[Darshan-commits] [Git][darshan/darshan][dev-detailed-hdf5-mod] 3 commits: changes for h5f/h5d module formats
Shane Snyder xgitlab at cels.anl.gov
Sun Feb 2 21:40:45 CST 2020
Shane Snyder pushed to branch dev-detailed-hdf5-mod at darshan / darshan
Commits:
ed312f5d by Shane Snyder at 2020-02-03T03:36:22Z
9933525a by Shane Snyder at 2020-02-03T03:38:32Z
darshan-runtime support for h5d/h5f
55c46988 by Shane Snyder at 2020-02-03T03:40:00Z
darshan-util support for h5d/h5f
8 changed files:
- darshan-hdf5-log-format.h
- darshan-log-format.h
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/share/ld-opts/darshan-hdf5-ld-opts
- darshan-util/darshan-analyzer.c
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-hdf5-logutils.h
- darshan-util/darshan-logutils.c
Changes:
@@ -7,53 +7,195 @@
 #ifndef __DARSHAN_HDF5_LOG_FORMAT_H
 #define __DARSHAN_HDF5_LOG_FORMAT_H
-/* current HDF5 log format version */
-#define DARSHAN_HDF5_VER 2
+/* current HDF5 log format versions */
+#define DARSHAN_H5F_VER 2
+#define DARSHAN_H5D_VER 1
-#define HDF5_COUNTERS \
-    /* count of HDF5 opens */\
-    X(HDF5_OPENS) \
+#define H5F_COUNTERS \
+    /* count of HDF5 file opens/creates */\
+    X(H5F_OPENS) \
+    /* count of HDF5 file flushes */\
+    X(H5F_FLUSHES) \
+    /* flag indicating whether MPI-IO is used for accessing this file */\
+    X(H5F_USE_MPIIO) \
     /* end of counters */\
-    X(HDF5_NUM_INDICES)
-#define HDF5_F_COUNTERS \
-    /* timestamp of first open */\
-    X(HDF5_F_OPEN_START_TIMESTAMP) \
-    /* timestamp of first close */\
-    X(HDF5_F_CLOSE_START_TIMESTAMP) \
-    /* timestamp of last open */\
-    X(HDF5_F_OPEN_END_TIMESTAMP) \
-    /* timestamp of last close */\
-    X(HDF5_F_CLOSE_END_TIMESTAMP) \
+    X(H5F_NUM_INDICES)
+#define H5F_F_COUNTERS \
+    /* timestamp of first file open */\
+    X(H5F_F_OPEN_START_TIMESTAMP) \
+    /* timestamp of first file close */\
+    X(H5F_F_CLOSE_START_TIMESTAMP) \
+    /* timestamp of last file open */\
+    X(H5F_F_OPEN_END_TIMESTAMP) \
+    /* timestamp of last file close */\
+    X(H5F_F_CLOSE_END_TIMESTAMP) \
+    /* cumulative H5F meta time */\
+    X(H5F_F_META_TIME) \
+    /* end of counters*/\
+    X(H5F_F_NUM_INDICES)
+#define H5D_COUNTERS \
+    /* count of HDF5 dataset opens/creates */\
+    X(H5D_OPENS) \
+    /* count of HDF5 datset reads */\
+    X(H5D_READS) \
+    /* count of HDF5 datset writes */\
+    X(H5D_WRITES) \
+    /* count of HDF5 dataset flushes */\
+    X(H5D_FLUSHES) \
+    /* total bytes read */\
+    X(H5D_BYTES_READ) \
+    /* total bytes written */\
+    X(H5D_BYTES_WRITTEN) \
+    /* number of times switching between H5D read and write */\
+    X(H5D_RW_SWITCHES) \
+    /* number of read/write ops with regular hyperslab selections */\
+    X(H5D_REGULAR_HYPERSLAB_SELECTS) \
+    /* number of read/write ops with irregular hyperslab selections */\
+    X(H5D_IRREGULAR_HYPERSLAB_SELECTS) \
+    /* number of read/write ops with point selections */\
+    X(H5D_POINT_SELECTS) \
+    /* sizes of the maximum read/write operations */\
+    X(H5D_MAX_READ_TIME_SIZE) \
+    X(H5D_MAX_WRITE_TIME_SIZE) \
+    /* buckets for H5D read size ranges */\
+    X(H5D_SIZE_READ_AGG_0_100) \
+    X(H5D_SIZE_READ_AGG_100_1K) \
+    X(H5D_SIZE_READ_AGG_1K_10K) \
+    X(H5D_SIZE_READ_AGG_10K_100K) \
+    X(H5D_SIZE_READ_AGG_100K_1M) \
+    X(H5D_SIZE_READ_AGG_1M_4M) \
+    X(H5D_SIZE_READ_AGG_4M_10M) \
+    X(H5D_SIZE_READ_AGG_10M_100M) \
+    X(H5D_SIZE_READ_AGG_100M_1G) \
+    X(H5D_SIZE_READ_AGG_1G_PLUS) \
+    /* buckets for H5D write size ranges */\
+    X(H5D_SIZE_WRITE_AGG_0_100) \
+    X(H5D_SIZE_WRITE_AGG_100_1K) \
+    X(H5D_SIZE_WRITE_AGG_1K_10K) \
+    X(H5D_SIZE_WRITE_AGG_10K_100K) \
+    X(H5D_SIZE_WRITE_AGG_100K_1M) \
+    X(H5D_SIZE_WRITE_AGG_1M_4M) \
+    X(H5D_SIZE_WRITE_AGG_4M_10M) \
+    X(H5D_SIZE_WRITE_AGG_10M_100M) \
+    X(H5D_SIZE_WRITE_AGG_100M_1G) \
+    X(H5D_SIZE_WRITE_AGG_1G_PLUS) \
+    /* the four most frequently appearing H5D access sizes */\
+    X(H5D_ACCESS1_ACCESS) \
+    X(H5D_ACCESS2_ACCESS) \
+    X(H5D_ACCESS3_ACCESS) \
+    X(H5D_ACCESS4_ACCESS) \
+    /* count of each of the most frequent H5D access sizes */\
+    X(H5D_ACCESS1_COUNT) \
+    X(H5D_ACCESS2_COUNT) \
+    X(H5D_ACCESS3_COUNT) \
+    X(H5D_ACCESS4_COUNT) \
+    /* number of dimensions in dataset's dataspace */\
+    X(H5D_DATASPACE_NDIMS) \
+    /* number of points in dataset's dataspace */\
+    X(H5D_DATASPACE_NPOINTS) \
+    /* size of dataset elements in bytes */\
+    X(H5D_DATATYPE_SIZE) \
+    /* flag indicating use of MPI-IO collectives */\
+    X(H5D_USE_MPIIO_COLLECTIVE) \
+    /* flag indicating whether deprecated create/open calls were used */\
+    X(H5D_USE_DEPRECATED) \
+    /* rank and number of bytes moved for fastest/slowest ranks */\
+    X(H5D_FASTEST_RANK) \
+    X(H5D_FASTEST_RANK_BYTES) \
+    X(H5D_SLOWEST_RANK) \
+    X(H5D_SLOWEST_RANK_BYTES) \
+    /* end of counters */\
+    X(H5D_NUM_INDICES)
+#define H5D_F_COUNTERS \
+    /* timestamp of first dataset open */\
+    X(H5D_F_OPEN_START_TIMESTAMP) \
+    /* timestamp of first dataset read */\
+    X(H5D_F_READ_START_TIMESTAMP) \
+    /* timestamp of first dataset write */\
+    X(H5D_F_WRITE_START_TIMESTAMP) \
+    /* timestamp of first dataset close */\
+    X(H5D_F_CLOSE_START_TIMESTAMP) \
+    /* timestamp of last dataset open */\
+    X(H5D_F_OPEN_END_TIMESTAMP) \
+    /* timestamp of last dataset read */\
+    X(H5D_F_READ_END_TIMESTAMP) \
+    /* timestamp of last dataset write */\
+    X(H5D_F_WRITE_END_TIMESTAMP) \
+    /* timestamp of last dataset close */\
+    X(H5D_F_CLOSE_END_TIMESTAMP) \
+    /* cumulative H5D read time */\
+    X(H5D_F_READ_TIME) \
+    /* cumulative H5D write time */\
+    X(H5D_F_WRITE_TIME) \
+    /* cumulative H5D meta time */\
+    X(H5D_F_META_TIME) \
+    /* maximum H5D read duration */\
+    X(H5D_F_MAX_READ_TIME) \
+    /* maximum H5D write duration */\
+    X(H5D_F_MAX_WRITE_TIME) \
+    /* total i/o and meta time for fastest/slowest ranks */\
+    X(H5D_F_FASTEST_RANK_TIME) \
+    X(H5D_F_SLOWEST_RANK_TIME) \
+    /* variance of total i/o time and bytes moved across all ranks */\
+    /* NOTE: for shared records only */\
+    X(H5D_F_VARIANCE_RANK_TIME) \
+    X(H5D_F_VARIANCE_RANK_BYTES) \
-    X(HDF5_F_NUM_INDICES)
+    X(H5D_F_NUM_INDICES)
 #define X(a) a,
 /* integer statistics for HDF5 file records */
-enum darshan_hdf5_indices
+enum darshan_h5f_indices
+    H5F_COUNTERS
+/* integer statistics for HDF5 dataset records */
+enum darshan_h5d_indices
-    HDF5_COUNTERS
+    H5D_COUNTERS
 /* floating point statistics for HDF5 file records */
-enum darshan_hdf5_f_indices
+enum darshan_h5f_f_indices
+    H5F_F_COUNTERS
+/* floating point statistics for HDF5 dataset records */
+enum darshan_h5d_f_indices
-    HDF5_F_COUNTERS
+    H5D_F_COUNTERS
 #undef X
-/* file record structure for HDF5 files. a record is created and stored for
+/* record structure for HDF5 files. a record is created and stored for
  * every HDF5 file opened by the original application. For the HDF5 module,
  * the record includes:
  *      - a darshan_base_record structure, which contains the record id & rank
  *      - integer file I/O statistics (open, read/write counts, etc)
- *      - floating point I/O statistics (timestamps, cumulative timers, etc.)
+ *      - floating point file I/O statistics (timestamps, cumulative timers, etc.)
 struct darshan_hdf5_file
     struct darshan_base_record base_rec;
-    int64_t counters[HDF5_NUM_INDICES];
-    double fcounters[HDF5_F_NUM_INDICES];
+    int64_t counters[H5F_NUM_INDICES];
+    double fcounters[H5F_F_NUM_INDICES];
+/* record structure for HDF5 datasets. a record is created and stored for
+ * every HDF5 dataset opened by the original application. For the HDF5 module,
+ * the record includes:
+ *      - a darshan_base_record structure, which contains the record id & rank
+ *      - integer dataset I/O statistics (open, read/write counts, etc)
+ *      - floating point dataset I/O statistics (timestamps, cumulative timers, etc.)
