[Darshan-commits] [Git][darshan/darshan][master] 3 commits: add rename support to POSIX module
Shane Snyder xgitlab at cels.anl.gov
Thu Jan 17 15:16:30 CST 2019
Shane Snyder pushed to branch master at darshan / darshan
Commits:
6f661320 by Shane Snyder at 2019-01-14T20:56:08Z
bcc58023 by Shane Snyder at 2019-01-17T21:13:51Z
add new RENAMED_FROM counter to POSIX module
202764eb by Shane Snyder at 2019-01-17T21:14:41Z
Merge branch 'rename-wrapping'
13 changed files:
- darshan-posix-log-format.h
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/share/ld-opts/darshan-posix-ld-opts
- darshan-util/darshan-bgq-logutils.c
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-logutils.h
- darshan-util/darshan-lustre-logutils.c
- darshan-util/darshan-mdhim-logutils.c
- darshan-util/darshan-mpiio-logutils.c
- darshan-util/darshan-null-logutils.c
- darshan-util/darshan-pnetcdf-logutils.c
- darshan-util/darshan-posix-logutils.c
- darshan-util/darshan-stdio-logutils.c
Changes:
@@ -30,6 +30,12 @@
     X(POSIX_FSYNCS) \
     /* count of posix fdatasyncs */\
     X(POSIX_FDSYNCS) \
+    /* count of renames (as source file) */\
+    X(POSIX_RENAME_SOURCES) \
+    /* count of renames (as target file) */\
+    X(POSIX_RENAME_TARGETS) \
+    /* Darshan record ID of first rename source */\
+    X(POSIX_RENAMED_FROM) \
     /* mode of file */\
     X(POSIX_MODE) \
     /* total bytes read */\
@@ -82,6 +82,7 @@ DARSHAN_FORWARD_DECL(aio_return, ssize_t, (struct aiocb *aiocbp));
 DARSHAN_FORWARD_DECL(aio_return64, ssize_t, (struct aiocb64 *aiocbp));
 DARSHAN_FORWARD_DECL(lio_listio, int, (int mode, struct aiocb *const aiocb_list[], int nitems, struct sigevent *sevp));
 DARSHAN_FORWARD_DECL(lio_listio64, int, (int mode, struct aiocb64 *const aiocb_list[], int nitems, struct sigevent *sevp));
+DARSHAN_FORWARD_DECL(rename, int, (const char *oldpath, const char *newpath));
 /* The posix_file_record_ref structure maintains necessary runtime metadata
  * for the POSIX file record (darshan_posix_file structure, defined in
@@ -1402,6 +1403,74 @@ int DARSHAN_DECL(lio_listio64)(int mode, struct aiocb64 *const aiocb_list[],
     return(ret);
+int DARSHAN_DECL(rename)(const char *oldpath, const char *newpath)
+    int ret;
+    double tm1, tm2;
+    char *oldpath_clean, *newpath_clean;
+    darshan_record_id old_rec_id, new_rec_id;
+    struct posix_file_record_ref *old_rec_ref, *new_rec_ref;
+    MAP_OR_FAIL(rename);
+    tm1 = darshan_core_wtime();
+    ret = __real_rename(oldpath, newpath);
+    tm2 = darshan_core_wtime();
+    if(ret == 0)
+        oldpath_clean = darshan_clean_file_path(oldpath);
+        if(!oldpath_clean) oldpath_clean = (char *)oldpath;
+        if(darshan_core_excluded_path(oldpath_clean))
+            if(oldpath_clean != oldpath) free(oldpath_clean);
+            return(ret);
+        old_rec_id = darshan_core_gen_record_id(oldpath_clean);
+        POSIX_PRE_RECORD();
+        old_rec_ref = darshan_lookup_record_ref(posix_runtime->rec_id_hash,
+            &old_rec_id, sizeof(darshan_record_id));
+        if(!old_rec_ref)
+            POSIX_POST_RECORD();
+            return(ret);
+        old_rec_ref->file_rec->counters[POSIX_RENAME_SOURCES] += 1;
+        DARSHAN_TIMER_INC_NO_OVERLAP(old_rec_ref->file_rec->fcounters[POSIX_F_META_TIME],
+            tm1, tm2, old_rec_ref->last_meta_end);
+        newpath_clean = darshan_clean_file_path(newpath);
+        if(!newpath_clean) newpath_clean = (char *)newpath;
+        if(darshan_core_excluded_path(newpath_clean))
+            if(newpath_clean != newpath) free(newpath_clean);
+            return(ret);
