[Darshan-commits] [Git][darshan/darshan][master] 2 commits: update ChangeLog for 3.2.0-pre1
Shane Snyder xgitlab at cels.anl.gov
Wed Dec 11 11:35:22 CST 2019
Shane Snyder pushed to branch master at darshan / darshan
Commits:
32daf6fd by Shane Snyder at 2019-12-11T17:34:19Z
57ffa711 by Shane Snyder at 2019-12-11T17:34:30Z
update version numbers for 3.2.0-pre1
5 changed files:
- ChangeLog
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-util/configure
- darshan-util/configure.in
Changes:
ChangeLog
@@ -2,6 +2,13 @@
 Darshan Release Change Log
+Darshan-3.2.0-pre1
+* added support for non-MPI instrumenation to Darshan, using GCC
+construct/destructor attributes for bootstrapping rather than
+intercepting MPI_Init()/MPI_Finalize(). This mechanism only
+works for Darshan's shared library instrumentation
 Darshan-3.1.8
 * added dynamic trace triggering functionality, allowing Darshan to
@@ -1,6 +1,6 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.8.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 3.2.0-pre1.
 # Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
 # Identity of this package.
 PACKAGE_NAME='darshan-runtime'
 PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='3.1.8'
-PACKAGE_STRING='darshan-runtime 3.1.8'
+PACKAGE_VERSION='3.2.0-pre1'
+PACKAGE_STRING='darshan-runtime 3.2.0-pre1'
 PACKAGE_BUGREPORT=''
 PACKAGE_URL=''
@@ -1287,7 +1287,7 @@ if test "$ac_init_help" = "long"; then
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures darshan-runtime 3.1.8 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 3.2.0-pre1 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1349,7 +1349,7 @@ fi
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of darshan-runtime 3.1.8:";;
+     short | recursive ) echo "Configuration of darshan-runtime 3.2.0-pre1:";;
    esac
   cat <<\_ACEOF
@@ -1476,7 +1476,7 @@ fi
 test -n "$ac_init_help" && exit $ac_status
 if $ac_init_version; then
   cat <<\_ACEOF
-darshan-runtime configure 3.1.8
+darshan-runtime configure 3.2.0-pre1
 generated by GNU Autoconf 2.69
 Copyright (C) 2012 Free Software Foundation, Inc.
@@ -1828,7 +1828,7 @@ cat >config.log <<_ACEOF
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 3.1.8, which was
+It was created by darshan-runtime $as_me 3.2.0-pre1, which was
 generated by GNU Autoconf 2.69.  Invocation command line was
   $ $0 $@
@@ -4832,7 +4832,7 @@ fi
 # End of MPI-only checks
-DARSHAN_VERSION="3.1.8"
+DARSHAN_VERSION="3.2.0-pre1"
@@ -5367,7 +5367,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 # report actual input values of CONFIG_FILES etc. instead of their
 # values after options handling.
 ac_log="
-This file was extended by darshan-runtime $as_me 3.1.8, which was
+This file was extended by darshan-runtime $as_me 3.2.0-pre1, which was
   CONFIG_FILES    = $CONFIG_FILES
@@ -5429,7 +5429,7 @@ _ACEOF
 cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
 ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
 ac_cs_version="\\
-darshan-runtime config.status 3.1.8
+darshan-runtime config.status 3.2.0-pre1
 configured by $0, generated by GNU Autoconf 2.69,
   with options \\"\$ac_cs_config\\"
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
 dnl You may need to use autoheader as well if changing any DEFINEs
 dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [3.1.8])
+AC_INIT([darshan-runtime], [3.2.0-pre1])
 AC_CONFIG_SRCDIR([darshan.h])
 AC_CONFIG_AUX_DIR(../maint/config)
 AC_CONFIG_MACRO_DIR(../maint/config)
@@ -1,6 +1,6 @@
 #! /bin/sh
-# Generated by GNU Autoconf 2.69 for darshan-util 3.1.8.
+# Generated by GNU Autoconf 2.69 for darshan-util 3.2.0-pre1.
