[Darshan-commits] [Git][darshan/darshan][dev-no-mpi] 2 commits: fix redundant MPIIO autoconf output
Shane Snyder
xgitlab at cels.anl.gov
Mon Nov 11 16:52:40 CST 2019
Shane Snyder pushed to branch dev-no-mpi at darshan / darshan
Commits:
6f70e04b by Shane Snyder at 2019-08-12T21:52:12Z
640275d2 by Shane Snyder at 2019-11-11T22:51:50Z
port mpiio, pnetcdf, stdio to non-mpi changes
10 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-core.h
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-core-init-finalize.c
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-pnetcdf.c
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/lib/darshan-stdio.c
Changes:
@@ -5898,13 +5898,6 @@ else
{ $as_echo "$as_me:${as_lineno-$LINENO}: NULL module support: yes" >&5
$as_echo "$as_me: NULL module support: yes" >&6;}
fi
-if test "x$BUILD_MPIIO_MODULE" = "x"; then :
- { $as_echo "$as_me:${as_lineno-$LINENO}: MPIIO module support: no" >&5
-$as_echo "$as_me: MPIIO module support: no" >&6;}
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: MPIIO module support: yes" >&5
-$as_echo "$as_me: MPIIO module support: yes" >&6;}
-fi
if test "x$BUILD_POSIX_MODULE" = "x"; then :
{ $as_echo "$as_me:${as_lineno-$LINENO}: POSIX module support: no" >&5
$as_echo "$as_me: POSIX module support: no" >&6;}
@@ -503,7 +503,6 @@ share/ld-opts/darshan-base-ld-opts
AC_MSG_NOTICE(Building Darshan with the following features:)
AS_IF([test "x$BUILD_NULL_MODULE" = "x"], [AC_MSG_NOTICE(NULL module support: no)], [AC_MSG_NOTICE(NULL module support: yes)])
-AS_IF([test "x$BUILD_MPIIO_MODULE" = "x"], [AC_MSG_NOTICE(MPIIO module support: no)], [AC_MSG_NOTICE(MPIIO module support: yes)])
AS_IF([test "x$BUILD_POSIX_MODULE" = "x"], [AC_MSG_NOTICE(POSIX module support: no)], [AC_MSG_NOTICE(POSIX module support: yes)])
AS_IF([test "x$BUILD_STDIO_MODULE" = "x"], [AC_MSG_NOTICE(STDIO module support: no)], [AC_MSG_NOTICE(STDIO module support: yes)])
@@ -37,6 +37,9 @@
/* Environment variable to override memory per module */
#define DARSHAN_MOD_MEM_OVERRIDE "DARSHAN_MODMEM"
+/* Environment variable to enable profiling without MPI */
+#define DARSHAN_ENABLE_NONMPI "DARSHAN_ENABLE_NONMPI"
#ifdef __DARSHAN_ENABLE_MMAP_LOGS
/* Environment variable to override default mmap log path */
#define DARSHAN_MMAP_LOG_PATH_OVERRIDE "DARSHAN_MMAP_LOGPATH"
@@ -146,10 +146,10 @@ void darshan_instrument_fs_data(
* shutdown functionality (including a possible data reduction step when
* using MPI). 'inout_mod_buf_size' is an input/output argument, with it
* being set to the requested amount of module memory on input, and set to
- * the amount allocated by darshan-core on output. If given, 'rank' is
- * a pointer to an integer which will contain the calling process's
- * MPI rank on return. If given, 'sys_mem_alignment' is a pointer to
- * an integer which will contain the memory alignment value Darshan
+ * the amount allocated by darshan-core on output. If Darshan is built with
+ * MPI support, 'rank' is a pointer to an integer which will contain the
+ * calling process's MPI rank on return. If given, 'sys_mem_alignment' is a
+ * pointer to an integer which will contain the memory alignment value Darshan
* was configured with on return.
