[Darshan-commits] [Git][darshan/darshan][master] 2 commits: Add openat support to POSIX module
Shane Snyder
xgitlab at cels.anl.gov
Thu Jun 11 15:17:34 CDT 2020
Shane Snyder pushed to branch master at darshan / darshan
Commits:
656f8155 by Shane Snyder at 2020-06-11T15:14:25-05:00
Fixes #282
e714fec8 by Shane Snyder at 2020-06-11T15:17:31-05:00
Merge branch 'dev-openat-wrappers' into 'master'
Closes #282
See merge request darshan/darshan!60
2 changed files:
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/share/ld-opts/darshan-posix-ld-opts
Changes:
@@ -25,6 +25,7 @@
#include <libgen.h>
#include <aio.h>
#include <pthread.h>
+#include <limits.h>
#include "utlist.h"
#include "darshan.h"
@@ -42,6 +43,8 @@ typedef int64_t off64_t;
DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
DARSHAN_FORWARD_DECL(open64, int, (const char *path, int flags, ...));
DARSHAN_FORWARD_DECL(__open_2, int, (const char *path, int oflag));
+DARSHAN_FORWARD_DECL(openat, int, (int dirfd, const char *pathname, int flags, ...));
+DARSHAN_FORWARD_DECL(openat64, int, (int dirfd, const char *pathname, int flags, ...));
DARSHAN_FORWARD_DECL(creat, int, (const char* path, mode_t mode));
DARSHAN_FORWARD_DECL(creat64, int, (const char* path, mode_t mode));
DARSHAN_FORWARD_DECL(dup, int, (int oldfd));
@@ -481,6 +484,148 @@ int DARSHAN_DECL(open64)(const char *path, int flags, ...)
return(ret);
+int DARSHAN_DECL(openat)(int dirfd, const char *pathname, int flags, ...)
+ int mode = 0;
+ int ret;
+ double tm1, tm2;
+ struct posix_file_record_ref *rec_ref;
+ char tmp_path[PATH_MAX] = {0};
+ char *dirpath = NULL;
+ MAP_OR_FAIL(openat);
+ if(flags & O_CREAT)
+ va_list arg;
+ va_start(arg, flags);
+ mode = va_arg(arg, int);
+ va_end(arg);
+ tm1 = darshan_core_wtime();
+ ret = __real_openat(dirfd, pathname, flags, mode);
+ tm2 = darshan_core_wtime();
+ else
+ ret = __real_openat(dirfd, pathname, flags);
+ POSIX_PRE_RECORD();
+ if(pathname[0] == '/' || dirfd == AT_FDCWD)
+ /* ignore dirfd in these cases:
+ * - absolute path
+ * - dirfd equal to CWD
+ POSIX_RECORD_OPEN(ret, pathname, mode, tm1, tm2);
+ else
+ /* construct path relative to dirfd */
+ rec_ref = darshan_lookup_record_ref(posix_runtime->fd_hash,
+ &dirfd, sizeof(dirfd));
+ if(rec_ref)
+ dirpath = darshan_core_lookup_record_name(rec_ref->file_rec->base_rec.id);
+ if(dirpath)
+ strcat(tmp_path, dirpath);
+ if(dirpath[strlen(dirpath)-1] != '/')
+ strcat(tmp_path, "/");
+ strcat(tmp_path, pathname);
+ if(dirpath)
+ /* we were able to construct an absolute path */
+ POSIX_RECORD_OPEN(ret, tmp_path, mode, tm1, tm2);
+ else
+ /* fallback to relative path if Darshan doesn't know dirfd path */
+ POSIX_POST_RECORD();
+ return(ret);
+int DARSHAN_DECL(openat64)(int dirfd, const char *pathname, int flags, ...)
+ int mode = 0;
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(openat64);
+ va_list arg;
+ va_end(arg);
+ ret = __real_openat64(dirfd, pathname, flags, mode);
+ else
+ ret = __real_openat64(dirfd, pathname, flags);
+ * - absolute path
+ else
+ if(rec_ref)
+ if(dirpath)
+ if(dirpath)
+ else
+ return(ret);
int DARSHAN_DECL(creat)(const char* path, mode_t mode)
int ret;
@@ -1,6 +1,8 @@
--wrap=open
--wrap=open64
--wrap=__open_2
+--wrap=openat
+--wrap=openat64
--wrap=creat
--wrap=creat64
--wrap=dup
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/55a2259b04ed8f668aa9ffc9898ebc6ade50434a...e714fec84a47950b7a7c21e8ba69d155a4b83e3f
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200611/849c8ecf/attachment-0001.html>
More information about the Darshan-commits
