[Darshan-commits] [Git][darshan/darshan][master] 2 commits: test stage should actually be shell, not batch
Shane Snyder
xgitlab at cels.anl.gov
Mon Apr 20 09:33:38 CDT 2020
Shane Snyder pushed to branch master at darshan / darshan
Commits:
3b575b42 by Shane Snyder at 2020-04-20T09:33:35-05:00
we invoke batch scheduler directly in our scripts
7dfbddce by Shane Snyder at 2020-04-20T09:33:35-05:00
Merge branch 'dev-gitlab-ci' into 'master'
add GitLab CI hooks
See merge request darshan/darshan!45
7 changed files:
- .gitlab-ci.yml
- darshan-test/automated/common/build.sh
- darshan-test/automated/common/configure.sh
- darshan-test/automated/common/setup.sh
- darshan-test/automated/generic/configure.sh
- darshan-test/automated/theta/configure.sh
- darshan-test/regression/cray-module-alcf/runjob.sh
Changes:
.gitlab-ci.yml
@@ -1,6 +1,5 @@
variables:
- ANL_THETA_SCHEDULER_PARAMETERS: "-A radix-io"
- ANL_THETA_PROJECT_SERVICE_USER: "darshan"
+ ANL_THETA_PROJECT_SERVICE_USER: "ecpcscstdm"
stages:
- build
@@ -11,24 +10,46 @@ build_darshan:
- shell
- ecp-theta
+ rules:
+ - if: '$CI_PIPELINE_SOURCE == "web"'
+ when: always
+ - if: '$CI_PIPELINE_SOURCE == "schedules"'
+ when: always
+ - if: '$CI_MERGE_REQUEST_TARGET_BRANCH_NAME == "master"'
+ when: always
stage: build
script:
- source darshan-test/automated/common/setup.sh
- - cat setup-result.xml
- - source darshan-test/automated/common/configure.sh
-# - source darshan-test/automated/common/build.sh
+ - source darshan-test/automated/theta/configure.sh
+ - source darshan-test/automated/common/build.sh
+ artifacts:
+ paths:
+ - install/
-#.test_darshan:
-# variables:
-# # XXX this info is hard-coded in our regression scripts
-# #SCHEDULER_PARAMETERS: "-A radix-io -n 1 -t 10 -q default"
+test_darshan:
+ tags:
+ - shell
+ - ecp-theta
-# tags:
-# - batch
-# - ecp-theta
+ rules:
+ - if: '$CI_PIPELINE_SOURCE == "web" && $RUN_TESTS == "true"'
+ when: on_success
+ - if: '$CI_PIPELINE_SOURCE == "schedules" && $RUN_TESTS == "true"'
+ when: on_success
-# stage: test
+ stage: test
-# script:
-# - darshan-test/regression/run-all.sh install scratch cray-module-alcf
+ script:
+ - ls $PWD/install
+ - ls $PWD/install/bin
+ - darshan-test/regression/run-all.sh $PWD/install $PWD/scratch cray-module-alcf
+ artifacts:
+ paths:
+ - $PWD/scratch/*.darshan
+ - $PWD/scratch/*.debuglog
+ - $PWD/scratch/*.out
+ - $PWD/scratch/*.err
@@ -40,4 +40,4 @@ echo "
</testsuites>
" > build-result.xml
-exit $fcount
+return $fcount
@@ -18,4 +18,4 @@ else
status=100
fi
-exit $status
+return $status
@@ -26,4 +26,5 @@ echo "
</testsuite>
</testsuites>
" > setup-result.xml
-exit $status
+return $status
@@ -39,4 +39,5 @@ echo "
</testsuite>
</testsuites>
" > configure-result.xml
-exit $fcount
+return $fcount
@@ -45,4 +45,5 @@ echo "
</testsuite>
</testsuites>
-exit $fcount
+return $fcount
@@ -6,7 +6,7 @@ if [ -n "${DXT_ENABLE_IO_TRACE+defined}" ]; then
fi
# submit job and get job id
-jobid=`qsub --env DARSHAN_LOGFILE=$DARSHAN_LOGFILE --env DARSHAN_DEFAULT_NPROCS=$DARSHAN_DEFAULT_NPROCS $DXT_ENV --proccount $DARSHAN_DEFAULT_NPROCS -A radix-io -q debug-cache-quad -t 20 -n 1 --output $DARSHAN_TMP/$$-tmp.out --error $DARSHAN_TMP/$$-tmp.err --debuglog $DARSHAN_TMP/$$-tmp.debuglog $DARSHAN_TESTDIR/$DARSHAN_PLATFORM/cobalt-submit.sh "$@"`
+jobid=`qsub --env DARSHAN_LOGFILE=$DARSHAN_LOGFILE --env DARSHAN_DEFAULT_NPROCS=$DARSHAN_DEFAULT_NPROCS $DXT_ENV --proccount $DARSHAN_DEFAULT_NPROCS -A CSC250STDM12 -q debug-cache-quad -t 20 -n 1 --output $DARSHAN_TMP/$$-tmp.out --error $DARSHAN_TMP/$$-tmp.err --debuglog $DARSHAN_TMP/$$-tmp.debuglog $DARSHAN_TESTDIR/$DARSHAN_PLATFORM/cobalt-submit.sh "$@"`
if [ $? -ne 0 ]; then
echo "Error: failed to qsub $@"
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/bbdfb4f9dd0f86dcb3ce452fba4addbff9c9e53f...7dfbddce4d4e467594162c7a9b3c8a4c74aeca64
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200420/e63f279b/attachment-0001.html>
More information about the Darshan-commits
