[Darshan-commits] [Git][darshan/darshan][autoperf-mod] 15 commits: Update darshan-job-summary.pl.in
Kevin Harms xgitlab at cels.anl.gov
Thu Jan 18 15:56:05 CST 2018
Kevin Harms pushed to branch autoperf-mod at darshan / darshan
Commits:
5fd87b0b by Thomas Applencourt at 2017-12-14T16:26:57-06:00
5ff6955f by Shane Snyder at 2017-12-15T14:46:06-06:00
fix bug in darshan-merge
utility was trying to aggregate DXT records, which have no
record aggregation function
61a1fa01 by Shane Snyder at 2017-12-19T15:24:08-06:00
Merge branch 'master' into 'master'
See merge request darshan/darshan!17
604df8cc by Phil Carns at 2018-01-05T12:14:13-08:00
fix __wrap_H5get_libversion undefined reference
- reported by Jialin Liu
- triggered by some HDF5 programs
- solved by eliminating incomplete wrapper mechanisms for H5get_libversion()
  and invoking it directly (Darshan needs to use, not wrap, this
  function)
e0051df0 by Shane Snyder at 2018-01-08T14:12:53-06:00
Merge branch 'dev-H5get_libversion_symbol' into 'master'
See merge request darshan/darshan!18
8f4d1e21 by Shane Snyder at 2018-01-09T04:59:24+00:00
propagate dxt env setting on bgq tests
1415afc1 by Shane Snyder at 2018-01-09T14:59:41+00:00
dxt bug fix in cobalt runjob script
866fe3d6 by Shane Snyder at 2018-01-09T09:01:56-06:00
update config versions for 3.1.5 release
52844ca8 by Shane Snyder at 2018-01-09T09:01:56-06:00
consistent DXT capitalization in darshan-util docs
db84851e by Shane Snyder at 2018-01-09T09:43:55-06:00
replace old example output that didn't include dxt
we should probably always include logs that contain dxt data in
the example output directory so we can track that module over
releases
cb8b3689 by Shane Snyder at 2018-01-09T09:44:55-06:00
new example log files for 3.1.5 release
3341b61f by Shane Snyder at 2018-01-09T18:09:34+00:00
fix broken cray-module-alcf runjob scripts
f6ee8cca by Shane Snyder at 2018-01-09T17:33:56-06:00
get dxt_analyzer show arg working
2becd2dc by Shane Snyder at 2018-01-09T17:43:18-06:00
brief note about dxt_analyzer in docs
86500f11 by Kevin Harms at 2018-01-18T21:55:44+00:00
Merge remote-tracking branch 'origin/master' into autoperf-mod
19 changed files:
- ChangeLog
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/share/ld-opts/darshan-hdf5-ld-opts
- darshan-test/example-output/mpi-io-test-ppc64-3.1.3.darshan
- darshan-test/example-output/mpi-io-test-ppc64-3.1.4.darshan
- + darshan-test/example-output/mpi-io-test-ppc64-3.1.5.darshan
- darshan-test/example-output/mpi-io-test-x86_64-3.1.3.darshan
- darshan-test/example-output/mpi-io-test-x86_64-3.1.4.darshan
- + darshan-test/example-output/mpi-io-test-x86_64-3.1.5.darshan
- darshan-test/regression/bg-profile-conf-alcf/runjob.sh
- darshan-test/regression/cray-module-alcf/runjob.sh
- darshan-util/configure
- darshan-util/configure.in
- darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
- darshan-util/darshan-merge.c
- darshan-util/doc/darshan-util.txt
- darshan-util/dxt_analyzer.py
Changes:
ChangeLog
--- a/ChangeLog
+++ b/ChangeLog
@@ -2,7 +2,7 @@
 Darshan Release Change Log
-Darshan-3.1.5-pre1
+Darshan-3.1.5
 * modify Darshan MPI instrumentation method to intercept both MPI and
   PMPI symbols to workaround MPI implementations that are calling
@@ -19,6 +19,10 @@ Darshan-3.1.5-pre1
 * add support for DARSHAN_EXCLUDE_DIRS environment variable to
   explicitly disable instrumentation for files in given
   directories. Contributed by Cristian Simarro.
+* correct "undefined reference to `__wrap_H5get_libversion'" linker failure
+  when compiling some HDF5 programs, reported by Jialin Liu
+* bug fix in darshan-merge utility related to logs containing DXT trace
+  data. Reported by Glenn Lockwood.
 Darshan-3.1.4
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1,6 +1,6 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.5-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.5.
 # Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
 # Identity of this package.
 PACKAGE_NAME='darshan-runtime'
 PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='3.1.5-pre1'
-PACKAGE_STRING='darshan-runtime 3.1.5-pre1'
+PACKAGE_VERSION='3.1.5'
+PACKAGE_STRING='darshan-runtime 3.1.5'
 PACKAGE_BUGREPORT=''
 PACKAGE_URL=''
@@ -1263,7 +1263,7 @@ if test "$ac_init_help" = "long"; then
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures darshan-runtime 3.1.5-pre1 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 3.1.5 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1325,7 +1325,7 @@ fi
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of darshan-runtime 3.1.5-pre1:";;
+     short | recursive ) echo "Configuration of darshan-runtime 3.1.5:";;
    esac
   cat <<\_ACEOF
@@ -1439,7 +1439,7 @@ fi
 test -n "$ac_init_help" && exit $ac_status
 if $ac_init_version; then
   cat <<\_ACEOF
-darshan-runtime configure 3.1.5-pre1
+darshan-runtime configure 3.1.5
 generated by GNU Autoconf 2.69
 Copyright (C) 2012 Free Software Foundation, Inc.
@@ -1791,7 +1791,7 @@ cat >config.log <<_ACEOF
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 3.1.5-pre1, which was
+It was created by darshan-runtime $as_me 3.1.5, which was
 generated by GNU Autoconf 2.69.  Invocation command line was
   $ $0 $@
@@ -4400,7 +4400,7 @@ else
   MPICH_LIB_OLD=0
 fi
-DARSHAN_VERSION="3.1.5-pre1"
+DARSHAN_VERSION="3.1.5"
@@ -4922,7 +4922,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 # report actual input values of CONFIG_FILES etc. instead of their
 # values after options handling.
 ac_log="
-This file was extended by darshan-runtime $as_me 3.1.5-pre1, which was
+This file was extended by darshan-runtime $as_me 3.1.5, which was
   CONFIG_FILES    = $CONFIG_FILES
@@ -4984,7 +4984,7 @@ _ACEOF
 cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
 ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
 ac_cs_version="\\
-darshan-runtime config.status 3.1.5-pre1
+darshan-runtime config.status 3.1.5
 configured by $0, generated by GNU Autoconf 2.69,
   with options \\"\$ac_cs_config\\"
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
 dnl You may need to use autoheader as well if changing any DEFINEs
 dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [3.1.5-pre1])
+AC_INIT([darshan-runtime], [3.1.5])
 AC_CONFIG_SRCDIR([darshan.h])
 AC_CONFIG_AUX_DIR(../maint/config)
 AC_CONFIG_HEADER(darshan-runtime-config.h)
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -36,7 +36,11 @@ typedef int herr_t;     //hf5-1.10.0p1: H5public.h:126
 DARSHAN_FORWARD_DECL(H5Fcreate, hid_t, (const char *filename, unsigned flags, hid_t create_plist, hid_t access_plist));
 DARSHAN_FORWARD_DECL(H5Fopen, hid_t, (const char *filename, unsigned flags, hid_t access_plist));
 DARSHAN_FORWARD_DECL(H5Fclose, herr_t, (hid_t file_id));
-DARSHAN_FORWARD_DECL(H5get_libversion, herr_t, (unsigned *majnum, unsigned *minnum, unsigned *relnum));
+/* prototype for HDF symbols that we will call directly from within other
+ * wrappers if HDF is linked in
+extern herr_t H5get_libversion(unsigned *majnum, unsigned *minnum, unsigned *relnum);
 /* structure that can track i/o stats for a given HDF5 file record at runtime */
 struct hdf5_file_record_ref
@@ -122,8 +126,7 @@ hid_t DARSHAN_DECL(H5Fcreate)(const char *filename, unsigned flags,