+struct darshan_hdf5_dataset
+    struct darshan_base_record base_rec;
+    int64_t counters[H5D_NUM_INDICES];
+    double fcounters[H5D_F_NUM_INDICES];
 #endif /* __DARSHAN_HDF5_LOG_FORMAT_H */
@@ -24,7 +24,7 @@
  * log format version, NOT when a new version of a module record is
  * introduced -- we have module-specific versions to handle that
-#define DARSHAN_LOG_VERSION "3.10"
+#define DARSHAN_LOG_VERSION "3.20"
 /* magic number for validating output files and checking byte order */
 #define DARSHAN_MAGIC_NR 6567223
@@ -131,11 +131,13 @@ struct darshan_base_record
  * component -- NULL can be passed if there are no
  * logutil definitions)
+/* XXX verify no back compat issues when adding HDF5 DATASETS in middle of this list */
 #define DARSHAN_MODULE_IDS \
     X(DARSHAN_NULL_MOD,     "NULL",     DARSHAN_NULL_VER,       NULL) \
     X(DARSHAN_POSIX_MOD,    "POSIX",    DARSHAN_POSIX_VER,      &posix_logutils) \
     X(DARSHAN_MPIIO_MOD,    "MPI-IO",   DARSHAN_MPIIO_VER,      &mpiio_logutils) \
-    X(DARSHAN_HDF5_MOD,     "HDF5",     DARSHAN_HDF5_VER,       &hdf5_logutils) \
+    X(DARSHAN_H5F_MOD,      "H5F",      DARSHAN_H5F_VER,        &hdf5_file_logutils) \
+    X(DARSHAN_H5D_MOD,      "H5D",      DARSHAN_H5D_VER,        &hdf5_dataset_logutils) \
     X(DARSHAN_PNETCDF_MOD,  "PNETCDF",  DARSHAN_PNETCDF_VER,    &pnetcdf_logutils) \
     X(DARSHAN_BGQ_MOD,      "BG/Q",     DARSHAN_BGQ_VER,        &bgq_logutils) \
     X(DARSHAN_LUSTRE_MOD,   "LUSTRE",   DARSHAN_LUSTRE_VER,     &lustre_logutils) \
@@ -24,28 +24,41 @@
 #include "darshan.h"
 #include "darshan-dynamic.h"
-/* hope this doesn't change any time soon */
-typedef int herr_t;     //hf5-1.10.0p1: H5public.h:126
-#ifdef __DARSHAN_ENABLE_HDF5110
-  typedef int64_t hid_t;  //hf5-1.10.0p1: H5Ipublic.h:56
-#else
-  typedef int hid_t;
-#endif
+#include <hdf5.h>
+/* H5F prototypes */
 DARSHAN_FORWARD_DECL(H5Fcreate, hid_t, (const char *filename, unsigned flags, hid_t create_plist, hid_t access_plist));
 DARSHAN_FORWARD_DECL(H5Fopen, hid_t, (const char *filename, unsigned flags, hid_t access_plist));
+DARSHAN_FORWARD_DECL(H5Fflush, herr_t, (hid_t object_id, H5F_scope_t scope));
 DARSHAN_FORWARD_DECL(H5Fclose, herr_t, (hid_t file_id));
-/* prototype for HDF symbols that we will call directly from within other
- * wrappers if HDF is linked in
-extern herr_t H5get_libversion(unsigned *majnum, unsigned *minnum, unsigned *relnum);
+/* H5D prototypes */
+DARSHAN_FORWARD_DECL(H5Dcreate1, hid_t, (hid_t loc_id, const char *name, hid_t type_id, hid_t space_id, hid_t dcpl_id));
+DARSHAN_FORWARD_DECL(H5Dcreate2, hid_t, (hid_t loc_id, const char *name, hid_t dtype_id, hid_t space_id, hid_t lcpl_id, hid_t dcpl_id, hid_t dapl_id));
+DARSHAN_FORWARD_DECL(H5Dopen1, hid_t, (hid_t loc_id, const char *name));
+DARSHAN_FORWARD_DECL(H5Dopen2, hid_t, (hid_t loc_id, const char *name, hid_t dapl_id));
+DARSHAN_FORWARD_DECL(H5Dread, herr_t, (hid_t dataset_id, hid_t mem_type_id, hid_t mem_space_id, hid_t file_space_id, hid_t xfer_plist_id, void * buf));
+DARSHAN_FORWARD_DECL(H5Dwrite, herr_t, (hid_t dataset_id, hid_t mem_type_id, hid_t mem_space_id, hid_t file_space_id, hid_t xfer_plist_id, const void * buf));
+DARSHAN_FORWARD_DECL(H5Dflush, herr_t, (hid_t dataset_id));
+DARSHAN_FORWARD_DECL(H5Dclose, herr_t, (hid_t dataset_id));
 /* structure that can track i/o stats for a given HDF5 file record at runtime */
 struct hdf5_file_record_ref
     struct darshan_hdf5_file* file_rec;
+    double last_meta_end;
+/* structure that can track i/o stats for a given HDF5 dataset record at runtime */
+struct hdf5_dataset_record_ref
+    struct darshan_hdf5_dataset* dataset_rec;
+    enum darshan_io_type last_io_type;
+    double last_read_end;
+    double last_write_end;
+    void *access_root;
+    int access_count;
 /* struct to encapsulate runtime state for the HDF5 module */
@@ -53,82 +66,106 @@ struct hdf5_runtime
     void *rec_id_hash;
     void *hid_hash;
-    int file_rec_count;
+    int rec_count;
-static void hdf5_runtime_initialize(
+static void hdf5_file_runtime_initialize(
+    void);
+static void hdf5_dataset_runtime_initialize(
     void);
 static struct hdf5_file_record_ref *hdf5_track_new_file_record(
-    darshan_record_id rec_id, const char *path);
-static void hdf5_cleanup_runtime(
+    darshan_record_id rec_id, const char *rec_name);
+static struct hdf5_dataset_record_ref *hdf5_track_new_dataset_record(
+static void hdf5_finalize_dataset_records(
+    void *rec_ref_p, void *user_ptr);
+static void hdf5_cleanup_file_runtime(
+    void);
+static void hdf5_cleanup_dataset_runtime(
     void);
 #ifdef HAVE_MPI
-static void hdf5_record_reduction_op(
-    void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
-static void hdf5_mpi_redux(
+static void hdf5_file_record_reduction_op(
+    void* inrec_v, void* inoutrec_v, int *len, MPI_Datatype *datatype);
+static void hdf5_dataset_record_reduction_op(
+static void hdf5_shared_dataset_record_variance(
+    MPI_Comm mod_comm, struct darshan_hdf5_dataset *inrec_array,
+    struct darshan_hdf5_dataset *outrec_array, int shared_rec_count);
+static void hdf5_file_mpi_redux(
+    void *hdf5_buf, MPI_Comm mod_comm,
+    darshan_record_id *shared_recs, int shared_rec_count);
+static void hdf5_dataset_mpi_redux(
 #endif
-static void hdf5_shutdown(
+static void hdf5_file_shutdown(
+    void **hdf5_buf, int *hdf5_buf_sz);
+static void hdf5_dataset_shutdown(
-static struct hdf5_runtime *hdf5_runtime = NULL;
+static struct hdf5_runtime *hdf5_file_runtime = NULL;
+static struct hdf5_runtime *hdf5_dataset_runtime = NULL;
 static pthread_mutex_t hdf5_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
 static int my_rank = -1;
 #define HDF5_LOCK() pthread_mutex_lock(&hdf5_runtime_mutex)
 #define HDF5_UNLOCK() pthread_mutex_unlock(&hdf5_runtime_mutex)
-#define HDF5_PRE_RECORD() do { \
+ *        Wrappers for H5F functions of interest         *
+#define H5F_PRE_RECORD() do { \
     HDF5_LOCK(); \
     if(!darshan_core_disabled_instrumentation()) { \
-        if(!hdf5_runtime) hdf5_runtime_initialize(); \
-        if(hdf5_runtime) break; \
+        if(!hdf5_file_runtime) hdf5_file_runtime_initialize(); \
+        if(hdf5_file_runtime) break; \
     HDF5_UNLOCK(); \
     return(ret); \
 } while(0)
-#define HDF5_POST_RECORD() do { \
+#define H5F_POST_RECORD() do { \
     HDF5_UNLOCK(); \
 } while(0)
-#define HDF5_RECORD_OPEN(__ret, __path, __tm1, __tm2) do { \
-    darshan_record_id rec_id; \
-    struct hdf5_file_record_ref *rec_ref; \
-    char *newpath; \
-    newpath = darshan_clean_file_path(__path); \
-    if(!newpath) newpath = (char *)__path; \
-    if(darshan_core_excluded_path(newpath)) { \
-        if(newpath != __path) free(newpath); \
+#define H5F_RECORD_OPEN(__ret, __path, __fapl, __tm1, __tm2) do { \
+    darshan_record_id __rec_id; \
+    struct hdf5_file_record_ref *__rec_ref; \
+    char *__newpath; \
+    __newpath = darshan_clean_file_path(__path); \
+    if(!__newpath) __newpath = (char *)__path; \
+    if(darshan_core_excluded_path(__newpath)) { \
+        if(__newpath != __path) free(__newpath); \
         break; \
-    rec_id = darshan_core_gen_record_id(newpath); \
-    rec_ref = darshan_lookup_record_ref(hdf5_runtime->rec_id_hash, &rec_id, sizeof(darshan_record_id)); \
-    if(!rec_ref) rec_ref = hdf5_track_new_file_record(rec_id, newpath); \
-    if(!rec_ref) { \
+    __rec_id = darshan_core_gen_record_id(__newpath); \
+    __rec_ref = darshan_lookup_record_ref(hdf5_file_runtime->rec_id_hash, &__rec_id, sizeof(darshan_record_id)); \
+    if(!__rec_ref) __rec_ref = hdf5_track_new_file_record(__rec_id, __newpath); \
+    if(!__rec_ref) { \
         break; \
-    if(rec_ref->file_rec->fcounters[HDF5_F_OPEN_START_TIMESTAMP] == 0 || \
-     rec_ref->file_rec->fcounters[HDF5_F_OPEN_START_TIMESTAMP] > __tm1) \
-        rec_ref->file_rec->fcounters[HDF5_F_OPEN_START_TIMESTAMP] = __tm1; \
-    rec_ref->file_rec->fcounters[HDF5_F_OPEN_END_TIMESTAMP] = __tm2; \
-    rec_ref->file_rec->counters[HDF5_OPENS] += 1; \
-    darshan_add_record_ref(&(hdf5_runtime->hid_hash), &__ret, sizeof(hid_t), rec_ref); \
+    if(H5Pget_fapl_mpio(__fapl, NULL, NULL) >= 0) \
+        __rec_ref->file_rec->counters[H5F_USE_MPIIO] = 1; \
+    __rec_ref->file_rec->counters[H5F_OPENS] += 1; \
+    if(__rec_ref->file_rec->fcounters[H5F_F_OPEN_START_TIMESTAMP] == 0 || \
+     __rec_ref->file_rec->fcounters[H5F_F_OPEN_START_TIMESTAMP] > __tm1) \
+        __rec_ref->file_rec->fcounters[H5F_F_OPEN_START_TIMESTAMP] = __tm1; \
+    __rec_ref->file_rec->fcounters[H5F_F_OPEN_END_TIMESTAMP] = __tm2; \
+    DARSHAN_TIMER_INC_NO_OVERLAP(__rec_ref->file_rec->fcounters[H5F_F_META_TIME], \
+        __tm1, __tm2, __rec_ref->last_meta_end); \
+    darshan_add_record_ref(&(hdf5_file_runtime->hid_hash), &__ret, sizeof(hid_t), __rec_ref); \
 } while(0)
- *        Wrappers for HDF5 functions of interest        *
 hid_t DARSHAN_DECL(H5Fcreate)(const char *filename, unsigned flags,
     hid_t ret;
     char* tmp;
     double tm1, tm2;
+#if 0
     unsigned majnum, minnum, relnum;
     H5get_libversion(&majnum, &minnum, &relnum);
@@ -146,6 +183,7 @@ hid_t DARSHAN_DECL(H5Fcreate)(const char *filename, unsigned flags,
         return(-1);
+#endif
     MAP_OR_FAIL(H5Fcreate);
@@ -164,9 +202,9 @@ hid_t DARSHAN_DECL(H5Fcreate)(const char *filename, unsigned flags,
             filename = tmp + 1;
-        HDF5_PRE_RECORD();
-        HDF5_RECORD_OPEN(ret, filename, tm1, tm2);
-        HDF5_POST_RECORD();
+        H5F_PRE_RECORD();
+        H5F_RECORD_OPEN(ret, filename, access_plist, tm1, tm2);
+        H5F_POST_RECORD();
     return(ret);
@@ -178,6 +216,7 @@ hid_t DARSHAN_DECL(H5Fopen)(const char *filename, unsigned flags,
     hid_t ret;
     char* tmp;
     double tm1, tm2;
+#if 0
@@ -195,6 +234,7 @@ hid_t DARSHAN_DECL(H5Fopen)(const char *filename, unsigned flags,
         return(-1);
+#endif
     MAP_OR_FAIL(H5Fopen);
@@ -213,15 +253,48 @@ hid_t DARSHAN_DECL(H5Fopen)(const char *filename, unsigned flags,
             filename = tmp + 1;
+        H5F_PRE_RECORD();
     return(ret);
+herr_t H5Fflush(hid_t object_id, H5F_scope_t scope)
+    struct hdf5_file_record_ref *rec_ref;
+    hid_t file_id;
+    double tm1, tm2;
+    herr_t ret;
+    MAP_OR_FAIL(H5Fflush);
+    tm1 = darshan_core_wtime();
+    ret = __real_H5Fflush(object_id, scope);
+    tm2 = darshan_core_wtime();
