
#endif
@@ -629,7 +629,7 @@ int DARSHAN_DECL(MPI_File_read_ordered)(MPI_File fh, void * buf, int count,
DARSHAN_WRAPPER_MAP(PMPI_File_read_ordered, int, (MPI_File fh, void * buf, int count,
- MPI_File_read_ordered(fh, buf, count, datatype, status))
+ MPI_File_read_ordered)
int DARSHAN_DECL(MPI_File_write_ordered)(MPI_File fh, const void * buf, int count,
@@ -658,11 +658,11 @@ int DARSHAN_DECL(MPI_File_write_ordered)(MPI_File fh, void * buf, int count,
DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered, int, (MPI_File fh, const void * buf, int count,
- MPI_File_write_ordered(fh, buf, count, datatype, status))
+ MPI_File_write_ordered)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered, int, (MPI_File fh, void * buf, int count,
#endif
int DARSHAN_DECL(MPI_File_read_all_begin)(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
@@ -683,7 +683,7 @@ int DARSHAN_DECL(MPI_File_read_all_begin)(MPI_File fh, void * buf, int count, MP
return(ret);
DARSHAN_WRAPPER_MAP(PMPI_File_read_all_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
- MPI_File_read_all_begin(fh, buf, count, datatype))
+ MPI_File_read_all_begin)
int DARSHAN_DECL(MPI_File_write_all_begin)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
@@ -708,10 +708,10 @@ int DARSHAN_DECL(MPI_File_write_all_begin)(MPI_File fh, void * buf, int count, M
DARSHAN_WRAPPER_MAP(PMPI_File_write_all_begin, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype),
- MPI_File_write_all_begin(fh, buf, count, datatype))
+ MPI_File_write_all_begin)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write_all_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
#endif
int DARSHAN_DECL(MPI_File_read_at_all_begin)(MPI_File fh, MPI_Offset offset, void * buf,
@@ -734,8 +734,7 @@ int DARSHAN_DECL(MPI_File_read_at_all_begin)(MPI_File fh, MPI_Offset offset, voi
return(ret);
DARSHAN_WRAPPER_MAP(PMPI_File_read_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void * buf,
- int count, MPI_Datatype datatype), MPI_File_read_at_all_begin(fh, offset, buf, count,
- datatype))
+ int count, MPI_Datatype datatype), MPI_File_read_at_all_begin)
int DARSHAN_DECL(MPI_File_write_at_all_begin)(MPI_File fh, MPI_Offset offset, const void * buf,
@@ -763,10 +762,10 @@ int DARSHAN_DECL(MPI_File_write_at_all_begin)(MPI_File fh, MPI_Offset offset, vo
DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, const void * buf,
- int count, MPI_Datatype datatype), MPI_File_write_at_all_begin( fh, offset, buf, count, datatype))
+ int count, MPI_Datatype datatype), MPI_File_write_at_all_begin)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write_at_all_begin, int, (MPI_File fh, MPI_Offset offset, void * buf,
#endif
int DARSHAN_DECL(MPI_File_read_ordered_begin)(MPI_File fh, void * buf, int count, MPI_Datatype datatype)
@@ -788,7 +787,7 @@ int DARSHAN_DECL(MPI_File_read_ordered_begin)(MPI_File fh, void * buf, int count
return(ret);
DARSHAN_WRAPPER_MAP(PMPI_File_read_ordered_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
- MPI_File_read_ordered_begin(fh, buf, count, datatype))
+ MPI_File_read_ordered_begin)
int DARSHAN_DECL(MPI_File_write_ordered_begin)(MPI_File fh, const void * buf, int count, MPI_Datatype datatype)
@@ -814,10 +813,10 @@ int DARSHAN_DECL(MPI_File_write_ordered_begin)(MPI_File fh, void * buf, int coun
DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered_begin, int, (MPI_File fh, const void * buf, int count, MPI_Datatype datatype),
- MPI_File_write_ordered_begin(fh, buf, count, datatype))
+ MPI_File_write_ordered_begin)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_write_ordered_begin, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype),
#endif
int DARSHAN_DECL(MPI_File_iread)(MPI_File fh, void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request)
@@ -838,7 +837,7 @@ int DARSHAN_DECL(MPI_File_iread)(MPI_File fh, void * buf, int count, MPI_Datatyp
return(ret);
