[Darshan-commits] [Git][darshan/darshan][autoperf-mod] Add darshan python interface
    Kevin Harms
    xgitlab at cels.anl.gov
    Mon Feb 19 19:53:46 CST 2018
Kevin Harms pushed to branch autoperf-mod at darshan / darshan
Commits:
41863019 by Kevin Harms at 2018-02-20T01:53:40+00:00
6 changed files:
- darshan-runtime/configure.in
- darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in
- darshan-util/darshan-logutils.c
- darshan-util/darshan-logutils.h
- + darshan-util/pydarshan.py
- modules/autoperf
Changes:
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -169,8 +169,15 @@ if test x$enable_lustre_mod != xno; then
 fi
-AC_MSG_NOTICE([value for $enable_autoperf_crayxc])
 if test x$enable_autoperf_crayxc = xyes; then
+    AC_CHECK_HEADER([papi.h],
+                    with_papi=-lpapi,
+                    [AC_MSG_ERROR([Cannot find required header for papi])],
+    AC_REQUIRE_AUX_FILE([modules/autoperf/crayxc/darshan-apxc-log-format.h])
+dnl    AC_CHECK_FILE([modules/autoperf/crayxc/darshan-apxc-log-format.h],
+dnl                  DARSHAN_USE_APXC=1,
+dnl                  [AC_MSG_ERROR([AutoPerf submodule not initialized])])
     DARSHAN_USE_APXC=1
 fi
@@ -395,6 +402,7 @@ AC_SUBST(DARSHAN_USE_LUSTRE)
 AC_SUBST(DARSHAN_USE_APXC)
 AC_SUBST(BUILD_HDF5_MODULE)
 AC_SUBST(DARSHAN_HDF5_LD_OPTS)
+AC_SUBST(with_papi)
 AC_OUTPUT(Makefile
 darshan-mk-log-dirs.pl
 darshan-gen-cc.pl
--- a/darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in
+++ b/darshan-runtime/lib/pkgconfig/darshan-runtime.pc.in
@@ -16,4 +16,4 @@ darshan_linkopts="-Wl,@${darshan_share}/ld-opts/darshan-base-ld-opts"
 Cflags:
 Libs:
-Libs.private: ${darshan_linkopts} ${darshan_libdir} -lfmpich -lmpichcxx -Wl,--start-group -ldarshan -ldarshan-stubs -Wl,--end-group
+Libs.private: ${darshan_linkopts} ${darshan_libdir} -lfmpich -lmpichcxx -Wl,--start-group -ldarshan -ldarshan-stubs -Wl,--end-group @with_papi@
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -1833,6 +1833,52 @@ int darshan_log_get_namerecs_3_00(void *name_rec_buf, int buf_len,
+ * Support functions for use with other languages
+ * darshan_log_get_modules
+ * Gets list of modules present in logs and returns the info
+void darshan_log_get_modules (darshan_fd fd,
+                              struct darshan_mod_info **mods,
+                              int* count)
+    int i;
+    int j;
+    *mods = malloc(sizeof(**mods) * DARSHAN_MAX_MODS);
+    assert(*mods);
+    for (i = 0, j = 0; i < DARSHAN_MAX_MODS; i++)
+        if (fd->mod_map[i].len)
+            (*mods)[j].name = darshan_module_names[i];
+            (*mods)[j].len  = fd->mod_map[i].len;
+            (*mods)[j].ver  = fd->mod_ver[i];
+            (*mods)[j].idx  = i;
+            j += 1;
+    *count = j;
+    return;
+int  darshan_log_get_record (darshan_fd fd,
+                             int mod_idx,
+                             void **buf)
+    int r;
+    r = mod_logutils[mod_idx]->log_get_record(fd, buf);
+    return r;
  * Local variables:
  *  c-indent-level: 4
  *  c-basic-offset: 4
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -68,6 +68,14 @@ struct darshan_mnt_info
     char mnt_path[DARSHAN_EXE_LEN];
+struct darshan_mod_info
+    char *name;
+    int  len;
+    int  ver;
+    int  idx;
 /* functions to be implemented by each module for integration with
  * darshan log file utilities (e.g., parser & convert tools)
@@ -161,6 +169,8 @@ int darshan_log_put_mod(darshan_fd fd, darshan_module_id mod_id,
     void *mod_buf, int mod_buf_sz, int ver);
 void darshan_log_close(darshan_fd file);
 void darshan_log_print_version_warnings(const char *version_string);
