[Darshan-commits] [Git][darshan/darshan][dev-no-mpi] add more autoconf logic for MPI, GCC detection
Shane Snyder xgitlab at cels.anl.gov
Thu Dec 5 13:28:35 CST 2019
Shane Snyder pushed to branch dev-no-mpi at darshan / darshan
Commits:
fe73ff3e by Shane Snyder at 2019-12-05T19:27:45Z
2 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
Changes:
@@ -650,11 +650,12 @@ GREP
 CPP
 OBJEXT
 EXEEXT
-ac_ct_CC
 CPPFLAGS
 LDFLAGS
 CFLAGS
+ac_ct_CC
 CC
+MPICC
 INSTALL_DATA
 INSTALL_SCRIPT
 INSTALL_PROGRAM
@@ -701,6 +702,7 @@ ac_subst_files=''
 ac_user_opts='
 enable_option_checking
 with_mpi
+with_gcc
 with_zlib
 enable_ld_preload
 enable_cuserid
@@ -727,6 +729,7 @@ enable_mdhim
       ac_precious_vars='build_alias
 host_alias
 target_alias
+MPICC
 CC
 CFLAGS
 LDFLAGS
@@ -1378,6 +1381,7 @@ Optional Packages:
   --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
   --without-PACKAGE       do not use PACKAGE (same as --with-PACKAGE=no)
   --without-mpi           Build without support for MPI
+  --without-gcc           Build without a GCC-compatible compiler
   --with-zlib=DIR root directory path of zlib installation defaults to
                     /usr/local or /usr if not found in /usr/local
   --without-zlib to disable zlib usage completely
@@ -1394,6 +1398,7 @@ Optional Packages:
   --with-mod-mem=<num>    Maximum amount of memory (in MiB) for each Darshan module
 Some influential environment variables:
+  MPICC       MPI C compiler command
   CC          C compiler command
   CFLAGS      C compiler flags
   LDFLAGS     linker flags, e.g. -L<lib dir> if you have libraries in a
@@ -1521,6 +1526,52 @@ fi
 } # ac_fn_c_try_compile
+# ac_fn_c_try_link LINENO
+# Try to link conftest.$ac_ext, and return whether this succeeded.
+ac_fn_c_try_link ()
+  as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
+  rm -f conftest.$ac_objext conftest$ac_exeext
+  if { { ac_try="$ac_link"
+case "(($ac_try" in
+  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+  *) ac_try_echo=$ac_try;;
+esac
+eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
+$as_echo "$ac_try_echo"; } >&5
+  (eval "$ac_link") 2>conftest.err
+  ac_status=$?
+  if test -s conftest.err; then
+    grep -v '^ *+' conftest.err >conftest.er1
+    cat conftest.er1 >&5
+    mv -f conftest.er1 conftest.err
+  fi
+  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
+  test $ac_status = 0; } && {
+	 test -z "$ac_c_werror_flag" ||
+	 test ! -s conftest.err
+       } && test -s conftest$ac_exeext && {
+	 test "$cross_compiling" = yes ||
+	 test -x conftest$ac_exeext
+       }; then :
+  ac_retval=0
+else
+  $as_echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+	ac_retval=1
+fi
+  # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
+  # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
+  # interfere with the next link command; also delete a directory that is
+  # left behind by Apple's compiler.  We do this before executing the actions.
+  rm -rf conftest.dSYM conftest_ipa8_conftest.oo
+  eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
+  as_fn_set_status $ac_retval
+} # ac_fn_c_try_link
 # ac_fn_c_try_cpp LINENO
 # Try to preprocess conftest.$ac_ext, and return whether this succeeded.
@@ -1718,52 +1769,6 @@ $as_echo "$ac_res" >&6; }
 } # ac_fn_c_check_header_compile
-# ac_fn_c_try_link LINENO
-# Try to link conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_link ()
-  as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
-  rm -f conftest.$ac_objext conftest$ac_exeext
-  if { { ac_try="$ac_link"
-case "(($ac_try" in
-  *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
-  *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
-  (eval "$ac_link") 2>conftest.err
-  ac_status=$?