+    /* convert object_id to file_id so we can look it up */
+    file_id = H5Iget_file_id(object_id);
+    if(file_id > 0)
+        H5F_PRE_RECORD();
+        rec_ref = darshan_lookup_record_ref(hdf5_file_runtime->hid_hash,
+            &file_id, sizeof(hid_t));
+        if(rec_ref)
+            rec_ref->file_rec->counters[H5F_FLUSHES] += 1;
+                rec_ref->file_rec->fcounters[H5F_F_META_TIME],
+                tm1, tm2, rec_ref->last_meta_end);
+    return(ret);
 herr_t DARSHAN_DECL(H5Fclose)(hid_t file_id)
@@ -234,37 +307,434 @@ herr_t DARSHAN_DECL(H5Fclose)(hid_t file_id)
     ret = __real_H5Fclose(file_id);
-    rec_ref = darshan_lookup_record_ref(hdf5_runtime->hid_hash,
+    H5F_PRE_RECORD();
     if(rec_ref)
-        if(rec_ref->file_rec->fcounters[HDF5_F_CLOSE_START_TIMESTAMP] == 0 ||
-         rec_ref->file_rec->fcounters[HDF5_F_CLOSE_START_TIMESTAMP] > tm1)
-           rec_ref->file_rec->fcounters[HDF5_F_CLOSE_START_TIMESTAMP] = tm1;
-        rec_ref->file_rec->fcounters[HDF5_F_CLOSE_END_TIMESTAMP] = tm2;
-        darshan_delete_record_ref(&(hdf5_runtime->hid_hash),
+        if(rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] == 0 ||
+         rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] > tm1)
+           rec_ref->file_rec->fcounters[H5F_F_CLOSE_START_TIMESTAMP] = tm1;
+        rec_ref->file_rec->fcounters[H5F_F_CLOSE_END_TIMESTAMP] = tm2;
+        darshan_delete_record_ref(&(hdf5_file_runtime->hid_hash),
     return(ret);
+ *        Wrappers for H5D functions of interest         *
+#define DARSHAN_HDF5_MAX_NAME_LEN 256
+#define DARSHAN_HDF5_DATASET_DELIM ":"
+#define H5D_PRE_RECORD() do { \
+    HDF5_LOCK(); \
+    if(!darshan_core_disabled_instrumentation()) { \
+        if(!hdf5_dataset_runtime) hdf5_dataset_runtime_initialize(); \
+        if(hdf5_dataset_runtime) break; \
+    HDF5_UNLOCK(); \
+    return(ret); \
+} while(0)
+#define H5D_POST_RECORD() do { \
+    HDF5_UNLOCK(); \
+} while(0)
+#define H5D_RECORD_OPEN(__ret, __loc_id, __name, __type_id, __space_id, __use_depr,  __tm1, __tm2) do { \
+    char *__file_path, *__tmp_ptr; \
+    char __rec_name[DARSHAN_HDF5_MAX_NAME_LEN] = {0}; \
+    ssize_t __req_name_len = DARSHAN_HDF5_MAX_NAME_LEN-1, __ret_name_len; \
+    struct hdf5_dataset_record_ref *__rec_ref; \
+    /* get corresponding file name */\
+    __ret_name_len = H5Fget_name(__loc_id, __rec_name, __req_name_len); \
+    if(__ret_name_len < 0) break; \
+    else if(__ret_name_len < __req_name_len) { \
+        /* fully resolve file path */\
+        __file_path = darshan_clean_file_path(__rec_name); \
+        if(darshan_core_excluded_path(__file_path)) { \
+            free(__file_path); \
+            break; \
+        strncpy(__rec_name, __file_path, __req_name_len); \
+        if(strlen(__rec_name) + 2 <= __req_name_len) { \
+            /* append dataset name if we have space */\
+            __tmp_ptr = __rec_name + strlen(__rec_name); \
+            strcat(__tmp_ptr, DARSHAN_HDF5_DATASET_DELIM); \
+            __tmp_ptr += 1; \
+            __req_name_len = DARSHAN_HDF5_MAX_NAME_LEN - 1 - strlen(__rec_name); \
+            __ret_name_len = H5Iget_name(__loc_id, __tmp_ptr, __req_name_len); \
+            if(__ret_name_len < 0) return(ret); \
+                strncat(__tmp_ptr, __name, __req_name_len); \
+    __rec_id = darshan_core_gen_record_id(__rec_name); \
+    __rec_ref = darshan_lookup_record_ref(hdf5_dataset_runtime->rec_id_hash, &__rec_id, sizeof(darshan_record_id)); \
+    if(!__rec_ref) __rec_ref = hdf5_track_new_dataset_record(__rec_id, __rec_name); \
+    if(!__rec_ref) break; \
+    __rec_ref->dataset_rec->counters[H5D_OPENS] += 1; \
+    __rec_ref->dataset_rec->counters[H5D_USE_DEPRECATED] = __use_depr; \
+    if(__rec_ref->dataset_rec->fcounters[H5D_F_OPEN_START_TIMESTAMP] == 0 || \
+     __rec_ref->dataset_rec->fcounters[H5D_F_OPEN_START_TIMESTAMP] > __tm1) \
+        __rec_ref->dataset_rec->fcounters[H5D_F_OPEN_START_TIMESTAMP] = __tm1; \
+    __rec_ref->dataset_rec->fcounters[H5D_F_OPEN_END_TIMESTAMP] = __tm2; \
+    DARSHAN_TIMER_INC_NO_OVERLAP(__rec_ref->dataset_rec->fcounters[H5D_F_META_TIME], \
+    __rec_ref->dataset_rec->counters[H5D_DATASPACE_NDIMS] = H5Sget_simple_extent_ndims(__space_id); \
+    __rec_ref->dataset_rec->counters[H5D_DATASPACE_NPOINTS] = H5Sget_simple_extent_npoints(__space_id); \
+    __rec_ref->dataset_rec->counters[H5D_DATATYPE_SIZE] = H5Tget_size(__type_id); \
+    darshan_add_record_ref(&(hdf5_dataset_runtime->hid_hash), &__ret, sizeof(hid_t), __rec_ref); \
+} while(0)
+hid_t H5Dcreate1(hid_t loc_id, const char *name, hid_t type_id, hid_t space_id, hid_t dcpl_id)
+    double tm1, tm2;
+    hid_t ret;
+    MAP_OR_FAIL(H5Dcreate1);
+    ret = __real_H5Dcreate1(loc_id, name, type_id, space_id, dcpl_id);
+    H5D_PRE_RECORD();
+    H5D_RECORD_OPEN(ret, loc_id, name, type_id, space_id, 1, tm1, tm2);
+    H5D_POST_RECORD();
+    return(ret);
+hid_t H5Dcreate2(hid_t loc_id, const char *name, hid_t dtype_id, hid_t space_id,
+    hid_t lcpl_id, hid_t dcpl_id, hid_t dapl_id)
+    double tm1, tm2;
+    hid_t ret;
+    MAP_OR_FAIL(H5Dcreate2);
+    ret = __real_H5Dcreate2(loc_id, name, dtype_id, space_id, lcpl_id, dcpl_id, dapl_id);
+    H5D_PRE_RECORD();
+    H5D_RECORD_OPEN(ret, loc_id, name, dtype_id, space_id, 0, tm1, tm2);
+    return(ret);
+hid_t H5Dopen1(hid_t loc_id, const char *name)
+    hid_t dtype_id;
+    hid_t space_id;
+    double tm1, tm2;
+    hid_t ret;
+    MAP_OR_FAIL(H5Dopen1);
+    ret = __real_H5Dopen1(loc_id, name);
+    /* query dataset datatype, dataspace, and creation property list */
+    dtype_id = H5Dget_type(ret);
+    if(dtype_id < 0)
+        return(ret);
+    space_id = H5Dget_space(ret);
+    if(space_id < 0)
+        H5Tclose(dtype_id);
+        return(ret);
+    H5D_PRE_RECORD();
+    H5D_RECORD_OPEN(ret, loc_id, name, dtype_id, space_id, 1, tm1, tm2);
+    H5Sclose(space_id);
+    return(ret);
+hid_t H5Dopen2(hid_t loc_id, const char *name, hid_t dapl_id)
+    hid_t dtype_id;
+    hid_t space_id;
+    double tm1, tm2;
+    hid_t ret;
+    MAP_OR_FAIL(H5Dopen2);
+    ret = __real_H5Dopen2(loc_id, name, dapl_id);
+    if(dtype_id < 0)
+        return(ret);
+    if(space_id < 0)
+        return(ret);
+    H5D_PRE_RECORD();
+    return(ret);
+herr_t H5Dread(hid_t dataset_id, hid_t mem_type_id, hid_t mem_space_id,
+    hid_t file_space_id, hid_t xfer_plist_id, void * buf)
+    struct hdf5_dataset_record_ref *rec_ref;
+    size_t access_size;
+    size_t type_size;
+    ssize_t file_sel_npoints;
+    H5S_sel_type file_sel_type;
+    H5FD_mpio_xfer_t xfer_mode;
+    double tm1, tm2, elapsed;
+    herr_t ret;
+    herr_t tmp_ret;
+    MAP_OR_FAIL(H5Dread);
+    ret = __real_H5Dread(dataset_id, mem_type_id, mem_space_id, file_space_id,
+        xfer_plist_id, buf);
+    H5D_PRE_RECORD();
+    rec_ref = darshan_lookup_record_ref(hdf5_dataset_runtime->hid_hash,
+        &dataset_id, sizeof(hid_t));
+    if(rec_ref)
+        rec_ref->dataset_rec->counters[H5D_READS] += 1;
+        if(rec_ref->last_io_type == DARSHAN_IO_WRITE)
+            rec_ref->dataset_rec->counters[H5D_RW_SWITCHES] += 1;
+        rec_ref->last_io_type = DARSHAN_IO_READ;
+        if(file_space_id == H5S_ALL)
+            file_sel_npoints = rec_ref->dataset_rec->counters[H5D_DATASPACE_NPOINTS];
+            file_sel_type = H5S_SEL_ALL;
+        else
+            file_sel_npoints = H5Sget_select_npoints(file_space_id);
+            file_sel_type = H5Sget_select_type(file_space_id);
+        if(file_sel_type == H5S_SEL_POINTS)
+            rec_ref->dataset_rec->counters[H5D_POINT_SELECTS] += 1;
+        else if(file_sel_type == H5S_SEL_ALL)
+            rec_ref->dataset_rec->counters[H5D_REGULAR_HYPERSLAB_SELECTS] += 1;
+        else
+            if(H5Sis_regular_hyperslab(file_space_id))
+            else
+                rec_ref->dataset_rec->counters[H5D_IRREGULAR_HYPERSLAB_SELECTS] += 1;
+        type_size = rec_ref->dataset_rec->counters[H5D_DATATYPE_SIZE];
+        access_size = file_sel_npoints * type_size;
+        rec_ref->dataset_rec->counters[H5D_BYTES_READ] += access_size;
+        DARSHAN_BUCKET_INC(
+            &(rec_ref->dataset_rec->counters[H5D_SIZE_READ_AGG_0_100]), access_size);
+        darshan_common_val_counter(&rec_ref->access_root, &rec_ref->access_count, access_size,
+            &(rec_ref->dataset_rec->counters[H5D_ACCESS1_ACCESS]),
+            &(rec_ref->dataset_rec->counters[H5D_ACCESS1_COUNT]));
+        tmp_ret = H5Pget_dxpl_mpio(xfer_plist_id, &xfer_mode);
+        if(tmp_ret >= 0 && xfer_mode == H5FD_MPIO_COLLECTIVE)
+            rec_ref->dataset_rec->counters[H5D_USE_MPIIO_COLLECTIVE] = 1;
+        if(rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] == 0 ||
+         rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] > tm1)
+            rec_ref->dataset_rec->fcounters[H5D_F_READ_START_TIMESTAMP] = tm1;
+        rec_ref->dataset_rec->fcounters[H5D_F_READ_END_TIMESTAMP] = tm2;
+        elapsed = tm2 - tm1;
+        if(rec_ref->dataset_rec->fcounters[H5D_F_MAX_READ_TIME] < elapsed)
+            rec_ref->dataset_rec->fcounters[H5D_F_MAX_READ_TIME] = elapsed;
+            rec_ref->dataset_rec->counters[H5D_MAX_READ_TIME_SIZE] = access_size;
+            rec_ref->dataset_rec->fcounters[H5D_F_READ_TIME],
+            tm1, tm2, rec_ref->last_read_end);
+    return(ret);
+herr_t H5Dwrite(hid_t dataset_id, hid_t mem_type_id, hid_t mem_space_id,
+    hid_t file_space_id, hid_t xfer_plist_id, const void * buf)
+    size_t type_size;
+    herr_t ret;
+    herr_t tmp_ret;
+    MAP_OR_FAIL(H5Dwrite);
+    ret = __real_H5Dwrite(dataset_id, mem_type_id, mem_space_id, file_space_id,
+    H5D_PRE_RECORD();
+    if(rec_ref)
+        rec_ref->dataset_rec->counters[H5D_WRITES] += 1;
+        if(rec_ref->last_io_type == DARSHAN_IO_READ)
+        rec_ref->last_io_type = DARSHAN_IO_WRITE;
+        else
+        else
+            else
+        rec_ref->dataset_rec->counters[H5D_BYTES_WRITTEN] += access_size;
+            &(rec_ref->dataset_rec->counters[H5D_SIZE_WRITE_AGG_0_100]), access_size);
+        if(rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] == 0 ||
+         rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] > tm1)
+            rec_ref->dataset_rec->fcounters[H5D_F_WRITE_START_TIMESTAMP] = tm1;
+        rec_ref->dataset_rec->fcounters[H5D_F_WRITE_END_TIMESTAMP] = tm2;