void darshan_core_register_module(
@@ -86,6 +86,29 @@ int DARSHAN_DECL(MPI_Finalize)(void)
DARSHAN_WRAPPER_MAP(PMPI_Finalize, int, (void), MPI_Finalize())
+ * Initialization hook that does not rely on MPI
+#ifdef __GNUC__
+__attribute__((constructor)) void serial_init(void)
+ char *no_mpi;
+ no_mpi = getenv(DARSHAN_ENABLE_NONMPI);
+ if (no_mpi)
+ darshan_core_initialize(0, NULL);
+ return;
+__attribute__((destructor)) void serial_finalize(void)
+ char *no_mpi;
+ if (no_mpi)
+ darshan_core_shutdown();
+ return;
+#endif
* Local variables:
* c-indent-level: 4
@@ -430,6 +430,7 @@ void darshan_core_shutdown()
DARSHAN_CORE_UNLOCK();
/* grab some initial timing information */
+ /* XXX move to MPI_Finalize wrapper */
#ifdef HAVE_MPI
/* if using mpi, sync across procs first */
if(using_mpi)
@@ -160,17 +160,20 @@ static struct mpiio_file_record_ref *mpiio_track_new_file_record(
darshan_record_id rec_id, const char *path);
static void mpiio_finalize_file_records(
void *rec_ref_p);
+static void mpiio_cleanup_runtime(
+ void);
+#ifdef HAVE_MPI
static void mpiio_record_reduction_op(
void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
static void mpiio_shared_record_variance(
MPI_Comm mod_comm, struct darshan_mpiio_file *inrec_array,
struct darshan_mpiio_file *outrec_array, int shared_rec_count);
-static void mpiio_cleanup_runtime(
- void);
+static void mpiio_mpi_redux(
+ void *mpiio_buf, MPI_Comm mod_comm,
+ darshan_record_id *shared_recs, int shared_rec_count);
+#endif
static void mpiio_shutdown(
- MPI_Comm mod_comm, darshan_record_id *shared_recs,
- int shared_rec_count, void **mpiio_buf, int *mpiio_buf_sz);
+ void **mpiio_buf, int *mpiio_buf_sz);
/* extern DXT function defs */
extern void dxt_mpiio_write(darshan_record_id rec_id, int64_t length,
@@ -1115,6 +1118,12 @@ DARSHAN_WRAPPER_MAP(PMPI_File_close, int, (MPI_File *fh), MPI_File_close(fh))
static void mpiio_runtime_initialize()
int mpiio_buf_size;
+ darshan_module_funcs mod_funcs = {
+#ifdef HAVE_MPI
+ .mod_redux_func = &mpiio_mpi_redux,
+#endif
+ .mod_shutdown_func = &mpiio_shutdown
/* try and store the default number of records for this module */
mpiio_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_mpiio_file);
@@ -1122,7 +1131,7 @@ static void mpiio_runtime_initialize()
/* register the mpiio module with darshan core */
DARSHAN_MPIIO_MOD,
- &mpiio_shutdown,
+ mod_funcs,
&mpiio_buf_size,
&my_rank,
NULL);
@@ -1207,11 +1216,20 @@ static void mpiio_finalize_file_records(void *rec_ref_p)
return;
-static void mpiio_record_reduction_op(
- void* infile_v,
- void* inoutfile_v,
- int *len,
- MPI_Datatype *datatype)
+static void mpiio_cleanup_runtime()
+ darshan_clear_record_refs(&(mpiio_runtime->fh_hash), 0);
+ darshan_clear_record_refs(&(mpiio_runtime->rec_id_hash), 1);
+ free(mpiio_runtime);
+ mpiio_runtime = NULL;
+ return;
+#ifdef HAVE_MPI
+static void mpiio_record_reduction_op(void* infile_v, void* inoutfile_v,
+ int *len, MPI_Datatype *datatype)
struct darshan_mpiio_file tmp_file;
struct darshan_mpiio_file *infile = infile_v;
@@ -1465,17 +1483,7 @@ static void mpiio_shared_record_variance(MPI_Comm mod_comm,
return;
-static void mpiio_cleanup_runtime()
- darshan_clear_record_refs(&(mpiio_runtime->fh_hash), 0);
- darshan_clear_record_refs(&(mpiio_runtime->rec_id_hash), 1);
- free(mpiio_runtime);
- mpiio_runtime = NULL;
- return;
+#endif
/* mpiio module shutdown benchmark routine */
void darshan_mpiio_shutdown_bench_setup(int test_case)
@@ -1561,16 +1569,16 @@ void darshan_mpiio_shutdown_bench_setup(int test_case)
* shutdown function exported by this module for coordinating with darshan-core *
-static void mpiio_shutdown(
+#ifdef HAVE_MPI
+ void *mpiio_buf,
MPI_Comm mod_comm,
- void **mpiio_buf,
- int *mpiio_buf_sz)
+ int shared_rec_count)
- struct mpiio_file_record_ref *rec_ref;
- struct darshan_mpiio_file *mpiio_rec_buf = *(struct darshan_mpiio_file **)mpiio_buf;
int mpiio_rec_count;
+ struct mpiio_file_record_ref *rec_ref;
+ struct darshan_mpiio_file *mpiio_rec_buf = (struct darshan_mpiio_file *)mpiio_buf;
double mpiio_time;
struct darshan_mpiio_file *red_send_buf = NULL;
struct darshan_mpiio_file *red_recv_buf = NULL;
@@ -1583,37 +1591,26 @@ static void mpiio_shutdown(
mpiio_rec_count = mpiio_runtime->file_rec_count;
- /* perform any final transformations on MPIIO file records before
- * writing them out to log file