     double tm1;
     unsigned majnum, minnum, relnum;
-    MAP_OR_FAIL(H5get_libversion);
-    __real_H5get_libversion(&majnum, &minnum, &relnum);
+    H5get_libversion(&majnum, &minnum, &relnum);
 #ifdef __DARSHAN_ENABLE_HDF5110
     if(majnum < 1 || (majnum == 1 && minnum < 10))
 #else
@@ -171,8 +174,7 @@ hid_t DARSHAN_DECL(H5Fopen)(const char *filename, unsigned flags,
     double tm1;
 #else
--- a/darshan-runtime/share/ld-opts/darshan-hdf5-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-hdf5-ld-opts
@@ -2,4 +2,3 @@
 --wrap=H5Fcreate
 --wrap=H5Fopen
 --wrap=H5Fclose
---wrap=H5get_libversion
Binary files a/darshan-test/example-output/mpi-io-test-ppc64-3.1.3.darshan and b/darshan-test/example-output/mpi-io-test-ppc64-3.1.3.darshan differ
Binary files a/darshan-test/example-output/mpi-io-test-ppc64-3.1.4.darshan and b/darshan-test/example-output/mpi-io-test-ppc64-3.1.4.darshan differ
Binary files /dev/null and b/darshan-test/example-output/mpi-io-test-ppc64-3.1.5.darshan differ
Binary files a/darshan-test/example-output/mpi-io-test-x86_64-3.1.3.darshan and b/darshan-test/example-output/mpi-io-test-x86_64-3.1.3.darshan differ
Binary files a/darshan-test/example-output/mpi-io-test-x86_64-3.1.4.darshan and b/darshan-test/example-output/mpi-io-test-x86_64-3.1.4.darshan differ
Binary files /dev/null and b/darshan-test/example-output/mpi-io-test-x86_64-3.1.5.darshan differ
--- a/darshan-test/regression/bg-profile-conf-alcf/runjob.sh
+++ b/darshan-test/regression/bg-profile-conf-alcf/runjob.sh
@@ -1,7 +1,12 @@
 #!/bin/bash
+# convert DXT env setting
+if [ -n "${DXT_ENABLE_IO_TRACE+defined}" ]; then
+	DXT_ENV="--env DXT_ENABLE_IO_TRACE=$DXT_ENABLE_IO_TRACE"
+fi
 # submit job and get job id
-jobid=`qsub --env DARSHAN_LOGFILE=$DARSHAN_LOGFILE --mode c16 --proccount $DARSHAN_DEFAULT_NPROCS -A radix-io -t 10 -n 1 --output $DARSHAN_TMP/$$-tmp.out --error $DARSHAN_TMP/$$-tmp.err --debuglog $DARSHAN_TMP/$$-tmp.debuglog "$@"`
+jobid=`qsub --env DARSHAN_LOGFILE=$DARSHAN_LOGFILE $DXT_ENV --mode c16 --proccount $DARSHAN_DEFAULT_NPROCS -A radix-io -t 10 -n 1 --output $DARSHAN_TMP/$$-tmp.out --error $DARSHAN_TMP/$$-tmp.err --debuglog $DARSHAN_TMP/$$-tmp.debuglog "$@"`
 if [ $? -ne 0 ]; then
 	echo "Error: failed to qsub $@"
 	exit 1
--- a/darshan-test/regression/cray-module-alcf/runjob.sh
+++ b/darshan-test/regression/cray-module-alcf/runjob.sh
@@ -1,7 +1,12 @@
 #!/bin/bash
+fi
-jobid=`qsub --env DARSHAN_LOGFILE=$DARSHAN_LOGFILE --env DARSHAN_DEFAULT_NPROCS=$DARSHAN_DEFAULT_NPROCS --proccount $DARSHAN_DEFAULT_NPROCS -A EarlyPerf_theta -t 20 -n 1 --output $DARSHAN_TMP/$$-tmp.out --error $DARSHAN_TMP/$$-tmp.err --debuglog $DARSHAN_TMP/$$-tmp.debuglog $DARSHAN_TESTDIR/$DARSHAN_PLATFORM/cobalt-submit.sh "$@"`
+jobid=`qsub --env DARSHAN_LOGFILE=$DARSHAN_LOGFILE --env DARSHAN_DEFAULT_NPROCS=$DARSHAN_DEFAULT_NPROCS $DXT_ENV --proccount $DARSHAN_DEFAULT_NPROCS -A radix-io -q debug-cache-quad -t 20 -n 1 --output $DARSHAN_TMP/$$-tmp.out --error $DARSHAN_TMP/$$-tmp.err --debuglog $DARSHAN_TMP/$$-tmp.debuglog $DARSHAN_TESTDIR/$DARSHAN_PLATFORM/cobalt-submit.sh "$@"`
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1,6 +1,6 @@
 #! /bin/sh
-# Generated by GNU Autoconf 2.69 for darshan-util 3.1.5-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-util 3.1.5.