-  if test -s conftest.err; then
-    grep -v '^ *+' conftest.err >conftest.er1
-    cat conftest.er1 >&5
-    mv -f conftest.er1 conftest.err
-  fi
-  $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
-  test $ac_status = 0; } && {
-	 test -z "$ac_c_werror_flag" ||
-	 test ! -s conftest.err
-       } && test -s conftest$ac_exeext && {
-	 test "$cross_compiling" = yes ||
-	 test -x conftest$ac_exeext
-       }; then :
-  ac_retval=0
-else
-  $as_echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-	ac_retval=1
-fi
-  # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
-  # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
-  # interfere with the next link command; also delete a directory that is
-  # left behind by Apple's compiler.  We do this before executing the actions.
-  rm -rf conftest.dSYM conftest_ipa8_conftest.oo
-  eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
-  as_fn_set_status $ac_retval
-} # ac_fn_c_try_link
 # ac_fn_c_check_type LINENO TYPE VAR INCLUDES
 # Tests whether TYPE exists after having included INCLUDES, setting cache
@@ -2297,23 +2302,135 @@ test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
 test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-ENABLE_MPI=1
 # Check whether --with-mpi was given.
 if test "${with_mpi+set}" = set; then :
   withval=$with_mpi;
+else
+  with_mpi=auto
 fi
-if test "x$with_mpi" = "xno"; then :
-  ENABLE_MPI=
+    { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether to compile using MPI" >&5
+$as_echo_n "checking whether to compile using MPI... " >&6; }
+    if test x"$with_mpi" != xno; then
+      _ax_prog_cc_mpi_mpi_wanted=yes
+    else
+      _ax_prog_cc_mpi_mpi_wanted=no
+    fi
+    { $as_echo "$as_me:${as_lineno-$LINENO}: result: $_ax_prog_cc_mpi_mpi_wanted" >&5
+$as_echo "$_ax_prog_cc_mpi_mpi_wanted" >&6; }
+  if test x"$_ax_prog_cc_mpi_mpi_wanted" = xyes; then
+    if test -z "$CC" && test -n "$MPICC"; then
+      CC="$MPICC"
+    else
+      if test -n "$ac_tool_prefix"; then
+  for ac_prog in mpicc mpixlc_r mpixlc hcc mpxlc_r mpxlc sxmpicc mpifcc mpgcc mpcc cmpicc cc gcc
+  do
+    # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
+set dummy $ac_tool_prefix$ac_prog; ac_word=$2
+{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
+$as_echo_n "checking for $ac_word... " >&6; }
+if ${ac_cv_prog_CC+:} false; then :
+  $as_echo_n "(cached) " >&6
 else
+  if test -n "$CC"; then
+  ac_cv_prog_CC="$CC" # Let the user override the test.
+else
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+    for ac_exec_ext in '' $ac_executable_extensions; do
+  if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+    ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
+    $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+  done
+IFS=$as_save_IFS
-$as_echo "#define HAVE_MPI /**/" >>confdefs.h
+fi
+fi
+CC=$ac_cv_prog_CC
+if test -n "$CC"; then
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
+$as_echo "$CC" >&6; }
+else
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
+fi
+    test -n "$CC" && break
+  done
+fi
+if test -z "$CC"; then
+  ac_ct_CC=$CC
+do
+  # Extract the first word of "$ac_prog", so it can be a program name with args.
+set dummy $ac_prog; ac_word=$2
+if ${ac_cv_prog_ac_ct_CC+:} false; then :
+else
+  if test -n "$ac_ct_CC"; then
+  ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CC="$ac_prog"
+    break 2
+  fi
+done
+  done
+IFS=$as_save_IFS
+fi
+fi
+ac_ct_CC=$ac_cv_prog_ac_ct_CC
+if test -n "$ac_ct_CC"; then
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
+$as_echo "$ac_ct_CC" >&6; }
+else
 fi
-ac_ext=c
+  test -n "$ac_ct_CC" && break
+done
+  if test "x$ac_ct_CC" = x; then
+    CC=""
+  else
+    case $cross_compiling:$ac_tool_warned in
+yes:)
+{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
+$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
+ac_tool_warned=yes ;;
+esac
+    CC=$ac_ct_CC
+  fi
+fi
+    fi
+  fi
+  ac_ext=c
 ac_cpp='$CPP $CPPFLAGS'
 ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
 ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
@@ -3103,34 +3220,171 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
 ac_compiler_gnu=$ac_cv_c_compiler_gnu
-if test "x$ENABLE_MPI" = "x1"; then :
-  { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the mpicc compiler works" >&5
-$as_echo_n "checking whether the mpicc compiler works... " >&6; }
-       cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+# Check for compiler
+# Needs to be split off into an extra macro to ensure right expansion
+# order.