- darshan_iter_record_refs(mpiio_runtime->rec_id_hash, &mpiio_finalize_file_records);
- /* if there are globally shared files, do a shared file reduction */
- /* NOTE: the shared file reduction is also skipped if the
- * DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
- if(shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
+ /* necessary initialization of shared records */
+ for(i = 0; i < shared_rec_count; i++)
- /* necessary initialization of shared records */
- for(i = 0; i < shared_rec_count; i++)
- rec_ref = darshan_lookup_record_ref(mpiio_runtime->rec_id_hash,
- &shared_recs[i], sizeof(darshan_record_id));
- assert(rec_ref);
+ rec_ref = darshan_lookup_record_ref(mpiio_runtime->rec_id_hash,
+ &shared_recs[i], sizeof(darshan_record_id));
+ assert(rec_ref);
- mpiio_time =
+ mpiio_time =
rec_ref->file_rec->fcounters[MPIIO_F_READ_TIME] +
rec_ref->file_rec->fcounters[MPIIO_F_WRITE_TIME] +
rec_ref->file_rec->fcounters[MPIIO_F_META_TIME];
- /* initialize fastest/slowest info prior to the reduction */
- rec_ref->file_rec->counters[MPIIO_FASTEST_RANK] =
- rec_ref->file_rec->base_rec.rank;
- rec_ref->file_rec->counters[MPIIO_FASTEST_RANK_BYTES] =
- rec_ref->file_rec->counters[MPIIO_BYTES_READ] +
- rec_ref->file_rec->counters[MPIIO_BYTES_WRITTEN];
- rec_ref->file_rec->fcounters[MPIIO_F_FASTEST_RANK_TIME] =
- mpiio_time;
+ /* initialize fastest/slowest info prior to the reduction */
+ rec_ref->file_rec->counters[MPIIO_FASTEST_RANK] =
+ rec_ref->file_rec->base_rec.rank;
+ rec_ref->file_rec->counters[MPIIO_FASTEST_RANK_BYTES] =
+ rec_ref->file_rec->counters[MPIIO_BYTES_READ] +
+ rec_ref->file_rec->counters[MPIIO_BYTES_WRITTEN];
+ rec_ref->file_rec->fcounters[MPIIO_F_FASTEST_RANK_TIME] =
+ mpiio_time;
/* until reduction occurs, we assume that this rank is both
* the fastest and slowest. It is up to the reduction operator
@@ -1627,68 +1624,88 @@ static void mpiio_shutdown(
rec_ref->file_rec->fcounters[MPIIO_F_FASTEST_RANK_TIME];
rec_ref->file_rec->base_rec.rank = -1;
- /* sort the array of records so we get all of the shared records
- * (marked by rank -1) in a contiguous portion at end of the array
- darshan_record_sort(mpiio_rec_buf, mpiio_rec_count,
- sizeof(struct darshan_mpiio_file));
+ /* sort the array of records so we get all of the shared records
+ * (marked by rank -1) in a contiguous portion at end of the array
+ darshan_record_sort(mpiio_rec_buf, mpiio_rec_count,
+ sizeof(struct darshan_mpiio_file));
- /* make send_buf point to the shared files at the end of sorted array */
- red_send_buf = &(mpiio_rec_buf[mpiio_rec_count-shared_rec_count]);
+ /* make send_buf point to the shared files at the end of sorted array */
+ red_send_buf = &(mpiio_rec_buf[mpiio_rec_count-shared_rec_count]);
- /* allocate memory for the reduction output on rank 0 */
- if(my_rank == 0)
+ /* allocate memory for the reduction output on rank 0 */
+ if(my_rank == 0)
+ red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_mpiio_file));
+ if(!red_recv_buf)
- red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_mpiio_file));
- if(!red_recv_buf)
- MPIIO_UNLOCK();
- return;
+ MPIIO_UNLOCK();
+ return;
- /* construct a datatype for a MPIIO file record. This is serving no purpose
- * except to make sure we can do a reduction on proper boundaries
- PMPI_Type_contiguous(sizeof(struct darshan_mpiio_file),
- MPI_BYTE, &red_type);
- PMPI_Type_commit(&red_type);
- /* register a MPIIO file record reduction operator */
- PMPI_Op_create(mpiio_record_reduction_op, 1, &red_op);
+ /* construct a datatype for a MPIIO file record. This is serving no purpose
+ * except to make sure we can do a reduction on proper boundaries
+ PMPI_Type_contiguous(sizeof(struct darshan_mpiio_file),
+ MPI_BYTE, &red_type);
+ PMPI_Type_commit(&red_type);
- /* reduce shared MPIIO file records */
- PMPI_Reduce(red_send_buf, red_recv_buf,
- shared_rec_count, red_type, red_op, 0, mod_comm);
+ /* register a MPIIO file record reduction operator */
+ PMPI_Op_create(mpiio_record_reduction_op, 1, &red_op);
- /* get the time and byte variances for shared files */
- mpiio_shared_record_variance(mod_comm, red_send_buf, red_recv_buf,
- shared_rec_count);
+ /* reduce shared MPIIO file records */
+ PMPI_Reduce(red_send_buf, red_recv_buf,
+ shared_rec_count, red_type, red_op, 0, mod_comm);
- /* clean up reduction state */
- if(my_rank == 0)
- int tmp_ndx = mpiio_rec_count - shared_rec_count;
