[Darshan-commits] [Git][darshan/darshan][autoperf-mod] set module id for apxc when submodule not present
Philip Carns
xgitlab at cels.anl.gov
Thu Feb 22 14:40:12 CST 2018
Philip Carns pushed to branch autoperf-mod at darshan / darshan
Commits:
61692df8 by Phil Carns at 2018-02-22T15:39:25-05:00
- compile cleanly when not using submodule, and reserve the same spot in
the module identifier space either way
1 changed file:
- darshan-log-format.h
Changes:
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -133,6 +133,18 @@ struct darshan_base_record
* component -- NULL can be passed if there are no
* logutil definitions)
+/* NOTE: if APXC support is not enabled, we still want to hold it's spot
+ * in the module id space
+#ifdef DARSHAN_USE_APXC
+#define __DARSHAN_APXC_VER DARSHAN_APXC_VER
+#define __apxc_logutils = &apx_logutils;
+#else
+#define __DARSHAN_APXC_VER 0
+#define __apxc_logutils NULL
+#endif
#define DARSHAN_MODULE_IDS \
X(DARSHAN_NULL_MOD, "NULL", DARSHAN_NULL_VER, NULL) \
X(DARSHAN_POSIX_MOD, "POSIX", DARSHAN_POSIX_VER, &posix_logutils) \
@@ -144,7 +156,7 @@ struct darshan_base_record
X(DARSHAN_STDIO_MOD, "STDIO", DARSHAN_STDIO_VER, &stdio_logutils) \
X(DXT_POSIX_MOD, "DXT_POSIX", DXT_POSIX_VER, &dxt_posix_logutils) \
X(DXT_MPIIO_MOD, "DXT_MPIIO", DXT_MPIIO_VER, &dxt_mpiio_logutils) \
- X(DARSHAN_APXC_MOD, "DARSHAN_APXC", DARSHAN_APXC_VER, &apxc_logutils)
+ X(DARSHAN_APXC_MOD, "DARSHAN_APXC", __DARSHAN_APXC_VER, __apxc_logutils)
/* unique identifiers to distinguish between available darshan modules */
/* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/61692df8abede2b37b8f12a8ac1f034780d8de24
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180222/0c9dbbd5/attachment.html>
More information about the Darshan-commits
