[Darshan-commits] [Git][darshan/darshan][dev-new-regression-tests] more gitlab ci debugging..
Shane Snyder xgitlab at cels.anl.gov
Mon Apr 27 09:12:20 CDT 2020
Shane Snyder pushed to branch dev-new-regression-tests at darshan / darshan
Commits:
ccbd97bb by Shane Snyder at 2020-04-27T09:11:54-05:00
1 changed file:
- .gitlab-ci.yml
Changes:
.gitlab-ci.yml
@@ -29,31 +29,31 @@ build_darshan:
     paths:
       - install/
-test_darshan_static:
-  tags:
-    - shell
-    - ecp-theta
-  rules:
-    - if: '$CI_PIPELINE_SOURCE == "web" && $RUN_TESTS == "true"'
-      when: on_success
-    - if: '$CI_PIPELINE_SOURCE == "schedules" && $RUN_TESTS == "true"'
-      when: on_success
-  stage: test
-  script:
-    - export CRAYPE_LINK_TYPE=static
-    - darshan-test/regression/run-all.sh $PWD/install $PWD/scratch cray-module-alcf
-  artifacts:
-    paths:
-        - $PWD/scratch/*.darshan
-        - $PWD/scratch/*.debuglog
-        - $PWD/scratch/*.out
-        - $PWD/scratch/*.err
-  resource_group: debug-queue
+#test_darshan_static:
+#  tags:
+#    - shell
+#    - ecp-theta
+#  rules:
+#    - if: '$CI_PIPELINE_SOURCE == "web" && $RUN_TESTS == "true"'
+#      when: on_success
+#    - if: '$CI_PIPELINE_SOURCE == "schedules" && $RUN_TESTS == "true"'
+#      when: on_success
+#  stage: test
+#  script:
+#    - export CRAYPE_LINK_TYPE=static
+#    - darshan-test/regression/run-all.sh $PWD/install $PWD/scratch cray-module-alcf
+#  artifacts:
+#    paths:
+#        - $PWD/scratch/*.darshan
+#        - $PWD/scratch/*.debuglog
+#        - $PWD/scratch/*.out
+#        - $PWD/scratch/*.err
+#  resource_group: debug-queue
 test_darshan_dynamic:
   tags:
@@ -71,6 +71,9 @@ test_darshan_dynamic:
   script:
     - export CRAYPE_LINK_TYPE=dynamic
+    - ldd $PWD/scratch/mpi-io-test
+    - nm $PWD/scratch/mpi-io-test | grep darshan
+    - nm $PWD/scratch/mpi-io-test | grep MPI
   artifacts:
     paths:
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/ccbd97bb673bc45861ee2709fef995bc3810dc73
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200427/63da6de7/attachment-0001.html>
More information about the Darshan-commits mailing list