- memcpy(&(mpiio_rec_buf[tmp_ndx]), red_recv_buf,
- shared_rec_count * sizeof(struct darshan_mpiio_file));
- free(red_recv_buf);
- else
- mpiio_rec_count -= shared_rec_count;
+ /* get the time and byte variances for shared files */
+ mpiio_shared_record_variance(mod_comm, red_send_buf, red_recv_buf,
+ shared_rec_count);
- PMPI_Type_free(&red_type);
- PMPI_Op_free(&red_op);
+ /* clean up reduction state */
+ if(my_rank == 0)
+ int tmp_ndx = mpiio_rec_count - shared_rec_count;
+ memcpy(&(mpiio_rec_buf[tmp_ndx]), red_recv_buf,
+ shared_rec_count * sizeof(struct darshan_mpiio_file));
+ free(red_recv_buf);
+ else
+ mpiio_rec_count -= shared_rec_count;
- *mpiio_buf_sz = mpiio_rec_count * sizeof(struct darshan_mpiio_file);
+ PMPI_Type_free(&red_type);
+ PMPI_Op_free(&red_op);
+ MPIIO_UNLOCK();
+ return;
+#endif
+static void mpiio_shutdown(
+ void **mpiio_buf,
+ int *mpiio_buf_sz)
+ int mpiio_rec_count;
+ MPIIO_LOCK();
+ assert(mpiio_runtime);
+ mpiio_rec_count = mpiio_runtime->file_rec_count;
+ /* perform any final transformations on MPIIO file records before
+ * writing them out to log file
+ darshan_iter_record_refs(mpiio_runtime->rec_id_hash, &mpiio_finalize_file_records);
/* shutdown internal structures used for instrumenting */
mpiio_cleanup_runtime();
+ *mpiio_buf_sz = mpiio_rec_count * sizeof(struct darshan_mpiio_file);
MPIIO_UNLOCK();
return;
@@ -46,14 +46,17 @@ static void pnetcdf_runtime_initialize(
void);
static struct pnetcdf_file_record_ref *pnetcdf_track_new_file_record(
-static void pnetcdf_record_reduction_op(
- void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
static void pnetcdf_cleanup_runtime(
void);
+#ifdef HAVE_MPI
+static void pnetcdf_record_reduction_op(
+ void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
+static void pnetcdf_mpi_redux(
+ void *pnetcdf_buf, MPI_Comm mod_comm,
+#endif
static void pnetcdf_shutdown(
- int shared_rec_count, void **pnetcdf_buf, int *pnetcdf_buf_sz);
+ void **pnetcdf_buf, int *pnetcdf_buf_sz);
static struct pnetcdf_runtime *pnetcdf_runtime = NULL;
static pthread_mutex_t pnetcdf_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
@@ -210,6 +213,12 @@ int DARSHAN_DECL(ncmpi_close)(int ncid)
static void pnetcdf_runtime_initialize()
int pnetcdf_buf_size;
+#ifdef HAVE_MPI
+ .mod_redux_func = &pnetcdf_mpi_redux,
+#endif
+ .mod_shutdown_func = &pnetcdf_shutdown
pnetcdf_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_pnetcdf_file);
@@ -217,7 +226,7 @@ static void pnetcdf_runtime_initialize()
/* register pnetcdf module with darshan-core */
DARSHAN_PNETCDF_MOD,
- &pnetcdf_shutdown,
+ mod_funcs,
&pnetcdf_buf_size,
&my_rank,
NULL);
@@ -288,6 +297,18 @@ static struct pnetcdf_file_record_ref *pnetcdf_track_new_file_record(
return(rec_ref);
+static void pnetcdf_cleanup_runtime()
+ darshan_clear_record_refs(&(pnetcdf_runtime->ncid_hash), 0);
+ darshan_clear_record_refs(&(pnetcdf_runtime->rec_id_hash), 1);
+ free(pnetcdf_runtime);
+ pnetcdf_runtime = NULL;
+ return;
+#ifdef HAVE_MPI
static void pnetcdf_record_reduction_op(void* infile_v, void* inoutfile_v,
@@ -337,33 +358,22 @@ static void pnetcdf_record_reduction_op(void* infile_v, void* inoutfile_v,
return;
-static void pnetcdf_cleanup_runtime()
- darshan_clear_record_refs(&(pnetcdf_runtime->ncid_hash), 0);
- darshan_clear_record_refs(&(pnetcdf_runtime->rec_id_hash), 1);
- free(pnetcdf_runtime);
- pnetcdf_runtime = NULL;
- return;
+#endif
* Functions exported by PNETCDF module for coordinating with darshan-core *
-static void pnetcdf_shutdown(
+#ifdef HAVE_MPI
MPI_Comm mod_comm,
- void **pnetcdf_buf,
- int *pnetcdf_buf_sz)
- struct pnetcdf_file_record_ref *rec_ref;
- struct darshan_pnetcdf_file *pnetcdf_rec_buf =
- *(struct darshan_pnetcdf_file **)pnetcdf_buf;
int pnetcdf_rec_count;
+ struct pnetcdf_file_record_ref *rec_ref;
+ struct darshan_pnetcdf_file *pnetcdf_rec_buf = (struct darshan_pnetcdf_file *)pnetcdf_buf;
struct darshan_pnetcdf_file *red_send_buf = NULL;
struct darshan_pnetcdf_file *red_recv_buf = NULL;
MPI_Datatype red_type;
@@ -375,80 +385,88 @@ static void pnetcdf_shutdown(
pnetcdf_rec_count = pnetcdf_runtime->file_rec_count;
- rec_ref = darshan_lookup_record_ref(pnetcdf_runtime->rec_id_hash,
- assert(rec_ref);
- rec_ref->file_rec->base_rec.rank = -1;
+ rec_ref = darshan_lookup_record_ref(pnetcdf_runtime->rec_id_hash,
+ assert(rec_ref);
+ rec_ref->file_rec->base_rec.rank = -1;
- darshan_record_sort(pnetcdf_rec_buf, pnetcdf_rec_count,