+        new_rec_id = darshan_core_gen_record_id(newpath_clean);
+        new_rec_ref = darshan_lookup_record_ref(posix_runtime->rec_id_hash,
+            &new_rec_id, sizeof(darshan_record_id));
+        if(!new_rec_ref)
+            new_rec_ref = posix_track_new_file_record(new_rec_id, newpath_clean);
+        if(new_rec_ref)
+            new_rec_ref->file_rec->counters[POSIX_RENAME_TARGETS] += 1;
+            if(new_rec_ref->file_rec->counters[POSIX_RENAMED_FROM] == 0)
+                new_rec_ref->file_rec->counters[POSIX_RENAMED_FROM] = old_rec_id;
+    return(ret);
  * Internal functions for manipulating POSIX module state *
@@ -1574,13 +1643,14 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
         tmp_file.base_rec.rank = -1;
         /* sum */
-        for(j=POSIX_OPENS; j<=POSIX_FDSYNCS; j++)
+        for(j=POSIX_OPENS; j<=POSIX_RENAME_TARGETS; j++)
             tmp_file.counters[j] = infile->counters[j] + inoutfile->counters[j];
             if(tmp_file.counters[j] < 0) /* make sure invalid counters are -1 exactly */
                 tmp_file.counters[j] = -1;
+        tmp_file.counters[POSIX_RENAMED_FROM] = infile->counters[POSIX_RENAMED_FROM];
         tmp_file.counters[POSIX_MODE] = infile->counters[POSIX_MODE];
         /* sum */
@@ -40,3 +40,4 @@
 --wrap=lio_listio
 --wrap=lio_listio64
 --wrap=fileno
+--wrap=rename
@@ -158,7 +158,7 @@ static void darshan_log_print_bgq_rec(void *file_rec, char *file_name,
     for(i=0; i<BGQ_NUM_INDICES; i++)
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_BGQ_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_BGQ_MOD],
             bgq_file_rec->base_rec.rank, bgq_file_rec->base_rec.id,
             bgq_counter_names[i], bgq_file_rec->counters[i],
             file_name, mnt_pt, fs_type);
@@ -204,7 +204,7 @@ static void darshan_log_print_bgq_rec_diff(void *file_rec1, char *file_name1,
         if(!file2)
             printf("- ");
                 file1->base_rec.rank, file1->base_rec.id, bgq_counter_names[i],
                 file1->counters[i], file_name1, "", "");
@@ -212,18 +212,18 @@ static void darshan_log_print_bgq_rec_diff(void *file_rec1, char *file_name1,
         else if(!file1)
             printf("+ ");
                 file2->base_rec.rank, file2->base_rec.id, bgq_counter_names[i],
                 file2->counters[i], file_name2, "", "");
         else if(file1->counters[i] != file2->counters[i])
             printf("- ");
             printf("+ ");
@@ -161,7 +161,7 @@ static void darshan_log_print_hdf5_file(void *file_rec, char *file_name,
     for(i=0; i<HDF5_NUM_INDICES; i++)
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_HDF5_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_HDF5_MOD],
             hdf5_file_rec->base_rec.rank, hdf5_file_rec->base_rec.id,
             hdf5_counter_names[i], hdf5_file_rec->counters[i],
@@ -209,7 +209,7 @@ static void darshan_log_print_hdf5_file_diff(void *file_rec1, char *file_name1,
         if(!file2)
             printf("- ");
                 file1->base_rec.rank, file1->base_rec.id, hdf5_counter_names[i],
@@ -217,18 +217,18 @@ static void darshan_log_print_hdf5_file_diff(void *file_rec1, char *file_name1,
         else if(!file1)
             printf("+ ");
                 file2->base_rec.rank, file2->base_rec.id, hdf5_counter_names[i],
             printf("- ");
             printf("+ ");
@@ -164,7 +164,7 @@ void darshan_log_print_version_warnings(const char *version_string);
     printf("\n#<module>\t<rank>\t<record id>\t<counter>\t<value>" \
            "\t<file name>\t<mount pt>\t<fs type>\n")
