[Darshan-commits] [Git][darshan/darshan][carns/dev-dyn-link-updates] update comments
Philip Carns
xgitlab at cels.anl.gov
Fri Mar 20 08:18:54 CDT 2020
Philip Carns pushed to branch carns/dev-dyn-link-updates at darshan / darshan
Commits:
fb87d7c6 by Phil Carns at 2020-03-20T09:18:48-04:00
update comments
1 changed file:
- darshan-runtime/darshan-gen-cc.pl.in
Changes:
@@ -237,10 +237,13 @@ print OUTPUT<<"EOF";
used_darshan=0
- # Trial run to generate a symbol listing. We only enable Darshan if MPI
- # symbols are present. Technically Darshan should not harm
- # non-MPI programs, but it may bring in unwanted dependencies or
- # interfere with autoconf checks.
+ # Perform a test link before the real link. This allows us to check
+ # for two things:
+ # 1) Are MPI symbols present? Technically Darshan should not harm
+ # non-MPI programs, but it may bring in unwanted dependencies or
+ # interfere with autoconf checks.
+ # 2) Is this link command line going to produce a static or dynamic
+ # linked executable? We will adjust Darshan link strategy accordingly.
# create a temporary file
tmpfile=`mktemp`
@@ -268,8 +271,8 @@ print OUTPUT<<"EOF";
rm \$tmpfile >& /dev/null
rm \$binfile >& /dev/null
- # disable darshan if the executable is not an MPI program (this feature
- # mainly allows runtime configure tests to work
+ # disable darshan if the executable is not an MPI program or we've
+ # detected an incompatible compiler
if [ \$rc_mpi -eq 0 ] && [ \$compiler_check -eq 0 ]; then
if [ \$rc_dyn -eq 0 ]; then
\$Show \$CC $link_cmd_prefix $dyn_link_cmd_suffix
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/fb87d7c66702d86e1a488267ebc92e5b05a73074
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200320/96fc9513/attachment.html>
More information about the Darshan-commits
