[Darshan-commits] [Git][darshan/darshan][master] 6 commits: first cut at dxt trace triggers
Shane Snyder
xgitlab at cels.anl.gov
Mon Sep 9 16:03:30 CDT 2019
Shane Snyder pushed to branch master at darshan / darshan
Commits:
9007db12 by Shane Snyder at 2019-08-07T22:09:06Z
dynamic triggers still not working
d172df2e by Shane Snyder at 2019-08-08T02:31:14Z
add user pointer to record_ref iterators
ea9fb7f2 by Shane Snyder at 2019-08-08T19:38:24Z
code for filtering dynamic trace data
86a9cb00 by Shane Snyder at 2019-08-09T18:51:05Z
finish implementing dynamic trace filtering
d710db8e by Shane Snyder at 2019-08-13T17:54:09Z
add missing dxt header
35a35fe5 by Shane Snyder at 2019-09-09T21:00:41Z
Merge branch 'dev-dynamic-dxt-trigger'
9 changed files:
- darshan-runtime/darshan-common.h
- + darshan-runtime/darshan-dxt.h
- darshan-runtime/lib/darshan-common.c
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-dxt.c
- darshan-runtime/lib/darshan-lustre.c
- darshan-runtime/lib/darshan-mdhim.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-posix.c
Changes:
@@ -210,12 +210,16 @@ void darshan_clear_record_refs(
* Iterate each record reference stored in the hash table pointed
* to by 'hash_head' and perform the given action 'iter_action'.
- * The action function takes a single pointer which points to the
- * corresponding record reference pointer.
+ * The action function takes two pointers as input: the first
+ * points to the corresponding record reference pointer and the
+ * second is a user-supplied pointer provided for the action.
+ * 'user_ptr' is the user-supplied pointer that will be passed
+ * as the 2nd argument to 'iter_action'.
void darshan_iter_record_refs(
void *hash_head,
- void (*iter_action)(void *));
+ void (*iter_action)(void *, void *),
+ void *user_ptr);
/* darshan_clean_file_path()
@@ -0,0 +1,56 @@
+ * Copyright (C) 2019 University of Chicago.
+ * See COPYRIGHT notice in top-level directory.
+#ifndef __DARSHAN_DXT_H
+#define __DARSHAN_DXT_H
+/* dxt_load_trigger_conf()
+ * DXT function exposed to Darshan core to read in any trace triggers
+ * from the file path in 'trigger_conf_path' before module
+ * initialization occurs.
+void dxt_load_trigger_conf(
+ char *trigger_conf_path);
+/* dxt_posix_runtime_initialize()
+ * DXT function exposed to POSIX module for initializing DXT-POSIX runtime.
+void dxt_posix_runtime_initialize(void);
+/* dxt_mpiio_runtime_initialize()
+ * DXT function exposed to MPIIO module for initializing DXT-MPIIO runtime.
+void dxt_mpiio_runtime_initialize(void);
+/* dxt_posix_write(), dxt_posix_read()
+ * DXT function to trace a POSIX write/read call to file record 'rec_id',
+ * at offset 'offset' and with 'length' size. 'start_time' and 'end_time'
+ * are starting and ending timestamps for the operation, respectively.
+void dxt_posix_write(darshan_record_id rec_id, int64_t offset,
+ int64_t length, double start_time, double end_time);
+void dxt_posix_read(darshan_record_id rec_id, int64_t offset,
+/* dxt_mpiio_write(), dxt_mpiio_read()
+ * DXT function to trace a MPIIO write/read call to file record 'rec_id',
+ * with 'length' size. 'start_time' and 'end_time' are starting and ending
+ * timestamps for the operation, respectively.
+void dxt_mpiio_write(darshan_record_id rec_id, int64_t length,
+ double start_time, double end_time);
+void dxt_mpiio_read(darshan_record_id rec_id, int64_t length,
+void dxt_posix_filter_dynamic_traces(
+ struct darshan_posix_file *(*rec_id_to_psx_file)(darshan_record_id));
+#endif /* __DARSHAN_DXT_H */
@@ -103,7 +103,8 @@ void darshan_clear_record_refs(void **hash_head_p, int free_flag)
return;
-void darshan_iter_record_refs(void *hash_head, void (*iter_action)(void *))
+void darshan_iter_record_refs(void *hash_head, void (*iter_action)(void *, void *),
+ void *user_ptr)
struct darshan_record_ref_tracker *ref_tracker, *tmp;
struct darshan_record_ref_tracker *ref_tracker_head =
@@ -114,7 +115,7 @@ void darshan_iter_record_refs(void *hash_head, void (*iter_action)(void *))
HASH_ITER(hlink, ref_tracker_head, ref_tracker, tmp)
- iter_action(ref_tracker->rec_ref_p);