- sizeof(struct darshan_pnetcdf_file));
+ darshan_record_sort(pnetcdf_rec_buf, pnetcdf_rec_count,
+ sizeof(struct darshan_pnetcdf_file));
- /* make *send_buf point to the shared files at the end of sorted array */
- red_send_buf = &(pnetcdf_rec_buf[pnetcdf_rec_count-shared_rec_count]);
+ /* make *send_buf point to the shared files at the end of sorted array */
+ red_send_buf = &(pnetcdf_rec_buf[pnetcdf_rec_count-shared_rec_count]);
- if(my_rank == 0)
+ if(my_rank == 0)
+ red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_pnetcdf_file));
+ if(!red_recv_buf)
- red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_pnetcdf_file));
- if(!red_recv_buf)
- PNETCDF_UNLOCK();
- return;
+ PNETCDF_UNLOCK();
+ return;
- /* construct a datatype for a PNETCDF file record. This is serving no purpose
- PMPI_Type_contiguous(sizeof(struct darshan_pnetcdf_file),
- /* register a PNETCDF file record reduction operator */
- PMPI_Op_create(pnetcdf_record_reduction_op, 1, &red_op);
+ /* construct a datatype for a PNETCDF file record. This is serving no purpose
+ PMPI_Type_contiguous(sizeof(struct darshan_pnetcdf_file),
- /* reduce shared PNETCDF file records */
+ /* register a PNETCDF file record reduction operator */
+ PMPI_Op_create(pnetcdf_record_reduction_op, 1, &red_op);
- if(my_rank == 0)
- int tmp_ndx = pnetcdf_rec_count - shared_rec_count;
- memcpy(&(pnetcdf_rec_buf[tmp_ndx]), red_recv_buf,
- shared_rec_count * sizeof(struct darshan_pnetcdf_file));
- else
- pnetcdf_rec_count -= shared_rec_count;
+ /* reduce shared PNETCDF file records */
+ if(my_rank == 0)
+ int tmp_ndx = pnetcdf_rec_count - shared_rec_count;
+ memcpy(&(pnetcdf_rec_buf[tmp_ndx]), red_recv_buf,
+ shared_rec_count * sizeof(struct darshan_pnetcdf_file));
+ else
+ pnetcdf_rec_count -= shared_rec_count;
- /* update output buffer size to account for shared file reduction */
- *pnetcdf_buf_sz = pnetcdf_rec_count * sizeof(struct darshan_pnetcdf_file);
+ PNETCDF_UNLOCK();
+ return;
+#endif
+static void pnetcdf_shutdown(
+ int *pnetcdf_buf_sz)
+ int pnetcdf_rec_count;
+ PNETCDF_LOCK();
+ assert(pnetcdf_runtime);
+ pnetcdf_rec_count = pnetcdf_runtime->file_rec_count;
pnetcdf_cleanup_runtime();
+ /* update output buffer size to account for shared file reduction */
+ *pnetcdf_buf_sz = pnetcdf_rec_count * sizeof(struct darshan_pnetcdf_file);
PNETCDF_UNLOCK();
return;
@@ -153,17 +153,14 @@ static struct posix_aio_tracker* posix_aio_tracker_del(
int fd, void *aiocbp);
static void posix_finalize_file_records(
void *rec_ref_p);
+static void posix_cleanup_runtime(
+ void);
#ifdef HAVE_MPI
static void posix_record_reduction_op(
static void posix_shared_record_variance(
MPI_Comm mod_comm, struct darshan_posix_file *inrec_array,
struct darshan_posix_file *outrec_array, int shared_rec_count);
-#endif
-static void posix_cleanup_runtime(
- void);
-#ifdef HAVE_MPI
static void posix_mpi_redux(
void *posix_buf, MPI_Comm mod_comm,
@@ -1640,6 +1637,17 @@ static void posix_finalize_file_records(void *rec_ref_p)
return;
+static void posix_cleanup_runtime()
+ darshan_clear_record_refs(&(posix_runtime->fd_hash), 0);
+ darshan_clear_record_refs(&(posix_runtime->rec_id_hash), 1);
+ free(posix_runtime);
+ posix_runtime = NULL;
+ return;
#ifdef HAVE_MPI
static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
@@ -1956,17 +1964,6 @@ static void posix_shared_record_variance(MPI_Comm mod_comm,
#endif
-static void posix_cleanup_runtime()
- darshan_clear_record_refs(&(posix_runtime->fd_hash), 0);
- darshan_clear_record_refs(&(posix_runtime->rec_id_hash), 1);
- free(posix_runtime);
- posix_runtime = NULL;
- return;
char *darshan_posix_lookup_record_name(int fd)
struct posix_file_record_ref *rec_ref;
@@ -2063,12 +2060,14 @@ void darshan_posix_shutdown_bench_setup(int test_case)
#ifdef HAVE_MPI
- void *posix_buf, MPI_Comm mod_comm,
- darshan_record_id *shared_recs, int shared_rec_count)
+ void *posix_buf,
+ MPI_Comm mod_comm,
int posix_rec_count;
- struct darshan_posix_file *posix_rec_buf = *(struct darshan_posix_file **)posix_buf;
+ struct darshan_posix_file *posix_rec_buf = (struct darshan_posix_file *)posix_buf;
double posix_time;
struct darshan_posix_file *red_send_buf = NULL;
struct darshan_posix_file *red_recv_buf = NULL;
@@ -146,21 +146,24 @@ static pthread_mutex_t stdio_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER
static int darshan_mem_alignment = 1;