+        if(rec_ref->dataset_rec->fcounters[H5D_F_MAX_WRITE_TIME] < elapsed)
+            rec_ref->dataset_rec->fcounters[H5D_F_MAX_WRITE_TIME] = elapsed;
+            rec_ref->dataset_rec->counters[H5D_MAX_WRITE_TIME_SIZE] = access_size;
+            rec_ref->dataset_rec->fcounters[H5D_F_WRITE_TIME],
+            tm1, tm2, rec_ref->last_write_end);
+    return(ret);
+herr_t H5Dflush(hid_t dataset_id)
+    double tm1, tm2;
+    herr_t ret;
+    MAP_OR_FAIL(H5Dflush);
+    ret = __real_H5Dflush(dataset_id);
+    H5D_PRE_RECORD();
+    if(rec_ref)
+        rec_ref->dataset_rec->counters[H5D_FLUSHES] += 1;
+            rec_ref->dataset_rec->fcounters[H5D_F_META_TIME],
+    return(ret);
+herr_t H5Dclose(hid_t dataset_id)
+    double tm1, tm2;
+    herr_t ret;
+    MAP_OR_FAIL(H5Dclose);
+    ret = __real_H5Dclose(dataset_id);
+    H5D_PRE_RECORD();
+    if(rec_ref)
+        if(rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] == 0 ||
+         rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] > tm1)
+           rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_START_TIMESTAMP] = tm1;
+        rec_ref->dataset_rec->fcounters[H5D_F_CLOSE_END_TIMESTAMP] = tm2;
+        DARSHAN_TIMER_INC_NO_OVERLAP(rec_ref->dataset_rec->fcounters[H5D_F_META_TIME],
+        darshan_delete_record_ref(&(hdf5_dataset_runtime->hid_hash), &dataset_id, sizeof(hid_t));
+    return(ret);
  * Internal functions for manipulating HDF5 module state *
 /* initialize internal HDF5 module data strucutres and register with darshan-core */
-static void hdf5_runtime_initialize()
+static void hdf5_file_runtime_initialize()
     int hdf5_buf_size;
     darshan_module_funcs mod_funcs = {
 #ifdef HAVE_MPI
-    .mod_redux_func = &hdf5_mpi_redux,
+    .mod_redux_func = &hdf5_file_mpi_redux,
 #endif
-    .mod_shutdown_func = &hdf5_shutdown
+    .mod_shutdown_func = &hdf5_file_shutdown
     /* try and store the default number of records for this module */
@@ -272,7 +742,7 @@ static void hdf5_runtime_initialize()
     /* register hdf5 module with darshan-core */
     darshan_core_register_module(
-        DARSHAN_HDF5_MOD,
+        DARSHAN_H5F_MOD,
         mod_funcs,
         &hdf5_buf_size,
         &my_rank,
@@ -281,17 +751,56 @@ static void hdf5_runtime_initialize()
     /* return if darshan-core does not provide enough module memory */
     if(hdf5_buf_size < sizeof(struct darshan_hdf5_file))
-        darshan_core_unregister_module(DARSHAN_HDF5_MOD);
+        darshan_core_unregister_module(DARSHAN_H5F_MOD);
+        return;
+    hdf5_file_runtime = malloc(sizeof(*hdf5_file_runtime));
+        return;
+    memset(hdf5_file_runtime, 0, sizeof(*hdf5_file_runtime));
+    return;
+static void hdf5_dataset_runtime_initialize()
+    int hdf5_buf_size;
+    darshan_module_funcs mod_funcs = {
+#ifdef HAVE_MPI
+    .mod_redux_func = &hdf5_dataset_mpi_redux,
+#endif
+    .mod_shutdown_func = &hdf5_dataset_shutdown
+    /* try and store the default number of records for this module */
+    hdf5_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_hdf5_dataset);
+    /* register hdf5 module with darshan-core */
+    darshan_core_register_module(
+        DARSHAN_H5D_MOD,
+        mod_funcs,
+        &hdf5_buf_size,
+        &my_rank,
+        NULL);
+    /* return if darshan-core does not provide enough module memory */
+    if(hdf5_buf_size < sizeof(struct darshan_hdf5_dataset))
+        darshan_core_unregister_module(DARSHAN_H5D_MOD);
         return;
-    hdf5_runtime = malloc(sizeof(*hdf5_runtime));
-    if(!hdf5_runtime)
+    hdf5_dataset_runtime = malloc(sizeof(*hdf5_dataset_runtime));
         return;
-    memset(hdf5_runtime, 0, sizeof(*hdf5_runtime));
+    memset(hdf5_dataset_runtime, 0, sizeof(*hdf5_dataset_runtime));
     return;
@@ -309,7 +818,7 @@ static struct hdf5_file_record_ref *hdf5_track_new_file_record(
     memset(rec_ref, 0, sizeof(*rec_ref));
     /* add a reference to this file record based on record id */
-    ret = darshan_add_record_ref(&(hdf5_runtime->rec_id_hash), &rec_id,
+    ret = darshan_add_record_ref(&(hdf5_file_runtime->rec_id_hash), &rec_id,
         sizeof(darshan_record_id), rec_ref);
     if(ret == 0)
@@ -323,88 +832,424 @@ static struct hdf5_file_record_ref *hdf5_track_new_file_record(
     file_rec = darshan_core_register_record(
         rec_id,
         path,
-        DARSHAN_HDF5_MOD,
+        DARSHAN_H5F_MOD,
         sizeof(struct darshan_hdf5_file),
         NULL);
     if(!file_rec)
-        darshan_delete_record_ref(&(hdf5_runtime->rec_id_hash),
+        darshan_delete_record_ref(&(hdf5_file_runtime->rec_id_hash),
         free(rec_ref);
         return(NULL);
-    /* registering this file record was successful, so initialize some fields */
+    /* registering this dataset record was successful, so initialize some fields */
     file_rec->base_rec.id = rec_id;
     file_rec->base_rec.rank = my_rank;
     rec_ref->file_rec = file_rec;
-    hdf5_runtime->file_rec_count++;
+    hdf5_file_runtime->rec_count++;
+    return(rec_ref);
+    darshan_record_id rec_id, const char *path)
+    struct darshan_hdf5_dataset *dataset_rec = NULL;
+    struct hdf5_dataset_record_ref *rec_ref = NULL;
+    int ret;
+    rec_ref = malloc(sizeof(*rec_ref));
+    if(!rec_ref)
+        return(NULL);
+    memset(rec_ref, 0, sizeof(*rec_ref));
+    /* add a reference to this dataset record based on record id */
+    ret = darshan_add_record_ref(&(hdf5_dataset_runtime->rec_id_hash), &rec_id,
+        sizeof(darshan_record_id), rec_ref);
+    if(ret == 0)
+        free(rec_ref);
+        return(NULL);
+    /* register the actual dataset record with darshan-core so it is persisted
+     * in the log file
+    dataset_rec = darshan_core_register_record(
+        rec_id,
+        path,
+        DARSHAN_H5D_MOD,
+        sizeof(struct darshan_hdf5_dataset),
+        NULL);
+    if(!dataset_rec)
+        darshan_delete_record_ref(&(hdf5_dataset_runtime->rec_id_hash),
+            &rec_id, sizeof(darshan_record_id));
+        free(rec_ref);
+        return(NULL);
+    dataset_rec->base_rec.id = rec_id;
+    dataset_rec->base_rec.rank = my_rank;
+    rec_ref->dataset_rec = dataset_rec;
+    hdf5_dataset_runtime->rec_count++;
     return(rec_ref);
-static void hdf5_cleanup_runtime()
+static void hdf5_finalize_dataset_records(void *rec_ref_p, void *user_ptr)
-    darshan_clear_record_refs(&(hdf5_runtime->hid_hash), 0);
-    darshan_clear_record_refs(&(hdf5_runtime->rec_id_hash), 1);
+        (struct hdf5_dataset_record_ref *)rec_ref_p;
-    free(hdf5_runtime);
-    hdf5_runtime = NULL;
+    tdestroy(rec_ref->access_root, free);
+    return;
+static void hdf5_cleanup_file_runtime()
+    darshan_clear_record_refs(&(hdf5_file_runtime->hid_hash), 0);
+    darshan_clear_record_refs(&(hdf5_file_runtime->rec_id_hash), 1);
+    free(hdf5_file_runtime);
+    hdf5_file_runtime = NULL;
+    return;
+static void hdf5_cleanup_dataset_runtime()
+    darshan_clear_record_refs(&(hdf5_dataset_runtime->hid_hash), 0);
+    darshan_clear_record_refs(&(hdf5_dataset_runtime->rec_id_hash), 1);
+    free(hdf5_dataset_runtime);
+    hdf5_dataset_runtime = NULL;
     return;
 #ifdef HAVE_MPI
-static void hdf5_record_reduction_op(void* infile_v, void* inoutfile_v,
+static void hdf5_file_record_reduction_op(void* inrec_v, void* inoutrec_v,
     struct darshan_hdf5_file tmp_file;
-    struct darshan_hdf5_file *infile = infile_v;
-    struct darshan_hdf5_file *inoutfile = inoutfile_v;
+    struct darshan_hdf5_file *inrec = inrec_v;
+    struct darshan_hdf5_file *inoutrec = inoutrec_v;
     int i, j;
-    assert(hdf5_runtime);
     for(i=0; i<*len; i++)
         memset(&tmp_file, 0, sizeof(struct darshan_hdf5_file));
-        tmp_file.base_rec.id = infile->base_rec.id;
+        tmp_file.base_rec.id = inrec->base_rec.id;
         tmp_file.base_rec.rank = -1;
         /* sum */
-        for(j=HDF5_OPENS; j<=HDF5_OPENS; j++)
+        for(j=H5F_OPENS; j<=H5F_FLUSHES; j++)
-            tmp_file.counters[j] = infile->counters[j] + inoutfile->counters[j];
+            tmp_file.counters[j] = inrec->counters[j] + inoutrec->counters[j];
+        if(inoutrec->counters[H5F_USE_MPIIO] == 1 || inrec->counters[H5F_USE_MPIIO] == 1)
+            tmp_file.counters[H5F_USE_MPIIO] = 1;
         /* min non-zero (if available) value */
-        for(j=HDF5_F_OPEN_START_TIMESTAMP; j<=HDF5_F_CLOSE_START_TIMESTAMP; j++)
+        for(j=H5F_F_OPEN_START_TIMESTAMP; j<=H5F_F_CLOSE_START_TIMESTAMP; j++)
-            if((infile->fcounters[j] < inoutfile->fcounters[j] &&
-               infile->fcounters[j] > 0) || inoutfile->fcounters[j] == 0)
-                tmp_file.fcounters[j] = infile->fcounters[j];
+            if((inrec->fcounters[j] < inoutrec->fcounters[j] &&
+               inrec->fcounters[j] > 0) || inoutrec->fcounters[j] == 0)
+                tmp_file.fcounters[j] = inrec->fcounters[j];
             else
-                tmp_file.fcounters[j] = inoutfile->fcounters[j];
+                tmp_file.fcounters[j] = inoutrec->fcounters[j];
         /* max */
-        for(j=HDF5_F_OPEN_END_TIMESTAMP; j<=HDF5_F_CLOSE_END_TIMESTAMP; j++)
+        for(j=H5F_F_OPEN_END_TIMESTAMP; j<=H5F_F_CLOSE_END_TIMESTAMP; j++)
-            if(infile->fcounters[j] > inoutfile->fcounters[j])
+            if(inrec->fcounters[j] > inoutrec->fcounters[j])
             else
+        /* sum */
+        tmp_file.fcounters[H5F_F_META_TIME] =
+            inrec->fcounters[H5F_F_META_TIME] + inoutrec->fcounters[H5F_F_META_TIME];
         /* update pointers */
-        *inoutfile = tmp_file;
-        inoutfile++;
-        infile++;
+        *inoutrec = tmp_file;
+        inoutrec++;
+        inrec++;
     return;
+static void hdf5_dataset_record_reduction_op(void* inrec_v, void* inoutrec_v,
+    int *len, MPI_Datatype *datatype)
+    struct darshan_hdf5_dataset tmp_dataset;
+    struct darshan_hdf5_dataset *inrec = inrec_v;
+    struct darshan_hdf5_dataset *inoutrec = inoutrec_v;
+    int i, j, k;
+    for(i=0; i<*len; i++)
+        memset(&tmp_dataset, 0, sizeof(struct darshan_hdf5_dataset));
+        tmp_dataset.base_rec.id = inrec->base_rec.id;
+        tmp_dataset.base_rec.rank = -1;
+        /* sum */
+        for(j=H5D_OPENS; j<=H5D_POINT_SELECTS; j++)
+            tmp_dataset.counters[j] = inrec->counters[j] + inoutrec->counters[j];
+        /* skip H5D_MAX_*_TIME_SIZE; handled in floating point section */