+ iter_action(ref_tracker->rec_ref_p, user_ptr);
return;
@@ -34,6 +34,7 @@
#include "darshan.h"
#include "darshan-core.h"
#include "darshan-dynamic.h"
+#include "darshan-dxt.h"
#ifdef DARSHAN_LUSTRE
#include <lustre/lustre_user.h>
@@ -308,6 +309,13 @@ void darshan_core_initialize(int argc, char **argv)
/* collect information about command line and mounted file systems */
darshan_get_exe_and_mounts(init_core, argc, argv);
+ /* determine if/when DXT should be enabled by looking for triggers */
+ char *trigger_conf = getenv("DARSHAN_DXT_TRIGGER_CONF_PATH");
+ if(trigger_conf)
+ dxt_load_trigger_conf(trigger_conf);
/* if darshan was successfully initialized, set the global pointer
* and bootstrap any modules with static initialization routines
@@ -24,11 +24,13 @@
#include <assert.h>
#include <libgen.h>
#include <pthread.h>
+#include <regex.h>
#include "utlist.h"
#include "uthash.h"
#ifndef HAVE_OFF64_T
typedef int64_t off64_t;
@@ -79,6 +81,8 @@ struct dxt_file_record_ref
segment_info *write_traces;
segment_info *read_traces;
+ char trace_enabled;
/* The dxt_runtime structure maintains necessary state for storing
@@ -101,24 +105,46 @@ struct dxt_mpiio_runtime
int record_buf_size;
-/* dxt read/write instrumentation wrappers for POSIX and MPI-IO */
-void dxt_posix_write(darshan_record_id rec_id, int64_t offset,
- int64_t length, double start_time, double end_time);
-void dxt_posix_read(darshan_record_id rec_id, int64_t offset,
-void dxt_mpiio_write(darshan_record_id rec_id, int64_t length,
- double start_time, double end_time);
-void dxt_mpiio_read(darshan_record_id rec_id, int64_t length,
+enum dxt_trigger_type
+ DXT_FILE_TRIGGER,
+ DXT_RANK_TRIGGER,
+ DXT_SMALL_IO_TRIGGER,
+ DXT_UNALIGNED_IO_TRIGGER
+struct dxt_trigger_info
+ int type;
+ union {
+ struct
+ regex_t regex;
+ } file;
+ struct
+ regex_t regex;
+ } rank;
+ struct
+ double thresh_pct;
+ } small_io;
+ struct
+ } unaligned_io;
+ } u;
+/* internal helper routines */
+static int dxt_should_trace_rank(
+ int rank);
+static int dxt_should_trace_file(
+ darshan_record_id rec_id);
static void check_wr_trace_buf(
struct dxt_file_record_ref *rec_ref);
static void check_rd_trace_buf(
-static void dxt_posix_runtime_initialize(
- void);
-static void dxt_mpiio_runtime_initialize(
- void);
static struct dxt_file_record_ref *dxt_posix_track_new_file_record(
static struct dxt_file_record_ref *dxt_mpiio_track_new_file_record(
@@ -128,6 +154,7 @@ static void dxt_posix_cleanup_runtime(
static void dxt_mpiio_cleanup_runtime(
void);
+/* DXT shutdown routines for darshan-core */
static void dxt_posix_shutdown(
MPI_Comm mod_comm, darshan_record_id *shared_recs,
int shared_rec_count, void **dxt_buf, int *dxt_buf_sz);
@@ -144,78 +171,225 @@ static int dxt_my_rank = -1;
static int dxt_total_mem = DXT_IO_TRACE_MEM_MAX;
static int dxt_mem_remaining = 0;
+#define MAX_DXT_TRIGGERS 20
+static int num_dxt_triggers = 0;
+static struct dxt_trigger_info dxt_triggers[MAX_DXT_TRIGGERS];
+static int dxt_use_file_triggers = 0;
+static int dxt_use_rank_triggers = 0;
+static int dxt_use_dynamic_triggers = 0;
+static int dxt_trace_all = 0;
#define DXT_LOCK() pthread_mutex_lock(&dxt_runtime_mutex)
#define DXT_UNLOCK() pthread_mutex_unlock(&dxt_runtime_mutex)
+ * DXT routines exposed to Darshan core and other modules *
- * Wrappers for DXT I/O functions of interest *
-static void check_wr_trace_buf(struct dxt_file_record_ref *rec_ref)
- struct dxt_file_record *file_rec = rec_ref->file_rec;
- int write_count = file_rec->write_count;
- int write_available_buf = rec_ref->write_available_buf;
+ FILE *fp;
+ char *line = NULL;
+ size_t len = 0;
+ char *tok;
+ struct dxt_trigger_info *next_trigger;
+ int ret;
- if (write_count >= write_available_buf) {
- int write_count_inc;
- if(write_available_buf == 0)
- write_count_inc = IO_TRACE_BUF_SIZE;
- else
- write_count_inc = write_available_buf;
+ fp = fopen(trigger_conf_path, "r");
+ if(!fp)
+ darshan_core_fprintf(stderr, "darshan library warning: "\
+ "unable to open DXT trigger config at path %s\n", trigger_conf_path);
+ return;
- DXT_LOCK();