+if test x"$_ax_prog_cc_mpi_mpi_wanted" = xno; then :
+   _ax_prog_cc_mpi_mpi_found=no
+else
+    ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+    # test whether MPI_Init is available
+    # We do not use AC_SEARCH_LIBS here, as it caches its outcome and
+    # thus disallows corresponding calls in the other AX_PROG_*_MPI
+    # macros.
+    for lib in NONE mpi mpich; do
+      save_LIBS=$LIBS
+      if test x"$lib" = xNONE; then
+        { $as_echo "$as_me:${as_lineno-$LINENO}: checking for function MPI_Init" >&5
+$as_echo_n "checking for function MPI_Init... " >&6; }
+      else
+        { $as_echo "$as_me:${as_lineno-$LINENO}: checking for function MPI_Init in -l$lib" >&5
+$as_echo_n "checking for function MPI_Init in -l$lib... " >&6; }
+        LIBS="-l$lib $LIBS"
+      fi
+      cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h.  */
+/* Override any GCC internal prototype to avoid an error.
+   Use char because int might match the return type of a GCC
+   builtin and then its argument prototype would still apply.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+char MPI_Init ();
+int
+main ()
+return MPI_Init ();
+  return 0;
+_ACEOF
+if ac_fn_c_try_link "$LINENO"; then :
+   _ax_prog_cc_mpi_mpi_found=yes
+else
+fi
+rm -f core conftest.err conftest.$ac_objext \
+    conftest$ac_exeext conftest.$ac_ext
+      { $as_echo "$as_me:${as_lineno-$LINENO}: result: $_ax_prog_cc_mpi_mpi_found" >&5
+$as_echo "$_ax_prog_cc_mpi_mpi_found" >&6; }
+      if test "x$_ax_prog_cc_mpi_mpi_found" = "xyes"; then
+        break;
+      fi
+      LIBS=$save_LIBS
+    done
+    # Check for header
+    if test x"$_ax_prog_cc_mpi_mpi_found" = xyes; then :
+      { $as_echo "$as_me:${as_lineno-$LINENO}: checking for mpi.h" >&5
+$as_echo_n "checking for mpi.h... " >&6; }
 #include <mpi.h>
 int
 main ()
-int ret = MPI_Init(0, (void*)0)
   return 0;
 _ACEOF
 if ac_fn_c_try_compile "$LINENO"; then :
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+   { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
 $as_echo "yes" >&6; }
 else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
-                      as_fn_error $? "CC doesn't appear to be a valid MPI compiler.  See INSTALL document or try adding CC=mpicc to your configure command line." "$LINENO" 5
 fi
 rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+fi
+    ac_ext=c
+fi
+# Finally, execute ACTION-IF-FOUND/ACTION-IF-NOT-FOUND:
+if test x"$_ax_prog_cc_mpi_mpi_found" = xyes; then :
+        use_mpi=yes
+else
+        use_mpi=no
+fi
+ENABLE_MPI=1
+if test "x$use_mpi" = "xno"; then :
+  ENABLE_MPI=
+       if test "x$with_mpi" = "xyes"; then :
+  as_fn_error $? "CC doesn't appear to be a valid MPI compiler and MPI support was requested. See INSTALL document or try adding CC=mpicc to your configure command line." "$LINENO" 5
+fi
 else
-  { $as_echo "$as_me:${as_lineno-$LINENO}: not checking whether the mpicc compiler works" >&5
-$as_echo "$as_me: not checking whether the mpicc compiler works" >&6;}
+  ENABLE_MPI=1
+$as_echo "#define HAVE_MPI /**/" >>confdefs.h
+fi
+# Check whether --with-gcc was given.
