[Darshan-commits] [Git][darshan/darshan][darshan_core_fprintf] 5 commits: bugfix to enable compilation on 32-bit platforms (resolves #252)
Shane Snyder
xgitlab at cels.anl.gov
Thu Nov 29 10:46:28 CST 2018
Shane Snyder pushed to branch darshan_core_fprintf at darshan / darshan
Commits:
ddc4cbb4 by Glenn K. Lockwood at 2018-11-24T17:46:38Z
1a8977a1 by Phil Carns at 2018-11-27T15:11:35Z
add wrapper for __open_2 function call
be086b44 by Shane Snyder at 2018-11-27T17:13:51Z
Merge branch 'carns/dev-issue-253' into 'master'
Closes #253
See merge request darshan/darshan!28
f119346b by Shane Snyder at 2018-11-27T17:26:17Z
Merge branch 'bugfix-32bit' into 'master'
Closes #252
See merge request darshan/darshan!26
9c83fab7 by Shane Snyder at 2018-11-29T16:45:57Z
Merge branch 'master' into darshan_core_fprintf
4 changed files:
- ChangeLog
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-posix-ld-opts
Changes:
ChangeLog
@@ -9,6 +9,8 @@ Darshan-3.1.7
were not properly up-converted. Reported by Teng Wang.
* bug fix to MiB reported in I/O performance estimate of
darshan-job-summary.pl when both posix and stdio access is present
+* added wrapper for __open_2(), bug reported by Cormac Garvey in which open
+ calls are not intercepted with some versions of glibc/gcc
Darshan-3.1.6
@@ -40,6 +40,7 @@ typedef int64_t off64_t;
DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
DARSHAN_FORWARD_DECL(open64, int, (const char *path, int flags, ...));
+DARSHAN_FORWARD_DECL(__open_2, int, (const char *path, int oflag));
DARSHAN_FORWARD_DECL(creat, int, (const char* path, mode_t mode));
DARSHAN_FORWARD_DECL(creat64, int, (const char* path, mode_t mode));
DARSHAN_FORWARD_DECL(mkstemp, int, (char *template));
@@ -403,6 +404,24 @@ int DARSHAN_DECL(open)(const char *path, int flags, ...)
return(ret);
+int DARSHAN_DECL(__open_2)(const char *path, int oflag)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(__open_2);
+ tm1 = darshan_core_wtime();
+ ret = __real___open_2(path, oflag);
+ tm2 = darshan_core_wtime();
+ POSIX_PRE_RECORD();
+ POSIX_RECORD_OPEN(ret, path, 0, tm1, tm2);
+ POSIX_POST_RECORD();
+ return(ret);
int DARSHAN_DECL(open64)(const char *path, int flags, ...)
int mode = 0;
@@ -752,7 +771,7 @@ off_t DARSHAN_DECL(lseek)(int fd, off_t offset, int whence)
return(ret);
-off_t DARSHAN_DECL(lseek64)(int fd, off_t offset, int whence)
+off64_t DARSHAN_DECL(lseek64)(int fd, off64_t offset, int whence)
off_t ret;
struct posix_file_record_ref *rec_ref;
@@ -84,6 +84,10 @@
#include "darshan.h"
#include "darshan-dynamic.h"
+#ifndef HAVE_OFF64_T
+typedef int64_t off64_t;
+#endif
DARSHAN_FORWARD_DECL(fopen, FILE*, (const char *path, const char *mode));
DARSHAN_FORWARD_DECL(fopen64, FILE*, (const char *path, const char *mode));
DARSHAN_FORWARD_DECL(fdopen, FILE*, (int fd, const char *mode));
@@ -110,7 +114,7 @@ DARSHAN_FORWARD_DECL(vfscanf, int, (FILE *stream, const char *format, va_list ap
DARSHAN_FORWARD_DECL(fgets, char*, (char *s, int size, FILE *stream));
DARSHAN_FORWARD_DECL(fseek, int, (FILE *stream, long offset, int whence));
DARSHAN_FORWARD_DECL(fseeko, int, (FILE *stream, off_t offset, int whence));
-DARSHAN_FORWARD_DECL(fseeko64, int, (FILE *stream, off_t offset, int whence));
+DARSHAN_FORWARD_DECL(fseeko64, int, (FILE *stream, off64_t offset, int whence));
DARSHAN_FORWARD_DECL(fsetpos, int, (FILE *stream, const fpos_t *pos));
DARSHAN_FORWARD_DECL(fsetpos64, int, (FILE *stream, const fpos64_t *pos));
DARSHAN_FORWARD_DECL(rewind, void, (FILE *stream));
@@ -855,7 +859,7 @@ int DARSHAN_DECL(fseeko)(FILE *stream, off_t offset, int whence)
return(ret);
-int DARSHAN_DECL(fseeko64)(FILE *stream, off_t offset, int whence)
+int DARSHAN_DECL(fseeko64)(FILE *stream, off64_t offset, int whence)
int ret;
struct stdio_file_record_ref *rec_ref;
@@ -1,5 +1,6 @@
--wrap=open
--wrap=open64
+--wrap=__open_2
--wrap=creat
--wrap=creat64
--wrap=mkstemp
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/500db6a0684154224f121f4f4422d0b52b0a2db6...9c83fab794b5733fb22f9b52c9e7594285f87abf
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20181129/5d177a2d/attachment-0001.html>
More information about the Darshan-commits
