[Darshan-commits] [Git][darshan/darshan][carns/dev-dyn-link-updates] add darshan-config option for dynamic link options
Philip Carns xgitlab at cels.anl.gov
Fri Mar 20 07:45:07 CDT 2020
Philip Carns pushed to branch carns/dev-dyn-link-updates at darshan / darshan
Commits:
6bab9cea by Phil Carns at 2020-03-20T08:44:49-04:00
1 changed file:
- darshan-runtime/darshan-config.in
Changes:
@@ -5,17 +5,22 @@ DARSHAN_SHARE_PATH="@darshan_share_path@"
 DARSHAN_LD_FLAGS="@LDFLAGS@"
 # NOTE:
-# - we deliberately list libdarshan twice in the link command.  The
-#   first is necessary to correctly use the MPI profiling interface.  The
-#   final one is necessary to give the linker a change to resolve indirect
-#   dependencies on PnetCDF and HDF5 symbols (if the app used a library which
-#   in turn used one of those HLLs).
+# - we deliberately list libdarshan twice in the link command when
+#   statically linking.  The first sets symbol wrapping options early in the
+#   link line. The final one is necessary to give the linker a change to
+#   resolve indirect dependencies on PnetCDF and HDF5 symbols (if the
+#   app used a library which in turn used one of those HLLs).
 PRE_LD_FLAGS="-L$DARSHAN_LIB_PATH $DARSHAN_LD_FLAGS -ldarshan -lz -Wl,@$DARSHAN_SHARE_PATH/ld-opts/darshan-base-ld-opts"
 POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -Wl,--start-group -ldarshan -ldarshan-stubs -Wl,--end-group -lz -lrt -lpthread"
+# NOTE:
+# - when dynamic linking there is no need for wrapping options, we simply
+#   need to get the darshan symbol definitions early enough in the link order.
+DYN_LD_FLAGS="-L$DARSHAN_LIB_PATH $DARSHAN_LD_FLAGS -ldarshan"
 usage="\
-Usage: darshan-config [--pre-ld-flags] [--post-ld-flags]"
+Usage: darshan-config [--pre-ld-flags] [--post-ld-flags] [--dyn-ld-flags]"
 if test $# -eq 0; then
       echo "${usage}" 1>&2
@@ -35,6 +40,9 @@ while test $# -gt 0; do
     --post-ld-flags)
       echo $POST_LD_FLAGS
+    --dyn-ld-flags)
+      echo $DYN_LD_FLAGS
       exit 1
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/6bab9ceac34c9104bbe9fddb90ba11d8bbd04947
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200320/cb3c8ba5/attachment-0001.html>
More information about the Darshan-commits mailing list
