[Darshan-commits] [Git][darshan/darshan][no-mpi] 2 commits: rename DARSHAN_NOMPI to DARSHAN_ENABLE_NONMPI
Glenn K. Lockwood
xgitlab at cels.anl.gov
Wed Nov 28 13:43:50 CST 2018
Glenn K. Lockwood pushed to branch no-mpi at darshan / darshan
Commits:
6a8e4062 by Glenn K. Lockwood at 2018-11-28T19:41:34Z
480799bd by Glenn K. Lockwood at 2018-11-28T19:42:53Z
remove signal handler and atexit options
3 changed files:
- darshan-runtime/darshan-core.h
- darshan-runtime/lib/darshan-core-init-finalize.c
- darshan-runtime/lib/darshan-core.c
Changes:
@@ -35,7 +35,7 @@
#define DARSHAN_MMAP_LOG_PATH_OVERRIDE "DARSHAN_MMAP_LOGPATH"
/* Environment variable to enable profiling without MPI */
-#define DARSHAN_NO_MPI "DARSHAN_NOMPI"
+#define DARSHAN_ENABLE_NONMPI "DARSHAN_ENABLE_NONMPI"
/* default path for storing mmap log files is '/tmp' */
#define DARSHAN_DEF_MMAP_LOG_PATH "/tmp"
@@ -93,7 +93,7 @@ DARSHAN_WRAPPER_MAP(PMPI_Finalize, int, (void), MPI_Finalize())
__attribute__((constructor)) void serial_init(void)
char *no_mpi;
- no_mpi = getenv(DARSHAN_NO_MPI);
+ no_mpi = getenv(DARSHAN_ENABLE_NONMPI);
if (no_mpi)
darshan_core_initialize(0, NULL);
return;
@@ -102,7 +102,7 @@ __attribute__((constructor)) void serial_init(void)
__attribute__((destructor)) void serial_finalize(void)
char *no_mpi;
if (no_mpi)
darshan_core_shutdown();
return;
@@ -156,14 +156,6 @@ static void darshan_sig_handler(int sig);
-#ifdef __DARSHAN_ATEXIT_HANDLER
-void darshan_atexit_handler(void)
- darshan_core_shutdown();
- return;
-#endif
void darshan_core_initialize(int argc, char **argv)
struct darshan_core_runtime *init_core = NULL;
@@ -341,29 +333,6 @@ void darshan_core_initialize(int argc, char **argv)
i++;
- /* if we've made it this far, go ahead and install the exit handlers
- if (!using_mpi)
- ret = atexit(darshan_atexit_handler);
- if (ret != 0)
- fprintf(stderr, "atexit handler could not be installed\n");
- else
- fprintf(stderr, "atexit handler is installed\n");
-#endif
-#ifdef __DARSHAN_SIGNAL_HANDLER
- /* install signal handlers to produce something on a soft abort
- * may be risky business though--if the core is locked when a signal is
- * trapped, we rely on recursive mutexes sorting themselves out to
- * prevent a deadlock. not necessarily worth biting off at this point.
- signal(SIGXCPU, darshan_sig_handler);
- signal(SIGTERM, darshan_sig_handler);
- signal(SIGABRT, darshan_sig_handler);
-#endif
if(internal_timing_flag)
@@ -1905,15 +1874,6 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
return;
-static void darshan_sig_handler(int sig)
- if (sig == SIGTERM || sig == SIGXCPU || sig == SIGABRT)
- return;
-#endif
/* crude benchmarking hook into darshan-core to benchmark Darshan
* shutdown overhead using a variety of application I/O workloads
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/df9d5388f806275b7f51b5f2f60e2298c5262c63...480799bdf252d1693d3b165bc92bb16c28b87b5d
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20181128/6a6ba995/attachment-0001.html>
More information about the Darshan-commits