- if((write_count_inc * sizeof(segment_info)) > dxt_mem_remaining)
- write_count_inc = dxt_mem_remaining / sizeof(segment_info);
+ while(getline(&line, &len, fp) != -1)
+ /* remove newline if present */
+ if(line[strlen(line) - 1] == '\n')
+ line[strlen(line) - 1] = '\0';
- dxt_mem_remaining -= (write_count_inc * sizeof(segment_info));
- DXT_UNLOCK();
+ next_trigger = &dxt_triggers[num_dxt_triggers];
- if(write_count_inc > 0)
+ /* extract trigger type and parameters */
+ tok = strtok(line, " \t");
+ if(strcmp(tok, "FILE") == 0)
- write_available_buf += write_count_inc;
- rec_ref->write_traces =
- (segment_info *)realloc(rec_ref->write_traces,
- write_available_buf * sizeof(segment_info));
- rec_ref->write_available_buf = write_available_buf;
+ next_trigger->type = DXT_FILE_TRIGGER;
+ tok += strlen(tok) + 1;
+ ret = regcomp(&next_trigger->u.file.regex, tok, REG_EXTENDED);
+ if(ret)
+ "unable to compile DXT trigger regex from %s\n", line);
+ continue;
+ dxt_use_file_triggers = 1;
+ else if(strcmp(tok, "RANK") == 0)
+ next_trigger->type = DXT_RANK_TRIGGER;
+ ret = regcomp(&next_trigger->u.rank.regex, tok, REG_EXTENDED);
+ if(ret)
+ continue;
+ dxt_use_rank_triggers= 1;
+ else if(strcmp(tok, "SMALL_IO") == 0)
+ next_trigger->type = DXT_SMALL_IO_TRIGGER;
+ next_trigger->u.small_io.thresh_pct = atof(tok);
+ dxt_use_dynamic_triggers= 1;
+ else if(strcmp(tok, "UNALIGNED_IO") == 0)
+ next_trigger->type = DXT_UNALIGNED_IO_TRIGGER;
+ next_trigger->u.unaligned_io.thresh_pct = atof(tok);
+ else
+ "unknown DXT trigger (%s) found in %s\n", tok, trigger_conf_path);
+ continue;
+ ++num_dxt_triggers;
+ fclose(fp);
+ free(line);
+ return;
-static void check_rd_trace_buf(struct dxt_file_record_ref *rec_ref)
+void dxt_posix_runtime_initialize()
+ /* DXT modules request 0 memory -- buffers will be managed internally by DXT
+ * and passed back to darshan-core at shutdown time to allow DXT more control
+ * over realloc'ing module memory as needed.
+ int dxt_psx_buf_size = 0;
+ int ret;
+ double tmpfloat;
+ char *envstr;
- int read_count = file_rec->read_count;
- int read_available_buf = rec_ref->read_available_buf;
+ /* determine whether tracing should be generally disabled/enabled */
+ if(getenv("DXT_ENABLE_IO_TRACE"))
+ dxt_trace_all = 1;
+ else if(getenv("DXT_DISABLE_IO_TRACE"))
+ return;
- if (read_count >= read_available_buf) {
- int read_count_inc;
- if(read_available_buf == 0)
- read_count_inc = IO_TRACE_BUF_SIZE;
- else
- read_count_inc = read_available_buf;
+ /* register the DXT module with darshan core */
+ darshan_core_register_module(
+ DXT_POSIX_MOD,
+ &dxt_posix_shutdown,
+ &dxt_psx_buf_size,
+ &dxt_my_rank,
+ NULL);
- DXT_LOCK();
- if((read_count_inc * sizeof(segment_info)) > dxt_mem_remaining)
- read_count_inc = dxt_mem_remaining / sizeof(segment_info);
+ /* return if darshan-core allocates an unexpected amount of memory */
+ if(dxt_psx_buf_size != 0)
+ darshan_core_unregister_module(DXT_POSIX_MOD);
+ return;
- dxt_mem_remaining -= (read_count_inc * sizeof(segment_info));
+ /* determine whether we should avoid tracing on this rank */
+ if(!dxt_should_trace_rank(dxt_my_rank))
+ if(!dxt_trace_all && !dxt_use_file_triggers && !dxt_use_dynamic_triggers)
+ /* nothing to trace, just back out */
+ return;
+ else
+ dxt_trace_all = 1; /* trace everything */
+ DXT_LOCK();
+ dxt_posix_runtime = malloc(sizeof(*dxt_posix_runtime));
+ if(!dxt_posix_runtime)
DXT_UNLOCK();
+ return;
+ memset(dxt_posix_runtime, 0, sizeof(*dxt_posix_runtime));
+ dxt_mem_remaining = dxt_total_mem;
+ DXT_UNLOCK();
- if(read_count_inc > 0)
+ return;
+void dxt_mpiio_runtime_initialize()
+ int dxt_mpiio_buf_size = 0;
+ int ret;
+ double tmpfloat;
+ char *envstr;
+ return;
+ DXT_MPIIO_MOD,
+ &dxt_mpiio_shutdown,
+ &dxt_mpiio_buf_size,
+ &dxt_my_rank,
+ NULL);
+ if(dxt_mpiio_buf_size != 0)
+ darshan_core_unregister_module(DXT_MPIIO_MOD);
+ return;
- read_available_buf += read_count_inc;
- rec_ref->read_traces =
- (segment_info *)realloc(rec_ref->read_traces,
- read_available_buf * sizeof(segment_info));
- rec_ref->read_available_buf = read_available_buf;
+ return;
+ else
+ DXT_LOCK();
