[Darshan-commits] [Git][darshan/darshan][dev-detailed-hdf5-mod] 3 commits: remove stubs library and undefined ld-opts
Shane Snyder xgitlab at cels.anl.gov
Fri Apr 10 14:57:16 CDT 2020
Shane Snyder pushed to branch dev-detailed-hdf5-mod at darshan / darshan
Commits:
254a02b1 by Shane Snyder at 2020-04-10T14:56:33-05:00
a7f7c9d7 by Shane Snyder at 2020-04-10T14:56:33-05:00
keep mpi/stdio ld-opts for static links
acb13c38 by Shane Snyder at 2020-04-10T14:56:33-05:00
make H5Dcreate1 undefined to avoid link issues
7 changed files:
- darshan-runtime/Makefile.in
- darshan-runtime/darshan-config.in
- − darshan-runtime/lib/darshan-hdf5-stubs.c
- − darshan-runtime/lib/darshan-pnetcdf-stubs.c
- darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in
- darshan-runtime/share/ld-opts/darshan-hdf5-ld-opts
- darshan-runtime/share/ld-opts/darshan-pnetcdf-ld-opts
Changes:
@@ -20,7 +20,7 @@ DARSHAN_LOG_FORMAT = $(srcdir)/../darshan-log-format.h
 DARSHAN_VERSION = @DARSHAN_VERSION@
 ifndef DISABLE_STATIC_LIB
-all: lib/libdarshan.a lib/libdarshan-stubs.a
+all: lib/libdarshan.a
 endif
 ifndef DISABLE_LDPRELOAD
 all: lib/libdarshan.so
@@ -155,18 +155,12 @@ lib/darshan-hdf5.o: lib/darshan-hdf5.c darshan.h darshan-common.h $(DARSHAN_LOG_
 lib/darshan-hdf5.po: lib/darshan-hdf5.c darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-hdf5-log-format.h | lib
 	$(CC) $(CFLAGS_SHARED) -c $< -o $@
-lib/darshan-hdf5-stubs.o: lib/darshan-hdf5-stubs.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
-	$(CC) $(CFLAGS) -c $< -o $@
 lib/darshan-pnetcdf.o: lib/darshan-pnetcdf.c darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-pnetcdf-log-format.h | lib
 lib/darshan-pnetcdf.po: lib/darshan-pnetcdf.c darshan.h darshan-dynamic.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-pnetcdf-log-format.h | lib
-lib/darshan-pnetcdf-stubs.o: lib/darshan-pnetcdf-stubs.c darshan.h $(DARSHAN_LOG_FORMAT) | lib
 lib/darshan-lustre.o: lib/darshan-lustre.c darshan-lustre.h darshan.h darshan-common.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-lustre-log-format.h | lib
@@ -210,20 +204,11 @@ lib/libdarshan.a: lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darsha
 lib/libdarshan.so: lib/darshan-core-init-finalize.po lib/darshan-core.po lib/darshan-common.po $(DARSHAN_DYNAMIC_MOD_OBJS) lib/lookup3.po lib/lookup8.po
 	$(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ -lpthread -lrt -lz -ldl
-ifdef BUILD_HDF5_MODULE
-lib/libdarshan-stubs.a: lib/darshan-hdf5-stubs.o lib/darshan-pnetcdf-stubs.o
-	ar rcs $@ $^
-else
-lib/libdarshan-stubs.a: lib/darshan-pnetcdf-stubs.o
-	ar rcs $@ $^
-endif
 install:: all
 	install -d $(DESTDIR)$(libdir)
 	install -m 755 lib/libdarshan.a $(DESTDIR)$(libdir)
-	install -m 755 lib/libdarshan-stubs.a $(DESTDIR)$(libdir)
 endif
 	install -m 755 lib/libdarshan.so $(DESTDIR)$(libdir)
@@ -12,7 +12,7 @@ DARSHAN_LD_FLAGS="@LDFLAGS@"
