[Darshan-commits] [Git][darshan/darshan][dev-nompi-prototype] add README for no-mpi branch of Darshan
Glenn K. Lockwood xgitlab at cels.anl.gov
Thu Jul 18 15:23:18 CDT 2019
Glenn K. Lockwood pushed to branch dev-nompi-prototype at darshan / darshan
Commits:
bbf90fb9 by Glenn K. Lockwood at 2019-07-18T20:22:39Z
1 changed file:
- + README.nompi.md
Changes:
README.nompi.md
@@ -0,0 +1,43 @@
+## Quick Start
+    $ cd darshan-serial/darshan-runtime
+    $ autoreconf -ivf
+    $ ./configure --with-log-path-by-env=PWD --with-jobid-env=RANDOM --with-mem-align=8 --disable-mpiio-mod --disable-stdio-mod --disable-pnetcdf-mod --disable-dxt-mod --disable-bgq-mod --disable-lustre-mod --without-mpi CC=gcc
+    $ make
+This will install serial Darshan in darshan-serial/install.  Then to use it,
+    $ LD_PRELOAD=/path/to/darshan-serial/darshan-runtime/lib/libdarshan.so DARSHAN_ENABLE_NONMPI=1 ./path/to/my.exe
+Your `my.exe` will run and create a Darshan log in `$PWD`.  Regular old
+`darshan-parser` can be used to parse the logfile.
+## Non-MPI Darshan
+This repository contains a version of Darshan that supports profiling in the
+absence of MPI at either runtime or compile time.  It can be built in two ways:
+1. **With MPI**, but capable of profiling non-MPI applications if linked against
+   them.  This is useful if a single build should work with both MPI and non-MPI
+   applications.
+2. **Without MPI** and capable of only profiling non-MPI applications.  This is
+   useful for building Darshan on systems that simply don't have MPI at all.
+At present, mode #2 only supports the POSIX module.  All other modules should be
+disabled at configure-time using:
+    ./configure --disable-mpiio-mod \
+                --disable-stdio-mod \
+                --disable-pnetcdf-mod \
+                --disable-bgq-mod \
+                --disable-lustre-mod \
+                --disable-dxt-mod \
+                --without-mpi \
+Then to profile an application,
+    LD_PRELOAD=$PWD/lib/libdarshan.so DARSHAN_ENABLE_NONMPI=1 ./path/to/my.exe
+Do _not_ define `DARSHAN_ENABLE_NONMPI=1` globally, as this will create Darshan
+logs for _everything_ including basic commands like `ls`.
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/bbf90fb9f47f00bcdff1ea5b57a06e70c5b22b1c
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20190718/de69e085/attachment-0001.html>
More information about the Darshan-commits mailing list