static int my_rank = -1;
-static void stdio_runtime_initialize(void);
-static void stdio_shutdown(
- void **stdio_buf,
- int *stdio_buf_sz);
+static void stdio_runtime_initialize(
+ void);
+static struct stdio_file_record_ref *stdio_track_new_file_record(
+ darshan_record_id rec_id, const char *path);
+static void stdio_cleanup_runtime(
+ void);
+#ifdef HAVE_MPI
static void stdio_record_reduction_op(void* infile_v, void* inoutfile_v,
static void stdio_shared_record_variance(
MPI_Comm mod_comm, struct darshan_stdio_file *inrec_array,
struct darshan_stdio_file *outrec_array, int shared_rec_count);
-static struct stdio_file_record_ref *stdio_track_new_file_record(
- darshan_record_id rec_id, const char *path);
-static void stdio_cleanup_runtime();
+static void stdio_mpi_redux(
+ void *stdio_buf, MPI_Comm mod_comm,
+#endif
+static void stdio_shutdown(
+ void **stdio_buf, int *stdio_buf_sz);
/* extern function def for querying record name from a POSIX fd */
extern char *darshan_posix_lookup_record_name(int fd);
@@ -994,6 +997,12 @@ int DARSHAN_DECL(fsetpos64)(FILE *stream, const fpos64_t *pos)
static void stdio_runtime_initialize()
int stdio_buf_size;
+#ifdef HAVE_MPI
+ .mod_redux_func = &stdio_mpi_redux,
+#endif
+ .mod_shutdown_func = &stdio_shutdown
/* try to store default number of records for this module */
stdio_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_stdio_file);
@@ -1001,7 +1010,7 @@ static void stdio_runtime_initialize()
/* register the stdio module with darshan core */
DARSHAN_STDIO_MOD,
- &stdio_shutdown,
+ mod_funcs,
&stdio_buf_size,
&my_rank,
&darshan_mem_alignment);
@@ -1027,10 +1036,68 @@ static void stdio_runtime_initialize()
STDIO_RECORD_OPEN(stderr, "<STDERR>", 0, 0);
- * Functions exported by this module for coordinating with darshan-core *
+ struct darshan_stdio_file *file_rec = NULL;
+ struct stdio_file_record_ref *rec_ref = NULL;
+ struct darshan_fs_info fs_info;
+ int ret;
+ rec_ref = malloc(sizeof(*rec_ref));
+ if(!rec_ref)
+ return(NULL);
+ memset(rec_ref, 0, sizeof(*rec_ref));
+ /* add a reference to this file record based on record id */
+ ret = darshan_add_record_ref(&(stdio_runtime->rec_id_hash), &rec_id,
+ sizeof(darshan_record_id), rec_ref);
+ if(ret == 0)
+ free(rec_ref);
+ return(NULL);
+ /* register the actual file record with darshan-core so it is persisted
+ * in the log file
+ file_rec = darshan_core_register_record(
+ rec_id,
+ path,
+ DARSHAN_STDIO_MOD,
+ sizeof(struct darshan_stdio_file),
+ &fs_info);
+ if(!file_rec)
+ darshan_delete_record_ref(&(stdio_runtime->rec_id_hash),
+ &rec_id, sizeof(darshan_record_id));
+ free(rec_ref);
+ return(NULL);
+ /* registering this file record was successful, so initialize some fields */
+ file_rec->base_rec.id = rec_id;
+ file_rec->base_rec.rank = my_rank;
+ rec_ref->fs_type = fs_info.fs_type;
+ rec_ref->file_rec = file_rec;
+ stdio_runtime->file_rec_count++;
+ return(rec_ref);
+static void stdio_cleanup_runtime()
+ darshan_clear_record_refs(&(stdio_runtime->stream_hash), 0);
+ darshan_clear_record_refs(&(stdio_runtime->rec_id_hash), 1);
+ free(stdio_runtime);
+ stdio_runtime = NULL;
+ return;
+#ifdef HAVE_MPI
@@ -1138,228 +1205,6 @@ static void stdio_record_reduction_op(void* infile_v, void* inoutfile_v,
return;
- void **stdio_buf,
- struct stdio_file_record_ref *rec_ref;
- struct darshan_stdio_file *stdio_rec_buf = *(struct darshan_stdio_file **)stdio_buf;
- int i;
- struct darshan_stdio_file *red_send_buf = NULL;
- struct darshan_stdio_file *red_recv_buf = NULL;
- MPI_Datatype red_type;
- MPI_Op red_op;
- int stdio_rec_count;
- double stdio_time;
- STDIO_LOCK();
- assert(stdio_runtime);
- stdio_rec_count = stdio_runtime->file_rec_count;
- rec_ref = darshan_lookup_record_ref(stdio_runtime->rec_id_hash,
- assert(rec_ref);
- stdio_time =
- rec_ref->file_rec->fcounters[STDIO_F_READ_TIME] +
- rec_ref->file_rec->fcounters[STDIO_F_WRITE_TIME] +
- rec_ref->file_rec->fcounters[STDIO_F_META_TIME];
- rec_ref->file_rec->counters[STDIO_FASTEST_RANK] =
- rec_ref->file_rec->counters[STDIO_FASTEST_RANK_BYTES] =
- rec_ref->file_rec->counters[STDIO_BYTES_READ] +
- rec_ref->file_rec->counters[STDIO_BYTES_WRITTEN];
- rec_ref->file_rec->fcounters[STDIO_F_FASTEST_RANK_TIME] =
- stdio_time;
- /* until reduction occurs, we assume that this rank is both
- * the fastest and slowest. It is up to the reduction operator
- * to find the true min and max.