 PACKAGE_NAME='darshan-util'
 PACKAGE_TARNAME='darshan-util'
-PACKAGE_STRING='darshan-util 3.1.5-pre1'
+PACKAGE_STRING='darshan-util 3.1.5'
 PACKAGE_URL=''
@@ -1247,7 +1247,7 @@ if test "$ac_init_help" = "long"; then
   cat <<_ACEOF
-\`configure' configures darshan-util 3.1.5-pre1 to adapt to many kinds of systems.
+\`configure' configures darshan-util 3.1.5 to adapt to many kinds of systems.
@@ -1309,7 +1309,7 @@ fi
-     short | recursive ) echo "Configuration of darshan-util 3.1.5-pre1:";;
+     short | recursive ) echo "Configuration of darshan-util 3.1.5:";;
    esac
   cat <<\_ACEOF
@@ -1405,7 +1405,7 @@ fi
   cat <<\_ACEOF
-darshan-util configure 3.1.5-pre1
+darshan-util configure 3.1.5
@@ -1770,7 +1770,7 @@ cat >config.log <<_ACEOF
-It was created by darshan-util $as_me 3.1.5-pre1, which was
+It was created by darshan-util $as_me 3.1.5, which was
   $ $0 $@
@@ -4117,7 +4117,7 @@ fi
 done
-DARSHAN_UTIL_VERSION="3.1.5-pre1"
+DARSHAN_UTIL_VERSION="3.1.5"
@@ -4633,7 +4633,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 ac_log="
-This file was extended by darshan-util $as_me 3.1.5-pre1, which was
+This file was extended by darshan-util $as_me 3.1.5, which was
@@ -4695,7 +4695,7 @@ _ACEOF
 ac_cs_version="\\
-darshan-util config.status 3.1.5-pre1
+darshan-util config.status 3.1.5
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
-AC_INIT([darshan-util], [3.1.5-pre1])
+AC_INIT([darshan-util], [3.1.5])
 AC_CONFIG_SRCDIR([darshan-logutils.h])
 AC_CONFIG_HEADER(darshan-util-config.h)
--- a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
+++ b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
@@ -32,6 +32,7 @@ my $gnuplot        = "gnuplot";
 my $orig_dir = getcwd;
 my $output_file = "summary.pdf";
 my $verbose_flag = 0;
+my $summary_flag = 0;
 my $input_file = "";
 my %posix_access_hash = ();
 my %mpiio_access_hash = ();
@@ -989,6 +990,12 @@ my $tmp_total_time = $slowest_uniq_time+$shared_file_time;
 print("Total absolute I/O time: $tmp_total_time\n");
 print("**NOTE: above shared and unique file times calculated using MPI-IO timers if MPI-IO interface used on a given file, POSIX timers otherwise.\n");
+#Exit here if user ask only for a summary
+if ($summary_flag)
+        exit(0);
 # move to tmp_dir
 chdir $tmp_dir;
@@ -1486,12 +1493,13 @@ sub process_file_record
 sub process_args
-    use vars qw( $opt_help $opt_output $opt_verbose );
+    use vars qw( $opt_help $opt_output $opt_verbose $opt_summary);
     Getopt::Long::Configure("no_ignore_case", "bundling");
     GetOptions( "help",
         "output=s",
-        "verbose");
+        "verbose",
+        "summary");
     if($opt_help)
@@ -1509,6 +1517,11 @@ sub process_args
         $verbose_flag = $opt_verbose;
+    if($opt_summary)
+        $summary_flag = $opt_summary;
     # there should only be one remaining argument: the input file
     if($#ARGV != 0)
@@ -1611,6 +1624,7 @@ Usage: $PROGRAM_NAME <options> input_file
     --help          Prints this help message
     --output        Specifies a file to write pdf output to
                     (defaults to ./summary.pdf)
+    --summary       Print a very succinct I/O timing summary and exit
     --verbose       Prints and retains tmpdir used for LaTeX output
 Purpose:
--- a/darshan-util/darshan-merge.c
+++ b/darshan-util/darshan-merge.c
@@ -98,6 +98,10 @@ int build_mod_shared_rec_hash(char **infile_list, int n_infiles,
     int ret;
     int i;
+    /* if this module has no method for aggregating shared records, do nothing */
+    if(!(mod_logutils[mod_id]->log_agg_records))
+        return(0);
     /* loop over each input log file */
     for(i = 0; i < n_infiles; i++)
@@ -233,6 +237,8 @@ int main(int argc, char *argv[])
             return(-1);
+#if 0
+        /* XXX: the darshan_shutdown tag is never set in darshan-core, currently */
         /* if the input darshan log has metadata set indicating the darshan
          * shutdown procedure was called on the log, then we error out. if the
          * shutdown procedure was started, then it's possible the log has
@@ -246,6 +252,7 @@ int main(int argc, char *argv[])
             darshan_log_close(in_fd);
             return(-1);
+#endif
         if(i == 0)
--- a/darshan-util/doc/darshan-util.txt
+++ b/darshan-util/doc/darshan-util.txt
@@ -589,9 +589,9 @@ This option is mainly useful for more detailed automated analysis.