+ dxt_mpiio_runtime = malloc(sizeof(*dxt_mpiio_runtime));
+ if(!dxt_mpiio_runtime)
+ DXT_UNLOCK();
+ return;
+ memset(dxt_mpiio_runtime, 0, sizeof(*dxt_mpiio_runtime));
+ dxt_mem_remaining = dxt_total_mem; /* XXX is this right? better with memory */
+ DXT_UNLOCK();
+ return;
@@ -223,21 +397,37 @@ void dxt_posix_write(darshan_record_id rec_id, int64_t offset,
struct dxt_file_record_ref* rec_ref = NULL;
struct dxt_file_record *file_rec;
+ int should_trace_file;
+ DXT_LOCK();
- /* make sure dxt posix runtime is initialized properly */
- dxt_posix_runtime_initialize();
- if(!dxt_posix_runtime) return;
+ DXT_UNLOCK();
+ return;
rec_ref = darshan_lookup_record_ref(dxt_posix_runtime->rec_id_hash,
&rec_id, sizeof(darshan_record_id));
if(!rec_ref)
+ /* check whether we should actually trace */
+ should_trace_file = dxt_should_trace_file(rec_id);
+ if(!should_trace_file && !dxt_trace_all && !dxt_use_dynamic_triggers)
+ DXT_UNLOCK();
+ return;
/* track new dxt file record */
rec_ref = dxt_posix_track_new_file_record(rec_id);
- if(!rec_ref) return;
+ if(!rec_ref)
+ DXT_UNLOCK();
+ return;
+ if(should_trace_file)
+ rec_ref->trace_enabled = 1;
@@ -246,6 +436,7 @@ void dxt_posix_write(darshan_record_id rec_id, int64_t offset,
/* no more memory for i/o segments ... back out */
SET_DXT_MOD_PARTIAL_FLAG(DXT_POSIX_MOD);
+ DXT_UNLOCK();
return;
@@ -254,6 +445,8 @@ void dxt_posix_write(darshan_record_id rec_id, int64_t offset,
rec_ref->write_traces[file_rec->write_count].start_time = start_time;
rec_ref->write_traces[file_rec->write_count].end_time = end_time;
file_rec->write_count += 1;
+ DXT_UNLOCK();
@@ -261,20 +454,37 @@ void dxt_posix_read(darshan_record_id rec_id, int64_t offset,
+ DXT_LOCK();
+ DXT_UNLOCK();
+ return;
- if (!rec_ref) {
+ if (!rec_ref)
+ DXT_UNLOCK();
+ return;
+ if(!rec_ref)
+ DXT_UNLOCK();
+ return;
@@ -283,6 +493,7 @@ void dxt_posix_read(darshan_record_id rec_id, int64_t offset,
+ DXT_UNLOCK();
return;
@@ -291,6 +502,8 @@ void dxt_posix_read(darshan_record_id rec_id, int64_t offset,
rec_ref->read_traces[file_rec->read_count].start_time = start_time;
rec_ref->read_traces[file_rec->read_count].end_time = end_time;
file_rec->read_count += 1;
+ DXT_UNLOCK();
@@ -298,21 +511,37 @@ void dxt_mpiio_write(darshan_record_id rec_id, int64_t length,
+ DXT_LOCK();
- /* make sure dxt mpiio runtime is initialized properly */
- dxt_mpiio_runtime_initialize();
- if(!dxt_mpiio_runtime) return;
+ DXT_UNLOCK();
+ return;
rec_ref = darshan_lookup_record_ref(dxt_mpiio_runtime->rec_id_hash,
if(!rec_ref)
+ DXT_UNLOCK();
+ return;
rec_ref = dxt_mpiio_track_new_file_record(rec_id);
+ if(!rec_ref)
+ DXT_UNLOCK();
+ return;
@@ -321,6 +550,7 @@ void dxt_mpiio_write(darshan_record_id rec_id, int64_t length,
SET_DXT_MOD_PARTIAL_FLAG(DXT_MPIIO_MOD);
+ DXT_UNLOCK();
return;
@@ -328,6 +558,8 @@ void dxt_mpiio_write(darshan_record_id rec_id, int64_t length,
+ DXT_UNLOCK();
@@ -335,21 +567,37 @@ void dxt_mpiio_read(darshan_record_id rec_id, int64_t length,
+ DXT_LOCK();
+ DXT_UNLOCK();
+ return;
if(!rec_ref)
+ DXT_UNLOCK();
+ return;
+ if(!rec_ref)
+ DXT_UNLOCK();
+ return;
@@ -358,6 +606,7 @@ void dxt_mpiio_read(darshan_record_id rec_id, int64_t length,
+ DXT_UNLOCK();
return;
@@ -365,118 +614,222 @@ void dxt_mpiio_read(darshan_record_id rec_id, int64_t length,
+ DXT_UNLOCK();
+static void dxt_posix_filter_dynamic_traces_iterator(void *rec_ref_p, void *user_ptr)
+ struct dxt_file_record_ref *psx_rec_ref, *mpiio_rec_ref;
+ struct darshan_posix_file *(*rec_id_to_psx_file)(darshan_record_id);
+ struct darshan_posix_file *psx_file;
+ int i;
+ int should_keep = 0;
- * Internal functions for manipulating DXT module state *
+ psx_rec_ref = (struct dxt_file_record_ref *)rec_ref_p;
+ if(psx_rec_ref->trace_enabled)
+ return; /* we're already tracing this file */
-/* initialize internal DXT module data structures and register with darshan-core */
-static void dxt_posix_runtime_initialize()
- /* DXT modules request 0 memory -- buffers will be managed internally by DXT
- * and passed back to darshan-core at shutdown time to allow DXT more control
- * over realloc'ing module memory as needed.