+        for(j=H5D_SIZE_READ_AGG_0_100; j<=H5D_SIZE_WRITE_AGG_1G_PLUS; j++)
+        /* first collapse any duplicates */
+        for(j=H5D_ACCESS1_ACCESS; j<=H5D_ACCESS4_ACCESS; j++)
+            for(k=H5D_ACCESS1_ACCESS; k<=H5D_ACCESS4_ACCESS; k++)
+                if(inrec->counters[j] == inoutrec->counters[k])
+                    inrec->counters[j+4] += inoutrec->counters[k+4];
+                    inoutrec->counters[k] = 0;
+                    inoutrec->counters[k+4] = 0;
+        /* first set */
+            DARSHAN_COMMON_VAL_COUNTER_INC(&(tmp_dataset.counters[H5D_ACCESS1_ACCESS]),
+                &(tmp_dataset.counters[H5D_ACCESS1_COUNT]), inrec->counters[j],
+                inrec->counters[j+4], 0);
+        /* second set */
+                &(tmp_dataset.counters[H5D_ACCESS1_COUNT]), inoutrec->counters[j],
+                inoutrec->counters[j+4], 0);
+        tmp_dataset.counters[H5D_DATASPACE_NDIMS] = inrec->counters[H5D_DATASPACE_NDIMS];
+        tmp_dataset.counters[H5D_DATASPACE_NPOINTS] = inrec->counters[H5D_DATASPACE_NPOINTS];
+        tmp_dataset.counters[H5D_DATATYPE_SIZE] = inrec->counters[H5D_DATATYPE_SIZE];
+        if(inoutrec->counters[H5D_USE_MPIIO_COLLECTIVE] == 1 ||
+                inrec->counters[H5D_USE_MPIIO_COLLECTIVE] == 1)
+            tmp_dataset.counters[H5D_USE_MPIIO_COLLECTIVE] = 1;
+        if(inoutrec->counters[H5D_USE_DEPRECATED] == 1 ||
+                inrec->counters[H5D_USE_DEPRECATED] == 1)
+            tmp_dataset.counters[H5D_USE_DEPRECATED] = 1;
+        /* min non-zero (if available) value */
+        for(j=H5D_F_OPEN_START_TIMESTAMP; j<=H5D_F_CLOSE_START_TIMESTAMP; j++)
+                tmp_dataset.fcounters[j] = inrec->fcounters[j];
+            else
+                tmp_dataset.fcounters[j] = inoutrec->fcounters[j];
+        /* max */
+        for(j=H5D_F_OPEN_END_TIMESTAMP; j<=H5D_F_CLOSE_END_TIMESTAMP; j++)
+            else
+        /* sum */
+        for(j=H5D_F_READ_TIME; j<=H5D_F_META_TIME; j++)
+            tmp_dataset.fcounters[j] = inrec->fcounters[j] + inoutrec->fcounters[j];
+        /* max (special case) */
+        if(inrec->fcounters[H5D_F_MAX_READ_TIME] >
+            inoutrec->fcounters[H5D_F_MAX_READ_TIME])
+            tmp_dataset.fcounters[H5D_F_MAX_READ_TIME] =
+                inrec->fcounters[H5D_F_MAX_READ_TIME];
+            tmp_dataset.counters[H5D_MAX_READ_TIME_SIZE] =
+                inrec->counters[H5D_MAX_READ_TIME_SIZE];
+        else
+                inoutrec->fcounters[H5D_F_MAX_READ_TIME];
+                inoutrec->counters[H5D_MAX_READ_TIME_SIZE];
+        if(inrec->fcounters[H5D_F_MAX_WRITE_TIME] >
+            inoutrec->fcounters[H5D_F_MAX_WRITE_TIME])
+            tmp_dataset.fcounters[H5D_F_MAX_WRITE_TIME] =
+                inrec->fcounters[H5D_F_MAX_WRITE_TIME];
+            tmp_dataset.counters[H5D_MAX_WRITE_TIME_SIZE] =
+                inrec->counters[H5D_MAX_WRITE_TIME_SIZE];
+        else
+                inoutrec->fcounters[H5D_F_MAX_WRITE_TIME];
+                inoutrec->counters[H5D_MAX_WRITE_TIME_SIZE];
+        /* min (zeroes are ok here; some procs don't do I/O) */
+        if(inrec->fcounters[H5D_F_FASTEST_RANK_TIME] <
+            inoutrec->fcounters[H5D_F_FASTEST_RANK_TIME])
+            tmp_dataset.counters[H5D_FASTEST_RANK] =
+                inrec->counters[H5D_FASTEST_RANK];
+            tmp_dataset.counters[H5D_FASTEST_RANK_BYTES] =
+                inrec->counters[H5D_FASTEST_RANK_BYTES];
+            tmp_dataset.fcounters[H5D_F_FASTEST_RANK_TIME] =
+                inrec->fcounters[H5D_F_FASTEST_RANK_TIME];
+        else
+                inoutrec->counters[H5D_FASTEST_RANK];
+                inoutrec->counters[H5D_FASTEST_RANK_BYTES];
+                inoutrec->fcounters[H5D_F_FASTEST_RANK_TIME];
+        /* max */
+        if(inrec->fcounters[H5D_F_SLOWEST_RANK_TIME] >
+           inoutrec->fcounters[H5D_F_SLOWEST_RANK_TIME])
+            tmp_dataset.counters[H5D_SLOWEST_RANK] =
+                inrec->counters[H5D_SLOWEST_RANK];
+            tmp_dataset.counters[H5D_SLOWEST_RANK_BYTES] =
+                inrec->counters[H5D_SLOWEST_RANK_BYTES];
+            tmp_dataset.fcounters[H5D_F_SLOWEST_RANK_TIME] =
+                inrec->fcounters[H5D_F_SLOWEST_RANK_TIME];
+        else
+                inoutrec->counters[H5D_SLOWEST_RANK];
+                inoutrec->counters[H5D_SLOWEST_RANK_BYTES];
+                inoutrec->fcounters[H5D_F_SLOWEST_RANK_TIME];
+        /* update pointers */
+        *inoutrec = tmp_dataset;
+        inoutrec++;
+        inrec++;
+    return;
+    MPI_Datatype var_dt;
+    MPI_Op var_op;
+    int i;
+    struct darshan_variance_dt *var_send_buf = NULL;
+    struct darshan_variance_dt *var_recv_buf = NULL;
+    PMPI_Type_contiguous(sizeof(struct darshan_variance_dt),
+        MPI_BYTE, &var_dt);
+    PMPI_Type_commit(&var_dt);
+    PMPI_Op_create(darshan_variance_reduce, 1, &var_op);
+    var_send_buf = malloc(shared_rec_count * sizeof(struct darshan_variance_dt));
+    if(!var_send_buf)
+        return;
+    if(my_rank == 0)
+        var_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_variance_dt));
+        if(!var_recv_buf)
+            return;
+    /* get total i/o time variances for shared records */
+    for(i=0; i<shared_rec_count; i++)
+        var_send_buf[i].n = 1;
+        var_send_buf[i].S = 0;
+        var_send_buf[i].T = inrec_array[i].fcounters[H5D_F_READ_TIME] +
+                            inrec_array[i].fcounters[H5D_F_WRITE_TIME] +
+                            inrec_array[i].fcounters[H5D_F_META_TIME];
+    PMPI_Reduce(var_send_buf, var_recv_buf, shared_rec_count,
+        var_dt, var_op, 0, mod_comm);
+    if(my_rank == 0)
+            outrec_array[i].fcounters[H5D_F_VARIANCE_RANK_TIME] =
+                (var_recv_buf[i].S / var_recv_buf[i].n);
+    /* get total bytes moved variances for shared records */
+        var_send_buf[i].T = (double)
+                            inrec_array[i].counters[H5D_BYTES_READ] +
+                            inrec_array[i].counters[H5D_BYTES_WRITTEN];
+    if(my_rank == 0)
+            outrec_array[i].fcounters[H5D_F_VARIANCE_RANK_BYTES] =
+    PMPI_Type_free(&var_dt);
+    PMPI_Op_free(&var_op);
+    free(var_send_buf);
+    free(var_recv_buf);
+    return;
 #endif
@@ -412,13 +1257,13 @@ static void hdf5_record_reduction_op(void* infile_v, void* inoutfile_v,
 #ifdef HAVE_MPI
     void *hdf5_buf,
     MPI_Comm mod_comm,
-    int hdf5_rec_count;
+    int rec_count;
     struct darshan_hdf5_file *hdf5_rec_buf = (struct darshan_hdf5_file *)hdf5_buf;
     struct darshan_hdf5_file *red_send_buf = NULL;
@@ -428,14 +1273,14 @@ static void hdf5_mpi_redux(
     int i;
     HDF5_LOCK();
+    assert(hdf5_file_runtime);
-    hdf5_rec_count = hdf5_runtime->file_rec_count;
+    rec_count = hdf5_file_runtime->rec_count;
     /* necessary initialization of shared records */
     for(i = 0; i < shared_rec_count; i++)
+        rec_ref = darshan_lookup_record_ref(hdf5_file_runtime->rec_id_hash,
             &shared_recs[i], sizeof(darshan_record_id));
         assert(rec_ref);
@@ -445,11 +1290,11 @@ static void hdf5_mpi_redux(
     /* sort the array of records so we get all of the shared records
      * (marked by rank -1) in a contiguous portion at end of the array
-    darshan_record_sort(hdf5_rec_buf, hdf5_rec_count,
+    darshan_record_sort(hdf5_rec_buf, rec_count,
-    /* make *send_buf point to the shared files at the end of sorted array */
-    red_send_buf = &(hdf5_rec_buf[hdf5_rec_count-shared_rec_count]);
+    /* make *send_buf point to the shared records at the end of sorted array */
+    red_send_buf = &(hdf5_rec_buf[rec_count-shared_rec_count]);
     /* allocate memory for the reduction output on rank 0 */
     if(my_rank == 0)
@@ -462,31 +1307,143 @@ static void hdf5_mpi_redux(
-    /* construct a datatype for a HDF5 file record.  This is serving no purpose
+    /* construct a datatype for a HDF5 dataset record.  This is serving no purpose
      * except to make sure we can do a reduction on proper boundaries
-    PMPI_Type_contiguous(sizeof(struct darshan_hdf5_file),
-        MPI_BYTE, &red_type);
+    PMPI_Type_contiguous(sizeof(struct darshan_hdf5_file), MPI_BYTE, &red_type);
     PMPI_Type_commit(&red_type);
-    /* register a HDF5 file record reduction operator */
-    PMPI_Op_create(hdf5_record_reduction_op, 1, &red_op);
+    /* register a HDF5 dataset record reduction operator */
+    PMPI_Op_create(hdf5_file_record_reduction_op, 1, &red_op);
-    /* reduce shared HDF5 file records */
+    /* reduce shared HDF5 dataset records */
     PMPI_Reduce(red_send_buf, red_recv_buf,
         shared_rec_count, red_type, red_op, 0, mod_comm);
     /* clean up reduction state */
     if(my_rank == 0)
-        int tmp_ndx = hdf5_rec_count - shared_rec_count;
+        int tmp_ndx = rec_count - shared_rec_count;
         memcpy(&(hdf5_rec_buf[tmp_ndx]), red_recv_buf,
             shared_rec_count * sizeof(struct darshan_hdf5_file));
         free(red_recv_buf);
     else
-        hdf5_runtime->file_rec_count -= shared_rec_count;
+        hdf5_file_runtime->rec_count -= shared_rec_count;
+    PMPI_Type_free(&red_type);
+    PMPI_Op_free(&red_op);
+    HDF5_UNLOCK();
+    return;
+    void *hdf5_buf,
+    int shared_rec_count)
+    int rec_count;
+    struct darshan_hdf5_dataset *hdf5_rec_buf = (struct darshan_hdf5_dataset *)hdf5_buf;
+    double hdf5_time;
+    struct darshan_hdf5_dataset *red_send_buf = NULL;
+    struct darshan_hdf5_dataset *red_recv_buf = NULL;
+    MPI_Datatype red_type;
+    MPI_Op red_op;
+    int i;
+    HDF5_LOCK();
+    assert(hdf5_dataset_runtime);
+    rec_count = hdf5_dataset_runtime->rec_count;
+    /* necessary initialization of shared records */
+    for(i = 0; i < shared_rec_count; i++)
+        rec_ref = darshan_lookup_record_ref(hdf5_dataset_runtime->rec_id_hash,
+            &shared_recs[i], sizeof(darshan_record_id));
+        assert(rec_ref);
+        hdf5_time =
+            rec_ref->dataset_rec->fcounters[H5D_F_READ_TIME] +
+            rec_ref->dataset_rec->fcounters[H5D_F_WRITE_TIME] +
+            rec_ref->dataset_rec->fcounters[H5D_F_META_TIME];
+        /* until reduction occurs, we assume that this rank is both
+         * the fastest and slowest. It is up to the reduction operator
+         * to find the true min and max.
