[Darshan-commits] [Git][darshan/darshan][dev-no-mpi] remove some trailing whitespace
Philip Carns xgitlab at cels.anl.gov
Tue Aug 6 10:06:01 CDT 2019
Philip Carns pushed to branch dev-no-mpi at darshan / darshan
Commits:
34563531 by Phil Carns at 2019-08-06T15:05:52Z
1 changed file:
- darshan-runtime/lib/darshan-core.c
Changes:
@@ -132,7 +132,7 @@ static void darshan_get_logfile_name(
 static int darshan_log_open(
     char *logfile_name, darshan_core_log_fh *log_fh);
 static int darshan_log_write_job_record(
-    darshan_core_log_fh log_fh, struct darshan_core_runtime *core,
+    darshan_core_log_fh log_fh, struct darshan_core_runtime *core,
     uint64_t *inout_off);
 static int darshan_log_write_name_record_hash(
@@ -573,12 +573,12 @@ void darshan_core_shutdown()
             if(this_mod->mod_funcs.mod_redux_func && (mod_shared_recs > 0) &&
                (!getenv("DARSHAN_DISABLE_SHARED_REDUCTION")))
                 this_mod->mod_funcs.mod_redux_func(mod_buf, MPI_COMM_WORLD, mod_shared_recs,
-                    mod_shared_rec_cnt);
+                    mod_shared_rec_cnt);
 #endif
         /* if module is registered locally, get the corresponding output buffer
          * NOTE: this function can be used to run collective operations across
          * modules, if there are records shared globally.
@@ -868,9 +868,9 @@ static void add_entry(char* buf, int* space_left, struct mntent* entry)
         DARSHAN_MAX_MNT_PATH-1);
     strncpy(mnt_data_array[mnt_data_count].type, entry->mnt_type,
         DARSHAN_MAX_MNT_TYPE-1);
-    /* NOTE: we now try to detect the preferred block size for each file
-     * system using fstatfs().  On Lustre we assume a size of 1 MiB
-     * because fstatfs() reports 4 KiB.
+    /* NOTE: we now try to detect the preferred block size for each file
+     * system using fstatfs().  On Lustre we assume a size of 1 MiB
+     * because fstatfs() reports 4 KiB.
 #ifndef LL_SUPER_MAGIC
 #define LL_SUPER_MAGIC 0x0BD00BD0
@@ -895,7 +895,7 @@ static void add_entry(char* buf, int* space_left, struct mntent* entry)
         DIR *mount_dir;
         mount_dir = opendir( entry->mnt_dir );
-        if ( mount_dir  )
+        if ( mount_dir  )
             /* n_ost and n_mdt are used for both input and output to ioctl */
             n_ost = 0;
@@ -976,13 +976,13 @@ static void darshan_get_exe_and_mounts(struct darshan_core_runtime *core,
         /* if DARSHAN_EXCLUDE_DIRS=none, do not exclude any dir */
         if(strncmp(env_exclusions,"none",strlen(env_exclusions))>=0)
-            if (my_rank == 0)
+            if (my_rank == 0)
                 darshan_core_fprintf(stderr, "Darshan info: no system dirs will be excluded\n");
             darshan_path_exclusions[0]=NULL;
         else
-            if (my_rank == 0)
+            if (my_rank == 0)
                 darshan_core_fprintf(stderr, "Darshan info: the following system dirs will be excluded: %s\n",
                     env_exclusions);
             string = strdup(env_exclusions);
@@ -1030,7 +1030,7 @@ static void darshan_get_exe_and_mounts(struct darshan_core_runtime *core,
     if(argc == 0)
-        /* get the name of the executable and the arguments from
+        /* get the name of the executable and the arguments from
            /proc/self/cmdline */
         cmdl[0] = '\0';
@@ -1598,7 +1598,7 @@ static int darshan_log_write_name_record_hash(darshan_core_log_fh log_fh,
             rec_len = sizeof(darshan_record_id) + strlen(name_rec->name) + 1;
             if(ref->global_mod_flags)
                 /* this record is shared globally, move to the temporary
                  * shared record buffer and update hash references
@@ -1612,7 +1612,7 @@ static int darshan_log_write_name_record_hash(darshan_core_log_fh log_fh,
                 shared_buf_len += rec_len;
             else
                 /* this record is not shared, but we still may need to
                  * move it forward in our buffer and update hash references
@@ -1697,15 +1697,14 @@ static int darshan_log_write_header(darshan_core_log_fh log_fh,
         ret = PMPI_File_write_at(log_fh.mpi_fh, 0, core->log_hdr_p,
             sizeof(struct darshan_header), MPI_BYTE, &status);
         if(ret != MPI_SUCCESS)
             DARSHAN_WARN("error writing darshan log header");
             ret = -1;
         else
             ret = 0;
         return(ret);
 #endif
@@ -1802,7 +1801,7 @@ static int darshan_log_append(darshan_core_log_fh log_fh, struct darshan_core_ru
 #endif
     ret = pwrite(log_fh.nompi_fd, core->comp_buf, comp_buf_sz, *inout_off);
-    if(ret != comp_buf_sz)
+    if(ret != comp_buf_sz)
         return(-1);
     *inout_off += comp_buf_sz;
     return(0);
@@ -1967,7 +1966,7 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
     for(i = 0; i < DARSHAN_MAX_MODS; i++)
         if(core->mod_array[i])
             free(core->mod_array[i]);
             core->mod_array[i] = NULL;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/34563531e74805d3f08b73b80fc814736a09a38f
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20190806/d1544018/attachment-0001.html>
More information about the Darshan-commits mailing list
