[Darshan-commits] [Git][darshan/darshan][master] bug fix in handling dxt in darshan-convert tool
Shane Snyder xgitlab at cels.anl.gov
Tue Jan 22 13:40:44 CST 2019
Shane Snyder pushed to branch master at darshan / darshan
Commits:
7d70eb0c by Shane Snyder at 2019-01-22T19:40:23Z
1 changed file:
- darshan-util/darshan-convert.c
Changes:
@@ -258,7 +258,7 @@ int main(int argc, char **argv)
     struct darshan_mnt_info *mnt_data_array;
     struct darshan_name_record_ref *name_hash = NULL;
     struct darshan_name_record_ref *ref, *tmp;
-    char *mod_buf;
+    char *mod_buf, *tmp_mod_buf;
     enum darshan_comp_type comp_type;
     int bzip2;
     int obfuscate;
@@ -388,26 +388,46 @@ int main(int argc, char **argv)
             continue;
-        /* we have module data to convert */
-        memset(mod_buf, 0, DEF_MOD_BUF_SIZE);
+        /* for dxt, don't use static record buffer and instead have
+         * darshan-logutils malloc us memory for the trace data
+        if(i == DXT_POSIX_MOD || i == DXT_MPIIO_MOD)
+            tmp_mod_buf = NULL;
+        else
+            tmp_mod_buf = mod_buf;
+            memset(tmp_mod_buf, 0, DEF_MOD_BUF_SIZE);
         /* loop over each of the module's records and convert */
-        while((ret = mod_logutils[i]->log_get_record(infile, (void **)&mod_buf)) == 1)
+        while((ret = mod_logutils[i]->log_get_record(infile, (void **)&tmp_mod_buf)) == 1)
-            base_rec = (struct darshan_base_record *)mod_buf;
+            base_rec = (struct darshan_base_record *)tmp_mod_buf;
             if(!hash || hash == base_rec->id)
-                ret = mod_logutils[i]->log_put_record(outfile, mod_buf);
+                ret = mod_logutils[i]->log_put_record(outfile, tmp_mod_buf);
                 if(ret < 0)
+                        free(tmp_mod_buf);
                     darshan_log_close(infile);
                     darshan_log_close(outfile);
                     unlink(outfile_name);
                     return(-1);
+            else
         if(ret < 0)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/7d70eb0c70b97c3e7b87ab2b3bff23189bfc8800
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20190122/3f612cbf/attachment-0001.html>
More information about the Darshan-commits mailing list
