[Darshan-commits] Build failed in Jenkins: Radix-IO » Darshan » theta-master-craymod #26
no-reply at alcf.anl.gov no-reply at alcf.anl.gov
Wed Jul 4 01:26:37 CDT 2018
See <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/theta-master-craymod/26/display/redirect>
Started by timer
Building remotely on RadixIO-Theta in workspace <https://cimaster.alcf.anl.gov/jenkins/job/Radix-IO/job/Darshan/job/theta-master-craymod/ws/>
 > git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url git at xgitlab.cels.anl.gov:darshan/darshan.git # timeout=10
Fetching upstream changes from git at xgitlab.cels.anl.gov:darshan/darshan.git
 > git --version # timeout=10
using GIT_SSH to set credentials
 > git fetch --tags --progress git at xgitlab.cels.anl.gov:darshan/darshan.git +refs/heads/*:refs/remotes/origin/*
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
 > git rev-parse refs/remotes/origin/origin/master^{commit} # timeout=10
Checking out Revision 1a362ac057543f3a74a3dff23dcfc2a1cdea2ab3 (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 1a362ac057543f3a74a3dff23dcfc2a1cdea2ab3
Commit message: "Merge branch 'hxhim-module' into 'master'"
 > git rev-list --no-walk 1a362ac057543f3a74a3dff23dcfc2a1cdea2ab3 # timeout=10
[theta-master-craymod] $ /bin/bash /tmp/jenkins4186691425710090542.sh
[theta-master-craymod] $ /bin/bash /tmp/jenkins2117140864623191532.sh
darshan-test/automated/theta/configure.sh: line 13: module: command not found
darshan-test/automated/theta/configure.sh: line 14: module: command not found
checking for a BSD-compatible install... /usr/bin/install -c
checking whether the mpicc compiler works... checking for x86_64-gcc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
no
configure: error: CC doesn't appear to be a valid MPI compiler.  See INSTALL document or try adding CC=mpicc to your configure command line.
checking for gcc... gcc
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for inflateEnd in -lz... yes
checking if bzlib is wanted... yes
checking for BZ2_bzCompressInit in -lbz2... yes
checking bzlib.h usability... yes
checking bzlib.h presence... yes
checking for bzlib.h... yes
checking for BZ2_bzCompressInit in -lbz2... (cached) yes
checking bzlib in /usr... ok
checking for inttypes.h... (cached) yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking for pdflatex... yes
checking for -halt-on-error argument to pdflatex... yes
checking whether byte ordering is bigendian... no
checking for off64_t... yes
checking for strndup... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating darshan-job-summary/bin/darshan-job-summary.pl
config.status: creating maint/darshan-util.pc
config.status: creating darshan-util-config.h
config.status: darshan-util-config.h is unchanged
Build step 'Execute shell' marked build as failure
Recording test results
More information about the Darshan-commits mailing list