+        rec_ref->dataset_rec->counters[H5D_FASTEST_RANK] =
+            rec_ref->dataset_rec->base_rec.rank;
+        rec_ref->dataset_rec->counters[H5D_FASTEST_RANK_BYTES] =
+            rec_ref->dataset_rec->counters[H5D_BYTES_WRITTEN];
+        rec_ref->dataset_rec->fcounters[H5D_F_FASTEST_RANK_TIME] =
+            hdf5_time;
+        rec_ref->dataset_rec->counters[H5D_SLOWEST_RANK] =
+            rec_ref->dataset_rec->counters[H5D_FASTEST_RANK];
+        rec_ref->dataset_rec->counters[H5D_SLOWEST_RANK_BYTES] =
+            rec_ref->dataset_rec->counters[H5D_FASTEST_RANK_BYTES];
+        rec_ref->dataset_rec->fcounters[H5D_F_SLOWEST_RANK_TIME] =
+            rec_ref->dataset_rec->fcounters[H5D_F_FASTEST_RANK_TIME];
+        rec_ref->dataset_rec->base_rec.rank = -1;
+    /* sort the array of records so we get all of the shared records
+     * (marked by rank -1) in a contiguous portion at end of the array
+        sizeof(struct darshan_hdf5_dataset));
+    /* allocate memory for the reduction output on rank 0 */
+    if(my_rank == 0)
+        red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_hdf5_dataset));
+        if(!red_recv_buf)
+            HDF5_UNLOCK();
+            return;
+     * except to make sure we can do a reduction on proper boundaries
+    PMPI_Type_contiguous(sizeof(struct darshan_hdf5_dataset),
+        MPI_BYTE, &red_type);
+    PMPI_Type_commit(&red_type);
+    PMPI_Op_create(hdf5_dataset_record_reduction_op, 1, &red_op);
+    PMPI_Reduce(red_send_buf, red_recv_buf,
+        shared_rec_count, red_type, red_op, 0, mod_comm);
+    /* get the time and byte variances for shared files */
+    hdf5_shared_dataset_record_variance(mod_comm, red_send_buf, red_recv_buf,
+        shared_rec_count);
+    /* clean up reduction state */
+    if(my_rank == 0)
+        memcpy(&(hdf5_rec_buf[tmp_ndx]), red_recv_buf,
+            shared_rec_count * sizeof(struct darshan_hdf5_dataset));
+        free(red_recv_buf);
+    else
+        hdf5_dataset_runtime->rec_count -= shared_rec_count;
@@ -497,22 +1454,49 @@ static void hdf5_mpi_redux(
 #endif
+    void **hdf5_buf,
+    int *hdf5_buf_sz)
+    int rec_count;
+    HDF5_LOCK();
+    /* shutdown internal structures used for instrumenting */
+    hdf5_cleanup_file_runtime();
+    /* update output buffer size to account for shared dataset reduction */
+    *hdf5_buf_sz = rec_count * sizeof(struct darshan_hdf5_file);
+    HDF5_UNLOCK();
+    return;
     void **hdf5_buf,
     int *hdf5_buf_sz)
+    int rec_count;
     HDF5_LOCK();
+    /* perform any final transformations on MPIIO file records before
+     * writing them out to log file
+    darshan_iter_record_refs(hdf5_dataset_runtime->rec_id_hash,
+        &hdf5_finalize_dataset_records, NULL);
-    hdf5_cleanup_runtime();
+    hdf5_cleanup_dataset_runtime();
-    /* update output buffer size to account for shared file reduction */
-    *hdf5_buf_sz = hdf5_rec_count * sizeof(struct darshan_hdf5_file);
+    *hdf5_buf_sz = rec_count * sizeof(struct darshan_hdf5_dataset);
     HDF5_UNLOCK();
     return;
@@ -1,4 +1,13 @@
 --undefined=__wrap_H5Fcreate
 --wrap=H5Fcreate
 --wrap=H5Fopen
+--wrap=H5Fflush
 --wrap=H5Fclose
+--wrap=H5Dcreate1
+--wrap=H5Dcreate2
+--wrap=H5Dopen1
+--wrap=H5Dopen2
+--wrap=H5Dread
+--wrap=H5Dwrite
+--wrap=H5Dflush
+--wrap=H5Dclose
@@ -88,7 +88,7 @@ int process_log(const char *fname, double *io_ratio, int *used_mpio, int *used_p
     if (file->mod_map[DARSHAN_MPIIO_MOD].len > 0)
         *used_mpio += 1;
-    if (file->mod_map[DARSHAN_HDF5_MOD].len > 0)
+    if (file->mod_map[DARSHAN_H5F_MOD].len > 0 || file->mod_map[DARSHAN_H5D_MOD].len > 0)
         *used_hdf5 += 1;
     if (file->mod_map[DARSHAN_PNETCDF_MOD].len > 0)
         *used_pnet += 1;
@@ -21,36 +21,61 @@
 /* counter name strings for the HDF5 module */
 #define X(a) #a,
-char *hdf5_counter_names[] = {
-    HDF5_COUNTERS
+char *h5f_counter_names[] = {
+    H5F_COUNTERS
+char *h5f_f_counter_names[] = {
+    H5F_F_COUNTERS
-char *hdf5_f_counter_names[] = {
-    HDF5_F_COUNTERS
+char *h5d_counter_names[] = {
+    H5D_COUNTERS
+char *h5d_f_counter_names[] = {
+    H5D_F_COUNTERS
 #undef X
-#define DARSHAN_HDF5_FILE_SIZE_1 40
+#define DARSHAN_H5F_FILE_SIZE_1 40
 static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p);
 static int darshan_log_put_hdf5_file(darshan_fd fd, void* hdf5_buf);
-static void darshan_log_print_hdf5_file(void *file_rec,
-    char *file_name, char *mnt_pt, char *fs_type);
-static void darshan_log_print_hdf5_description(int ver);
-static void darshan_log_print_hdf5_file_diff(void *file_rec1, char *file_name1,
-    void *file_rec2, char *file_name2);
+static void darshan_log_print_hdf5_file(void *ds_rec,
+    char *ds_name, char *mnt_pt, char *fs_type);
+static void darshan_log_print_hdf5_file_description(int ver);
+static void darshan_log_print_hdf5_file_diff(void *ds_rec1, char *ds_name1,
+    void *ds_rec2, char *ds_name2);
 static void darshan_log_agg_hdf5_files(void *rec, void *agg_rec, int init_flag);
-struct darshan_mod_logutil_funcs hdf5_logutils =
+static int darshan_log_get_hdf5_dataset(darshan_fd fd, void** hdf5_buf_p);
+static int darshan_log_put_hdf5_dataset(darshan_fd fd, void* hdf5_buf);
+static void darshan_log_print_hdf5_dataset(void *ds_rec,
+static void darshan_log_print_hdf5_dataset_description(int ver);
+static void darshan_log_print_hdf5_dataset_diff(void *ds_rec1, char *ds_name1,
+static void darshan_log_agg_hdf5_datasets(void *rec, void *agg_rec, int init_flag);
+struct darshan_mod_logutil_funcs hdf5_file_logutils =
     .log_get_record = &darshan_log_get_hdf5_file,
     .log_put_record = &darshan_log_put_hdf5_file,
     .log_print_record = &darshan_log_print_hdf5_file,
-    .log_print_description = &darshan_log_print_hdf5_description,
+    .log_print_description = &darshan_log_print_hdf5_file_description,
     .log_print_diff = &darshan_log_print_hdf5_file_diff,
     .log_agg_records = &darshan_log_agg_hdf5_files
+struct darshan_mod_logutil_funcs hdf5_dataset_logutils =
+    .log_get_record = &darshan_log_get_hdf5_dataset,
+    .log_put_record = &darshan_log_put_hdf5_dataset,
+    .log_print_record = &darshan_log_print_hdf5_dataset,
+    .log_print_description = &darshan_log_print_hdf5_dataset_description,
+    .log_print_diff = &darshan_log_print_hdf5_dataset_diff,
+    .log_agg_records = &darshan_log_agg_hdf5_datasets
     struct darshan_hdf5_file *file = *((struct darshan_hdf5_file **)hdf5_buf_p);
@@ -58,7 +83,7 @@ static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p)
     int i;
     int ret;
-    if(fd->mod_map[DARSHAN_HDF5_MOD].len == 0)
+    if(fd->mod_map[DARSHAN_H5F_MOD].len == 0)
         return(0);
     if(*hdf5_buf_p == NULL)
@@ -68,13 +93,13 @@ static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p)
             return(-1);
-    if(fd->mod_ver[DARSHAN_HDF5_MOD] == DARSHAN_HDF5_VER)
+    if(fd->mod_ver[DARSHAN_H5F_MOD] == DARSHAN_H5F_VER)
         /* log format is in current version, so we don't need to do any
          * translation of counters while reading
         rec_len = sizeof(struct darshan_hdf5_file);
-        ret = darshan_log_get_mod(fd, DARSHAN_HDF5_MOD, file, rec_len);
+        ret = darshan_log_get_mod(fd, DARSHAN_H5F_MOD, file, rec_len);
     else
@@ -82,8 +107,8 @@ static int darshan_log_get_hdf5_file(darshan_fd fd, void** hdf5_buf_p)
         char *src_p, *dest_p;
         int len;
-        rec_len = DARSHAN_HDF5_FILE_SIZE_1;
-        ret = darshan_log_get_mod(fd, DARSHAN_HDF5_MOD, scratch, rec_len);
+        rec_len = DARSHAN_H5F_FILE_SIZE_1;
+        ret = darshan_log_get_mod(fd, DARSHAN_H5F_MOD, scratch, rec_len);
         if(ret != rec_len)
             goto exit;
@@ -120,16 +145,16 @@ exit:
             DARSHAN_BSWAP64(&(file->base_rec.id));
             DARSHAN_BSWAP64(&(file->base_rec.rank));
-            for(i=0; i<HDF5_NUM_INDICES; i++)
+            for(i=0; i<H5F_NUM_INDICES; i++)
                 DARSHAN_BSWAP64(&file->counters[i]);
-            for(i=0; i<HDF5_F_NUM_INDICES; i++)
+            for(i=0; i<H5F_F_NUM_INDICES; i++)
                 /* skip counters we explicitly set to -1 since they don't
                  * need to be byte swapped
-                if((fd->mod_ver[DARSHAN_HDF5_MOD] == 1) &&
-                    ((i == HDF5_F_CLOSE_START_TIMESTAMP) ||
-                     (i == HDF5_F_OPEN_END_TIMESTAMP)))
+                if((fd->mod_ver[DARSHAN_H5F_MOD] == 1) &&
+                    ((i == H5F_F_CLOSE_START_TIMESTAMP) ||
+                     (i == H5F_F_OPEN_END_TIMESTAMP)))
                     continue;
                 DARSHAN_BSWAP64(&file->fcounters[i]);
@@ -139,13 +164,82 @@ exit:
+    struct darshan_hdf5_dataset *ds = *((struct darshan_hdf5_dataset **)hdf5_buf_p);
+    int rec_len;
+    int i;
+    int ret;
+    if(fd->mod_map[DARSHAN_H5D_MOD].len == 0)
+        return(0);
+    if(*hdf5_buf_p == NULL)
+        ds = malloc(sizeof(*ds));
+        if(!ds)
+            return(-1);
+    if(fd->mod_ver[DARSHAN_H5D_MOD] == DARSHAN_H5D_VER)
+        /* log format is in current version, so we don't need to do any
+         * translation of counters while reading
+        rec_len = sizeof(struct darshan_hdf5_dataset);
+        ret = darshan_log_get_mod(fd, DARSHAN_H5D_MOD, ds, rec_len);
+exit:
+        if(ret == rec_len)
+            *hdf5_buf_p = ds;
+        else
+            free(ds);
+    if(ret < 0)
+        return(-1);
+    else if(ret < rec_len)
+        return(0);
+    else
+        /* if the read was successful, do any necessary byte-swapping */
+        if(fd->swap_flag)
+            DARSHAN_BSWAP64(&(ds->base_rec.id));
+            DARSHAN_BSWAP64(&(ds->base_rec.rank));
+            for(i=0; i<H5D_NUM_INDICES; i++)
+                DARSHAN_BSWAP64(&ds->counters[i]);
+            for(i=0; i<H5D_F_NUM_INDICES; i++)
+                DARSHAN_BSWAP64(&ds->fcounters[i]);
+        return(1);
     struct darshan_hdf5_file *file = (struct darshan_hdf5_file *)hdf5_buf;
     int ret;
-    ret = darshan_log_put_mod(fd, DARSHAN_HDF5_MOD, file,
-        sizeof(struct darshan_hdf5_file), DARSHAN_HDF5_VER);