-#define DARSHAN_COUNTER_PRINT(__mod_name, __rank, __file_id, \
+#define DARSHAN_D_COUNTER_PRINT(__mod_name, __rank, __file_id, \
                               __counter, __counter_val, __file_name, \
                               __mnt_pt, __fs_type) do { \
     printf("%s\t%" PRId64 "\t%" PRIu64 "\t%s\t%" PRId64 "\t%s\t%s\t%s\n", \
@@ -172,6 +172,14 @@ void darshan_log_print_version_warnings(const char *version_string);
         __file_name, __mnt_pt, __fs_type); \
 } while(0)
+#define DARSHAN_U_COUNTER_PRINT(__mod_name, __rank, __file_id, \
+                              __counter, __counter_val, __file_name, \
+                              __mnt_pt, __fs_type) do { \
+    printf("%s\t%" PRId64 "\t%" PRIu64 "\t%s\t%" PRIu64 "\t%s\t%s\t%s\n", \
+        __mod_name, __rank, __file_id, __counter, __counter_val, \
+        __file_name, __mnt_pt, __fs_type); \
+} while(0)
 #define DARSHAN_F_COUNTER_PRINT(__mod_name, __rank, __file_id, \
@@ -136,7 +136,7 @@ static void darshan_log_print_lustre_record(void *rec, char *file_name,
     for(i=0; i<LUSTRE_NUM_INDICES; i++)
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_LUSTRE_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_LUSTRE_MOD],
             lustre_rec->base_rec.rank, lustre_rec->base_rec.id, lustre_counter_names[i],
             lustre_rec->counters[i], file_name, mnt_pt, fs_type);
@@ -145,7 +145,7 @@ static void darshan_log_print_lustre_record(void *rec, char *file_name,
         char strbuf[25];
         snprintf( strbuf, 25, "LUSTRE_OST_ID_%d", i );
             strbuf,
@@ -185,7 +185,7 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
         if(!lustre_rec2)
             printf("- ");
                 lustre_rec1->base_rec.rank, lustre_rec1->base_rec.id,
                 lustre_counter_names[i], lustre_rec1->counters[i], file_name1, "", "");
@@ -193,18 +193,18 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
         else if(!lustre_rec1)
             printf("+ ");
                 lustre_rec2->base_rec.rank, lustre_rec2->base_rec.id,
                 lustre_counter_names[i], lustre_rec2->counters[i], file_name2, "", "");
         else if(lustre_rec1->counters[i] != lustre_rec2->counters[i])
             printf("- ");
             printf("+ ");
@@ -219,7 +219,7 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
         if (!lustre_rec2 || (i >= lustre_rec2->counters[LUSTRE_STRIPE_WIDTH]))
             printf("- ");
                 strbuf,
@@ -231,7 +231,7 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
         else if (!lustre_rec1 || (i >= lustre_rec1->counters[LUSTRE_STRIPE_WIDTH]))
             printf("+ ");
                 strbuf,
@@ -243,7 +243,7 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
         else if (lustre_rec1->ost_ids[i] != lustre_rec2->ost_ids[i])
             printf("- ");
                 strbuf,
@@ -252,7 +252,7 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
             printf("+ ");
                 strbuf,
@@ -158,7 +158,7 @@ static void darshan_log_print_mdhim_record(void *file_rec, char *file_name,
     for(i=0; i<MDHIM_NUM_INDICES; i++)
         /* macro defined in darshan-logutils.h */
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_MDHIM_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_MDHIM_MOD],
             mdhim_rec->base_rec.rank, mdhim_rec->base_rec.id,
             mdhim_counter_names[i], mdhim_rec->counters[i],
@@ -176,7 +176,7 @@ static void darshan_log_print_mdhim_record(void *file_rec, char *file_name,
         char strbuf[25];
         snprintf(strbuf, 25, "MDHIM_SERVER_%d", i);
                 strbuf,