- int dxt_psx_buf_size = 0;
- int ret;
- double tmpfloat;
- char *envstr;
+ rec_id_to_psx_file = (struct darshan_posix_file *(*)(darshan_record_id))user_ptr;
+ psx_file = rec_id_to_psx_file(psx_rec_ref->file_rec->base_rec.id);
- /* register the DXT module with darshan core */
- darshan_core_register_module(
- DXT_POSIX_MOD,
- &dxt_posix_shutdown,
- &dxt_psx_buf_size,
- &dxt_my_rank,
- NULL);
+ /* analyze dynamic triggers to determine whether we should keep the record */
+ for(i = 0; i < num_dxt_triggers; i++)
+ switch(dxt_triggers[i].type)
+ case DXT_SMALL_IO_TRIGGER:
+ int total_ops = psx_file->counters[POSIX_WRITES] +
+ psx_file->counters[POSIX_READS];
+ int small_ops = psx_file->counters[POSIX_SIZE_WRITE_0_100] +
+ psx_file->counters[POSIX_SIZE_WRITE_100_1K] +
+ psx_file->counters[POSIX_SIZE_WRITE_1K_10K] +
+ psx_file->counters[POSIX_SIZE_READ_0_100] +
+ psx_file->counters[POSIX_SIZE_READ_100_1K] +
+ psx_file->counters[POSIX_SIZE_READ_1K_10K];
+ double small_pct = (small_ops / (double)(total_ops));
+ if(small_pct > dxt_triggers[i].u.small_io.thresh_pct)
+ should_keep = 1;
+ break;
+ case DXT_UNALIGNED_IO_TRIGGER:
+ int unaligned_ops = psx_file->counters[POSIX_FILE_NOT_ALIGNED];
+ double unaligned_pct = (unaligned_ops / (double)(total_ops));
+ if(unaligned_pct > dxt_triggers[i].u.unaligned_io.thresh_pct)
+ should_keep = 1;
+ break;
+ default:
+ continue;
+ if(should_keep)
+ break;
- /* return if darshan-core allocates an unexpected amount of memory */
- if(dxt_psx_buf_size != 0)
+ /* drop the record if no dynamic trace triggers occurred */
+ if(!should_keep)
- darshan_core_unregister_module(DXT_POSIX_MOD);
- return;
+ printf("DROP RECORD %lu on rank %d\n", psx_file->base_rec.id, dxt_my_rank);
+ /* first check the MPI-IO traces to see if we should drop there */
+ mpiio_rec_ref = darshan_delete_record_ref(&dxt_mpiio_runtime->rec_id_hash,
+ &psx_file->base_rec.id, sizeof(darshan_record_id));
+ if(mpiio_rec_ref)
+ free(mpiio_rec_ref->write_traces);
+ free(mpiio_rec_ref->read_traces);
+ free(mpiio_rec_ref->file_rec);
+ free(mpiio_rec_ref);
+ /* then delete the POSIX trace records */
+ psx_rec_ref = darshan_delete_record_ref(&dxt_posix_runtime->rec_id_hash,
+ if(psx_rec_ref)
+ free(psx_rec_ref->write_traces);
+ free(psx_rec_ref->read_traces);
+ free(psx_rec_ref->file_rec);
+ free(psx_rec_ref);
+ return;
DXT_LOCK();
- dxt_posix_runtime = malloc(sizeof(*dxt_posix_runtime));
+ if(!dxt_posix_runtime || !dxt_use_dynamic_triggers || dxt_trace_all)
DXT_UNLOCK();
return;
- memset(dxt_posix_runtime, 0, sizeof(*dxt_posix_runtime));
- /* set the memory quota for DXT, if it has not been initialized */
- envstr = getenv("DXT_ENABLE_IO_TRACE");
- if(envstr && dxt_mpiio_runtime == NULL)
- ret = sscanf(envstr, "%lf", &tmpfloat);
- /* silently ignore if the env variable is set poorly */
- if(ret == 1 && tmpfloat > 0)
- dxt_total_mem = tmpfloat * 1024 * 1024; /* convert from MiB */
- dxt_mem_remaining = dxt_total_mem;
+ darshan_iter_record_refs(dxt_posix_runtime->rec_id_hash,
+ dxt_posix_filter_dynamic_traces_iterator, rec_id_to_psx_file);
DXT_UNLOCK();
return;
-void dxt_mpiio_runtime_initialize()
+ * internal DXT helper routines *
+static int dxt_should_trace_rank(int my_rank)
- int dxt_mpiio_buf_size = 0;
- int ret;
- double tmpfloat;
- char *envstr;
+ int i;
+ char rank_str[16] = {0};
- DXT_MPIIO_MOD,
- &dxt_mpiio_shutdown,
- &dxt_mpiio_buf_size,
- &dxt_my_rank,
- NULL);
+ sprintf(rank_str, "%d", my_rank);
- if(dxt_mpiio_buf_size != 0)
+ if(!dxt_use_rank_triggers)
+ return(0);
- darshan_core_unregister_module(DXT_MPIIO_MOD);
- return;
+ if((dxt_triggers[i].type == DXT_RANK_TRIGGER) &&
+ (regexec(&dxt_triggers[i].u.rank.regex, rank_str, 0, NULL, 0) == 0))
+ return(1);
- DXT_LOCK();
- dxt_mpiio_runtime = malloc(sizeof(*dxt_mpiio_runtime));
+ return(0);
+static int dxt_should_trace_file(darshan_record_id rec_id)
+ char *rec_name;
+ int i;
+ if(!dxt_use_file_triggers)
+ return(0);
+ rec_name = darshan_core_lookup_record_name(rec_id);
+ if(rec_name)
- DXT_UNLOCK();
- return;
+ /* compare file name against cached triggers to see if we should trace */
+ if((dxt_triggers[i].type == DXT_FILE_TRIGGER) &&
+ (regexec(&dxt_triggers[i].u.file.regex, rec_name, 0, NULL, 0) == 0))
+ return(1);