+    ret = darshan_log_put_mod(fd, DARSHAN_H5F_MOD, file,
+        sizeof(struct darshan_hdf5_file), DARSHAN_H5F_VER);
+    if(ret < 0)
+        return(-1);
+    return(0);
+    struct darshan_hdf5_dataset *ds = (struct darshan_hdf5_dataset *)hdf5_buf;
+    int ret;
+    ret = darshan_log_put_mod(fd, DARSHAN_H5D_MOD, ds,
+        sizeof(struct darshan_hdf5_dataset), DARSHAN_H5D_VER);
     if(ret < 0)
         return(-1);
@@ -159,42 +253,102 @@ static void darshan_log_print_hdf5_file(void *file_rec, char *file_name,
     struct darshan_hdf5_file *hdf5_file_rec =
         (struct darshan_hdf5_file *)file_rec;
-        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_HDF5_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_H5F_MOD],
             hdf5_file_rec->base_rec.rank, hdf5_file_rec->base_rec.id,
-            hdf5_counter_names[i], hdf5_file_rec->counters[i],
+            h5f_counter_names[i], hdf5_file_rec->counters[i],
             file_name, mnt_pt, fs_type);
-        DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_HDF5_MOD],
+        DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_H5F_MOD],
-            hdf5_f_counter_names[i], hdf5_file_rec->fcounters[i],
+            h5f_f_counter_names[i], hdf5_file_rec->fcounters[i],
     return;
+static void darshan_log_print_hdf5_dataset(void *ds_rec, char *ds_name,
+    char *mnt_pt, char *fs_type)
+    int i;
+    struct darshan_hdf5_dataset *hdf5_ds_rec =
+        (struct darshan_hdf5_dataset *)ds_rec;
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_H5D_MOD],
+            hdf5_ds_rec->base_rec.rank, hdf5_ds_rec->base_rec.id,
+            h5d_counter_names[i], hdf5_ds_rec->counters[i],
+            ds_name, mnt_pt, fs_type);
+        DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_H5D_MOD],
+            h5d_f_counter_names[i], hdf5_ds_rec->fcounters[i],
+    return;
     printf("\n# description of HDF5 counters:\n");
-    printf("#   HDF5_OPENS: HDF5 file open operation counts.\n");
-    printf("#   HDF5_F_*_START_TIMESTAMP: timestamp of first HDF5 file open/close.\n");
-    printf("#   HDF5_F_*_END_TIMESTAMP: timestamp of last HDF5 file open/close.\n");
+    printf("#   H5F_OPENS: HDF5 file open/create operation counts.\n");
+    printf("#   H5F_FLUSHES: HDF5 file flush operation counts.\n");
+    printf("#   H5F_USE_MPIIO: flag indicating whether MPI-IO was used to access this file.\n");
+    printf("#   H5F_F_*_START_TIMESTAMP: timestamp of first HDF5 file open/close.\n");
+    printf("#   H5F_F_*_END_TIMESTAMP: timestamp of last HDF5 file open/close.\n");
+    printf("#   H5F_F_META_TIME: cumulative time spent in HDF5 metadata operations.\n");
     if(ver == 1)
         printf("\n# WARNING: HDF5 module log format version 1 does not support the following counters:\n");
-        printf("# - HDF5_F_CLOSE_START_TIMESTAMP\n");
-        printf("# - HDF5_F_OPEN_END_TIMESTAMP\n");
+        printf("# - H5F_F_CLOSE_START_TIMESTAMP\n");
+        printf("# - H5F_F_OPEN_END_TIMESTAMP\n");
     return;
+    printf("\n# description of HDF5 counters:\n");
+    printf("#   H5D_OPENS: HDF5 dataset open/create operation counts.\n");
+    printf("#   H5D_READS: HDF5 dataset read operation counts.\n");
+    printf("#   H5D_WRITES: HDF5 dataset write operation counts.\n");
+    printf("#   H5D_FLUSHES: HDF5 dataset flush operation counts.\n");
+    printf("#   H5D_BYTES_*: total bytes read and written at HDF5 dataset layer.\n");
+    printf("#   H5D_RW_SWITCHES: number of times access alternated between read and write.\n");
+    printf("#   H5D_*_SELECTS: number of different access selections (regular/irregular hyperslab or points).\n");
+    printf("#   H5D_MAX_*_TIME_SIZE: size of the slowest read and write operations.\n");
+    printf("#   H5D_SIZE_*_AGG_*: histogram of H5D total access sizes for read and write operations.\n");
+    printf("#   H5D_ACCESS*_ACCESS: the four most common total access sizes.\n");
+    printf("#   H5D_ACCESS*_COUNT: count of the four most common total access sizes.\n");
+    printf("#   H5D_DATASPACE_NDIMS: number of dimensions in dataset's dataspace.\n");
+    printf("#   H5D_DATASPACE_NPOINTS: number of points in dataset's dataspace.\n");
+    printf("#   H5D_DATATYPE_SIZE: size of each dataset element.\n");
+    printf("#   H5F_USE_MPIIO_COLLECTIVE: flag indicating whether MPI-IO collectives were used to access this file.\n");
+    printf("#   H5F_USE_DEPRECATED: flag indicating whether deprecated H5D calls were used.\n");
+    printf("#   H5D_*_RANK: rank of the processes that were the fastest and slowest at I/O (for shared files).\n");
+    printf("#   H5D_*_RANK_BYTES: total bytes transferred at H5D layer by the fastest and slowest ranks (for shared files).\n");
+    printf("#   H5D_F_*_START_TIMESTAMP: timestamp of first HDF5 file open/read/write/close.\n");
+    printf("#   H5D_F_*_END_TIMESTAMP: timestamp of last HDF5 file open/read/write/close.\n");
+    printf("#   H5D_F_READ/WRITE/META_TIME: cumulative time spent in H5D read, write, or metadata operations.\n");
+    printf("#   H5D_F_MAX_*_TIME: duration of the slowest H5D read and write operations.\n");
+    printf("#   H5D_F_*_RANK_TIME: fastest and slowest I/O time for a single rank (for shared files).\n");
+    printf("#   H5D_F_VARIANCE_RANK_*: variance of total I/O time and bytes moved for all ranks (for shared files).\n");
+    return;
@@ -204,62 +358,62 @@ static void darshan_log_print_hdf5_file_diff(void *file_rec1, char *file_name1,
     /* NOTE: we assume that both input records are the same module format version */
         if(!file2)
             printf("- ");
-                file1->base_rec.rank, file1->base_rec.id, hdf5_counter_names[i],
+                file1->base_rec.rank, file1->base_rec.id, h5f_counter_names[i],
                 file1->counters[i], file_name1, "", "");
         else if(!file1)
             printf("+ ");
-                file2->base_rec.rank, file2->base_rec.id, hdf5_counter_names[i],
+                file2->base_rec.rank, file2->base_rec.id, h5f_counter_names[i],
                 file2->counters[i], file_name2, "", "");
         else if(file1->counters[i] != file2->counters[i])
             printf("- ");
             printf("+ ");
         if(!file2)
             printf("- ");
-                file1->base_rec.rank, file1->base_rec.id, hdf5_f_counter_names[i],
+                file1->base_rec.rank, file1->base_rec.id, h5f_f_counter_names[i],
                 file1->fcounters[i], file_name1, "", "");
         else if(!file1)
             printf("+ ");
-                file2->base_rec.rank, file2->base_rec.id, hdf5_f_counter_names[i],
+                file2->base_rec.rank, file2->base_rec.id, h5f_f_counter_names[i],
                 file2->fcounters[i], file_name2, "", "");
         else if(file1->fcounters[i] != file2->fcounters[i])
             printf("- ");
             printf("+ ");
@@ -267,32 +421,310 @@ static void darshan_log_print_hdf5_file_diff(void *file_rec1, char *file_name1,
     return;
+    struct darshan_hdf5_dataset *ds1 = (struct darshan_hdf5_dataset *)ds_rec1;
+    struct darshan_hdf5_dataset *ds2 = (struct darshan_hdf5_dataset *)ds_rec2;
+    int i;
+    /* NOTE: we assume that both input records are the same module format version */
+        if(!ds2)
+            printf("- ");
+                ds1->base_rec.rank, ds1->base_rec.id, h5d_counter_names[i],
+                ds1->counters[i], ds_name1, "", "");
+        else if(!ds1)
+            printf("+ ");
+                ds2->base_rec.rank, ds2->base_rec.id, h5d_counter_names[i],
+                ds2->counters[i], ds_name2, "", "");
+        else if(ds1->counters[i] != ds2->counters[i])
+            printf("- ");
+            printf("+ ");
+        if(!ds2)
+            printf("- ");
+                ds1->base_rec.rank, ds1->base_rec.id, h5d_f_counter_names[i],
+                ds1->fcounters[i], ds_name1, "", "");
+        else if(!ds1)
+            printf("+ ");
+                ds2->base_rec.rank, ds2->base_rec.id, h5d_f_counter_names[i],
+                ds2->fcounters[i], ds_name2, "", "");
+        else if(ds1->fcounters[i] != ds2->fcounters[i])
+            printf("- ");
+            printf("+ ");
+    return;
     struct darshan_hdf5_file *hdf5_rec = (struct darshan_hdf5_file *)rec;
     struct darshan_hdf5_file *agg_hdf5_rec = (struct darshan_hdf5_file *)agg_rec;
     int i;
-    for(i = 0; i < HDF5_NUM_INDICES; i++)
+    for(i = 0; i < H5F_NUM_INDICES; i++)
+        switch(i)
+            case H5F_OPENS:
+            case H5F_FLUSHES:
+                /* sum */
+                agg_hdf5_rec->counters[i] += hdf5_rec->counters[i];
+                break;
+            case H5F_USE_MPIIO:
+                if(hdf5_rec->counters[i] > 0)
+                    agg_hdf5_rec->counters[i] = 1;
+                break;
+            default:
+                agg_hdf5_rec->counters[i] = -1;
+                break;
+    for(i = 0; i < H5F_F_NUM_INDICES; i++)
+        switch(i)
+            case H5F_F_OPEN_START_TIMESTAMP:
+            case H5F_F_CLOSE_START_TIMESTAMP:
+                /* minimum non-zero */
+                if((hdf5_rec->fcounters[i] > 0)  &&
+                    ((agg_hdf5_rec->fcounters[i] == 0) ||
+                    (hdf5_rec->fcounters[i] < agg_hdf5_rec->fcounters[i])))
+                    agg_hdf5_rec->fcounters[i] = hdf5_rec->fcounters[i];
+                break;
+            case H5F_F_OPEN_END_TIMESTAMP:
+            case H5F_F_CLOSE_END_TIMESTAMP:
+                /* maximum */
+                if(hdf5_rec->fcounters[i] > agg_hdf5_rec->fcounters[i])
+                break;
+            case H5F_F_META_TIME:
+                /* sum */
+                break;
+            default:
+                agg_hdf5_rec->fcounters[i] = -1;
+                break;
+    return;
+/* simple helper struct for determining time & byte variances */
+struct var_t
+    double n;
+    double M;
+    double S;
+    struct darshan_hdf5_dataset *hdf5_rec = (struct darshan_hdf5_dataset *)rec;
