[Darshan-commits] [Git][darshan/darshan][master] more automated build refactoring
Shane Snyder
xgitlab at cels.anl.gov
Tue Apr 10 17:39:11 CDT 2018
Shane Snyder pushed to branch master at darshan / darshan
Commits:
2ffc3584 by Shane Snyder at 2018-04-10T17:38:24-05:00
2 changed files:
- darshan-test/automated/common/build.sh
- − darshan-test/automated/mcs/build.sh
Changes:
--- a/darshan-test/automated/common/build.sh
+++ b/darshan-test/automated/common/build.sh
@@ -1,17 +1,43 @@
#!/bin/bash
-# Base build script which calls the system specific version.
+# Build darshan runtime and util code
+fcount=0
+runtime_status=0
+util_status=0
+runtime_result=""
+util_result=""
+thedate=$(date)
-status=0
+cd build/darshan-runtime
+make && make install
+runtime_status=$?
+if [ $runtime_status -ne 0 ]; then
+ fcount=$((fcount+1));
+ runtime_result="<error type='$runtime_status' message='build failed' />"
+fi
-if [[ $NODE_LABELS =~ "mcs" ]];
-then
- source darshan-test/automated/mcs/build.sh
- status=$?
-else
- # unknown machine
- status=100
+cd ../../build/darshan-util
+util_status=$?
+if [ $util_status -ne 0 ]; then
+ util_result="<error type='$util_status' message='build failed' />"
fi
-exit $status
+cd ../../;
+echo "
+<testsuites>
+ <testsuite name='build' tests='2' failures='$fcount' time='$thedate'>
+ <testcase name='darshan-runtime' time='$thedate'>
+ $runtime_result
+ </testcase>
+ <testcase name='darshan-util' time='$thedate'>
+ $util_result
+ </testcase>
+ </testsuite>
+</testsuites>
+" > build-result.xml
+exit $fcount
darshan-test/automated/mcs/build.sh deleted
--- a/darshan-test/automated/mcs/build.sh
+++ /dev/null
@@ -1,43 +0,0 @@
-#!/bin/bash
-# Build darshan runtime and util code
-fcount=0
-runtime_status=0
-util_status=0
-runtime_result=""
-util_result=""
-thedate=$(date)
-cd build/darshan-runtime
-make && make install
-runtime_status=$?
-if [ $runtime_status -ne 0 ]; then
- fcount=$((fcount+1));
- runtime_result="<error type='$runtime_status' message='build failed' />"
-fi
-cd ../../build/darshan-util
-util_status=$?
-if [ $util_status -ne 0 ]; then
- util_result="<error type='$util_status' message='build failed' />"
-fi
-cd ../../;
-echo "
-<testsuites>
- <testsuite name='build' tests='2' failures='$fcount' time='$thedate'>
- <testcase name='darshan-runtime' time='$thedate'>
- $runtime_result
- </testcase>
- <testcase name='darshan-util' time='$thedate'>
- $util_result
- </testcase>
- </testsuite>
-</testsuites>
-" > build-result.xml
-exit $fcount
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/2ffc358418f23149c3259f9506bc53b1d1dbd2b8
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20180410/6e1cb169/attachment-0001.html>
More information about the Darshan-commits