DARSHAN_WRAPPER_MAP(PMPI_File_iread, int, (MPI_File fh, void * buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST * request),
- MPI_File_iread(fh, buf, count, datatype, request))
+ MPI_File_iread)
int DARSHAN_DECL(MPI_File_iwrite)(MPI_File fh, const void * buf, int count,
@@ -866,11 +865,11 @@ int DARSHAN_DECL(MPI_File_iwrite)(MPI_File fh, void * buf, int count,
DARSHAN_WRAPPER_MAP(PMPI_File_iwrite, int, (MPI_File fh, const void * buf, int count,
- MPI_File_iwrite(fh, buf, count, datatype, request))
+ MPI_File_iwrite)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_iwrite, int, (MPI_File fh, void * buf, int count,
+ MPI_File_iwrite)
#endif
int DARSHAN_DECL(MPI_File_iread_at)(MPI_File fh, MPI_Offset offset, void * buf,
@@ -894,7 +893,7 @@ int DARSHAN_DECL(MPI_File_iread_at)(MPI_File fh, MPI_Offset offset, void * buf,
DARSHAN_WRAPPER_MAP(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void * buf,
int count, MPI_Datatype datatype, __D_MPI_REQUEST *request),
- MPI_File_iread_at(fh, offset,buf,count,datatype,request))
+ MPI_File_iread_at)
int DARSHAN_DECL(MPI_File_iwrite_at)(MPI_File fh, MPI_Offset offset, const void * buf,
@@ -923,11 +922,11 @@ int DARSHAN_DECL(MPI_File_iwrite_at)(MPI_File fh, MPI_Offset offset, void * buf,
DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, const void * buf,
- MPI_File_iwrite_at(fh, offset, buf, count, datatype, request))
+ MPI_File_iwrite_at)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_at, int, (MPI_File fh, MPI_Offset offset, void * buf,
#endif
int DARSHAN_DECL(MPI_File_iread_shared)(MPI_File fh, void * buf, int count,
@@ -951,7 +950,7 @@ int DARSHAN_DECL(MPI_File_iread_shared)(MPI_File fh, void * buf, int count,
DARSHAN_WRAPPER_MAP(PMPI_File_iread_shared, int, (MPI_File fh, void * buf, int count,
- MPI_File_iread_shared(fh, buf, count, datatype, request))
+ MPI_File_iread_shared)
int DARSHAN_DECL(MPI_File_iwrite_shared)(MPI_File fh, const void * buf, int count,
@@ -980,11 +979,11 @@ int DARSHAN_DECL(MPI_File_iwrite_shared)(MPI_File fh, void * buf, int count,
DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_shared, int, (MPI_File fh, const void * buf, int count,
- MPI_File_iwrite_shared(fh, buf, count, datatype, request))
+ MPI_File_iwrite_shared)
#else
DARSHAN_WRAPPER_MAP(PMPI_File_iwrite_shared, int, (MPI_File fh, void * buf, int count,
#endif
int DARSHAN_DECL(MPI_File_sync)(MPI_File fh)
@@ -1016,7 +1015,7 @@ int DARSHAN_DECL(MPI_File_sync)(MPI_File fh)
return(ret);
-DARSHAN_WRAPPER_MAP(PMPI_File_sync, int, (MPI_File fh), MPI_File_sync(fh))
+DARSHAN_WRAPPER_MAP(PMPI_File_sync, int, (MPI_File fh), MPI_File_sync)
int DARSHAN_DECL(MPI_File_set_view)(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
@@ -1060,10 +1059,10 @@ int DARSHAN_DECL(MPI_File_set_view)(MPI_File fh, MPI_Offset disp, MPI_Datatype e
DARSHAN_WRAPPER_MAP(PMPI_File_set_view, int, (MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
- MPI_Datatype filetype, const char *datarep, MPI_Info info), MPI_File_set_view(fh, disp, etype, filetype, datarep, info))
+ MPI_Datatype filetype, const char *datarep, MPI_Info info), MPI_File_set_view)
#else
- MPI_Datatype filetype, char *datarep, MPI_Info info), MPI_File_set_view(fh, disp, etype, filetype, datarep, info))
+ MPI_Datatype filetype, char *datarep, MPI_Info info), MPI_File_set_view)
#endif
int DARSHAN_DECL(MPI_File_close)(MPI_File *fh)
@@ -1098,7 +1097,7 @@ int DARSHAN_DECL(MPI_File_close)(MPI_File *fh)
return(ret);
-DARSHAN_WRAPPER_MAP(PMPI_File_close, int, (MPI_File *fh), MPI_File_close(fh))
+DARSHAN_WRAPPER_MAP(PMPI_File_close, int, (MPI_File *fh), MPI_File_close)
* Internal functions for manipulating MPI-IO module state *
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/428247f44ce98f2d5430f8b90d8699dfaa164b84...405131f9acd5e6448f573b203745b39fb8802ac9
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200327/0b0a4bd5/attachment-0001.html>
More information about the Darshan-commits