+void darshan_log_get_modules (darshan_fd fd, struct darshan_mod_info **mods, int* count);
+int darshan_log_get_record (darshan_fd fd, int mod_idx, void **buf);
 /* convenience macros for printing Darshan counters */
 #define DARSHAN_PRINT_HEADER() \
--- /dev/null
+++ b/darshan-util/pydarshan.py
@@ -0,0 +1,268 @@
+import cffi
+import numpy
+API_def_c = r"""
+/* from darshan-logutils.h */
+struct darshan_mnt_info
+    char mnt_type[3031];
+    char mnt_path[3031];
+    char *name;
+    int  len;
+    int  ver;
+    int  idx;
+/* from darshan-log-format.h */
+struct darshan_job
+    int64_t uid;
+    int64_t start_time;
+    int64_t end_time;
+    int64_t nprocs;
+    int64_t jobid;
+    char metadata[1024];
+struct darshan_base_record
+    uint64_t id;
+    int64_t rank;
+struct darshan_posix_file
+    struct darshan_base_record base_rec;
+    int64_t counters[64];
+    double fcounters[17];
+struct darshan_stdio_file
+    int64_t counters[13];
+    double fcounters[15];
+struct darshan_mpiio_file
+    int64_t counters[51];
+struct darshan_hdf5_file
+    int64_t counters[1];
+    double fcounters[2];
+struct darshan_pnetcdf_file
+    int64_t counters[2];
+struct darshan_bgq_record
+    int64_t counters[11];
+    double fcounters[1];
+/* from darshan-apxc-log-format.h */
+struct darshan_apxc_header_record
+    int64_t magic;
+    int nblades;
+    int nchassis;
+    int ngroups;
+    int memory_mode;
+    int cluster_mode;
+struct darshan_apxc_perf_record
+    int64_t counters[396];
+/* counter names */
+char *apxc_counter_names[];
+char *bgq_counter_names[];
+char *bgq_f_counter_names[];
+char *hdf5_counter_names[];
+char *hdf5_f_counter_names[];
+char *mpiio_counter_names[];
+char *mpiio_f_counter_names[];
+char *pnetcdf_counter_names[];
+char *pnetcdf_f_counter_names[];
+char *posix_counter_names[];
+char *posix_f_counter_names[];
+char *stdio_counter_names[];
+char *stdio_f_counter_names[];
+/* Supported Functions */
+void* darshan_log_open(char *);
+int darshan_log_get_job(void *, struct darshan_job *);
+void darshan_log_close(void*);
+int darshan_log_get_exe(void*, char *);
+int darshan_log_get_mounts(void*, struct darshan_mnt_info **, int*);
+void darshan_log_get_modules(void*, struct darshan_mod_info **, int*);
+int darshan_log_get_record(void*, int, void **);
+ffi = cffi.FFI()
+ffi.cdef(API_def_c)
+libdutil = ffi.dlopen("/home/harms/working/darshan/theta/install/lib/libdarshan-util.so")
+modules = {}
+def log_open(filename):
+  b_fname = filename.encode()
+  log = libdutil.darshan_log_open(b_fname)
+  mods = log_get_modules(log)
+  return log
+def log_close(log):
+  libdutil.darshan_log_close(log)
+  modules = {}
+  return
+def log_get_job(log):
+  job = {}
+  jobrec = ffi.new("struct darshan_job *")
+  libdutil.darshan_log_get_job(log, jobrec)
+  job['jobid'] = jobrec[0].jobid
+  job['uid']   = jobrec[0].uid
+  job['start_time'] = jobrec[0].start_time
+  job['end_time']   = jobrec[0].end_time
+  mstr = ffi.string(jobrec[0].metadata).decode("utf-8")
+  md = {}
+  for kv in mstr.split('\n')[:-1]:
+    k,v = kv.split('=', maxsplit=1)
+    md[k] = v
+  job['metadata']   = md
+  return job
+def log_get_exe(log):
+  exestr = ffi.new("char[]", 4096)
+  libdutil.darshan_log_get_exe(log, exestr)
+  return ffi.string(exestr).decode("utf-8")
+def log_get_mounts(log):
+  mntlst = []
+  mnts = ffi.new("struct darshan_mnt_info **")
+  cnt  = ffi.new("int *")
+  libdutil.darshan_log_get_mounts(log, mnts, cnt)
+  for i in range(0, cnt[0]):
+      mntlst.append((ffi.string(mnts[0][i].mnt_path).decode("utf-8"),
+                     ffi.string(mnts[0][i].mnt_type).decode("utf-8")))