@@ -215,7 +215,7 @@ static void darshan_log_print_mdhim_record_diff(void *file_rec1, char *file_name
         if(!file2)
             printf("- ");
                 file1->base_rec.rank, file1->base_rec.id, mdhim_counter_names[i],
@@ -223,18 +223,18 @@ static void darshan_log_print_mdhim_record_diff(void *file_rec1, char *file_name
         else if(!file1)
             printf("+ ");
                 file2->base_rec.rank, file2->base_rec.id, mdhim_counter_names[i],
             printf("- ");
             printf("+ ");
@@ -277,7 +277,7 @@ static void darshan_log_print_mdhim_record_diff(void *file_rec1, char *file_name
         if (!file2 || (i >= file2->counters[MDHIM_SERVERS]))
             printf("- ");
                     file1->base_rec.id,
                     strbuf,
@@ -287,7 +287,7 @@ static void darshan_log_print_mdhim_record_diff(void *file_rec1, char *file_name
         else if (!file1 || (i >= file1->counters[MDHIM_SERVERS]))
             printf("+ ");
                     file2->base_rec.id,
                     strbuf,
@@ -297,14 +297,14 @@ static void darshan_log_print_mdhim_record_diff(void *file_rec1, char *file_name
         else if (file1->server_histogram[i] != file2->server_histogram[i])
             printf("- ");
                     file1->base_rec.id,
                     strbuf,
                     (int64_t)file1->server_histogram[i],
             printf("+ ");
                     file2->base_rec.id,
                     strbuf,
@@ -161,7 +161,7 @@ static void darshan_log_print_mpiio_file(void *file_rec, char *file_name,
     for(i=0; i<MPIIO_NUM_INDICES; i++)
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_MPIIO_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_MPIIO_MOD],
             mpiio_file_rec->base_rec.rank, mpiio_file_rec->base_rec.id,
             mpiio_counter_names[i], mpiio_file_rec->counters[i],
@@ -234,7 +234,7 @@ static void darshan_log_print_mpiio_file_diff(void *file_rec1, char *file_name1,
         if(!file2)
             printf("- ");
                 file1->base_rec.rank, file1->base_rec.id, mpiio_counter_names[i],
@@ -242,18 +242,18 @@ static void darshan_log_print_mpiio_file_diff(void *file_rec1, char *file_name1,
         else if(!file1)
             printf("+ ");
                 file2->base_rec.rank, file2->base_rec.id, mpiio_counter_names[i],
             printf("- ");
             printf("+ ");
@@ -137,7 +137,7 @@ static void darshan_log_print_null_record(void *file_rec, char *file_name,
     for(i=0; i<NULL_NUM_INDICES; i++)
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_NULL_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_NULL_MOD],
             null_rec->base_rec.rank, null_rec->base_rec.id,
             null_counter_names[i], null_rec->counters[i],
@@ -182,7 +182,7 @@ static void darshan_log_print_null_record_diff(void *file_rec1, char *file_name1
         if(!file2)
             printf("- ");
                 file1->base_rec.rank, file1->base_rec.id, null_counter_names[i],
@@ -190,18 +190,18 @@ static void darshan_log_print_null_record_diff(void *file_rec1, char *file_name1
         else if(!file1)
             printf("+ ");
                 file2->base_rec.rank, file2->base_rec.id, null_counter_names[i],
             printf("- ");
             printf("+ ");
@@ -161,7 +161,7 @@ static void darshan_log_print_pnetcdf_file(void *file_rec, char *file_name,
     for(i=0; i<PNETCDF_NUM_INDICES; i++)
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_PNETCDF_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_PNETCDF_MOD],
             pnetcdf_file_rec->base_rec.rank, pnetcdf_file_rec->base_rec.id,
