[Darshan-commits] [Git][darshan/darshan][master] 5 commits: add autoconf test for fscanf redirect
Philip Carns
xgitlab at cels.anl.gov
Fri Feb 14 07:33:18 CST 2020
Philip Carns pushed to branch master at darshan / darshan
Commits:
36d8e168 by Shane Snyder at 2020-02-13T22:10:11Z
bb2909d1 by Shane Snyder at 2020-02-13T23:42:31Z
slight modification of autoconf test
82eb9e9e by Shane Snyder at 2020-02-14T00:00:35Z
need gnu_source for config check
7ff18700 by Shane Snyder at 2020-02-14T00:03:18Z
ifdef wrap in fscanf redirect case
9c769b2c by Philip Carns at 2020-02-14T13:33:14Z
Merge branch 'dev-fscanf-redefined' into 'master'
fix fscanf redefinitions
See merge request darshan/darshan!35
4 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-runtime-config.h.in
- darshan-runtime/lib/darshan-stdio.c
Changes:
@@ -4832,6 +4832,38 @@ fi
# End of MPI-only checks
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for fscanf redirect" >&5
+$as_echo_n "checking for fscanf redirect... " >&6; }
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h. */
+ #define _GNU_SOURCE
+ #include <stdio.h>
+ int fscanf(FILE *stream, const char *format, ...) {return(0);}
+ int __isoc99_fscanf(FILE *stream, const char *format, ...) {return(0);}
+int
+main ()
+ return 0;
+_ACEOF
+if ac_fn_c_try_compile "$LINENO"; then :
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
+else
+ { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
+$as_echo "#define HAVE_FSCANF_REDIRECT 1" >>confdefs.h
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
DARSHAN_VERSION="3.2.0-pre1"
@@ -481,6 +481,21 @@ AS_IF([$CC -show foo.c -o foo >& /dev/null],
+AC_MSG_CHECKING(for fscanf redirect)
+AC_TRY_COMPILE(
+ AC_MSG_RESULT(no),
+ AC_MSG_RESULT(yes)
+ AC_DEFINE(HAVE_FSCANF_REDIRECT, 1, Define if fscanf is redirected to another function)
DARSHAN_VERSION="AC_PACKAGE_VERSION"
AC_SUBST(darshan_lib_path)
AC_SUBST(darshan_share_path)
@@ -6,6 +6,9 @@
/* Define if struct aiocb64 type is defined */
#undef HAVE_AIOCB64
+/* Define if fscanf is redirected to another function */
+#undef HAVE_FSCANF_REDIRECT
/* Define to 1 if you have the <inttypes.h> header file. */
#undef HAVE_INTTYPES_H
@@ -109,7 +109,9 @@ DARSHAN_FORWARD_DECL(getw, int, (FILE *stream));
DARSHAN_FORWARD_DECL(_IO_getc, int, (FILE *stream));
DARSHAN_FORWARD_DECL(_IO_putc, int, (int, FILE *stream));
DARSHAN_FORWARD_DECL(fscanf, int, (FILE *stream, const char *format, ...));
+#ifndef HAVE_FSCANF_REDIRECT
DARSHAN_FORWARD_DECL(__isoc99_fscanf, int, (FILE *stream, const char *format, ...));
+#endif
DARSHAN_FORWARD_DECL(vfscanf, int, (FILE *stream, const char *format, va_list ap));
DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
@@ -696,6 +698,7 @@ int DARSHAN_DECL(getw)(FILE *stream)
return(ret);
/* NOTE: some glibc versions use __isoc99_fscanf as the underlying symbol
* rather than fscanf
@@ -726,7 +729,7 @@ int DARSHAN_DECL(__isoc99_fscanf)(FILE *stream, const char *format, ...)
return(ret);
+#endif
int DARSHAN_DECL(fscanf)(FILE *stream, const char *format, ...)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/733cac5d4597128584321ccc2d43f7643bfd2ea4...9c769b2cf415ea024d56df27526cb6d75e9199cc
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200214/f46d98f4/attachment-0001.html>
More information about the Darshan-commits