+  return mntlst
+def log_get_modules(log):
+  mods = ffi.new("struct darshan_mod_info **")
+  libdutil.darshan_log_get_modules(log, mods, cnt)
+      modules[ffi.string(mods[0][i].name).decode("utf-8")] = \
+        {'len': mods[0][i].len, 'ver': mods[0][i].ver, 'idx': mods[0][i].idx}
+  return modules
+def log_get_generic_record(log, mod_name, mod_type):
+  rec = {}
+  buf = ffi.new("void **")
+  r = libdutil.darshan_log_get_record(log, modules[mod_name]['idx'], buf)
+  if r < 1:
+    return None
+  rbuf = ffi.cast(mod_type, buf)
+  clst = []
+  for i in range(0, len(rbuf[0].counters)):
+    clst.append(rbuf[0].counters[i])
+  rec['counters'] = numpy.array(clst, dtype=numpy.uint64)
+  flst = []
+  for i in range(0, len(rbuf[0].fcounters)):
+    flst.append(rbuf[0].fcounters[i])
+  rec['fcounters'] = numpy.array(clst, dtype=numpy.float64)
+  return rec
+def counter_names(mod_name, fcnts=False):
+  names = []
+  i = 0
+  if fcnts:
+    F = "f_"
+  else:
+   F1 = ""
+   F2 = ""
+  end = "{0}_{1}NUM_INDICES".format(mod_name.upper(), F.upper())
+  var_name = "{0}_{1}counter_names".format(mod_name.lower(), F.lower())
+  while True:
+    try:
+      var = getattr(libdutil, var_name)
+    except:
+      var = None
+    if not var:
+      return None
+    name = ffi.string(var[i]).decode("utf-8")
+    if name == end:
+      break
+    names.append(name)
+    i += 1
+  return names
+def fcounter_names(mod_name):
+  return counter_names(mod_name, fcnts=True)
+def log_get_bgq_record(log):
+  return log_get_generic_record(log, "BGQ", "struct darshan_bgq_file **")
+def log_get_hdf5_record(log):
+  return log_get_generic_record(log, "HDF5", "struct darshan_hdf5_file **")
+def log_get_mpiio_record(log):
+  return log_get_generic_record(log, "MPIIO", "struct darshan_mpiio_file **")
+def log_get_pnetcdf_record(log):
+  return log_get_generic_record(log, "PNETCDF", "struct darshan_pnetcdf_file **")
+def log_get_posix_record(log):
+  return log_get_generic_record(log, "POSIX", "struct darshan_posix_file **")
+def log_get_stdio_record(log):
+  return log_get_generic_record(log, "STDIO", "struct darshan_stdio_file **")
+def log_get_apxc_record(log):
+  rec = {}
+  memory_modes = ['unknown', 'flat', 'equal', 'split', 'cache']
+  cluster_modes = ['unknown', 'all2all', 'quad', 'hemi', 'snc4', 'snc2']
+  r = libdutil.darshan_log_get_record(log, modules['DARSHAN_APXC']['idx'], buf)
+  if r < 1:
+    return None
+  prf = ffi.cast("struct darshan_apxc_perf_record **", buf)
+  hdr = ffi.cast("struct darshan_apxc_header_record **", buf)
+  if hdr[0].magic == 4707761685111591494:
+    mm = hdr[0].memory_mode & ~(1 << 31)
+    cm = hdr[0].cluster_mode & ~(1 << 31)
+    rec['nblades'] = hdr[0].nblades
+    rec['nchassis'] = hdr[0].nchassis
+    rec['ngroups'] = hdr[0].ngroups
+    rec['memory_mode'] = memory_modes[mm]
+    rec['cluster_mode'] = cluster_modes[cm]
+  else:
+    rec['group'] = prf[0].counters[0]
+    rec['chassis'] = prf[0].counters[1]
+    rec['blade'] = prf[0].counters[2]
+    rec['node'] = prf[0].counters[3]
+    clst = []
+    for i in range(0, len(prf[0].counters)):
+      clst.append(prf[0].counters[i])
+  return rec
modules/autoperf
--- a/modules/autoperf
+++ b/modules/autoperf
@@ -1 +1 @@
-Subproject commit 09e73498f2ac4eda2c6cd4228d2d59e710f49ccc
+Subproject commit 1c0e3d0a8caed2e9aec0da241514f9e27fca05f9
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/41863019d58923e9021dda73449fc51cfb8ef8ac
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180219/35790e7a/attachment-0001.html>
More information about the Darshan-commits
