[Darshan-commits] [Git][darshan/darshan][dev-new-regression-tests] try static/dynamic theta tests for gitlab ci
Shane Snyder
xgitlab at cels.anl.gov
Fri Apr 24 10:30:42 CDT 2020
Shane Snyder pushed to branch dev-new-regression-tests at darshan / darshan
Commits:
672cd7e9 by Shane Snyder at 2020-04-24T10:30:18-05:00
1 changed file:
- .gitlab-ci.yml
Changes:
.gitlab-ci.yml
@@ -3,7 +3,8 @@ variables:
stages:
- build
- - test
+ - test_static
+ - test_dynamic
build_darshan:
tags:
@@ -29,7 +30,7 @@ build_darshan:
paths:
- install/
-test_darshan:
+test_darshan_static:
tags:
- shell
- ecp-theta
@@ -40,12 +41,41 @@ test_darshan:
- if: '$CI_PIPELINE_SOURCE == "schedules" && $RUN_TESTS == "true"'
when: on_success
- stage: test
+ stage: test_static
script:
- - ls $PWD/install
- - ls $PWD/install/bin
+ - export CRAYPE_LINK_TYPE=dynamic
- darshan-test/regression/run-all.sh $PWD/install $PWD/scratch cray-module-alcf
+ - ldd $PWD/scratch/mpi-io-test
+ - nm $PWD/scratch/mpi-io-test | grep darshan
+ - nm $PWD/scratch/mpi-io-test | grep MPI
+ artifacts:
+ paths:
+ - $PWD/scratch/*.darshan
+ - $PWD/scratch/*.debuglog
+ - $PWD/scratch/*.out
+ - $PWD/scratch/*.err
+test_darshan_dynamic:
+ tags:
+ - shell
+ - ecp-theta
+ rules:
+ - if: '$CI_PIPELINE_SOURCE == "web" && $RUN_TESTS == "true"'
+ when: on_success
+ - if: '$CI_PIPELINE_SOURCE == "schedules" && $RUN_TESTS == "true"'
+ when: on_success
+ stage: test_dynamic
+ script:
+ - darshan-test/regression/run-all.sh $PWD/install $PWD/scratch cray-module-alcf
artifacts:
paths:
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/672cd7e9ebf3b8da190dc9197b02309690f1f868
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200424/f776e7d6/attachment-0001.html>
More information about the Darshan-commits