+    struct darshan_hdf5_dataset *agg_hdf5_rec = (struct darshan_hdf5_dataset *)agg_rec;
+    int i, j, k;
+    int total_count;
+    int64_t tmp_val[4];
+    int64_t tmp_cnt[4];
+    int tmp_ndx;
+    double old_M;
+    double hdf5_time = hdf5_rec->fcounters[H5D_F_READ_TIME] +
+        hdf5_rec->fcounters[H5D_F_WRITE_TIME] +
+        hdf5_rec->fcounters[H5D_F_META_TIME];
+    double hdf5_bytes = (double)hdf5_rec->counters[H5D_BYTES_READ] +
+        hdf5_rec->counters[H5D_BYTES_WRITTEN];
+    struct var_t *var_time_p = (struct var_t *)
+        ((char *)rec + sizeof(struct darshan_hdf5_dataset));
+    struct var_t *var_bytes_p = (struct var_t *)
+        ((char *)var_time_p + sizeof(struct var_t));
+    for(i = 0; i < H5D_NUM_INDICES; i++)
         switch(i)
-            case HDF5_OPENS:
+            case H5D_OPENS:
+            case H5D_READS:
+            case H5D_WRITES:
+            case H5D_FLUSHES:
+            case H5D_BYTES_READ:
+            case H5D_BYTES_WRITTEN:
+            case H5D_RW_SWITCHES:
+            case H5D_REGULAR_HYPERSLAB_SELECTS:
+            case H5D_IRREGULAR_HYPERSLAB_SELECTS:
+            case H5D_POINT_SELECTS:
+            case H5D_SIZE_READ_AGG_0_100:
+            case H5D_SIZE_READ_AGG_100_1K:
+            case H5D_SIZE_READ_AGG_1K_10K:
+            case H5D_SIZE_READ_AGG_10K_100K:
+            case H5D_SIZE_READ_AGG_100K_1M:
+            case H5D_SIZE_READ_AGG_1M_4M:
+            case H5D_SIZE_READ_AGG_4M_10M:
+            case H5D_SIZE_READ_AGG_10M_100M:
+            case H5D_SIZE_READ_AGG_100M_1G:
+            case H5D_SIZE_READ_AGG_1G_PLUS:
+            case H5D_SIZE_WRITE_AGG_0_100:
+            case H5D_SIZE_WRITE_AGG_100_1K:
+            case H5D_SIZE_WRITE_AGG_1K_10K:
+            case H5D_SIZE_WRITE_AGG_10K_100K:
+            case H5D_SIZE_WRITE_AGG_100K_1M:
+            case H5D_SIZE_WRITE_AGG_1M_4M:
+            case H5D_SIZE_WRITE_AGG_4M_10M:
+            case H5D_SIZE_WRITE_AGG_10M_100M:
+            case H5D_SIZE_WRITE_AGG_100M_1G:
+            case H5D_SIZE_WRITE_AGG_1G_PLUS:
                 /* sum */
                 break;
+            case H5D_MAX_READ_TIME_SIZE:
+            case H5D_MAX_WRITE_TIME_SIZE:
+            case H5D_FASTEST_RANK:
+            case H5D_FASTEST_RANK_BYTES:
+            case H5D_SLOWEST_RANK:
+            case H5D_SLOWEST_RANK_BYTES:
+                /* these are set with the FP counters */
+                break;
+            case H5D_ACCESS1_ACCESS:
+                /* increment common value counters */
+                if(hdf5_rec->counters[i] == 0) break;
+                /* first, collapse duplicates */
+                for(j = i; j < i + 4; j++)
+                    for(k = 0; k < 4; k++)
+                        if(agg_hdf5_rec->counters[i + k] == hdf5_rec->counters[j])
+                            agg_hdf5_rec->counters[i + k + 4] += hdf5_rec->counters[j + 4];
+                            hdf5_rec->counters[j] = hdf5_rec->counters[j + 4] = 0;
+                /* second, add new counters */
+                    tmp_ndx = 0;
+                    memset(tmp_val, 0, 4 * sizeof(int64_t));
+                    memset(tmp_cnt, 0, 4 * sizeof(int64_t));
+                    if(hdf5_rec->counters[j] == 0) break;
+                            total_count = agg_hdf5_rec->counters[i + k + 4] +
+                                hdf5_rec->counters[j + 4];
+                            break;
+                    if(k == 4) total_count = hdf5_rec->counters[j + 4];
+                        if((agg_hdf5_rec->counters[i + k + 4] > total_count) ||
+                           ((agg_hdf5_rec->counters[i + k + 4] == total_count) &&
+                            (agg_hdf5_rec->counters[i + k] > hdf5_rec->counters[j])))
+                            tmp_val[tmp_ndx] = agg_hdf5_rec->counters[i + k];
+                            tmp_cnt[tmp_ndx] = agg_hdf5_rec->counters[i + k + 4];
+                            tmp_ndx++;
+                        else break;
+                    if(tmp_ndx == 4) break;
+                    tmp_val[tmp_ndx] = hdf5_rec->counters[j];
+                    tmp_cnt[tmp_ndx] = hdf5_rec->counters[j + 4];
+                    tmp_ndx++;
+                    while(tmp_ndx != 4)
+                        if(agg_hdf5_rec->counters[i + k] != hdf5_rec->counters[j])
+                            tmp_ndx++;
+                        k++;
+                    memcpy(&(agg_hdf5_rec->counters[i]), tmp_val, 4 * sizeof(int64_t));
+                    memcpy(&(agg_hdf5_rec->counters[i + 4]), tmp_cnt, 4 * sizeof(int64_t));
+                break;
+            case H5D_DATASPACE_NDIMS:
+            case H5D_DATASPACE_NPOINTS:
+            case H5D_DATATYPE_SIZE:
+                /* just set to the input value */
+                agg_hdf5_rec->counters[i] = hdf5_rec->counters[i];
+                break;
+            case H5D_USE_MPIIO_COLLECTIVE:
+            case H5D_USE_DEPRECATED:
+                break;
             default:
                 break;
-    for(i = 0; i < HDF5_F_NUM_INDICES; i++)
+    for(i = 0; i < H5D_F_NUM_INDICES; i++)
         switch(i)
-            case HDF5_F_OPEN_START_TIMESTAMP:
-            case HDF5_F_CLOSE_START_TIMESTAMP:
+            case H5D_F_READ_TIME:
+            case H5D_F_WRITE_TIME:
+            case H5D_F_META_TIME:
+                /* sum */
+                agg_hdf5_rec->fcounters[i] += hdf5_rec->fcounters[i];
+                break;
+            case H5D_F_OPEN_START_TIMESTAMP:
+            case H5D_F_READ_START_TIMESTAMP:
+            case H5D_F_WRITE_START_TIMESTAMP:
+            case H5D_F_CLOSE_START_TIMESTAMP:
@@ -301,14 +733,106 @@ static void darshan_log_agg_hdf5_files(void *rec, void *agg_rec, int init_flag)
                 break;
-            case HDF5_F_OPEN_END_TIMESTAMP:
-            case HDF5_F_CLOSE_END_TIMESTAMP:
+            case H5D_F_OPEN_END_TIMESTAMP:
+            case H5D_F_READ_END_TIMESTAMP:
+            case H5D_F_WRITE_END_TIMESTAMP:
+            case H5D_F_CLOSE_END_TIMESTAMP:
                 /* maximum */
                 break;
+            case H5D_F_MAX_READ_TIME:
+                    agg_hdf5_rec->counters[H5D_MAX_READ_TIME_SIZE] =
+                        hdf5_rec->counters[H5D_MAX_READ_TIME_SIZE];
+                break;
+            case H5D_F_MAX_WRITE_TIME:
+                    agg_hdf5_rec->counters[H5D_MAX_WRITE_TIME_SIZE] =
+                        hdf5_rec->counters[H5D_MAX_WRITE_TIME_SIZE];
+                break;
+            case H5D_F_FASTEST_RANK_TIME:
+                if(init_flag)
+                    /* set fastest rank counters according to root rank. these counters
+                     * will be determined as the aggregation progresses.
+                    agg_hdf5_rec->counters[H5D_FASTEST_RANK] = hdf5_rec->base_rec.rank;
+                    agg_hdf5_rec->counters[H5D_FASTEST_RANK_BYTES] = hdf5_bytes;
+                    agg_hdf5_rec->fcounters[H5D_F_FASTEST_RANK_TIME] = hdf5_time;
+                if(hdf5_time < agg_hdf5_rec->fcounters[H5D_F_FASTEST_RANK_TIME])
+                break;
+            case H5D_F_SLOWEST_RANK_TIME:
+                if(init_flag)
+                    /* set slowest rank counters according to root rank. these counters
+                    agg_hdf5_rec->counters[H5D_SLOWEST_RANK] = hdf5_rec->base_rec.rank;
+                    agg_hdf5_rec->counters[H5D_SLOWEST_RANK_BYTES] = hdf5_bytes;
+                    agg_hdf5_rec->fcounters[H5D_F_SLOWEST_RANK_TIME] = hdf5_time;
+                if(hdf5_time > agg_hdf5_rec->fcounters[H5D_F_SLOWEST_RANK_TIME])
+                break;
+            case H5D_F_VARIANCE_RANK_TIME:
+                if(init_flag)
+                    var_time_p->n = 1;
+                    var_time_p->M = hdf5_time;
+                    var_time_p->S = 0;
+                else
+                    old_M = var_time_p->M;
+                    var_time_p->n++;
+                    var_time_p->M += (hdf5_time - var_time_p->M) / var_time_p->n;
+                    var_time_p->S += (hdf5_time - var_time_p->M) * (hdf5_time - old_M);
+                    agg_hdf5_rec->fcounters[H5D_F_VARIANCE_RANK_TIME] =
+                        var_time_p->S / var_time_p->n;
+                break;
+            case H5D_F_VARIANCE_RANK_BYTES:
+                if(init_flag)
+                    var_bytes_p->n = 1;
+                    var_bytes_p->M = hdf5_bytes;
+                    var_bytes_p->S = 0;
+                else
+                    old_M = var_bytes_p->M;
+                    var_bytes_p->n++;
+                    var_bytes_p->M += (hdf5_bytes - var_bytes_p->M) / var_bytes_p->n;
+                    var_bytes_p->S += (hdf5_bytes - var_bytes_p->M) * (hdf5_bytes - old_M);
+                    agg_hdf5_rec->fcounters[H5D_F_VARIANCE_RANK_BYTES] =
+                        var_bytes_p->S / var_bytes_p->n;
+                break;
             default:
                 break;
darshan-util/darshan-hdf5-logutils.h
@@ -7,9 +7,13 @@
 #ifndef __DARSHAN_HDF5_LOG_UTILS_H
 #define __DARSHAN_HDF5_LOG_UTILS_H
-extern char *hdf5_counter_names[];
-extern char *hdf5_f_counter_names[];
+extern char *h5f_counter_names[];
+extern char *h5f_f_counter_names[];
-extern struct darshan_mod_logutil_funcs hdf5_logutils;
+extern char *h5d_counter_names[];
+extern char *h5d_f_counter_names[];
+extern struct darshan_mod_logutil_funcs hdf5_file_logutils;
+extern struct darshan_mod_logutil_funcs hdf5_dataset_logutils;
 #endif
darshan-util/darshan-logutils.c
@@ -896,6 +896,10 @@ static int darshan_log_get_header(darshan_fd fd)
         fd->state->get_namerecs = darshan_log_get_namerecs_3_00;
     else if(strcmp(fd->version, "3.10") == 0)
+        /* XXX */
+    else if(strcmp(fd->version, "3.20") == 0)
         fd->state->get_namerecs = darshan_log_get_namerecs;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/d89229b7b1c04aa4900ec7fa66e95bb678a53839...55c469885b7e17d0995c4c67a1e205d0dc4d18ee
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200202/a2a6680f/attachment-0001.html>
More information about the Darshan-commits mailing list