 PACKAGE_NAME='darshan-util'
 PACKAGE_TARNAME='darshan-util'
-PACKAGE_STRING='darshan-util 3.1.8'
+PACKAGE_STRING='darshan-util 3.2.0-pre1'
 PACKAGE_URL=''
@@ -661,6 +661,7 @@ infodir
 docdir
 oldincludedir
 includedir
+runstatedir
 localstatedir
 sharedstatedir
 sysconfdir
@@ -734,6 +735,7 @@ datadir='${datarootdir}'
 sysconfdir='${prefix}/etc'
 sharedstatedir='${prefix}/com'
 localstatedir='${prefix}/var'
+runstatedir='${localstatedir}/run'
 includedir='${prefix}/include'
 oldincludedir='/usr/include'
 docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
@@ -986,6 +988,15 @@ do
   | -silent | --silent | --silen | --sile | --sil)
     silent=yes ;;
+  -runstatedir | --runstatedir | --runstatedi | --runstated \
+  | --runstate | --runstat | --runsta | --runst | --runs \
+  | --run | --ru | --r)
+    ac_prev=runstatedir ;;
+  -runstatedir=* | --runstatedir=* | --runstatedi=* | --runstated=* \
+  | --runstate=* | --runstat=* | --runsta=* | --runst=* | --runs=* \
+  | --run=* | --ru=* | --r=*)
+    runstatedir=$ac_optarg ;;
   -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
     ac_prev=sbindir ;;
   -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
@@ -1123,7 +1134,7 @@ fi
 for ac_var in	exec_prefix prefix bindir sbindir libexecdir datarootdir \
 		datadir sysconfdir sharedstatedir localstatedir includedir \
 		oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
-		libdir localedir mandir
+		libdir localedir mandir runstatedir
 do
   eval ac_val=\$$ac_var
   # Remove trailing slashes.
@@ -1236,7 +1247,7 @@ if test "$ac_init_help" = "long"; then
   cat <<_ACEOF
-\`configure' configures darshan-util 3.1.8 to adapt to many kinds of systems.
+\`configure' configures darshan-util 3.2.0-pre1 to adapt to many kinds of systems.
@@ -1276,6 +1287,7 @@ Fine tuning of the installation directories:
   --sysconfdir=DIR        read-only single-machine data [PREFIX/etc]
   --sharedstatedir=DIR    modifiable architecture-independent data [PREFIX/com]
   --localstatedir=DIR     modifiable single-machine data [PREFIX/var]
+  --runstatedir=DIR       modifiable per-process data [LOCALSTATEDIR/run]
   --libdir=DIR            object code libraries [EPREFIX/lib]
   --includedir=DIR        C header files [PREFIX/include]
   --oldincludedir=DIR     C header files for non-gcc [/usr/include]
@@ -1297,7 +1309,7 @@ fi
-     short | recursive ) echo "Configuration of darshan-util 3.1.8:";;
+     short | recursive ) echo "Configuration of darshan-util 3.2.0-pre1:";;
    esac
   cat <<\_ACEOF
@@ -1393,7 +1405,7 @@ fi
   cat <<\_ACEOF
-darshan-util configure 3.1.8
+darshan-util configure 3.2.0-pre1
@@ -1758,7 +1770,7 @@ cat >config.log <<_ACEOF
-It was created by darshan-util $as_me 3.1.8, which was
+It was created by darshan-util $as_me 3.2.0-pre1, which was
   $ $0 $@
@@ -4105,7 +4117,7 @@ fi
 done
-DARSHAN_UTIL_VERSION="3.1.8"
+DARSHAN_UTIL_VERSION="3.2.0-pre1"
@@ -4621,7 +4633,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 ac_log="
-This file was extended by darshan-util $as_me 3.1.8, which was
+This file was extended by darshan-util $as_me 3.2.0-pre1, which was
@@ -4683,7 +4695,7 @@ _ACEOF
 ac_cs_version="\\
-darshan-util config.status 3.1.8
+darshan-util config.status 3.2.0-pre1
-AC_INIT([darshan-util], [3.1.8])
+AC_INIT([darshan-util], [3.2.0-pre1])
 AC_CONFIG_SRCDIR([darshan-logutils.h])
 AC_CONFIG_HEADER(darshan-util-config.h)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/9dfed193086a50adf591205638b4dd4ba7113b03...57ffa7115155bc241668bc616f356e577932cdd6
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20191211/c54667a7/attachment-0001.html>
More information about the Darshan-commits mailing list
