[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » x86-master-cc-wrapper-static #622
no-reply at alcf.anl.gov
Fri Jul 17 05:59:33 CDT 2020
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-cc-wrapper-static/622/display/redirect>
Changes:
Started by timer
Running as SYSTEM
Building remotely on RadixIO-CINOW-01 in workspace <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-cc-wrapper-static/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
No credentials specified
Cloning the remote Git repository
Cloning repository https://xgitlab.cels.anl.gov/darshan/darshan.git
> git init <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/x86-master-cc-wrapper-static/ws/> # timeout=10
Fetching upstream changes from https://xgitlab.cels.anl.gov/darshan/darshan.git
> git --version # timeout=10
> git fetch --tags --progress -- https://xgitlab.cels.anl.gov/darshan/darshan.git +refs/heads/*:refs/remotes/origin/* # timeout=10
> git config remote.origin.url https://xgitlab.cels.anl.gov/darshan/darshan.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse refs/remotes/origin/dev-new-regression-tests^{commit} # timeout=10
> git rev-parse refs/remotes/origin/origin/dev-new-regression-tests^{commit} # timeout=10
> git rev-parse origin/dev-new-regression-tests^{commit} # timeout=10
ERROR: Couldn't find any revision to build. Verify the repository and branch configuration for this job.
Recording test results
ERROR: Step ‘Publish JUnit test result report’ failed: No test report files were found. Configuration error?
More information about the Darshan-commits
