[Darshan-commits] [Git][darshan/darshan][master] 2 commits: example output logs for 3.1.6 release
Shane Snyder xgitlab at cels.anl.gov
Mon Mar 5 16:35:58 CST 2018
Shane Snyder pushed to branch master at darshan / darshan
Commits:
1c9b46a4 by Shane Snyder at 2018-03-05T16:20:49-06:00
04f97af4 by Shane Snyder at 2018-03-05T16:31:03-06:00
updated changelog for 3.1.6. release
3 changed files:
- ChangeLog
- + darshan-test/example-output/mpi-io-test-ppc64-3.1.6.darshan
- + darshan-test/example-output/mpi-io-test-x86_64-3.1.6.darshan
Changes:
ChangeLog
--- a/ChangeLog
+++ b/ChangeLog
@@ -2,6 +2,13 @@
 Darshan Release Change Log
+Darshan-3.1.6
+* bug fix for linker failures caused when linking external libraries
+that use MPI internally (e.g., PETSc). Reported by Bilel Hadri.
+* bug fix in mapping of Darshan's MPI_File_read_all wrapper to the
+  underlying MPI library call in dynamic linking case
 Darshan-3.1.5
 * modify Darshan MPI instrumentation method to intercept both MPI and
Binary files /dev/null and b/darshan-test/example-output/mpi-io-test-ppc64-3.1.6.darshan differ
Binary files /dev/null and b/darshan-test/example-output/mpi-io-test-x86_64-3.1.6.darshan differ
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/43648780498d8b4dbc8977d26176b9e8df8eda12...04f97af462589fc3b93c3d6fdb6e5866cb9238a8
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180305/bc547a04/attachment.html>
More information about the Darshan-commits mailing list