- rec_ref->file_rec->counters[STDIO_SLOWEST_RANK] =
- rec_ref->file_rec->counters[STDIO_FASTEST_RANK];
- rec_ref->file_rec->counters[STDIO_SLOWEST_RANK_BYTES] =
- rec_ref->file_rec->counters[STDIO_FASTEST_RANK_BYTES];
- rec_ref->file_rec->fcounters[STDIO_F_SLOWEST_RANK_TIME] =
- rec_ref->file_rec->fcounters[STDIO_F_FASTEST_RANK_TIME];
- /* sort the array of files descending by rank so that we get all of the
- * shared files (marked by rank -1) in a contiguous portion at end
- * of the array
- darshan_record_sort(stdio_rec_buf, stdio_rec_count, sizeof(struct darshan_stdio_file));
- red_send_buf = &(stdio_rec_buf[stdio_rec_count-shared_rec_count]);
- if(my_rank == 0)
- red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_stdio_file));
- if(!red_recv_buf)
- return;
- /* construct a datatype for a STDIO file record. This is serving no purpose
- PMPI_Type_contiguous(sizeof(struct darshan_stdio_file),
- /* register a STDIO file record reduction operator */
- PMPI_Op_create(stdio_record_reduction_op, 1, &red_op);
- /* reduce shared STDIO file records */
- stdio_shared_record_variance(mod_comm, red_send_buf, red_recv_buf,
- if(my_rank == 0)
- int tmp_ndx = stdio_rec_count - shared_rec_count;
- memcpy(&(stdio_rec_buf[tmp_ndx]), red_recv_buf,
- shared_rec_count * sizeof(struct darshan_stdio_file));
- else
- stdio_rec_count -= shared_rec_count;
- /* filter out any records that have no activity on them; this is
- * specifically meant to filter out unused stdin, stdout, or stderr
- * entries
- * NOTE: we can no longer use the darshan_lookup_record_ref()
- * function at this point to find specific records, because the
- * logic above has likely broken the mapping to the static array.
- * We walk it manually here instead.
- darshan_record_id stdin_rec_id = darshan_core_gen_record_id("<STDIN>");
- darshan_record_id stdout_rec_id = darshan_core_gen_record_id("<STDOUT>");
- darshan_record_id stderr_rec_id = darshan_core_gen_record_id("<STDERR>");
- for(i=0; i<stdio_rec_count; i++)
- if((stdio_rec_buf[i].base_rec.id == stdin_rec_id) ||
- (stdio_rec_buf[i].base_rec.id == stdout_rec_id) ||
- (stdio_rec_buf[i].base_rec.id == stderr_rec_id))
- if(stdio_rec_buf[i].counters[STDIO_WRITES] == 0 &&
- stdio_rec_buf[i].counters[STDIO_READS] == 0)
- if(i != (stdio_rec_count-1))
- memmove(&stdio_rec_buf[i], &stdio_rec_buf[i+1],
- (stdio_rec_count-i-1)*sizeof(stdio_rec_buf[i]));
- i--;
- stdio_rec_count--;
- *stdio_buf_sz = stdio_rec_count * sizeof(struct darshan_stdio_file);
- /* shutdown internal structures used for instrumenting */
- stdio_cleanup_runtime();
- STDIO_UNLOCK();
- return;
- struct darshan_stdio_file *file_rec = NULL;
- struct stdio_file_record_ref *rec_ref = NULL;
- struct darshan_fs_info fs_info;
- int ret;
- rec_ref = malloc(sizeof(*rec_ref));
- if(!rec_ref)
- return(NULL);
- memset(rec_ref, 0, sizeof(*rec_ref));
- /* add a reference to this file record based on record id */
- ret = darshan_add_record_ref(&(stdio_runtime->rec_id_hash), &rec_id,
- sizeof(darshan_record_id), rec_ref);
- if(ret == 0)
- free(rec_ref);
- return(NULL);
- /* register the actual file record with darshan-core so it is persisted
- * in the log file
- file_rec = darshan_core_register_record(
- rec_id,
- path,
- DARSHAN_STDIO_MOD,
- sizeof(struct darshan_stdio_file),
- &fs_info);
- if(!file_rec)
- darshan_delete_record_ref(&(stdio_runtime->rec_id_hash),
- &rec_id, sizeof(darshan_record_id));
- free(rec_ref);
- return(NULL);
- /* registering this file record was successful, so initialize some fields */
- file_rec->base_rec.id = rec_id;
- file_rec->base_rec.rank = my_rank;
- rec_ref->fs_type = fs_info.fs_type;
- rec_ref->file_rec = file_rec;
- stdio_runtime->file_rec_count++;
- return(rec_ref);
- darshan_clear_record_refs(&(stdio_runtime->stream_hash), 0);
- darshan_clear_record_refs(&(stdio_runtime->rec_id_hash), 1);
- free(stdio_runtime);
- stdio_runtime = NULL;
- return;
static void stdio_shared_record_variance(MPI_Comm mod_comm,
struct darshan_stdio_file *inrec_array, struct darshan_stdio_file *outrec_array,
@@ -1441,6 +1286,7 @@ static void stdio_shared_record_variance(MPI_Comm mod_comm,
return;
+#endif
char *darshan_stdio_lookup_record_name(FILE *stream)
@@ -1460,6 +1306,182 @@ char *darshan_stdio_lookup_record_name(FILE *stream)
return(rec_name);
+ * Functions exported by this module for coordinating with darshan-core *
+#ifdef HAVE_MPI
+ void *stdio_buf,
+ int stdio_rec_count;
+ struct stdio_file_record_ref *rec_ref;
+ struct darshan_stdio_file *stdio_rec_buf = (struct darshan_stdio_file *)stdio_buf;
+ double stdio_time;
+ struct darshan_stdio_file *red_send_buf = NULL;
+ struct darshan_stdio_file *red_recv_buf = NULL;
+ MPI_Datatype red_type;
+ MPI_Op red_op;
+ int i;
+ STDIO_LOCK();
+ assert(stdio_runtime);
+ stdio_rec_count = stdio_runtime->file_rec_count;
+ rec_ref = darshan_lookup_record_ref(stdio_runtime->rec_id_hash,
+ assert(rec_ref);
+ stdio_time =
+ rec_ref->file_rec->fcounters[STDIO_F_READ_TIME] +
+ rec_ref->file_rec->fcounters[STDIO_F_WRITE_TIME] +
+ rec_ref->file_rec->fcounters[STDIO_F_META_TIME];
+ rec_ref->file_rec->counters[STDIO_FASTEST_RANK] =
+ rec_ref->file_rec->counters[STDIO_FASTEST_RANK_BYTES] =
+ rec_ref->file_rec->counters[STDIO_BYTES_READ] +
+ rec_ref->file_rec->counters[STDIO_BYTES_WRITTEN];
+ rec_ref->file_rec->fcounters[STDIO_F_FASTEST_RANK_TIME] =
+ stdio_time;
+ /* until reduction occurs, we assume that this rank is both
+ * the fastest and slowest. It is up to the reduction operator
+ * to find the true min and max.