 === darshan-dxt-parser
-The `darshan-dxt-parser` utility can be used to parse DxT traces out of Darshan
-log files, assuming the corresponding application was executed with the DxT
-modules enabled. The following example parses all DxT trace information out
+The `darshan-dxt-parser` utility can be used to parse DXT traces out of Darshan
+log files, assuming the corresponding application was executed with the DXT
+modules enabled. The following example parses all DXT trace information out
 of a Darshan log file and stores it in a text file:
@@ -604,7 +604,7 @@ The preamble to `darshan-dxt-parser` output is identical to that of the traditio
 `darshan-parser` utility, which is described above.
 `darshan-dxt-parser` displays detailed trace information contained within a Darshan log
-that was generated with DxT instrumentation enabled. Trace data is captured from both
+that was generated with DXT instrumentation enabled. Trace data is captured from both
 POSIX and MPI-IO interfaces. Example output is given below:
 .Example output
@@ -646,15 +646,15 @@ POSIX and MPI-IO interfaces. Example output is given below:
  X_MPIIO       0   read        3       262144      0.0050      0.0051
-===== DxT POSIX module
+===== DXT POSIX module
 This module provides details on each read or write access at the POSIX layer.
 The trace output is organized first by file then by process rank. So, for each
-file accessed by the application, DxT will provide each process's I/O trace
+file accessed by the application, DXT will provide each process's I/O trace
 segments in separate blocks, ordered by increasing process rank. Within each
 file/rank block, I/O trace segments are ordered chronologically.
-Before providing details on each I/O operation, DxT provides a short preamble
+Before providing details on each I/O operation, DXT provides a short preamble
 for each file/rank trace block with the following bits of information: the Darshan
 identifier for the file (which is equivalent to the identifers used by Darshan in its
 traditional modules), the full file path, the corresponding MPI rank the current
@@ -668,7 +668,7 @@ The output format for each indvidual I/O operation segment is:
 # Module    Rank  Wt/Rd  Segment          Offset       Length    Start(s)      End(s)
-* Module: corresponding DxT module (DXT_POSIX or DXT_MPIIO)
+* Module: corresponding DXT module (DXT_POSIX or DXT_MPIIO)
 * Rank: process rank responsible for I/O operation
 * Wt/Rd: whether the operation was a write or read
 * Segment: The operation number for this segment (first operation is segment 0)
@@ -677,14 +677,14 @@ The output format for each indvidual I/O operation segment is:
 * Start: timestamp of the start of the operation (w.r.t. application start time)
 * End: timestamp of the end of the operation (w.r.t. application start time)
-===== DxT MPI-IO module
+===== DXT MPI-IO module
 If the MPI-IO interface is used by an application, this module provides details on
 each read or write access at the MPI-IO layer. This data is often useful in
 understanding how MPI-IO read or write operations map to underlying POSIX read
 or write operations issued to the traced file.
-The output format for the DxT MPI-IO module is essentially identical to the DxT
+The output format for the DXT MPI-IO module is essentially identical to the DXT
 POSIX module, except that the offset of file operations is not tracked.
 === Other darshan-util utilities
@@ -706,4 +706,5 @@ provides a C interface for opening and parsing Darshan log files.  This is
 the recommended method for writing custom utilities, as darshan-logutils
 provides a relatively stable interface across different versions of Darshan
 and different log formats.
+* dxt_analyzer: plots the read or write activity of a job using data obtained
+from Darshan's DXT modules (if DXT is enabled).
--- a/darshan-util/dxt_analyzer.py
+++ b/darshan-util/dxt_analyzer.py
@@ -75,7 +75,7 @@ python dxt_analyzer.py -i darshan_dxt-v.txt
 import numpy as np
 import matplotlib
-matplotlib.use('PDF')
+#matplotlib.use('PDF')
 import matplotlib.pyplot as plt
 import re
 import argparse
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/ea7af5f33ef5ece946dbef81191fa19847512320...86500f11cbbf65289545c35bab7ad96b5958d336
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180118/c617d8cc/attachment-0001.html>
More information about the Darshan-commits mailing list