- memset(dxt_mpiio_runtime, 0, sizeof(*dxt_mpiio_runtime));
- if(envstr && dxt_posix_runtime == NULL)
+ return(0);
+static void check_wr_trace_buf(struct dxt_file_record_ref *rec_ref)
+ struct dxt_file_record *file_rec = rec_ref->file_rec;
+ int write_count = file_rec->write_count;
+ int write_available_buf = rec_ref->write_available_buf;
+ if (write_count >= write_available_buf) {
+ int write_count_inc;
+ if(write_available_buf == 0)
+ write_count_inc = IO_TRACE_BUF_SIZE;
+ else
+ write_count_inc = write_available_buf;
+ DXT_LOCK();
+ if((write_count_inc * sizeof(segment_info)) > dxt_mem_remaining)
+ write_count_inc = dxt_mem_remaining / sizeof(segment_info);
+ dxt_mem_remaining -= (write_count_inc * sizeof(segment_info));
+ DXT_UNLOCK();
+ if(write_count_inc > 0)
+ write_available_buf += write_count_inc;
+ rec_ref->write_traces =
+ (segment_info *)realloc(rec_ref->write_traces,
+ write_available_buf * sizeof(segment_info));
+ rec_ref->write_available_buf = write_available_buf;
- DXT_UNLOCK();
- return;
+static void check_rd_trace_buf(struct dxt_file_record_ref *rec_ref)
+ int read_count = file_rec->read_count;
+ int read_available_buf = rec_ref->read_available_buf;
+ if (read_count >= read_available_buf) {
+ int read_count_inc;
+ if(read_available_buf == 0)
+ read_count_inc = IO_TRACE_BUF_SIZE;
+ else
+ read_count_inc = read_available_buf;
+ DXT_LOCK();
+ if((read_count_inc * sizeof(segment_info)) > dxt_mem_remaining)
+ read_count_inc = dxt_mem_remaining / sizeof(segment_info);
+ dxt_mem_remaining -= (read_count_inc * sizeof(segment_info));
+ DXT_UNLOCK();
+ if(read_count_inc > 0)
+ read_available_buf += read_count_inc;
+ rec_ref->read_traces =
+ (segment_info *)realloc(rec_ref->read_traces,
+ read_available_buf * sizeof(segment_info));
+ rec_ref->read_available_buf = read_available_buf;
@@ -555,6 +908,7 @@ static struct dxt_file_record_ref *dxt_mpiio_track_new_file_record(
rec_ref = malloc(sizeof(*rec_ref));
if(!rec_ref)
DXT_UNLOCK();
return(NULL);
@@ -595,7 +949,7 @@ static struct dxt_file_record_ref *dxt_mpiio_track_new_file_record(
return(rec_ref);
-static void dxt_free_record_data(void *rec_ref_p)
+static void dxt_free_record_data(void *rec_ref_p, void *user_ptr)
struct dxt_file_record_ref *dxt_rec_ref = (struct dxt_file_record_ref *)rec_ref_p;
@@ -606,7 +960,8 @@ static void dxt_free_record_data(void *rec_ref_p)
static void dxt_posix_cleanup_runtime()
- darshan_iter_record_refs(dxt_posix_runtime->rec_id_hash, dxt_free_record_data);
+ dxt_free_record_data, NULL);
darshan_clear_record_refs(&(dxt_posix_runtime->rec_id_hash), 1);
free(dxt_posix_runtime);
@@ -617,7 +972,8 @@ static void dxt_posix_cleanup_runtime()
static void dxt_mpiio_cleanup_runtime()
- darshan_iter_record_refs(dxt_mpiio_runtime->rec_id_hash, dxt_free_record_data);
+ darshan_iter_record_refs(dxt_mpiio_runtime->rec_id_hash,
darshan_clear_record_refs(&(dxt_mpiio_runtime->rec_id_hash), 1);
free(dxt_mpiio_runtime);
@@ -626,12 +982,11 @@ static void dxt_mpiio_cleanup_runtime()
return;
* shutdown function exported by this module for coordinating with darshan-core *
-static void dxt_serialize_posix_records(void *rec_ref_p)
+static void dxt_serialize_posix_records(void *rec_ref_p, void *user_ptr)
struct dxt_file_record_ref *rec_ref = (struct dxt_file_record_ref *)rec_ref_p;
@@ -732,7 +1087,8 @@ static void dxt_posix_shutdown(
dxt_posix_runtime->record_buf_size = 0;
/* iterate all dxt posix records and serialize them to the output buffer */
- darshan_iter_record_refs(dxt_posix_runtime->rec_id_hash, dxt_serialize_posix_records);
+ dxt_serialize_posix_records, NULL);
/* set output */
*dxt_posix_buf = dxt_posix_runtime->record_buf;
@@ -744,7 +1100,7 @@ static void dxt_posix_shutdown(
return;
-static void dxt_serialize_mpiio_records(void *rec_ref_p)
+static void dxt_serialize_mpiio_records(void *rec_ref_p, void *user_ptr)
@@ -842,7 +1198,8 @@ static void dxt_mpiio_shutdown(
dxt_mpiio_runtime->record_buf_size = 0;
- darshan_iter_record_refs(dxt_mpiio_runtime->rec_id_hash, dxt_serialize_mpiio_records);
+ dxt_serialize_mpiio_records, NULL);
/* set output */
*dxt_mpiio_buf = dxt_mpiio_runtime->record_buf;
@@ -27,9 +27,9 @@
static void lustre_runtime_initialize(
void);
static void lustre_subtract_shared_rec_size(
- void *rec_ref_p);