             pnetcdf_counter_names[i], pnetcdf_file_rec->counters[i],
@@ -210,7 +210,7 @@ static void darshan_log_print_pnetcdf_file_diff(void *file_rec1, char *file_name
         if(!file2)
             printf("- ");
                 file1->base_rec.rank, file1->base_rec.id, pnetcdf_counter_names[i],
@@ -218,18 +218,18 @@ static void darshan_log_print_pnetcdf_file_diff(void *file_rec1, char *file_name
         else if(!file1)
             printf("+ ");
                 file2->base_rec.rank, file2->base_rec.id, pnetcdf_counter_names[i],
             printf("- ");
             printf("+ ");
@@ -196,10 +196,16 @@ static void darshan_log_print_posix_file(void *file_rec, char *file_name,
     for(i=0; i<POSIX_NUM_INDICES; i++)
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_POSIX_MOD],
-            posix_file_rec->base_rec.rank, posix_file_rec->base_rec.id,
-            posix_counter_names[i], posix_file_rec->counters[i],
-            file_name, mnt_pt, fs_type);
+        if(i == POSIX_RENAMED_FROM)
+            DARSHAN_U_COUNTER_PRINT(darshan_module_names[DARSHAN_POSIX_MOD],
+                posix_file_rec->base_rec.rank, posix_file_rec->base_rec.id,
+                posix_counter_names[i], posix_file_rec->counters[i],
+                file_name, mnt_pt, fs_type);
+        else
+            DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_POSIX_MOD],
     for(i=0; i<POSIX_F_NUM_INDICES; i++)
@@ -272,28 +278,48 @@ static void darshan_log_print_posix_file_diff(void *file_rec1, char *file_name1,
         if(!file2)
             printf("- ");
-                file1->base_rec.rank, file1->base_rec.id, posix_counter_names[i],
-                file1->counters[i], file_name1, "", "");
+                    file1->base_rec.rank, file1->base_rec.id, posix_counter_names[i],
+                    file1->counters[i], file_name1, "", "");
+            else
         else if(!file1)
             printf("+ ");
-                file2->base_rec.rank, file2->base_rec.id, posix_counter_names[i],
-                file2->counters[i], file_name2, "", "");
+                    file2->base_rec.rank, file2->base_rec.id, posix_counter_names[i],
+                    file2->counters[i], file_name2, "", "");
+            else
             printf("- ");
+            else
             printf("+ ");
+            else
@@ -137,7 +137,7 @@ static void darshan_log_print_stdio_record(void *file_rec, char *file_name,
     for(i=0; i<STDIO_NUM_INDICES; i++)
-        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_STDIO_MOD],
+        DARSHAN_D_COUNTER_PRINT(darshan_module_names[DARSHAN_STDIO_MOD],
             stdio_rec->base_rec.rank, stdio_rec->base_rec.id, stdio_counter_names[i],
             stdio_rec->counters[i], file_name, mnt_pt, fs_type);
@@ -185,7 +185,7 @@ static void darshan_log_print_stdio_record_diff(void *file_rec1, char *file_name
         if(!file2)
             printf("- ");
                 file1->base_rec.rank, file1->base_rec.id, stdio_counter_names[i],
@@ -193,18 +193,18 @@ static void darshan_log_print_stdio_record_diff(void *file_rec1, char *file_name
         else if(!file1)
             printf("+ ");
                 file2->base_rec.rank, file2->base_rec.id, stdio_counter_names[i],
             printf("- ");
             printf("+ ");
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/598a2e85ab3350ba8336a130930758597e986a4b...202764eb8aac7a968f520d1fd8f8e9cf9a99b864
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20190117/b288f3c3/attachment-0001.html>
More information about the Darshan-commits mailing list