+if test "${with_gcc+set}" = set; then :
+  withval=$with_gcc;
+else
+  with_gcc=yes
 fi
+cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+int
+main ()
+        #ifndef __GNUC__
+        #error GCC ERROR
+        #endif
+  return 0;
+_ACEOF
+if ac_fn_c_try_compile "$LINENO"; then :
+else
+  if test "x$with_gcc" = "xyes"; then :
+  as_fn_error which is strongly recommended for building Darshan. To force use of a non-GCC compatible compiler "CC doesn't appear to be a GNU-compatible compiler" "$LINENO" 5
+fi
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
 ac_ext=c
@@ -5889,8 +6143,9 @@ $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
 fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: Building Darshan with the following features:" >&5
-$as_echo "$as_me: Building Darshan with the following features:" >&6;}
+msg="Building Darshan with CC=$CC and with the following features:"
+{ $as_echo "$as_me:${as_lineno-$LINENO}: $msg" >&5
+$as_echo "$as_me: $msg" >&6;}
 if test "x$BUILD_NULL_MODULE" = "x"; then :
   { $as_echo "$as_me:${as_lineno-$LINENO}: NULL module support:    no" >&5
 $as_echo "$as_me: NULL module support:    no" >&6;}
@@ -14,23 +14,38 @@ AC_CONFIG_HEADER(darshan-runtime-config.h)
 AC_PROG_INSTALL
 dnl Check for MPI
-ENABLE_MPI=1
 AC_ARG_WITH(mpi,
-            AS_HELP_STRING([--without-mpi], [Build without support for MPI]))
-AS_IF([test "x$with_mpi" = "xno"],
-      ENABLE_MPI=,
-      [AC_DEFINE([HAVE_MPI], [], [Define if build is MPI-enabled])])
+            [AS_HELP_STRING([--without-mpi], [Build without support for MPI])],
+            [with_mpi=auto])
+AX_PROG_CC_MPI([test x"$with_mpi" != xno],
+               [use_mpi=yes],
+               [use_mpi=no])
-dnl Check to see if CC is an MPI compiler
-dnl TODO: better error message here
-AS_IF([test "x$ENABLE_MPI" = "x1"],
-      [AC_MSG_CHECKING(whether the mpicc compiler works)
-       AC_TRY_COMPILE([#include <mpi.h>], [int ret = MPI_Init(0, (void*)0)],
-    AC_MSG_RESULT(yes),
-    AC_MSG_RESULT(no)
-                      AC_MSG_ERROR(CC doesn't appear to be a valid MPI compiler.  See INSTALL document or try adding CC=mpicc to your configure command line.))],
-       AC_MSG_NOTICE(not checking whether the mpicc compiler works))
+ENABLE_MPI=1
+AS_IF([test "x$use_mpi" = "xno"],
+      [ENABLE_MPI=
+       AS_IF([test "x$with_mpi" = "xyes"],
+             [AC_MSG_ERROR(CC doesn't appear to be a valid MPI compiler and MPI support was requested. See INSTALL document or try adding CC=mpicc to your configure command line.)],)],
+      [ENABLE_MPI=1
+       AC_DEFINE([HAVE_MPI], [], [Define if build is MPI-enabled])])
+dnl check for GCC compiler support
+AC_ARG_WITH(gcc,
+            [AS_HELP_STRING([--without-gcc], [Build without a GCC-compatible compiler])],
+            [with_gcc=yes])
+AC_COMPILE_IFELSE([
+    AC_LANG_PROGRAM(,[
+        #ifndef __GNUC__
+        #error GCC ERROR
+        #endif
+    [AS_IF([test "x$with_gcc" = "xyes"],
+           [AC_MSG_ERROR(CC doesn't appear to be a GNU-compatible compiler, which is strongly recommended for building Darshan. To force use of a non-GCC compatible compiler, add --without-gcc to your configure command line.)],)])
 dnl runtime libraries require zlib
 CHECK_ZLIB
@@ -501,7 +516,8 @@ share/mpi-profile/darshan-bg-f.conf
 share/ld-opts/darshan-base-ld-opts
-AC_MSG_NOTICE(Building Darshan with the following features:)
+AC_MSG_NOTICE($msg)
 AS_IF([test "x$BUILD_NULL_MODULE" = "x"],   [AC_MSG_NOTICE(NULL module support:    no)], [AC_MSG_NOTICE(NULL module support:    yes)])
 AS_IF([test "x$BUILD_POSIX_MODULE" = "x"],   [AC_MSG_NOTICE(POSIX module support:   no)], [AC_MSG_NOTICE(POSIX module support:   yes)])
 AS_IF([test "x$BUILD_MPIIO_MODULE" = "x"],   [AC_MSG_NOTICE(MPIIO module support:   no)], [AC_MSG_NOTICE(MPIIO module support:   yes)])
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/fe73ff3e38a116108790ca910115197a34b4da2d
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20191205/6e00fd58/attachment-0001.html>
More information about the Darshan-commits mailing list