+ void *rec_ref_p, void *user_ptr);
static void lustre_set_rec_ref_pointers(
- void *rec_ref_p);
static int lustre_record_compare(
const void* a_p, const void* b_p);
int sort_lustre_records(
@@ -266,7 +266,7 @@ static void lustre_shutdown(
if (my_rank != 0)
darshan_iter_record_refs(lustre_runtime->record_id_hash,
- &lustre_subtract_shared_rec_size);
+ &lustre_subtract_shared_rec_size, NULL);
@@ -282,7 +282,7 @@ static void lustre_shutdown(
return;
-static void lustre_subtract_shared_rec_size(void *rec_ref_p)
+static void lustre_subtract_shared_rec_size(void *rec_ref_p, void *user_ptr)
struct lustre_record_ref *l_rec_ref = (struct lustre_record_ref *)rec_ref_p;
@@ -291,7 +291,7 @@ static void lustre_subtract_shared_rec_size(void *rec_ref_p)
LUSTRE_RECORD_SIZE( l_rec_ref->record->counters[LUSTRE_STRIPE_WIDTH] );
-static void lustre_set_rec_ref_pointers(void *rec_ref_p)
+static void lustre_set_rec_ref_pointers(void *rec_ref_p, void *user_ptr)
lustre_runtime->record_ref_array[lustre_runtime->record_ref_array_ndx] = rec_ref_p;
lustre_runtime->record_ref_array_ndx++;
@@ -356,7 +356,7 @@ int sort_lustre_records()
/* build the array of record reference pointers we want to sort */
- &lustre_set_rec_ref_pointers);
+ &lustre_set_rec_ref_pointers, NULL);
/* qsort breaks the hash table, so delete it now to free its memory buffers
* and prevent later confusion */
@@ -578,7 +578,7 @@ static void mdhim_shutdown(
if (my_rank != 0)
darshan_iter_record_refs(mdhim_runtime->rec_id_hash,
- &mdhim_subtract_shared_rec_size);
+ &mdhim_subtract_shared_rec_size, NULL);
*mdhim_buf_sz = mdhim_rec_count * mdhim_runtime->record_buffer_size;
@@ -24,6 +24,7 @@
DARSHAN_FORWARD_DECL(PMPI_File_close, int, (MPI_File *fh));
DARSHAN_FORWARD_DECL(PMPI_File_iread_at, int, (MPI_File fh, MPI_Offset offset, void *buf, int count, MPI_Datatype datatype, __D_MPI_REQUEST *request));
@@ -159,7 +160,7 @@ static void mpiio_runtime_initialize(
static struct mpiio_file_record_ref *mpiio_track_new_file_record(
darshan_record_id rec_id, const char *path);
static void mpiio_finalize_file_records(
- void *rec_ref_p);
static void mpiio_record_reduction_op(
void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
static void mpiio_shared_record_variance(
@@ -172,16 +173,9 @@ static void mpiio_shutdown(
int shared_rec_count, void **mpiio_buf, int *mpiio_buf_sz);
-/* extern DXT function defs */
-extern void dxt_mpiio_write(darshan_record_id rec_id, int64_t length,
-extern void dxt_mpiio_read(darshan_record_id rec_id, int64_t length,
static struct mpiio_runtime *mpiio_runtime = NULL;
static pthread_mutex_t mpiio_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
static int my_rank = -1;
-static int enable_dxt_io_trace = 0;
#define MPIIO_LOCK() pthread_mutex_lock(&mpiio_runtime_mutex)
#define MPIIO_UNLOCK() pthread_mutex_unlock(&mpiio_runtime_mutex)
@@ -249,9 +243,7 @@ static int enable_dxt_io_trace = 0;
PMPI_Type_size(__datatype, &size); \
size = size * __count; \
/* DXT to record detailed read tracing information */ \
- if(enable_dxt_io_trace) { \
- dxt_mpiio_read(rec_ref->file_rec->base_rec.id, size, __tm1, __tm2); \
+ dxt_mpiio_read(rec_ref->file_rec->base_rec.id, size, __tm1, __tm2); \
DARSHAN_BUCKET_INC(&(rec_ref->file_rec->counters[MPIIO_SIZE_READ_AGG_0_100]), size); \
darshan_common_val_counter(&rec_ref->access_root, &rec_ref->access_count, size, \
&(rec_ref->file_rec->counters[MPIIO_ACCESS1_ACCESS]), \
@@ -281,10 +273,8 @@ static int enable_dxt_io_trace = 0;
if(!rec_ref) break; \
- /* DXT to record detailed write tracing information */ \
- dxt_mpiio_write(rec_ref->file_rec->base_rec.id, size, __tm1, __tm2); \
+ /* DXT to record detailed write tracing information */ \
+ dxt_mpiio_write(rec_ref->file_rec->base_rec.id, size, __tm1, __tm2); \
DARSHAN_BUCKET_INC(&(rec_ref->file_rec->counters[MPIIO_SIZE_WRITE_AGG_0_100]), size); \
@@ -1142,10 +1132,8 @@ static void mpiio_runtime_initialize()
memset(mpiio_runtime, 0, sizeof(*mpiio_runtime));
- /* check if DXT (Darshan extended tracing) should be enabled */
- if (getenv("DXT_ENABLE_IO_TRACE")) {
- enable_dxt_io_trace = 1;
+ /* allow DXT module to initialize if needed */
+ dxt_mpiio_runtime_initialize();
return;
@@ -1198,7 +1186,7 @@ static struct mpiio_file_record_ref *mpiio_track_new_file_record(
