[Darshan-commits] Build failed in Jenkins: darshan-master-mpich-3.0.4-profile-conf #1004
help at cels.anl.gov help at cels.anl.gov
Tue Apr 10 17:12:18 CDT 2018
See <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/1004/display/redirect>
Started by user Shane Snyder
[EnvInject] - Loading node environment variables.
Building remotely on churn.mcs.anl.gov (mcs) in workspace <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/>
 > git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://xgitlab.cels.anl.gov/darshan/darshan.git # timeout=10
Fetching upstream changes from https://xgitlab.cels.anl.gov/darshan/darshan.git
 > git --version # timeout=10
 > git fetch --tags --progress https://xgitlab.cels.anl.gov/darshan/darshan.git +refs/heads/*:refs/remotes/origin/*
 > git rev-parse origin/master^{commit} # timeout=10
Checking out Revision c5443990024d0fa8ae6f51206bdcc1007a623f35 (origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f c5443990024d0fa8ae6f51206bdcc1007a623f35
 > git rev-list c5443990024d0fa8ae6f51206bdcc1007a623f35 # timeout=10
 > git tag -a -f -m Jenkins Build #1004 jenkins-darshan-master-mpich-3.0.4-profile-conf-1004 # timeout=10
[darshan-master-mpich-3.0.4-profile-conf] $ /bin/bash /tmp/hudson2621299925592928481.sh
***SDS churn.mcs.anl.gov mcs
Build step 'Execute shell' marked build as failure
Recording test results
ERROR: Step ‘Publish JUnit test result report’ failed: Test reports were found but none of them are new. Did tests run?
For example, <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/build-result.xml> is 4 min 56 sec old
More information about the Darshan-commits mailing list