 #   app used a library which in turn used one of those HLLs).
 PRE_LD_FLAGS="-L$DARSHAN_LIB_PATH $DARSHAN_LD_FLAGS -ldarshan -lz -Wl,@$DARSHAN_SHARE_PATH/ld-opts/darshan-base-ld-opts"
-POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -Wl,--start-group -ldarshan -ldarshan-stubs -Wl,--end-group -lz -lrt -lpthread"
+POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -ldarshan -lz -lrt -lpthread"
 # NOTE:
 # - when dynamic linking there is no need for wrapping options, we simply
darshan-runtime/lib/darshan-hdf5-stubs.c deleted
@@ -1,95 +0,0 @@
- * Copyright (C) 2015 University of Chicago.
- * See COPYRIGHT notice in top-level directory.
-/* This file contains stubs for the H5F functions intercepted by Darshan.
- * They are defined as weak symbols in order to satisfy dependencies of the
- * hdf5 wrappers in cases where hdf5 is not being used.
-#include "darshan-runtime-config.h"
-#include <stdio.h>
-#include <pthread.h>
-#include <string.h>
-#include "mpi.h"
-#include "darshan.h"
-/* hope this doesn't change any time soon */
-typedef int hid_t;
-typedef int herr_t;
-hid_t H5Fcreate(const char *filename, unsigned flags,
-    hid_t create_plist, hid_t access_plist) __attribute__((weak));
-    int rank;
-    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan H5Fcreate() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-hid_t H5Fopen(const char *filename, unsigned flags,
-    hid_t access_plist) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan H5Fopen() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-herr_t H5Fclose(hid_t file_id) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan H5Fclose() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-herr_t H5get_libversion(unsigned *majnum, unsigned *minnum, unsigned *relnum) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan H5get_libversion() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
- * Local variables:
- *  c-indent-level: 4
- *  c-basic-offset: 4
- * End:
- * vim: ts=8 sts=4 sw=4 expandtab
darshan-runtime/lib/darshan-pnetcdf-stubs.c deleted
@@ -1,77 +0,0 @@
-/* This file contains stubs for the ncmpi functions intercepted by Darshan.
- * pnetcdf wrappers in cases where pnetcdf is not being used.
-#include <stdio.h>
-#include "mpi.h"
-int ncmpi_create(MPI_Comm comm, const char *path,
-    int cmode, MPI_Info info, int *ncidp) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan ncmpi_create() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-int ncmpi_open(MPI_Comm comm, const char *path,
-    int omode, MPI_Info info, int *ncidp) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan ncmpi_open() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
-int ncmpi_close(int ncid) __attribute__((weak));
-    int rank;
-    if(rank == 0)
-        fprintf(stderr, "WARNING: Darshan ncmpi_close() stub called; this is probably the result of a link-time problem.\n");
-    return(-1);
- * End:
@@ -16,4 +16,4 @@ darshan_linkopts="-Wl,@${darshan_share}/ld-opts/darshan-base-ld-opts"
 Cflags:
 Libs: -ldarshan
-Libs.private: ${darshan_linkopts} ${darshan_libdir} -lfmpich -lmpichcxx -Wl,--start-group -ldarshan -ldarshan-stubs -Wl,--end-group
+Libs.private: ${darshan_linkopts} ${darshan_libdir} -lfmpich -lmpichcxx -ldarshan
@@ -1,4 +1,4 @@
---undefined=__wrap_H5Fcreate
+--undefined=H5Dcreate1
 --wrap=H5Fcreate
 --wrap=H5Fopen
 --wrap=H5Fflush
@@ -1,4 +1,3 @@
---undefined=__wrap_ncmpi_create
 --wrap=ncmpi_create
 --wrap=ncmpi_open
 --wrap=ncmpi_close
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/e1832e4d504621c1ed7ccad5689be34263eaafb5...acb13c383e448d3c589ac8eb736e71ff122f1586
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20200410/2a0503a2/attachment-0001.html>
More information about the Darshan-commits mailing list
