[Darshan-commits] [Git][darshan/darshan][carns/dev-289-pwritev] add support for 64 bit variants of preadv/pwritev
Philip Carns
xgitlab at cels.anl.gov
Tue Dec 1 12:47:03 CST 2020
Philip Carns pushed to branch carns/dev-289-pwritev at darshan / darshan
Commits:
4374b2e7 by Phil Carns at 2020-12-01T13:46:43-05:00
2 changed files:
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/share/ld-opts/darshan-posix-ld-opts
Changes:
@@ -64,16 +64,21 @@ DARSHAN_FORWARD_DECL(pwrite64, ssize_t, (int fd, const void *buf, size_t count,
DARSHAN_FORWARD_DECL(readv, ssize_t, (int fd, const struct iovec *iov, int iovcnt));
#ifdef HAVE_PREADV
DARSHAN_FORWARD_DECL(preadv, ssize_t, (int fd, const struct iovec *iov, int iovcnt, off_t offset));
+ DARSHAN_FORWARD_DECL(preadv64, ssize_t, (int fd, const struct iovec *iov, int iovcnt, off64_t offset));
#endif
#ifdef HAVE_PREADV2
DARSHAN_FORWARD_DECL(preadv2, ssize_t, (int fd, const struct iovec *iov, int iovcnt, off_t offset, int flags));
+ DARSHAN_FORWARD_DECL(preadv64v2, ssize_t, (int fd, const struct iovec *iov, int iovcnt, off64_t offset, int flags));
#endif
DARSHAN_FORWARD_DECL(writev, ssize_t, (int fd, const struct iovec *iov, int iovcnt));
+DARSHAN_FORWARD_DECL(writev64, ssize_t, (int fd, const struct iovec *iov, int iovcnt));
#ifdef HAVE_PWRITEV
DARSHAN_FORWARD_DECL(pwritev, ssize_t, (int fd, const struct iovec *iov, int iovcnt, off_t offset));
+ DARSHAN_FORWARD_DECL(pwritev64, ssize_t, (int fd, const struct iovec *iov, int iovcnt, off64_t offset));
#endif
#ifdef HAVE_PWRITEV2
DARSHAN_FORWARD_DECL(pwritev2, ssize_t, (int fd, const struct iovec *iov, int iovcnt, off_t offset, int flags));
+ DARSHAN_FORWARD_DECL(pwritev64v2, ssize_t, (int fd, const struct iovec *iov, int iovcnt, off64_t offset, int flags));
#endif
DARSHAN_FORWARD_DECL(lseek, off_t, (int fd, off_t offset, int whence));
DARSHAN_FORWARD_DECL(lseek64, off64_t, (int fd, off64_t offset, int whence));
@@ -1029,6 +1034,33 @@ ssize_t DARSHAN_DECL(preadv)(int fd, const struct iovec *iov, int iovcnt, off_t
return(ret);
+ssize_t DARSHAN_DECL(preadv64)(int fd, const struct iovec *iov, int iovcnt, off64_t offset)
+ ssize_t ret;
+ int aligned_flag = 1;
+ int i;
+ double tm1, tm2;
+ MAP_OR_FAIL(preadv64);
+ for(i=0; i<iovcnt; i++)
+ if(((unsigned long)iov[i].iov_base % darshan_mem_alignment) != 0)
+ aligned_flag = 0;
+ tm1 = darshan_core_wtime();
+ ret = __real_preadv64(fd, iov, iovcnt, offset);
+ tm2 = darshan_core_wtime();
+ POSIX_PRE_RECORD();
+ POSIX_RECORD_READ(ret, fd, 1, offset, aligned_flag, tm1, tm2);
+ POSIX_POST_RECORD();
+ return(ret);
#endif /* HAVE_PREADV */
#ifdef HAVE_PREADV2
@@ -1057,6 +1089,32 @@ ssize_t DARSHAN_DECL(preadv2)(int fd, const struct iovec *iov, int iovcnt, off_t
return(ret);
+ssize_t DARSHAN_DECL(preadv64v2)(int fd, const struct iovec *iov, int iovcnt, off64_t offset, int flags)
+ ssize_t ret;
+ int i;
+ double tm1, tm2;
+ MAP_OR_FAIL(preadv64v2);
+ aligned_flag = 0;
+ ret = __real_preadv64v2(fd, iov, iovcnt, offset, flags);
+ return(ret);
#endif /* HAVE_PREADV2 */
ssize_t DARSHAN_DECL(writev)(int fd, const struct iovec *iov, int iovcnt)
@@ -1111,6 +1169,32 @@ ssize_t DARSHAN_DECL(pwritev)(int fd, const struct iovec *iov, int iovcnt, off_t
return(ret);
+ssize_t DARSHAN_DECL(pwritev64)(int fd, const struct iovec *iov, int iovcnt, off64_t offset)
+ ssize_t ret;
+ int i;
+ double tm1, tm2;
+ MAP_OR_FAIL(pwritev64);
+ aligned_flag = 0;
+ ret = __real_pwritev64(fd, iov, iovcnt, offset);
+ POSIX_RECORD_WRITE(ret, fd, 1, offset, aligned_flag, tm1, tm2);
+ return(ret);
#endif /* HAVE_PWRITEV */
@@ -1139,6 +1223,33 @@ ssize_t DARSHAN_DECL(pwritev2)(int fd, const struct iovec *iov, int iovcnt, off_
return(ret);
+ssize_t DARSHAN_DECL(pwritev64v2)(int fd, const struct iovec *iov, int iovcnt, off64_t offset, int flags)
+ ssize_t ret;
+ int i;
+ double tm1, tm2;
+ MAP_OR_FAIL(pwritev64v2);
+ aligned_flag = 0;
+ ret = __real_pwritev64v2(fd, iov, iovcnt, offset, flags);
+ return(ret);
#endif
off_t DARSHAN_DECL(lseek)(int fd, off_t offset, int whence)
@@ -21,9 +21,13 @@
--wrap=readv
--wrap=preadv
--wrap=preadv2
+--wrap=preadv64
+--wrap=preadv64v2
--wrap=writev
--wrap=pwritev
--wrap=pwritev2
+--wrap=pwritev64
+--wrap=pwritev64v2
--wrap=lseek
--wrap=lseek64
--wrap=__xstat
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/-/commit/4374b2e762dd27aa55e957e0449989ba40e0223a
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20201201/009a1662/attachment-0001.html>
More information about the Darshan-commits