+ rec_ref->file_rec->counters[STDIO_SLOWEST_RANK] =
+ rec_ref->file_rec->counters[STDIO_FASTEST_RANK];
+ rec_ref->file_rec->counters[STDIO_SLOWEST_RANK_BYTES] =
+ rec_ref->file_rec->counters[STDIO_FASTEST_RANK_BYTES];
+ rec_ref->file_rec->fcounters[STDIO_F_SLOWEST_RANK_TIME] =
+ rec_ref->file_rec->fcounters[STDIO_F_FASTEST_RANK_TIME];
+ /* sort the array of files descending by rank so that we get all of the
+ * shared files (marked by rank -1) in a contiguous portion at end
+ * of the array
+ darshan_record_sort(stdio_rec_buf, stdio_rec_count, sizeof(struct darshan_stdio_file));
+ red_send_buf = &(stdio_rec_buf[stdio_rec_count-shared_rec_count]);
+ if(my_rank == 0)
+ red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_stdio_file));
+ if(!red_recv_buf)
+ STDIO_UNLOCK();
+ return;
+ /* construct a datatype for a STDIO file record. This is serving no purpose
+ PMPI_Type_contiguous(sizeof(struct darshan_stdio_file),
+ /* register a STDIO file record reduction operator */
+ PMPI_Op_create(stdio_record_reduction_op, 1, &red_op);
+ /* reduce shared STDIO file records */
+ stdio_shared_record_variance(mod_comm, red_send_buf, red_recv_buf,
+ if(my_rank == 0)
+ int tmp_ndx = stdio_rec_count - shared_rec_count;
+ memcpy(&(stdio_rec_buf[tmp_ndx]), red_recv_buf,
+ shared_rec_count * sizeof(struct darshan_stdio_file));
+ else
+ stdio_rec_count -= shared_rec_count;
+ STDIO_UNLOCK();
+ return;
+#endif
+ void **stdio_buf,
+ int *stdio_buf_sz)
+ struct darshan_stdio_file *stdio_rec_buf = *(struct darshan_stdio_file **)stdio_buf;
+ int i;
+ STDIO_LOCK();
+ /* filter out any records that have no activity on them; this is
+ * specifically meant to filter out unused stdin, stdout, or stderr
+ * entries
+ * NOTE: we can no longer use the darshan_lookup_record_ref()
+ * function at this point to find specific records, because the
+ * logic above has likely broken the mapping to the static array.
+ * We walk it manually here instead.
+ darshan_record_id stdin_rec_id = darshan_core_gen_record_id("<STDIN>");
+ darshan_record_id stdout_rec_id = darshan_core_gen_record_id("<STDOUT>");
+ darshan_record_id stderr_rec_id = darshan_core_gen_record_id("<STDERR>");
+ for(i=0; i<stdio_rec_count; i++)
+ if((stdio_rec_buf[i].base_rec.id == stdin_rec_id) ||
+ (stdio_rec_buf[i].base_rec.id == stdout_rec_id) ||
+ (stdio_rec_buf[i].base_rec.id == stderr_rec_id))
+ if(stdio_rec_buf[i].counters[STDIO_WRITES] == 0 &&
+ stdio_rec_buf[i].counters[STDIO_READS] == 0)
+ if(i != (stdio_rec_count-1))
+ memmove(&stdio_rec_buf[i], &stdio_rec_buf[i+1],
+ (stdio_rec_count-i-1)*sizeof(stdio_rec_buf[i]));
+ i--;
+ stdio_rec_count--;
+ /* shutdown internal structures used for instrumenting */
+ stdio_cleanup_runtime();
+ *stdio_buf_sz = stdio_rec_count * sizeof(struct darshan_stdio_file);
+ STDIO_UNLOCK();
+ return;
* Local variables:
* c-indent-level: 4
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/157643db4c5aaf7677fe42370eebd318a092974f...640275d22e06e183bd3e597d4a709aa24a897830
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20191111/6d0985b4/attachment-0001.html>
More information about the Darshan-commits