return(rec_ref);
-static void mpiio_finalize_file_records(void *rec_ref_p)
+static void mpiio_finalize_file_records(void *rec_ref_p, void *user_ptr)
struct mpiio_file_record_ref *rec_ref =
(struct mpiio_file_record_ref *)rec_ref_p;
@@ -1586,7 +1574,8 @@ static void mpiio_shutdown(
/* perform any final transformations on MPIIO file records before
* writing them out to log file
- darshan_iter_record_refs(mpiio_runtime->rec_id_hash, &mpiio_finalize_file_records);
+ darshan_iter_record_refs(mpiio_runtime->rec_id_hash,
+ &mpiio_finalize_file_records, NULL);
/* if there are globally shared files, do a shared file reduction */
/* NOTE: the shared file reduction is also skipped if the
@@ -29,6 +29,7 @@
#include "utlist.h"
@@ -152,7 +153,7 @@ static void posix_aio_tracker_add(
static struct posix_aio_tracker* posix_aio_tracker_del(
int fd, void *aiocbp);
static void posix_finalize_file_records(
- void *rec_ref_p);
static void posix_record_reduction_op(
static void posix_shared_record_variance(
@@ -165,12 +166,6 @@ static void posix_shutdown(
int shared_rec_count, void **posix_buf, int *posix_buf_sz);
-extern void dxt_posix_write(darshan_record_id rec_id, int64_t offset,
-extern void dxt_posix_read(darshan_record_id rec_id, int64_t offset,
/* extern function def for querying record name from a STDIO stream */
extern char *darshan_stdio_lookup_record_name(FILE *stream);
@@ -178,7 +173,6 @@ static struct posix_runtime *posix_runtime = NULL;
static pthread_mutex_t posix_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
static int darshan_mem_alignment = 1;
#define POSIX_LOCK() pthread_mutex_lock(&posix_runtime_mutex)
#define POSIX_UNLOCK() pthread_mutex_unlock(&posix_runtime_mutex)
@@ -259,9 +253,7 @@ static int enable_dxt_io_trace = 0;
else \
this_offset = rec_ref->offset; \
- dxt_posix_read(rec_ref->file_rec->base_rec.id, this_offset, __ret, __tm1, __tm2); \
+ dxt_posix_read(rec_ref->file_rec->base_rec.id, this_offset, __ret, __tm1, __tm2); \
if(this_offset > rec_ref->last_byte_read) \
rec_ref->file_rec->counters[POSIX_SEQ_READS] += 1; \
if(this_offset == (rec_ref->last_byte_read + 1)) \
@@ -317,9 +309,7 @@ static int enable_dxt_io_trace = 0;
else \
- dxt_posix_write(rec_ref->file_rec->base_rec.id, this_offset, __ret, __tm1, __tm2); \
+ dxt_posix_write(rec_ref->file_rec->base_rec.id, this_offset, __ret, __tm1, __tm2); \
if(this_offset > rec_ref->last_byte_written) \
rec_ref->file_rec->counters[POSIX_SEQ_WRITES] += 1; \
if(this_offset == (rec_ref->last_byte_written + 1)) \
@@ -1506,10 +1496,8 @@ static void posix_runtime_initialize()
memset(posix_runtime, 0, sizeof(*posix_runtime));
+ dxt_posix_runtime_initialize();
return;
@@ -1618,7 +1606,7 @@ static void posix_aio_tracker_add(int fd, void *aiocbp)
return;
-static void posix_finalize_file_records(void *rec_ref_p)
+static void posix_finalize_file_records(void *rec_ref_p, void *user_ptr)
struct posix_file_record_ref *rec_ref =
(struct posix_file_record_ref *)rec_ref_p;
@@ -1971,6 +1959,18 @@ char *darshan_posix_lookup_record_name(int fd)
return(rec_name);
+static struct darshan_posix_file *darshan_posix_rec_id_to_file(darshan_record_id rec_id)
+ struct posix_file_record_ref *rec_ref;
+ rec_ref = darshan_lookup_record_ref(posix_runtime->rec_id_hash,
+ &rec_id, sizeof(darshan_record_id));
+ if(rec_ref)
+ return(rec_ref->file_rec);
+ else
+ return(NULL);
/* posix module shutdown benchmark routine */
void darshan_posix_shutdown_bench_setup(int test_case)
@@ -2067,12 +2067,16 @@ static void posix_shutdown(
POSIX_LOCK();
assert(posix_runtime);
+ /* allow DXT a chance to filter traces based on dynamic triggers */
+ dxt_posix_filter_dynamic_traces(darshan_posix_rec_id_to_file);
posix_rec_count = posix_runtime->file_rec_count;
/* perform any final transformations on POSIX file records before
- darshan_iter_record_refs(posix_runtime->rec_id_hash, &posix_finalize_file_records);
+ darshan_iter_record_refs(posix_runtime->rec_id_hash,
+ &posix_finalize_file_records, NULL);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/07e48c1167de94399bce1d230aa114acccdcb227...35a35fe575f618a2c2564c5578fc173dbf03c4ea
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20190909/2ac8a0fb/attachment-0001.html>
More information about the Darshan-commits
