[Darshan-commits] [Git][darshan/darshan][master] 2 commits: add wrapper for __open_2 function call
Shane Snyder
xgitlab at cels.anl.gov
Tue Nov 27 11:13:52 CST 2018
Shane Snyder pushed to branch master at darshan / darshan
Commits:
1a8977a1 by Phil Carns at 2018-11-27T15:11:35Z
be086b44 by Shane Snyder at 2018-11-27T17:13:51Z
Merge branch 'carns/dev-issue-253' into 'master'
Closes #253
See merge request darshan/darshan!28
3 changed files:
- ChangeLog
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/share/ld-opts/darshan-posix-ld-opts
Changes:
ChangeLog
@@ -9,6 +9,8 @@ Darshan-3.1.7
were not properly up-converted. Reported by Teng Wang.
* bug fix to MiB reported in I/O performance estimate of
darshan-job-summary.pl when both posix and stdio access is present
+* added wrapper for __open_2(), bug reported by Cormac Garvey in which open
+ calls are not intercepted with some versions of glibc/gcc
Darshan-3.1.6
@@ -40,6 +40,7 @@ typedef int64_t off64_t;
DARSHAN_FORWARD_DECL(open, int, (const char *path, int flags, ...));
DARSHAN_FORWARD_DECL(open64, int, (const char *path, int flags, ...));
+DARSHAN_FORWARD_DECL(__open_2, int, (const char *path, int oflag));
DARSHAN_FORWARD_DECL(creat, int, (const char* path, mode_t mode));
DARSHAN_FORWARD_DECL(creat64, int, (const char* path, mode_t mode));
DARSHAN_FORWARD_DECL(mkstemp, int, (char *template));
@@ -403,6 +404,24 @@ int DARSHAN_DECL(open)(const char *path, int flags, ...)
return(ret);
+int DARSHAN_DECL(__open_2)(const char *path, int oflag)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(__open_2);
+ tm1 = darshan_core_wtime();
+ ret = __real___open_2(path, oflag);
+ tm2 = darshan_core_wtime();
+ POSIX_PRE_RECORD();
+ POSIX_RECORD_OPEN(ret, path, 0, tm1, tm2);
+ POSIX_POST_RECORD();
+ return(ret);
int DARSHAN_DECL(open64)(const char *path, int flags, ...)
int mode = 0;
@@ -1,5 +1,6 @@
--wrap=open
--wrap=open64
+--wrap=__open_2
--wrap=creat
--wrap=creat64
--wrap=mkstemp
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/4c900db7a5f71c1577aff0b0b4addd353d49b941...be086b444241ef5b641c6a763f532ce96db261b7
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20181127/c0deae74/attachment-0001.html>
More information about the Darshan-commits
